For the latest stable version, please use Spring Authorization Server 1.4.2!spring-doc.cn
How-to: Implement core services with JPA
This guide shows how to implement the core services of Spring Authorization Server with JPA. The purpose of this guide is to provide a starting point for implementing these services yourself, with the intention that you can make modifications to suit your needs.spring-doc.cn
Define the data model
This guide provides a starting point for the data model and uses the simplest possible structure and data types. To come up with the initial schema, we begin by reviewing the domain objects used by the core services.spring-doc.cn
Except for token, state, metadata, settings, and claims values, we use the JPA default column length of 255 for all columns. In reality, the length and even type of columns you use may need to be customized. You are encouraged to experiment and test before deploying to production.
Client Schema
The RegisteredClient domain object contains a few multi-valued fields and some settings fields that require storing arbitrary key/value data. The following listing shows the client schema.spring-doc.cn
Client Schema
CREATE TABLE client (
    id varchar(255) NOT NULL,
    clientId varchar(255) NOT NULL,
    clientIdIssuedAt timestamp DEFAULT CURRENT_TIMESTAMP NOT NULL,
    clientSecret varchar(255) DEFAULT NULL,
    clientSecretExpiresAt timestamp DEFAULT NULL,
    clientName varchar(255) NOT NULL,
    clientAuthenticationMethods varchar(1000) NOT NULL,
    authorizationGrantTypes varchar(1000) NOT NULL,
    redirectUris varchar(1000) DEFAULT NULL,
    postLogoutRedirectUris varchar(1000) DEFAULT NULL,
    scopes varchar(1000) NOT NULL,
    clientSettings varchar(2000) NOT NULL,
    tokenSettings varchar(2000) NOT NULL,
    PRIMARY KEY (id)
Authorization Schema
The OAuth2Authorization domain object is more complex and contains several multi-valued fields as well as numerous arbitrarily long token values, metadata, settings and claims values. The built-in JDBC implementation utilizes a flattened structure that prefers performance over normalization, which we adopt here as well.spring-doc.cn
It has been difficult to find a flattened database schema that works well in all cases and with all database vendors. You may need to normalize or heavily alter the following schema for your needs.
The following listing shows the authorization schema.spring-doc.cn
CREATE TABLE authorization (
    registeredClientId varchar(255) NOT NULL,
    principalName varchar(255) NOT NULL,
    authorizationGrantType varchar(255) NOT NULL,
    authorizedScopes varchar(1000) DEFAULT NULL,
    attributes varchar(4000) DEFAULT NULL,
    state varchar(500) DEFAULT NULL,
    authorizationCodeValue varchar(4000) DEFAULT NULL,
    authorizationCodeIssuedAt timestamp DEFAULT NULL,
    authorizationCodeExpiresAt timestamp DEFAULT NULL,
    authorizationCodeMetadata varchar(2000) DEFAULT NULL,
    accessTokenValue varchar(4000) DEFAULT NULL,
    accessTokenIssuedAt timestamp DEFAULT NULL,
    accessTokenExpiresAt timestamp DEFAULT NULL,
    accessTokenMetadata varchar(2000) DEFAULT NULL,
    accessTokenType varchar(255) DEFAULT NULL,
    accessTokenScopes varchar(1000) DEFAULT NULL,
    refreshTokenValue varchar(4000) DEFAULT NULL,
    refreshTokenIssuedAt timestamp DEFAULT NULL,
    refreshTokenExpiresAt timestamp DEFAULT NULL,
    refreshTokenMetadata varchar(2000) DEFAULT NULL,
    oidcIdTokenValue varchar(4000) DEFAULT NULL,
    oidcIdTokenIssuedAt timestamp DEFAULT NULL,
    oidcIdTokenExpiresAt timestamp DEFAULT NULL,
    oidcIdTokenMetadata varchar(2000) DEFAULT NULL,
    oidcIdTokenClaims varchar(2000) DEFAULT NULL,
    userCodeValue varchar(4000) DEFAULT NULL,
    userCodeIssuedAt timestamp DEFAULT NULL,
    userCodeExpiresAt timestamp DEFAULT NULL,
    userCodeMetadata varchar(2000) DEFAULT NULL,
    deviceCodeValue varchar(4000) DEFAULT NULL,
    deviceCodeIssuedAt timestamp DEFAULT NULL,
    deviceCodeExpiresAt timestamp DEFAULT NULL,
    deviceCodeMetadata varchar(2000) DEFAULT NULL,
    PRIMARY KEY (id)
The OAuth2AuthorizationConsent domain object is the simplest to model and contains only a single multi-valued field in addition to a composite key. The following listing shows the authorizationconsent schema.spring-doc.cn
Authorization Consent Schema
CREATE TABLE authorizationConsent (
    authorities varchar(1000) NOT NULL,
    PRIMARY KEY (registeredClientId, principalName)
Create JPA entities
The preceding schema examples provide a reference for the structure of the entities we need to create.spring-doc.cn
The following entities are minimally annotated and are just examples. They allow the schema to be created dynamically and therefore do not require the above sql scripts to be executed manually.
Client Entity
The following listing shows the Client entity, which is used to persist information mapped from the RegisteredClient domain object.spring-doc.cn
Client Entity
import java.time.Instant;
import jakarta.persistence.Column;
import jakarta.persistence.Entity;
import jakarta.persistence.Id;
import jakarta.persistence.Table;
@Entity
@Table(name = "`client`")
public class Client {
	@Id
	private String id;
	private String clientId;
	private Instant clientIdIssuedAt;
	private String clientSecret;
	private Instant clientSecretExpiresAt;
	private String clientName;
	@Column(length = 1000)
	private String clientAuthenticationMethods;
	private String authorizationGrantTypes;
	private String redirectUris;
	private String postLogoutRedirectUris;
	private String scopes;
	@Column(length = 2000)
	private String clientSettings;
	private String tokenSettings;
	public String getId() {
		return id;
	public void setId(String id) {
		this.id = id;
	public String getClientId() {
		return clientId;
	public void setClientId(String clientId) {
		this.clientId = clientId;
	public Instant getClientIdIssuedAt() {
		return clientIdIssuedAt;
	public void setClientIdIssuedAt(Instant clientIdIssuedAt) {
		this.clientIdIssuedAt = clientIdIssuedAt;
	public String getClientSecret() {
		return clientSecret;
	public void setClientSecret(String clientSecret) {
		this.clientSecret = clientSecret;
	public Instant getClientSecretExpiresAt() {
		return clientSecretExpiresAt;
	public void setClientSecretExpiresAt(Instant clientSecretExpiresAt) {
		this.clientSecretExpiresAt = clientSecretExpiresAt;
	public String getClientName() {
		return clientName;
	public void setClientName(String clientName) {
		this.clientName = clientName;
	public String getClientAuthenticationMethods() {
		return clientAuthenticationMethods;
	public void setClientAuthenticationMethods(String clientAuthenticationMethods) {
		this.clientAuthenticationMethods = clientAuthenticationMethods;
	public String getAuthorizationGrantTypes() {
		return authorizationGrantTypes;
	public void setAuthorizationGrantTypes(String authorizationGrantTypes) {
		this.authorizationGrantTypes = authorizationGrantTypes;
	public String getRedirectUris() {
		return redirectUris;
	public void setRedirectUris(String redirectUris) {
		this.redirectUris = redirectUris;
	public String getPostLogoutRedirectUris() {
		return this.postLogoutRedirectUris;
	public void setPostLogoutRedirectUris(String postLogoutRedirectUris) {
		this.postLogoutRedirectUris = postLogoutRedirectUris;
	public String getScopes() {
		return scopes;
	public void setScopes(String scopes) {
		this.scopes = scopes;
	public String getClientSettings() {
		return clientSettings;
	public void setClientSettings(String clientSettings) {
		this.clientSettings = clientSettings;
	public String getTokenSettings() {
		return tokenSettings;
	public void setTokenSettings(String tokenSettings) {
		this.tokenSettings = tokenSettings;
Authorization Entity
The following listing shows the Authorization entity, which is used to persist information mapped from the OAuth2Authorization domain object.spring-doc.cn
@Entity
@Table(name = "`authorization`")
public class Authorization {
	@Id
	@Column
	private String id;
	private String registeredClientId;
	private String principalName;
	private String authorizationGrantType;
	private String authorizedScopes;
	@Column(length = 4000)
	private String attributes;
	@Column(length = 500)
	private String state;
	private String authorizationCodeValue;
	private Instant authorizationCodeIssuedAt;
	private Instant authorizationCodeExpiresAt;
	private String authorizationCodeMetadata;
	private String accessTokenValue;
	private Instant accessTokenIssuedAt;
	private Instant accessTokenExpiresAt;
	private String accessTokenMetadata;
	private String accessTokenType;
	private String accessTokenScopes;
	private String refreshTokenValue;
	private Instant refreshTokenIssuedAt;
	private Instant refreshTokenExpiresAt;
	private String refreshTokenMetadata;
	private String oidcIdTokenValue;
	private Instant oidcIdTokenIssuedAt;
	private Instant oidcIdTokenExpiresAt;
	private String oidcIdTokenMetadata;
	private String oidcIdTokenClaims;
	private String userCodeValue;
	private Instant userCodeIssuedAt;
	private Instant userCodeExpiresAt;
	private String userCodeMetadata;
	private String deviceCodeValue;
	private Instant deviceCodeIssuedAt;
	private Instant deviceCodeExpiresAt;
	private String deviceCodeMetadata;
		return id;
		this.id = id;
	public String getRegisteredClientId() {
		return registeredClientId;
	public void setRegisteredClientId(String registeredClientId) {
		this.registeredClientId = registeredClientId;
	public String getPrincipalName() {
		return principalName;
	public void setPrincipalName(String principalName) {
		this.principalName = principalName;
	public String getAuthorizationGrantType() {
		return authorizationGrantType;
	public void setAuthorizationGrantType(String authorizationGrantType) {
		this.authorizationGrantType = authorizationGrantType;
	public String getAuthorizedScopes() {
		return this.authorizedScopes;
	public void setAuthorizedScopes(String authorizedScopes) {
		this.authorizedScopes = authorizedScopes;
	public String getAttributes() {
		return attributes;
	public void setAttributes(String attributes) {
		this.attributes = attributes;
	public String getState() {
		return state;
	public void setState(String state) {
		this.state = state;
	public String getAuthorizationCodeValue() {
		return authorizationCodeValue;
	public void setAuthorizationCodeValue(String authorizationCode) {
		this.authorizationCodeValue = authorizationCode;
	public Instant getAuthorizationCodeIssuedAt() {
		return authorizationCodeIssuedAt;
	public void setAuthorizationCodeIssuedAt(Instant authorizationCodeIssuedAt) {
		this.authorizationCodeIssuedAt = authorizationCodeIssuedAt;
	public Instant getAuthorizationCodeExpiresAt() {
		return authorizationCodeExpiresAt;
	public void setAuthorizationCodeExpiresAt(Instant authorizationCodeExpiresAt) {
		this.authorizationCodeExpiresAt = authorizationCodeExpiresAt;
	public String getAuthorizationCodeMetadata() {
		return authorizationCodeMetadata;
	public void setAuthorizationCodeMetadata(String authorizationCodeMetadata) {
		this.authorizationCodeMetadata = authorizationCodeMetadata;
	public String getAccessTokenValue() {
		return accessTokenValue;
	public void setAccessTokenValue(String accessToken) {
		this.accessTokenValue = accessToken;
	public Instant getAccessTokenIssuedAt() {
		return accessTokenIssuedAt;
	public void setAccessTokenIssuedAt(Instant accessTokenIssuedAt) {
		this.accessTokenIssuedAt = accessTokenIssuedAt;
	public Instant getAccessTokenExpiresAt() {
		return accessTokenExpiresAt;
	public void setAccessTokenExpiresAt(Instant accessTokenExpiresAt) {
		this.accessTokenExpiresAt = accessTokenExpiresAt;
	public String getAccessTokenMetadata() {
		return accessTokenMetadata;
	public void setAccessTokenMetadata(String accessTokenMetadata) {
		this.accessTokenMetadata = accessTokenMetadata;
	public String getAccessTokenType() {
		return accessTokenType;
	public void setAccessTokenType(String accessTokenType) {
		this.accessTokenType = accessTokenType;
	public String getAccessTokenScopes() {
		return accessTokenScopes;
	public void setAccessTokenScopes(String accessTokenScopes) {
		this.accessTokenScopes = accessTokenScopes;
	public String getRefreshTokenValue() {
		return refreshTokenValue;
	public void setRefreshTokenValue(String refreshToken) {
		this.refreshTokenValue = refreshToken;
	public Instant getRefreshTokenIssuedAt() {
		return refreshTokenIssuedAt;
	public void setRefreshTokenIssuedAt(Instant refreshTokenIssuedAt) {
		this.refreshTokenIssuedAt = refreshTokenIssuedAt;
	public Instant getRefreshTokenExpiresAt() {
		return refreshTokenExpiresAt;
	public void setRefreshTokenExpiresAt(Instant refreshTokenExpiresAt) {
		this.refreshTokenExpiresAt = refreshTokenExpiresAt;
	public String getRefreshTokenMetadata() {
		return refreshTokenMetadata;
	public void setRefreshTokenMetadata(String refreshTokenMetadata) {
		this.refreshTokenMetadata = refreshTokenMetadata;
	public String getOidcIdTokenValue() {
		return oidcIdTokenValue;
	public void setOidcIdTokenValue(String idToken) {
		this.oidcIdTokenValue = idToken;
	public Instant getOidcIdTokenIssuedAt() {
		return oidcIdTokenIssuedAt;
	public void setOidcIdTokenIssuedAt(Instant idTokenIssuedAt) {
		this.oidcIdTokenIssuedAt = idTokenIssuedAt;
	public Instant getOidcIdTokenExpiresAt() {
		return oidcIdTokenExpiresAt;
	public void setOidcIdTokenExpiresAt(Instant idTokenExpiresAt) {
		this.oidcIdTokenExpiresAt = idTokenExpiresAt;
	public String getOidcIdTokenMetadata() {
		return oidcIdTokenMetadata;
	public void setOidcIdTokenMetadata(String idTokenMetadata) {
		this.oidcIdTokenMetadata = idTokenMetadata;
	public String getOidcIdTokenClaims() {
		return oidcIdTokenClaims;
	public void setOidcIdTokenClaims(String idTokenClaims) {
		this.oidcIdTokenClaims = idTokenClaims;
	public String getUserCodeValue() {
		return this.userCodeValue;
	public void setUserCodeValue(String userCodeValue) {
		this.userCodeValue = userCodeValue;
	public Instant getUserCodeIssuedAt() {
		return this.userCodeIssuedAt;
	public void setUserCodeIssuedAt(Instant userCodeIssuedAt) {
		this.userCodeIssuedAt = userCodeIssuedAt;
	public Instant getUserCodeExpiresAt() {
		return this.userCodeExpiresAt;
	public void setUserCodeExpiresAt(Instant userCodeExpiresAt) {
		this.userCodeExpiresAt = userCodeExpiresAt;
	public String getUserCodeMetadata() {
		return this.userCodeMetadata;
	public void setUserCodeMetadata(String userCodeMetadata) {
		this.userCodeMetadata = userCodeMetadata;
	public String getDeviceCodeValue() {
		return this.deviceCodeValue;
	public void setDeviceCodeValue(String deviceCodeValue) {
		this.deviceCodeValue = deviceCodeValue;
	public Instant getDeviceCodeIssuedAt() {
		return this.deviceCodeIssuedAt;
	public void setDeviceCodeIssuedAt(Instant deviceCodeIssuedAt) {
		this.deviceCodeIssuedAt = deviceCodeIssuedAt;
	public Instant getDeviceCodeExpiresAt() {
		return this.deviceCodeExpiresAt;
	public void setDeviceCodeExpiresAt(Instant deviceCodeExpiresAt) {
		this.deviceCodeExpiresAt = deviceCodeExpiresAt;
	public String getDeviceCodeMetadata() {
		return this.deviceCodeMetadata;
	public void setDeviceCodeMetadata(String deviceCodeMetadata) {
		this.deviceCodeMetadata = deviceCodeMetadata;
The following listing shows the AuthorizationConsent entity, which is used to persist information mapped from the OAuth2AuthorizationConsent domain object.spring-doc.cn
Authorization Consent Entity
import java.io.Serializable;
import java.util.Objects;
import jakarta.persistence.IdClass;
@Entity
@Table(name = "`authorizationConsent`")
@IdClass(AuthorizationConsent.AuthorizationConsentId.class)
public class AuthorizationConsent {
	@Id
	@Id
	private String authorities;
	public String getAuthorities() {
		return authorities;
	public void setAuthorities(String authorities) {
		this.authorities = authorities;
	public static class AuthorizationConsentId implements Serializable {
		public boolean equals(Object o) {
			if (this == o) return true;
			if (o == null || getClass() != o.getClass()) return false;
			AuthorizationConsentId that = (AuthorizationConsentId) o;
			return registeredClientId.equals(that.registeredClientId) && principalName.equals(that.principalName);
		public int hashCode() {
			return Objects.hash(registeredClientId, principalName);
Create Spring Data repositories
By closely examining the interfaces of each core service and reviewing the Jdbc implementations, we can derive a minimal set of queries needed for supporting a JPA version of each interface.spring-doc.cn
Client Repository
The following listing shows the ClientRepository, which is able to find a Client by the id and clientId fields.spring-doc.cn
Client Repository
import java.util.Optional;
import sample.jpa.entity.client.Client;
import org.springframework.data.jpa.repository.JpaRepository;
import org.springframework.stereotype.Repository;
@Repository
public interface ClientRepository extends JpaRepository<Client, String> {
	Optional<Client> findByClientId(String clientId);
Authorization Repository
The following listing shows the AuthorizationRepository, which is able to find an Authorization by the id field as well as the state, authorizationCodeValue, accessTokenValue, refreshTokenValue, userCodeValue and deviceCodeValue token fields. It also allows querying a combination of token fields.spring-doc.cn
import sample.jpa.entity.authorization.Authorization;
import org.springframework.data.jpa.repository.Query;
import org.springframework.data.repository.query.Param;
@Repository
public interface AuthorizationRepository extends JpaRepository<Authorization, String> {
	Optional<Authorization> findByState(String state);
	Optional<Authorization> findByAuthorizationCodeValue(String authorizationCode);
	Optional<Authorization> findByAccessTokenValue(String accessToken);
	Optional<Authorization> findByRefreshTokenValue(String refreshToken);
	Optional<Authorization> findByOidcIdTokenValue(String idToken);
	Optional<Authorization> findByUserCodeValue(String userCode);
	Optional<Authorization> findByDeviceCodeValue(String deviceCode);
	@Query("select a from Authorization a where a.state = :token" +
			" or a.authorizationCodeValue = :token" +
			" or a.accessTokenValue = :token" +
			" or a.refreshTokenValue = :token" +
			" or a.oidcIdTokenValue = :token" +
			" or a.userCodeValue = :token" +
			" or a.deviceCodeValue = :token"
	Optional<Authorization> findByStateOrAuthorizationCodeValueOrAccessTokenValueOrRefreshTokenValueOrOidcIdTokenValueOrUserCodeValueOrDeviceCodeValue(@Param("token") String token);
The following listing shows the AuthorizationConsentRepository, which is able to find and delete an AuthorizationConsent by the registeredClientId and principalName fields that form a composite primary key.spring-doc.cn
Authorization Consent Repository
import sample.jpa.entity.authorizationconsent.AuthorizationConsent;
@Repository
public interface AuthorizationConsentRepository extends JpaRepository<AuthorizationConsent, AuthorizationConsent.AuthorizationConsentId> {
	Optional<AuthorizationConsent> findByRegisteredClientIdAndPrincipalName(String registeredClientId, String principalName);
	void deleteByRegisteredClientIdAndPrincipalName(String registeredClientId, String principalName);
With the above entities and repositories, we can begin implementing the core services. By reviewing the Jdbc implementations, we can derive a minimal set of internal utilities for converting to and from string values for enumerations and reading and writing JSON data for attributes, settings, metadata and claims fields.spring-doc.cn
Keep in mind that writing JSON data to text columns with a fixed length has proven problematic with the Jdbc implementations. While these examples continue to do so, you may need to split these fields out into a separate table or data store that supports arbitrarily long data values.
Registered Client Repository
The following listing shows the JpaRegisteredClientRepository, which uses a ClientRepository for persisting a Client and maps to and from the RegisteredClient domain object.spring-doc.cn
RegisteredClientRepository Implementation
import java.util.ArrayList;
import java.util.List;
import java.util.Map;
import java.util.Set;
import com.fasterxml.jackson.core.type.TypeReference;
import com.fasterxml.jackson.databind.Module;
import com.fasterxml.jackson.databind.ObjectMapper;
import sample.jpa.repository.client.ClientRepository;
import org.springframework.security.jackson2.SecurityJackson2Modules;
import org.springframework.security.oauth2.core.AuthorizationGrantType;
import org.springframework.security.oauth2.core.ClientAuthenticationMethod;
import org.springframework.security.oauth2.server.authorization.client.RegisteredClient;
import org.springframework.security.oauth2.server.authorization.client.RegisteredClientRepository;
import org.springframework.security.oauth2.server.authorization.jackson2.OAuth2AuthorizationServerJackson2Module;
import org.springframework.security.oauth2.server.authorization.settings.ClientSettings;
import org.springframework.security.oauth2.server.authorization.settings.TokenSettings;
import org.springframework.util.Assert;
import org.springframework.util.StringUtils;
@Component
public class JpaRegisteredClientRepository implements RegisteredClientRepository {
	private final ClientRepository clientRepository;
	private final ObjectMapper objectMapper = new ObjectMapper();
	public JpaRegisteredClientRepository(ClientRepository clientRepository) {
		Assert.notNull(clientRepository, "clientRepository cannot be null");
		this.clientRepository = clientRepository;
		ClassLoader classLoader = JpaRegisteredClientRepository.class.getClassLoader();
		List<Module> securityModules = SecurityJackson2Modules.getModules(classLoader);
		this.objectMapper.registerModules(securityModules);
		this.objectMapper.registerModule(new OAuth2AuthorizationServerJackson2Module());
	public void save(RegisteredClient registeredClient) {
		Assert.notNull(registeredClient, "registeredClient cannot be null");
		this.clientRepository.save(toEntity(registeredClient));
	public RegisteredClient findById(String id) {
		Assert.hasText(id, "id cannot be empty");
		return this.clientRepository.findById(id).map(this::toObject).orElse(null);
	public RegisteredClient findByClientId(String clientId) {
		Assert.hasText(clientId, "clientId cannot be empty");
		return this.clientRepository.findByClientId(clientId).map(this::toObject).orElse(null);
	private RegisteredClient toObject(Client client) {
		Set<String> clientAuthenticationMethods = StringUtils.commaDelimitedListToSet(
				client.getClientAuthenticationMethods());
		Set<String> authorizationGrantTypes = StringUtils.commaDelimitedListToSet(
				client.getAuthorizationGrantTypes());
		Set<String> redirectUris = StringUtils.commaDelimitedListToSet(
				client.getRedirectUris());
		Set<String> postLogoutRedirectUris = StringUtils.commaDelimitedListToSet(
				client.getPostLogoutRedirectUris());
		Set<String> clientScopes = StringUtils.commaDelimitedListToSet(
				client.getScopes());
		RegisteredClient.Builder builder = RegisteredClient.withId(client.getId())
				.clientId(client.getClientId())
				.clientIdIssuedAt(client.getClientIdIssuedAt())
				.clientSecret(client.getClientSecret())
				.clientSecretExpiresAt(client.getClientSecretExpiresAt())
				.clientName(client.getClientName())
				.clientAuthenticationMethods(authenticationMethods ->
						clientAuthenticationMethods.forEach(authenticationMethod ->
								authenticationMethods.add(resolveClientAuthenticationMethod(authenticationMethod))))
				.authorizationGrantTypes((grantTypes) ->
						authorizationGrantTypes.forEach(grantType ->
								grantTypes.add(resolveAuthorizationGrantType(grantType))))
				.redirectUris((uris) -> uris.addAll(redirectUris))
				.postLogoutRedirectUris((uris) -> uris.addAll(postLogoutRedirectUris))
				.scopes((scopes) -> scopes.addAll(clientScopes));
		Map<String, Object> clientSettingsMap = parseMap(client.getClientSettings());
		builder.clientSettings(ClientSettings.withSettings(clientSettingsMap).build());
		Map<String, Object> tokenSettingsMap = parseMap(client.getTokenSettings());
		builder.tokenSettings(TokenSettings.withSettings(tokenSettingsMap).build());
		return builder.build();
	private Client toEntity(RegisteredClient registeredClient) {
		List<String> clientAuthenticationMethods = new ArrayList<>(registeredClient.getClientAuthenticationMethods().size());
		registeredClient.getClientAuthenticationMethods().forEach(clientAuthenticationMethod ->
				clientAuthenticationMethods.add(clientAuthenticationMethod.getValue()));
		List<String> authorizationGrantTypes = new ArrayList<>(registeredClient.getAuthorizationGrantTypes().size());
		registeredClient.getAuthorizationGrantTypes().forEach(authorizationGrantType ->
				authorizationGrantTypes.add(authorizationGrantType.getValue()));
		Client entity = new Client();
		entity.setId(registeredClient.getId());
		entity.setClientId(registeredClient.getClientId());
		entity.setClientIdIssuedAt(registeredClient.getClientIdIssuedAt());
		entity.setClientSecret(registeredClient.getClientSecret());
		entity.setClientSecretExpiresAt(registeredClient.getClientSecretExpiresAt());
		entity.setClientName(registeredClient.getClientName());
		entity.setClientAuthenticationMethods(StringUtils.collectionToCommaDelimitedString(clientAuthenticationMethods));
		entity.setAuthorizationGrantTypes(StringUtils.collectionToCommaDelimitedString(authorizationGrantTypes));
		entity.setRedirectUris(StringUtils.collectionToCommaDelimitedString(registeredClient.getRedirectUris()));
		entity.setPostLogoutRedirectUris(StringUtils.collectionToCommaDelimitedString(registeredClient.getPostLogoutRedirectUris()));
		entity.setScopes(StringUtils.collectionToCommaDelimitedString(registeredClient.getScopes()));
		entity.setClientSettings(writeMap(registeredClient.getClientSettings().getSettings()));
		entity.setTokenSettings(writeMap(registeredClient.getTokenSettings().getSettings()));
		return entity;
	private Map<String, Object> parseMap(String data) {
		try {
			return this.objectMapper.readValue(data, new TypeReference<Map<String, Object>>() {
		} catch (Exception ex) {
			throw new IllegalArgumentException(ex.getMessage(), ex);
	private String writeMap(Map<String, Object> data) {
		try {
			return this.objectMapper.writeValueAsString(data);
	private static AuthorizationGrantType resolveAuthorizationGrantType(String authorizationGrantType) {
		if (AuthorizationGrantType.AUTHORIZATION_CODE.getValue().equals(authorizationGrantType)) {
			return AuthorizationGrantType.AUTHORIZATION_CODE;
		} else if (AuthorizationGrantType.CLIENT_CREDENTIALS.getValue().equals(authorizationGrantType)) {
			return AuthorizationGrantType.CLIENT_CREDENTIALS;
		} else if (AuthorizationGrantType.REFRESH_TOKEN.getValue().equals(authorizationGrantType)) {
			return AuthorizationGrantType.REFRESH_TOKEN;
		return new AuthorizationGrantType(authorizationGrantType);              // Custom authorization grant type
	private static ClientAuthenticationMethod resolveClientAuthenticationMethod(String clientAuthenticationMethod) {
		if (ClientAuthenticationMethod.CLIENT_SECRET_BASIC.getValue().equals(clientAuthenticationMethod)) {
			return ClientAuthenticationMethod.CLIENT_SECRET_BASIC;
		} else if (ClientAuthenticationMethod.CLIENT_SECRET_POST.getValue().equals(clientAuthenticationMethod)) {
			return ClientAuthenticationMethod.CLIENT_SECRET_POST;
		} else if (ClientAuthenticationMethod.NONE.getValue().equals(clientAuthenticationMethod)) {
			return ClientAuthenticationMethod.NONE;
		return new ClientAuthenticationMethod(clientAuthenticationMethod);      // Custom client authentication method
Authorization Service
The following listing shows the JpaOAuth2AuthorizationService, which uses an AuthorizationRepository for persisting an Authorization and maps to and from the OAuth2Authorization domain object.spring-doc.cn
OAuth2AuthorizationService Implementation
import java.util.function.Consumer;
import sample.jpa.repository.authorization.AuthorizationRepository;
import org.springframework.dao.DataRetrievalFailureException;
import org.springframework.security.oauth2.core.OAuth2AccessToken;
import org.springframework.security.oauth2.core.OAuth2DeviceCode;
import org.springframework.security.oauth2.core.OAuth2RefreshToken;
import org.springframework.security.oauth2.core.OAuth2Token;
import org.springframework.security.oauth2.core.OAuth2UserCode;
import org.springframework.security.oauth2.core.endpoint.OAuth2ParameterNames;
import org.springframework.security.oauth2.core.oidc.OidcIdToken;
import org.springframework.security.oauth2.core.oidc.endpoint.OidcParameterNames;
import org.springframework.security.oauth2.server.authorization.OAuth2Authorization;
import org.springframework.security.oauth2.server.authorization.OAuth2AuthorizationCode;
import org.springframework.security.oauth2.server.authorization.OAuth2AuthorizationService;
import org.springframework.security.oauth2.server.authorization.OAuth2TokenType;
@Component
public class JpaOAuth2AuthorizationService implements OAuth2AuthorizationService {
	private final AuthorizationRepository authorizationRepository;
	private final RegisteredClientRepository registeredClientRepository;
	public JpaOAuth2AuthorizationService(AuthorizationRepository authorizationRepository, RegisteredClientRepository registeredClientRepository) {
		Assert.notNull(authorizationRepository, "authorizationRepository cannot be null");
		Assert.notNull(registeredClientRepository, "registeredClientRepository cannot be null");
		this.authorizationRepository = authorizationRepository;
		this.registeredClientRepository = registeredClientRepository;
		ClassLoader classLoader = JpaOAuth2AuthorizationService.class.getClassLoader();
	public void save(OAuth2Authorization authorization) {
		Assert.notNull(authorization, "authorization cannot be null");
		this.authorizationRepository.save(toEntity(authorization));
	public void remove(OAuth2Authorization authorization) {
		this.authorizationRepository.deleteById(authorization.getId());
	public OAuth2Authorization findById(String id) {
		return this.authorizationRepository.findById(id).map(this::toObject).orElse(null);
	public OAuth2Authorization findByToken(String token, OAuth2TokenType tokenType) {
		Assert.hasText(token, "token cannot be empty");
		Optional<Authorization> result;
		if (tokenType == null) {
			result = this.authorizationRepository.findByStateOrAuthorizationCodeValueOrAccessTokenValueOrRefreshTokenValueOrOidcIdTokenValueOrUserCodeValueOrDeviceCodeValue(token);
		} else if (OAuth2ParameterNames.STATE.equals(tokenType.getValue())) {
			result = this.authorizationRepository.findByState(token);
		} else if (OAuth2ParameterNames.CODE.equals(tokenType.getValue())) {
			result = this.authorizationRepository.findByAuthorizationCodeValue(token);
		} else if (OAuth2ParameterNames.ACCESS_TOKEN.equals(tokenType.getValue())) {
			result = this.authorizationRepository.findByAccessTokenValue(token);
		} else if (OAuth2ParameterNames.REFRESH_TOKEN.equals(tokenType.getValue())) {
			result = this.authorizationRepository.findByRefreshTokenValue(token);
		} else if (OidcParameterNames.ID_TOKEN.equals(tokenType.getValue())) {
			result = this.authorizationRepository.findByOidcIdTokenValue(token);
		} else if (OAuth2ParameterNames.USER_CODE.equals(tokenType.getValue())) {
			result = this.authorizationRepository.findByUserCodeValue(token);
		} else if (OAuth2ParameterNames.DEVICE_CODE.equals(tokenType.getValue())) {
			result = this.authorizationRepository.findByDeviceCodeValue(token);
		} else {
			result = Optional.empty();
		return result.map(this::toObject).orElse(null);
	private OAuth2Authorization toObject(Authorization entity) {
		RegisteredClient registeredClient = this.registeredClientRepository.findById(entity.getRegisteredClientId());
		if (registeredClient == null) {
			throw new DataRetrievalFailureException(
					"The RegisteredClient with id '" + entity.getRegisteredClientId() + "' was not found in the RegisteredClientRepository.");
		OAuth2Authorization.Builder builder = OAuth2Authorization.withRegisteredClient(registeredClient)
				.id(entity.getId())
				.principalName(entity.getPrincipalName())
				.authorizationGrantType(resolveAuthorizationGrantType(entity.getAuthorizationGrantType()))
				.authorizedScopes(StringUtils.commaDelimitedListToSet(entity.getAuthorizedScopes()))
				.attributes(attributes -> attributes.putAll(parseMap(entity.getAttributes())));
		if (entity.getState() != null) {
			builder.attribute(OAuth2ParameterNames.STATE, entity.getState());
		if (entity.getAuthorizationCodeValue() != null) {
			OAuth2AuthorizationCode authorizationCode = new OAuth2AuthorizationCode(
					entity.getAuthorizationCodeValue(),
					entity.getAuthorizationCodeIssuedAt(),
					entity.getAuthorizationCodeExpiresAt());
			builder.token(authorizationCode, metadata -> metadata.putAll(parseMap(entity.getAuthorizationCodeMetadata())));
		if (entity.getAccessTokenValue() != null) {
			OAuth2AccessToken accessToken = new OAuth2AccessToken(
					OAuth2AccessToken.TokenType.BEARER,
					entity.getAccessTokenValue(),
					entity.getAccessTokenIssuedAt(),
					entity.getAccessTokenExpiresAt(),
					StringUtils.commaDelimitedListToSet(entity.getAccessTokenScopes()));
			builder.token(accessToken, metadata -> metadata.putAll(parseMap(entity.getAccessTokenMetadata())));
		if (entity.getRefreshTokenValue() != null) {
			OAuth2RefreshToken refreshToken = new OAuth2RefreshToken(
					entity.getRefreshTokenValue(),
					entity.getRefreshTokenIssuedAt(),
					entity.getRefreshTokenExpiresAt());
			builder.token(refreshToken, metadata -> metadata.putAll(parseMap(entity.getRefreshTokenMetadata())));
		if (entity.getOidcIdTokenValue() != null) {
			OidcIdToken idToken = new OidcIdToken(
					entity.getOidcIdTokenValue(),
					entity.getOidcIdTokenIssuedAt(),
					entity.getOidcIdTokenExpiresAt(),
					parseMap(entity.getOidcIdTokenClaims()));
			builder.token(idToken, metadata -> metadata.putAll(parseMap(entity.getOidcIdTokenMetadata())));
		if (entity.getUserCodeValue() != null) {
			OAuth2UserCode userCode = new OAuth2UserCode(
					entity.getUserCodeValue(),
					entity.getUserCodeIssuedAt(),
					entity.getUserCodeExpiresAt());
			builder.token(userCode, metadata -> metadata.putAll(parseMap(entity.getUserCodeMetadata())));
		if (entity.getDeviceCodeValue() != null) {
			OAuth2DeviceCode deviceCode = new OAuth2DeviceCode(
					entity.getDeviceCodeValue(),
					entity.getDeviceCodeIssuedAt(),
					entity.getDeviceCodeExpiresAt());
			builder.token(deviceCode, metadata -> metadata.putAll(parseMap(entity.getDeviceCodeMetadata())));
	private Authorization toEntity(OAuth2Authorization authorization) {
		Authorization entity = new Authorization();
		entity.setId(authorization.getId());
		entity.setRegisteredClientId(authorization.getRegisteredClientId());
		entity.setPrincipalName(authorization.getPrincipalName());
		entity.setAuthorizationGrantType(authorization.getAuthorizationGrantType().getValue());
		entity.setAuthorizedScopes(StringUtils.collectionToDelimitedString(authorization.getAuthorizedScopes(), ","));
		entity.setAttributes(writeMap(authorization.getAttributes()));
		entity.setState(authorization.getAttribute(OAuth2ParameterNames.STATE));
		OAuth2Authorization.Token<OAuth2AuthorizationCode> authorizationCode =
				authorization.getToken(OAuth2AuthorizationCode.class);
		setTokenValues(
				authorizationCode,
				entity::setAuthorizationCodeValue,
				entity::setAuthorizationCodeIssuedAt,
				entity::setAuthorizationCodeExpiresAt,
				entity::setAuthorizationCodeMetadata
		OAuth2Authorization.Token<OAuth2AccessToken> accessToken =
				authorization.getToken(OAuth2AccessToken.class);
		setTokenValues(
				accessToken,
				entity::setAccessTokenValue,
				entity::setAccessTokenIssuedAt,
				entity::setAccessTokenExpiresAt,
				entity::setAccessTokenMetadata
		if (accessToken != null && accessToken.getToken().getScopes() != null) {
			entity.setAccessTokenScopes(StringUtils.collectionToDelimitedString(accessToken.getToken().getScopes(), ","));
		OAuth2Authorization.Token<OAuth2RefreshToken> refreshToken =
				authorization.getToken(OAuth2RefreshToken.class);
		setTokenValues(
				refreshToken,
				entity::setRefreshTokenValue,
				entity::setRefreshTokenIssuedAt,
				entity::setRefreshTokenExpiresAt,
				entity::setRefreshTokenMetadata
		OAuth2Authorization.Token<OidcIdToken> oidcIdToken =
				authorization.getToken(OidcIdToken.class);
		setTokenValues(
				oidcIdToken,
				entity::setOidcIdTokenValue,
				entity::setOidcIdTokenIssuedAt,
				entity::setOidcIdTokenExpiresAt,
				entity::setOidcIdTokenMetadata
		if (oidcIdToken != null) {
			entity.setOidcIdTokenClaims(writeMap(oidcIdToken.getClaims()));
		OAuth2Authorization.Token<OAuth2UserCode> userCode =
				authorization.getToken(OAuth2UserCode.class);
		setTokenValues(
				userCode,
				entity::setUserCodeValue,
				entity::setUserCodeIssuedAt,
				entity::setUserCodeExpiresAt,
				entity::setUserCodeMetadata
		OAuth2Authorization.Token<OAuth2DeviceCode> deviceCode =
				authorization.getToken(OAuth2DeviceCode.class);
		setTokenValues(
				deviceCode,
				entity::setDeviceCodeValue,
				entity::setDeviceCodeIssuedAt,
				entity::setDeviceCodeExpiresAt,
				entity::setDeviceCodeMetadata
		return entity;
	private void setTokenValues(
			OAuth2Authorization.Token<?> token,
			Consumer<String> tokenValueConsumer,
			Consumer<Instant> issuedAtConsumer,
			Consumer<Instant> expiresAtConsumer,
			Consumer<String> metadataConsumer) {
		if (token != null) {
			OAuth2Token oAuth2Token = token.getToken();
			tokenValueConsumer.accept(oAuth2Token.getTokenValue());
			issuedAtConsumer.accept(oAuth2Token.getIssuedAt());
			expiresAtConsumer.accept(oAuth2Token.getExpiresAt());
			metadataConsumer.accept(writeMap(token.getMetadata()));
		try {
	private String writeMap(Map<String, Object> metadata) {
		try {
			return this.objectMapper.writeValueAsString(metadata);
		} else if (AuthorizationGrantType.DEVICE_CODE.getValue().equals(authorizationGrantType)) {
			return AuthorizationGrantType.DEVICE_CODE;
The following listing shows the JpaOAuth2AuthorizationConsentService, which uses an AuthorizationConsentRepository for persisting an AuthorizationConsent and maps to and from the OAuth2AuthorizationConsent domain object.spring-doc.cn
OAuth2AuthorizationConsentService Implementation
import java.util.HashSet;
import sample.jpa.repository.authorizationconsent.AuthorizationConsentRepository;
import org.springframework.security.core.GrantedAuthority;
import org.springframework.security.core.authority.SimpleGrantedAuthority;
import org.springframework.security.oauth2.server.authorization.OAuth2AuthorizationConsent;
import org.springframework.security.oauth2.server.authorization.OAuth2AuthorizationConsentService;
@Component
public class JpaOAuth2AuthorizationConsentService implements OAuth2AuthorizationConsentService {
	private final AuthorizationConsentRepository authorizationConsentRepository;
	public JpaOAuth2AuthorizationConsentService(AuthorizationConsentRepository authorizationConsentRepository, RegisteredClientRepository registeredClientRepository) {
		Assert.notNull(authorizationConsentRepository, "authorizationConsentRepository cannot be null");
		this.authorizationConsentRepository = authorizationConsentRepository;
	public void save(OAuth2AuthorizationConsent authorizationConsent) {
		Assert.notNull(authorizationConsent, "authorizationConsent cannot be null");
		this.authorizationConsentRepository.save(toEntity(authorizationConsent));
	public void remove(OAuth2AuthorizationConsent authorizationConsent) {
		this.authorizationConsentRepository.deleteByRegisteredClientIdAndPrincipalName(
				authorizationConsent.getRegisteredClientId(), authorizationConsent.getPrincipalName());
	public OAuth2AuthorizationConsent findById(String registeredClientId, String principalName) {
		Assert.hasText(registeredClientId, "registeredClientId cannot be empty");
		Assert.hasText(principalName, "principalName cannot be empty");
		return this.authorizationConsentRepository.findByRegisteredClientIdAndPrincipalName(
				registeredClientId, principalName).map(this::toObject).orElse(null);
	private OAuth2AuthorizationConsent toObject(AuthorizationConsent authorizationConsent) {
		String registeredClientId = authorizationConsent.getRegisteredClientId();
		RegisteredClient registeredClient = this.registeredClientRepository.findById(registeredClientId);
					"The RegisteredClient with id '" + registeredClientId + "' was not found in the RegisteredClientRepository.");
		OAuth2AuthorizationConsent.Builder builder = OAuth2AuthorizationConsent.withId(
				registeredClientId, authorizationConsent.getPrincipalName());
		if (authorizationConsent.getAuthorities() != null) {
			for (String authority : StringUtils.commaDelimitedListToSet(authorizationConsent.getAuthorities())) {
				builder.authority(new SimpleGrantedAuthority(authority));
	private AuthorizationConsent toEntity(OAuth2AuthorizationConsent authorizationConsent) {
		AuthorizationConsent entity = new AuthorizationConsent();
		entity.setRegisteredClientId(authorizationConsent.getRegisteredClientId());
		entity.setPrincipalName(authorizationConsent.getPrincipalName());
		Set<String> authorities = new HashSet<>();
		for (GrantedAuthority authority : authorizationConsent.getAuthorities()) {
			authorities.add(authority.getAuthority());
		entity.setAuthorities(StringUtils.collectionToCommaDelimitedString(authorities));
		return entity;
