Micrometer Observation Documentation
This section describes the Micrometer integration.spring-doc.cn
Observability - Metrics
Below you can find a list of all metrics declared by this project.spring-doc.cn
Listener Observation
Observation for Rabbit listeners.spring-doc.cn
Metric name spring.rabbit.listener (defined by convention class RabbitListenerObservation$DefaultRabbitListenerObservationConvention). Type timer.spring-doc.cn
Metric name spring.rabbit.listener.active (defined by convention class RabbitListenerObservation$DefaultRabbitListenerObservationConvention). Type long task timer.spring-doc.cn
KeyValues that are added after starting the Observation might be missing from the *.active metrics.
Micrometer internally uses nanoseconds for the baseunit. However, each backend determines the actual baseunit. (i.e. Prometheus uses seconds)
Name of the enclosing class RabbitListenerObservation.spring-doc.cn
Table 1. Low cardinality Keys
Descriptionspring-doc.cn
messaging.destination.name (required)spring-doc.cn
The queue the listener is plugged to.spring-doc.cn
messaging.rabbitmq.message.delivery_tag (required)spring-doc.cn
The delivery tag. After deprecation this key is not exposed as a low cardinality tag.spring-doc.cn
spring.rabbit.listener.id (required)spring-doc.cn
Listener id.spring-doc.cn
Stream Listener Observation
Observation for Rabbit stream listeners.spring-doc.cn
Metric name spring.rabbit.stream.listener (defined by convention class RabbitStreamListenerObservation$DefaultRabbitStreamListenerObservationConvention). Type timer.spring-doc.cn
Metric name spring.rabbit.stream.listener.active (defined by convention class RabbitStreamListenerObservation$DefaultRabbitStreamListenerObservationConvention). Type long task timer.spring-doc.cn
Name of the enclosing class RabbitStreamListenerObservation.spring-doc.cn
All tags must be prefixed with spring.rabbit.stream.listener prefix!
Table 2. Low cardinality Keys
spring.rabbit.stream.listener.id (required)spring-doc.cn
Stream Template Observation
Observation for `RabbitStreamTemplate`s.spring-doc.cn
Metric name spring.rabbit.stream.template (defined by convention class RabbitStreamTemplateObservation$DefaultRabbitStreamTemplateObservationConvention). Type timer.spring-doc.cn
Metric name spring.rabbit.stream.template.active (defined by convention class RabbitStreamTemplateObservation$DefaultRabbitStreamTemplateObservationConvention). Type long task timer.spring-doc.cn
Name of the enclosing class RabbitStreamTemplateObservation.spring-doc.cn
All tags must be prefixed with spring.rabbit.stream.template prefix!
Table 3. Low cardinality Keys
spring.rabbit.stream.template.name (required)spring-doc.cn
Bean name of the template.spring-doc.cn
Observation for RabbitTemplates.spring-doc.cn
Metric name spring.rabbit.template (defined by convention class RabbitTemplateObservation$DefaultRabbitTemplateObservationConvention). Type timer.spring-doc.cn
Metric name spring.rabbit.template.active (defined by convention class RabbitTemplateObservation$DefaultRabbitTemplateObservationConvention). Type long task timer.spring-doc.cn
Name of the enclosing class RabbitTemplateObservation.spring-doc.cn
Table 4. Low cardinality Keys
The destination exchange (empty if default exchange).spring-doc.cn
messaging.rabbitmq.destination.routing_key (required)spring-doc.cn
The destination routing key.spring-doc.cn
spring.rabbit.template.name (required)spring-doc.cn
Observability - Spans
Below you can find a list of all spans declared by this project.spring-doc.cn
Listener Observation Span
Span name spring.rabbit.listener (defined by convention class RabbitListenerObservation$DefaultRabbitListenerObservationConvention).spring-doc.cn
Table 5. Tag Keys
Namespring-doc.cn
The delivery tag.spring-doc.cn
Stream Listener Observation Span
Span name spring.rabbit.stream.listener (defined by convention class RabbitStreamListenerObservation$DefaultRabbitStreamListenerObservationConvention).spring-doc.cn
Table 6. Tag Keys
Namespring-doc.cn
Stream Template Observation Span
Span name spring.rabbit.stream.template (defined by convention class RabbitStreamTemplateObservation$DefaultRabbitStreamTemplateObservationConvention).spring-doc.cn
Table 7. Tag Keys
Namespring-doc.cn
Span name spring.rabbit.template (defined by convention class RabbitTemplateObservation$DefaultRabbitTemplateObservationConvention).spring-doc.cn
Table 8. Tag Keys
Namespring-doc.cn
Observability - Conventions
Below you can find a list of all GlobalObservationConvention and ObservationConvention declared by this project.spring-doc.cn
Table 9. ObservationConvention implementations
ObservationConvention Class Namespring-doc.cn
Applicable ObservationContext Class Namespring-doc.cn
RabbitListenerObservationspring-doc.cn
RabbitMessageReceiverContextspring-doc.cn
RabbitListenerObservation.DefaultRabbitListenerObservationConventionspring-doc.cn
RabbitStreamMessageReceiverContextspring-doc.cn
RabbitStreamMessageReceiverContext.DefaultRabbitListenerObservationConventionspring-doc.cn
RabbitTemplateObservationspring-doc.cn
RabbitMessageSenderContextspring-doc.cn
RabbitTemplateObservation.DefaultRabbitTemplateObservationConventionspring-doc.cn
RabbitStreamListenerObservationspring-doc.cn
RabbitStreamListenerObservation.DefaultRabbitStreamListenerObservationConventionspring-doc.cn
RabbitStreamTemplateObservationspring-doc.cn
RabbitStreamMessageSenderContextspring-doc.cn
RabbitStreamTemplateObservation.DefaultRabbitStreamTemplateObservationConventionspring-doc.cn
