For the latest stable version, please use Spring Authorization Server 1.4.2!spring-doc.cn
How-to: Implement an Extension Authorization Grant Type
This guide shows how to extend Spring Authorization Server with an extension authorization grant type. The purpose of this guide is to demonstrate how to implement an extension authorization grant type and configure it at the OAuth2 Token endpoint.spring-doc.cn
Extending Spring Authorization Server with a new authorization grant type requires implementing an AuthenticationConverter and AuthenticationProvider, and configuring both components at the OAuth2 Token endpoint. In addition to the component implementations, a unique absolute URI needs to be assigned for use with the grant_type parameter.spring-doc.cn
Implement AuthenticationConverter
Assuming the absolute URI for the grant_type parameter is urn:ietf:params:oauth:grant-type:custom_code and the code parameter represents the authorization grant, the following example shows a sample implementation of the AuthenticationConverter:spring-doc.cn
import java.util.HashMap;
import java.util.Map;
import jakarta.servlet.http.HttpServletRequest;
import org.springframework.lang.Nullable;
import org.springframework.security.core.Authentication;
import org.springframework.security.core.context.SecurityContextHolder;
import org.springframework.security.oauth2.core.OAuth2AuthenticationException;
import org.springframework.security.oauth2.core.OAuth2ErrorCodes;
import org.springframework.security.oauth2.core.endpoint.OAuth2ParameterNames;
import org.springframework.security.web.authentication.AuthenticationConverter;
import org.springframework.util.LinkedMultiValueMap;
import org.springframework.util.MultiValueMap;
import org.springframework.util.StringUtils;
public class CustomCodeGrantAuthenticationConverter implements AuthenticationConverter {
	@Nullable
	public Authentication convert(HttpServletRequest request) {
		// grant_type (REQUIRED)
		String grantType = request.getParameter(OAuth2ParameterNames.GRANT_TYPE);
		if (!"urn:ietf:params:oauth:grant-type:custom_code".equals(grantType)) { (1)
			return null;
		Authentication clientPrincipal = SecurityContextHolder.getContext().getAuthentication();
		MultiValueMap<String, String> parameters = getParameters(request);
		// code (REQUIRED)
		String code = parameters.getFirst(OAuth2ParameterNames.CODE); (2)
		if (!StringUtils.hasText(code) ||
				parameters.get(OAuth2ParameterNames.CODE).size() != 1) {
			throw new OAuth2AuthenticationException(OAuth2ErrorCodes.INVALID_REQUEST);
		Map<String, Object> additionalParameters = new HashMap<>();
		parameters.forEach((key, value) -> {
			if (!key.equals(OAuth2ParameterNames.GRANT_TYPE) &&
					!key.equals(OAuth2ParameterNames.CLIENT_ID) &&
					!key.equals(OAuth2ParameterNames.CODE)) {
				additionalParameters.put(key, value.get(0));
		return new CustomCodeGrantAuthenticationToken(code, clientPrincipal, additionalParameters); (3)
	private static MultiValueMap<String, String> getParameters(HttpServletRequest request) {
		Map<String, String[]> parameterMap = request.getParameterMap();
		MultiValueMap<String, String> parameters = new LinkedMultiValueMap<>(parameterMap.size());
		parameterMap.forEach((key, values) -> {
			if (values.length > 0) {
				for (String value : values) {
					parameters.add(key, value);
		return parameters;
Click on the "Expand folded text" icon in the code sample above to display the full example.
1 If the grant_type parameter is not urn:ietf:params:oauth:grant-type:custom_code, then return null, allowing another AuthenticationConverter to process the token request.
2 The code parameter contains the authorization grant.
3 Return an instance of CustomCodeGrantAuthenticationToken, which is processed by CustomCodeGrantAuthenticationProvider.
Implement AuthenticationProvider
The AuthenticationProvider implementation is responsible for validating the authorization grant, and if valid and authorized, issues an access token.spring-doc.cn
The following example shows a sample implementation of the AuthenticationProvider:spring-doc.cn
import org.springframework.security.authentication.AuthenticationProvider;
import org.springframework.security.core.AuthenticationException;
import org.springframework.security.oauth2.core.ClaimAccessor;
import org.springframework.security.oauth2.core.OAuth2AccessToken;
import org.springframework.security.oauth2.core.OAuth2Error;
import org.springframework.security.oauth2.core.OAuth2Token;
import org.springframework.security.oauth2.server.authorization.OAuth2Authorization;
import org.springframework.security.oauth2.server.authorization.OAuth2AuthorizationService;
import org.springframework.security.oauth2.server.authorization.OAuth2TokenType;
import org.springframework.security.oauth2.server.authorization.authentication.OAuth2AccessTokenAuthenticationToken;
import org.springframework.security.oauth2.server.authorization.authentication.OAuth2ClientAuthenticationToken;
import org.springframework.security.oauth2.server.authorization.client.RegisteredClient;
import org.springframework.security.oauth2.server.authorization.context.AuthorizationServerContextHolder;
import org.springframework.security.oauth2.server.authorization.token.DefaultOAuth2TokenContext;
import org.springframework.security.oauth2.server.authorization.token.OAuth2TokenContext;
import org.springframework.security.oauth2.server.authorization.token.OAuth2TokenGenerator;
import org.springframework.util.Assert;
public class CustomCodeGrantAuthenticationProvider implements AuthenticationProvider {
	private final OAuth2AuthorizationService authorizationService;
	private final OAuth2TokenGenerator<? extends OAuth2Token> tokenGenerator;
	public CustomCodeGrantAuthenticationProvider(OAuth2AuthorizationService authorizationService,
			OAuth2TokenGenerator<? extends OAuth2Token> tokenGenerator) {
		Assert.notNull(authorizationService, "authorizationService cannot be null");
		Assert.notNull(tokenGenerator, "tokenGenerator cannot be null");
		this.authorizationService = authorizationService;
		this.tokenGenerator = tokenGenerator;
	public Authentication authenticate(Authentication authentication) throws AuthenticationException {
		CustomCodeGrantAuthenticationToken customCodeGrantAuthentication =
				(CustomCodeGrantAuthenticationToken) authentication;
		// Ensure the client is authenticated
		OAuth2ClientAuthenticationToken clientPrincipal =
				getAuthenticatedClientElseThrowInvalidClient(customCodeGrantAuthentication);
		RegisteredClient registeredClient = clientPrincipal.getRegisteredClient();
		// Ensure the client is configured to use this authorization grant type
		if (!registeredClient.getAuthorizationGrantTypes().contains(customCodeGrantAuthentication.getGrantType())) {
			throw new OAuth2AuthenticationException(OAuth2ErrorCodes.UNAUTHORIZED_CLIENT);
		// TODO Validate the code parameter
		// Generate the access token
		OAuth2TokenContext tokenContext = DefaultOAuth2TokenContext.builder()
				.registeredClient(registeredClient)
				.principal(clientPrincipal)
				.authorizationServerContext(AuthorizationServerContextHolder.getContext())
				.tokenType(OAuth2TokenType.ACCESS_TOKEN)
				.authorizationGrantType(customCodeGrantAuthentication.getGrantType())
				.authorizationGrant(customCodeGrantAuthentication)
		OAuth2Token generatedAccessToken = this.tokenGenerator.generate(tokenContext);
		if (generatedAccessToken == null) {
			OAuth2Error error = new OAuth2Error(OAuth2ErrorCodes.SERVER_ERROR,
					"The token generator failed to generate the access token.", null);
			throw new OAuth2AuthenticationException(error);
		OAuth2AccessToken accessToken = new OAuth2AccessToken(OAuth2AccessToken.TokenType.BEARER,
				generatedAccessToken.getTokenValue(), generatedAccessToken.getIssuedAt(),
				generatedAccessToken.getExpiresAt(), null);
		// Initialize the OAuth2Authorization
		OAuth2Authorization.Builder authorizationBuilder = OAuth2Authorization.withRegisteredClient(registeredClient)
				.principalName(clientPrincipal.getName())
				.authorizationGrantType(customCodeGrantAuthentication.getGrantType());
		if (generatedAccessToken instanceof ClaimAccessor) {
			authorizationBuilder.token(accessToken, (metadata) ->
				metadata.put(
					OAuth2Authorization.Token.CLAIMS_METADATA_NAME,
					((ClaimAccessor) generatedAccessToken).getClaims())
		} else {
			authorizationBuilder.accessToken(accessToken);
		OAuth2Authorization authorization = authorizationBuilder.build();
		// Save the OAuth2Authorization
		this.authorizationService.save(authorization);
		return new OAuth2AccessTokenAuthenticationToken(registeredClient, clientPrincipal, accessToken);
	public boolean supports(Class<?> authentication) {
		return CustomCodeGrantAuthenticationToken.class.isAssignableFrom(authentication);
	private static OAuth2ClientAuthenticationToken getAuthenticatedClientElseThrowInvalidClient(Authentication authentication) {
		OAuth2ClientAuthenticationToken clientPrincipal = null;
		if (OAuth2ClientAuthenticationToken.class.isAssignableFrom(authentication.getPrincipal().getClass())) {
			clientPrincipal = (OAuth2ClientAuthenticationToken) authentication.getPrincipal();
		if (clientPrincipal != null && clientPrincipal.isAuthenticated()) {
			return clientPrincipal;
		throw new OAuth2AuthenticationException(OAuth2ErrorCodes.INVALID_CLIENT);
CustomCodeGrantAuthenticationProvider processes CustomCodeGrantAuthenticationToken, which is created by CustomCodeGrantAuthenticationConverter.
Configure OAuth2 Token Endpoint
The following example shows how to configure the OAuth2 Token endpoint with the AuthenticationConverter and AuthenticationProvider:spring-doc.cn
SecurityConfig
import java.util.UUID;
import com.nimbusds.jose.jwk.source.JWKSource;
import com.nimbusds.jose.proc.SecurityContext;
import org.springframework.security.config.annotation.web.builders.HttpSecurity;
import org.springframework.security.config.annotation.web.configuration.EnableWebSecurity;
import org.springframework.security.oauth2.core.AuthorizationGrantType;
import org.springframework.security.oauth2.core.ClientAuthenticationMethod;
import org.springframework.security.oauth2.jwt.NimbusJwtEncoder;
import org.springframework.security.oauth2.server.authorization.InMemoryOAuth2AuthorizationService;
import org.springframework.security.oauth2.server.authorization.client.InMemoryRegisteredClientRepository;
import org.springframework.security.oauth2.server.authorization.client.RegisteredClientRepository;
import org.springframework.security.oauth2.server.authorization.config.annotation.web.configurers.OAuth2AuthorizationServerConfigurer;
import org.springframework.security.oauth2.server.authorization.token.DelegatingOAuth2TokenGenerator;
import org.springframework.security.oauth2.server.authorization.token.JwtGenerator;
import org.springframework.security.oauth2.server.authorization.token.OAuth2AccessTokenGenerator;
import org.springframework.security.oauth2.server.authorization.token.OAuth2RefreshTokenGenerator;
import org.springframework.security.web.SecurityFilterChain;
import org.springframework.security.web.util.matcher.RequestMatcher;
@EnableWebSecurity
public class SecurityConfig {
	SecurityFilterChain authorizationServerSecurityFilterChain(
			HttpSecurity http,
			OAuth2TokenGenerator<?> tokenGenerator) throws Exception {
		OAuth2AuthorizationServerConfigurer authorizationServerConfigurer =
				new OAuth2AuthorizationServerConfigurer();
			.tokenEndpoint(tokenEndpoint ->
				tokenEndpoint
					.accessTokenRequestConverter( (1)
						new CustomCodeGrantAuthenticationConverter())
					.authenticationProvider( (2)
						new CustomCodeGrantAuthenticationProvider(
							authorizationService, tokenGenerator)));
		RequestMatcher endpointsMatcher = authorizationServerConfigurer.getEndpointsMatcher();
		http
			.securityMatcher(endpointsMatcher)
			.authorizeHttpRequests(authorize ->
				authorize
					.anyRequest().authenticated()
			.csrf(csrf -> csrf.ignoringRequestMatchers(endpointsMatcher))
			.apply(authorizationServerConfigurer);
		return http.build();
	RegisteredClientRepository registeredClientRepository() {
		RegisteredClient messagingClient = RegisteredClient.withId(UUID.randomUUID().toString())
				.clientId("messaging-client")
				.clientSecret("{noop}secret")
				.clientAuthenticationMethod(ClientAuthenticationMethod.CLIENT_SECRET_BASIC)
				.authorizationGrantType(new AuthorizationGrantType("urn:ietf:params:oauth:grant-type:custom_code"))
				.scope("message.read")
				.scope("message.write")
		return new InMemoryRegisteredClientRepository(messagingClient);
	OAuth2AuthorizationService authorizationService() {
		return new InMemoryOAuth2AuthorizationService();
	OAuth2TokenGenerator<?> tokenGenerator(JWKSource<SecurityContext> jwkSource) {
		JwtGenerator jwtGenerator = new JwtGenerator(new NimbusJwtEncoder(jwkSource));
		OAuth2AccessTokenGenerator accessTokenGenerator = new OAuth2AccessTokenGenerator();
		OAuth2RefreshTokenGenerator refreshTokenGenerator = new OAuth2RefreshTokenGenerator();
		return new DelegatingOAuth2TokenGenerator(
				jwtGenerator, accessTokenGenerator, refreshTokenGenerator);
1 Add the AuthenticationConverter to the OAuth2 Token endpoint configuration.
2 Add the AuthenticationProvider to the OAuth2 Token endpoint configuration.
Request the Access Token
The client can request the access token by making the following (authenticated) request to the OAuth2 Token endpoint:spring-doc.cn
POST /oauth2/token HTTP/1.1
Authorization: Basic bWVzc2FnaW5nLWNsaWVudDpzZWNyZXQ=
Content-Type: application/x-www-form-urlencoded
grant_type=urn:ietf:params:oauth:grant-type:custom_code&code=7QR49T1W3
