Message Listener Container Configuration
There are quite a few options for configuring a SimpleMessageListenerContainer (SMLC) and a DirectMessageListenerContainer (DMLC) related to transactions and quality of service, and some of them interact with each other. Properties that apply to the SMLC, DMLC, or StreamListenerContainer (StLC) (see Using the RabbitMQ Stream Plugin) are indicated by the check mark in the appropriate column. See Choosing a Container for information to help you decide which container is appropriate for your application.spring-doc.cn
The following table shows the container property names and their equivalent attribute names (in parentheses) when using the namespace to configure a <rabbit:listener-container/>. The type attribute on that element can be simple (default) or direct to specify an SMLC or DMLC respectively. Some properties are not exposed by the namespace. These are indicated by N/A for the attribute.spring-doc.cn
Table 1. Configuration options for a message listener container
Property (Attribute) Description SMLC DMLC StLC
ackTimeout
(N/A)spring-doc.cn
When messagesPerAck is set, this timeout is used as an alternative to send an ack. When a new message arrives, the count of unacked messages is compared to messagesPerAck, and the time since the last ack is compared to this value. If either condition is true, the message is acknowledged. When no new messages arrive and there are unacked messages, this timeout is approximate since the condition is only checked each monitorInterval. See also messagesPerAck and monitorInterval in this table.spring-doc.cn
tickmark
acknowledgeMode
(acknowledge)spring-doc.cn
  • NONE: No acks are sent (incompatible with channelTransacted=true). RabbitMQ calls this “autoack”, because the broker assumes all messages are acked without any action from the consumer.spring-doc.cn
  • MANUAL: The listener must acknowledge all messages by calling Channel.basicAck().spring-doc.cn
  • AUTO: The container acknowledges the message automatically, unless the MessageListener throws an exception. Note that acknowledgeMode is complementary to channelTransacted — if the channel is transacted, the broker requires a commit notification in addition to the ack. This is the default mode. See also batchSize.spring-doc.cn
tickmark
tickmark
adviceChain
(advice-chain)spring-doc.cn
An array of AOP Advice to apply to the listener execution. This can be used to apply additional cross-cutting concerns, such as automatic retry in the event of broker death. Note that simple re-connection after an AMQP error is handled by the CachingConnectionFactory, as long as the broker is still alive.spring-doc.cn
tickmark
tickmark
afterReceivePostProcessors
(N/A)spring-doc.cn
An array of MessagePostProcessor instances that are invoked before invoking the listener. Post processors can implement PriorityOrdered or Ordered. The array is sorted with un-ordered members invoked last. If a post processor returns null, the message is discarded (and acknowledged, if appropriate).spring-doc.cn
tickmark
tickmark
alwaysRequeueWithTxManagerRollback
(N/A)spring-doc.cn
Set to true to always requeue messages on rollback when a transaction manager is configured.spring-doc.cn
tickmark
tickmark
autoDeclare
(auto-declare)spring-doc.cn
When set to true (default), the container uses a RabbitAdmin to redeclare all AMQP objects (queues, exchanges, bindings), if it detects that at least one of its queues is missing during startup, perhaps because it is an auto-delete or an expired queue, but the redeclaration proceeds if the queue is missing for any reason. To disable this behavior, set this property to false. Note that the container fails to start if all of its queues are missing.spring-doc.cn
Prior to version 1.6, if there was more than one admin in the context, the container would randomly select one. If there were no admins, it would create one internally. In either case, this could cause unexpected results. Starting with version 1.6, for autoDeclare to work, there must be exactly one RabbitAdmin in the context, or a reference to a specific instance must be configured on the container using the rabbitAdmin property.
tickmark
tickmark
autoStartup
(auto-startup)spring-doc.cn
Flag to indicate that the container should start when the ApplicationContext does (as part of the SmartLifecycle callbacks, which happen after all beans are initialized). Defaults to true, but you can set it to false if your broker might not be available on startup and call start() later manually when you know the broker is ready.spring-doc.cn
tickmark
tickmark
tickmark
batchSize
(transaction-size) (batch-size)spring-doc.cn
When used with acknowledgeMode set to AUTO, the container tries to process up to this number of messages before sending an ack (waiting for each one up to the receive timeout setting). This is also when a transactional channel is committed. If the prefetchCount is less than the batchSize, it is increased to match the batchSize.spring-doc.cn
tickmark
batchingStrategy
(N/A)spring-doc.cn
The strategy used when debatchng messages. Default SimpleDebatchingStrategy. See Batching and @RabbitListener with Batching.spring-doc.cn
tickmark
tickmark
channelTransacted
(channel-transacted)spring-doc.cn
Boolean flag to signal that all messages should be acknowledged in a transaction (either manually or automatically).spring-doc.cn
tickmark
tickmark
concurrency
(N/A)spring-doc.cn
m-n The range of concurrent consumers for each listener (min, max). If only n is provided, n is a fixed number of consumers. See Listener Concurrency.spring-doc.cn
tickmark
concurrentConsumers
(concurrency)spring-doc.cn
The number of concurrent consumers to initially start for each listener. See Listener Concurrency. For the StLC, concurrency is controlled via an overloaded superStream method; see Consuming Super Streams with Single Active Consumers.spring-doc.cn
tickmark
tickmark
connectionFactory
(connection-factory)spring-doc.cn
A reference to the ConnectionFactory. When configuring by using the XML namespace, the default referenced bean name is rabbitConnectionFactory.spring-doc.cn
tickmark
tickmark
consecutiveActiveTrigger
(min-consecutive-active)spring-doc.cn
The minimum number of consecutive messages received by a consumer, without a receive timeout occurring, when considering starting a new consumer. Also impacted by 'batchSize'. See Listener Concurrency. Default: 10.spring-doc.cn
tickmark
consecutiveIdleTrigger
(min-consecutive-idle)spring-doc.cn
The minimum number of receive timeouts a consumer must experience before considering stopping a consumer. Also impacted by 'batchSize'. See Listener Concurrency. Default: 10.spring-doc.cn
tickmark
consumerBatchEnabled
(batch-enabled)spring-doc.cn
If the MessageListener supports it, setting this to true enables batching of discrete messages, up to batchSize; a partial batch will be delivered if no new messages arrive in receiveTimeout or gathering batch messages time exceeded batchReceiveTimeout. When this is false, batching is only supported for batches created by a producer; see Batching.spring-doc.cn
tickmark
consumerCustomizer
(N/A)spring-doc.cn
A ConsumerCustomizer bean used to modify stream consumers created by the container.spring-doc.cn
tickmark
consumerStartTimeout
(N/A)spring-doc.cn
The time in milliseconds to wait for a consumer thread to start. If this time elapses, an error log is written. An example of when this might happen is if a configured taskExecutor has insufficient threads to support the container concurrentConsumers.spring-doc.cn
See Threading and Asynchronous Consumers. Default: 60000 (one minute).spring-doc.cn
tickmark
consumerTagStrategy
(consumer-tag-strategy)spring-doc.cn
Set an implementation of ConsumerTagStrategy, enabling the creation of a (unique) tag for each consumer.spring-doc.cn
tickmark
tickmark
consumersPerQueue
(consumers-per-queue)spring-doc.cn
The number of consumers to create for each configured queue. See Listener Concurrency.spring-doc.cn
tickmark
consumeDelay
(N/A)spring-doc.cn
When using the RabbitMQ Sharding Plugin with concurrentConsumers > 1, there is a race condition that can prevent even distribution of the consumers across the shards. Use this property to add a small delay between consumer starts to avoid this race condition. You should experiment with values to determine the suitable delay for your environment.spring-doc.cn
tickmark
tickmark
debatchingEnabled
(N/A)spring-doc.cn
When true, the listener container will debatch batched messages and invoke the listener with each message from the batch. Starting with version 2.2.7, producer created batches will be debatched as a List<Message> if the listener is a BatchMessageListener or ChannelAwareBatchMessageListener. Otherwise messages from the batch are presented one-at-a-time. Default true. See Batching and @RabbitListener with Batching.spring-doc.cn
tickmark
tickmark
declarationRetries
(declaration-retries)spring-doc.cn
The number of retry attempts when passive queue declaration fails. Passive queue declaration occurs when the consumer starts or, when consuming from multiple queues, when not all queues were available during initialization. When none of the configured queues can be passively declared (for any reason) after the retries are exhausted, the container behavior is controlled by the missingQueuesFatal property, described earlier. Default: Three retries (for a total of four attempts).spring-doc.cn
tickmark
defaultRequeueRejected
(requeue-rejected)spring-doc.cn
Determines whether messages that are rejected because the listener threw an exception should be requeued or not. Default: true.spring-doc.cn
tickmark
tickmark
errorHandler
(error-handler)spring-doc.cn
A reference to an ErrorHandler strategy for handling any uncaught exceptions that may occur during the execution of the MessageListener. Default: ConditionalRejectingErrorHandlerspring-doc.cn
tickmark
tickmark
exclusive
(exclusive)spring-doc.cn
Determines whether the single consumer in this container has exclusive access to the queues. The concurrency of the container must be 1 when this is true. If another consumer has exclusive access, the container tries to recover the consumer, according to the recovery-interval or recovery-back-off. When using the namespace, this attribute appears on the <rabbit:listener/> element along with the queue names. Default: false.spring-doc.cn
tickmark
tickmark
exclusiveConsumerExceptionLogger
(N/A)spring-doc.cn
An exception logger used when an exclusive consumer cannot gain access to a queue. By default, this is logged at the WARN level.spring-doc.cn
tickmark
tickmark
failedDeclarationRetryInterval
(failed-declaration -retry-interval)spring-doc.cn
The interval between passive queue declaration retry attempts. Passive queue declaration occurs when the consumer starts or, when consuming from multiple queues, when not all queues were available during initialization. Default: 5000 (five seconds).spring-doc.cn
tickmark
tickmark
forceCloseChannel
(N/A)spring-doc.cn
If the consumers do not respond to a shutdown within shutdownTimeout, if this is true, the channel will be closed, causing any unacked messages to be requeued. Defaults to true since 2.0. You can set it to false to revert to the previous behavior.spring-doc.cn
tickmark
tickmark
forceStop
(N/A)spring-doc.cn
Set to true to stop (when the container is stopped) after the current record is processed; causing all prefetched messages to be requeued. By default, the container will cancel the consumer and process all prefetched messages before stopping. Since versions 2.4.14, 3.0.6 Defaults to false.spring-doc.cn
tickmark
tickmark
globalQos
(global-qos)spring-doc.cn
When true, the prefetchCount is applied globally to the channel rather than to each consumer on the channel. See basicQos.global for more information.spring-doc.cn
tickmark
tickmark
(group)spring-doc.cn
This is available only when using the namespace. When specified, a bean of type Collection<MessageListenerContainer> is registered with this name, and the container for each <listener/> element is added to the collection. This allows, for example, starting and stopping the group of containers by iterating over the collection. If multiple <listener-container/> elements have the same group value, the containers in the collection form an aggregate of all containers so designated.spring-doc.cn
tickmark
tickmark
idleEventInterval
(idle-event-interval)spring-doc.cn
See Detecting Idle Asynchronous Consumers.spring-doc.cn
tickmark
tickmark
javaLangErrorHandler
(N/A)spring-doc.cn
An AbstractMessageListenerContainer.JavaLangErrorHandler implementation that is called when a container thread catches an Error. The default implementation calls System.exit(99); to revert to the previous behavior (do nothing), add a no-op handler.spring-doc.cn
tickmark
tickmark
maxConcurrentConsumers
(max-concurrency)spring-doc.cn
The maximum number of concurrent consumers to start, if needed, on demand. Must be greater than or equal to 'concurrentConsumers'. See Listener Concurrency.spring-doc.cn
tickmark
messagesPerAck
(N/A)spring-doc.cn
The number of messages to receive between acks. Use this to reduce the number of acks sent to the broker (at the cost of increasing the possibility of redelivered messages). Generally, you should set this property only on high-volume listener containers. If this is set and a message is rejected (exception thrown), pending acks are acknowledged and the failed message is rejected. Not allowed with transacted channels. If the prefetchCount is less than the messagesPerAck, it is increased to match the messagesPerAck. Default: ack every message. See also ackTimeout in this table.spring-doc.cn
tickmark
mismatchedQueuesFatal
(mismatched-queues-fatal)spring-doc.cn
When the container starts, if this property is true (default: false), the container checks that all queues declared in the context are compatible with queues already on the broker. If mismatched properties (such as auto-delete) or arguments (such as x-message-ttl) exist, the container (and application context) fails to start with a fatal exception.spring-doc.cn
If the problem is detected during recovery (for example, after a lost connection), the container is stopped.spring-doc.cn
There must be a single RabbitAdmin in the application context (or one specifically configured on the container by using the rabbitAdmin property). Otherwise, this property must be false.spring-doc.cn
If the broker is not available during initial startup, the container starts and the conditions are checked when the connection is established.
The check is done against all queues in the context, not just the queues that a particular listener is configured to use. If you wish to limit the checks to just those queues used by a container, you should configure a separate RabbitAdmin for the container, and provide a reference to it using the rabbitAdmin property. See Conditional Declaration for more information.
Mismatched queue argument detection is disabled while starting a container for a @RabbitListener in a bean that is marked @Lazy. This is to avoid a potential deadlock which can delay the start of such containers for up to 60 seconds. Applications using lazy listener beans should check the queue arguments before getting a reference to the lazy bean.
tickmark
tickmark
missingQueuesFatal
(missing-queues-fatal)spring-doc.cn
When set to true (default), if none of the configured queues are available on the broker, it is considered fatal. This causes the application context to fail to initialize during startup. Also, when the queues are deleted while the container is running, by default, the consumers make three retries to connect to the queues (at five second intervals) and stop the container if these attempts fail.spring-doc.cn
This was not configurable in previous versions.spring-doc.cn
When set to false, after making the three retries, the container goes into recovery mode, as with other problems, such as the broker being down. The container tries to recover according to the recoveryInterval property. During each recovery attempt, each consumer again tries four times to passively declare the queues at five second intervals. This process continues indefinitely.spring-doc.cn
You can also use a properties bean to set the property globally for all containers, as follows:spring-doc.cn
<util:properties
        id="spring.amqp.global.properties">
    <prop key="mlc.missing.queues.fatal">
        false
    </prop>
</util:properties>
This global property is not applied to any containers that have an explicit missingQueuesFatal property set.spring-doc.cn
The default retry properties (three retries at five-second intervals) can be overridden by setting the properties below.spring-doc.cn
Missing queue detection is disabled while starting a container for a @RabbitListener in a bean that is marked @Lazy. This is to avoid a potential deadlock which can delay the start of such containers for up to 60 seconds. Applications using lazy listener beans should check the queue(s) before getting a reference to the lazy bean.
tickmark
tickmark
monitorInterval
(monitor-interval)spring-doc.cn
With the DMLC, a task is scheduled to run at this interval to monitor the state of the consumers and recover any that have failed.spring-doc.cn
tickmark
noLocal
(N/A)spring-doc.cn
Set to true to disable delivery from the server to consumers messages published on the same channel’s connection.spring-doc.cn
tickmark
tickmark
phase
(phase)spring-doc.cn
When autoStartup is true, the lifecycle phase within which this container should start and stop. The lower the value, the earlier this container starts and the later it stops. The default is Integer.MAX_VALUE, meaning the container starts as late as possible and stops as soon as possible.spring-doc.cn
tickmark
tickmark
possibleAuthenticationFailureFatal
(possible-authentication-failure-fatal)spring-doc.cn
When set to true (default for SMLC), if a PossibleAuthenticationFailureException is thrown during connection, it is considered fatal. This causes the application context to fail to initialize during startup (if the container is configured with auto startup).spring-doc.cn
Since version 2.0.spring-doc.cn
DirectMessageListenerContainerspring-doc.cn
When set to false (default), each consumer will attempt to reconnect according to the monitorInterval.spring-doc.cn
SimpleMessageListenerContainerspring-doc.cn
When set to false, after making the 3 retries, the container will go into recovery mode, as with other problems, such as the broker being down. The container will attempt to recover according to the recoveryInterval property. During each recovery attempt, each consumer will again try 4 times to start. This process will continue indefinitely.spring-doc.cn
<util:properties
  <prop
    key="mlc.possible.authentication.failure.fatal">
     false
  </prop>
</util:properties>
This global property will not be applied to any containers that have an explicit missingQueuesFatal property set.spring-doc.cn
The default retry properties (3 retries at 5 second intervals) can be overridden using the properties after this one.spring-doc.cn
tickmark
tickmark
prefetchCount
(prefetch)spring-doc.cn
The number of unacknowledged messages that can be outstanding at each consumer. The higher this value is, the faster the messages can be delivered, but the higher the risk of non-sequential processing. Ignored if the acknowledgeMode is NONE. This is increased, if necessary, to match the batchSize or messagePerAck. Defaults to 250 since 2.0. You can set it to 1 to revert to the previous behavior.spring-doc.cn
There are scenarios where the prefetch value should be low — for example, with large messages, especially if the processing is slow (messages could add up to a large amount of memory in the client process), and if strict message ordering is necessary (the prefetch value should be set back to 1 in this case). Also, with low-volume messaging and multiple consumers (including concurrency within a single listener container instance), you may wish to reduce the prefetch to get a more even distribution of messages across consumers.
Also see globalQos.spring-doc.cn
tickmark
tickmark
rabbitAdmin
(admin)spring-doc.cn
When a listener container listens to at least one auto-delete queue and it is found to be missing during startup, the container uses a RabbitAdmin to declare the queue and any related bindings and exchanges. If such elements are configured to use conditional declaration (see Conditional Declaration), the container must use the admin that was configured to declare those elements. Specify that admin here. It is required only when using auto-delete queues with conditional declaration. If you do not wish the auto-delete queues to be declared until the container is started, set auto-startup to false on the admin. Defaults to a RabbitAdmin that declares all non-conditional elements.spring-doc.cn
tickmark
tickmark
receiveTimeout
(receive-timeout)spring-doc.cn
The maximum time to wait for each message. If acknowledgeMode=NONE, this has very little effect — the container spins round and asks for another message. It has the biggest effect for a transactional Channel with batchSize > 1, since it can cause messages already consumed not to be acknowledged until the timeout expires. When consumerBatchEnabled is true, a partial batch will be delivered if this timeout occurs before a batch is complete.spring-doc.cn
tickmark
batchReceiveTimeout
(batch-receive-timeout)spring-doc.cn
The number of milliseconds of timeout for gathering batch messages. It limits the time to wait to fill batchSize. When batchSize > 1 and the time to gathering batch messages is greater than batchReceiveTime, batch will be delivered. Default is 0 (no timeout).spring-doc.cn
tickmark
recoveryBackOff
(recovery-back-off)spring-doc.cn
Specifies the BackOff for intervals between attempts to start a consumer if it fails to start for non-fatal reasons. Default is FixedBackOff with unlimited retries every five seconds. Mutually exclusive with recoveryInterval.spring-doc.cn
tickmark
tickmark
recoveryInterval
(recovery-interval)spring-doc.cn
Determines the time in milliseconds between attempts to start a consumer if it fails to start for non-fatal reasons. Default: 5000. Mutually exclusive with recoveryBackOff.spring-doc.cn
tickmark
tickmark
retryDeclarationInterval
(missing-queue- retry-interval)spring-doc.cn
If a subset of the configured queues are available during consumer initialization, the consumer starts consuming from those queues. The consumer tries to passively declare the missing queues by using this interval. When this interval elapses, the 'declarationRetries' and 'failedDeclarationRetryInterval' is used again. If there are still missing queues, the consumer again waits for this interval before trying again. This process continues indefinitely until all queues are available. Default: 60000 (one minute).spring-doc.cn
tickmark
shutdownTimeout
(N/A)spring-doc.cn
When a container shuts down (for example, if its enclosing ApplicationContext is closed), it waits for in-flight messages to be processed up to this limit. Defaults to five seconds.spring-doc.cn
tickmark
tickmark
startConsumerMinInterval
(min-start-interval)spring-doc.cn
The time in milliseconds that must elapse before each new consumer is started on demand. See Listener Concurrency. Default: 10000 (10 seconds).spring-doc.cn
tickmark
statefulRetryFatal
WithNullMessageId (N/A)spring-doc.cn
When using a stateful retry advice, if a message with a missing messageId property is received, it is considered fatal for the consumer (it is stopped) by default. Set this to false to discard (or route to a dead-letter queue) such messages.spring-doc.cn
tickmark
tickmark
stopConsumerMinInterval
(min-stop-interval)spring-doc.cn
The time in milliseconds that must elapse before a consumer is stopped since the last consumer was stopped when an idle consumer is detected. See Listener Concurrency. Default: 60000 (one minute).spring-doc.cn
tickmark
streamConverter
(N/A)spring-doc.cn
A StreamMessageConverter to convert a native Stream message to a Spring AMQP message.spring-doc.cn
tickmark
taskExecutor
(task-executor)spring-doc.cn
A reference to a Spring TaskExecutor (or standard JDK 1.5+ Executor) for executing listener invokers. Default is a SimpleAsyncTaskExecutor, using internally managed threads.spring-doc.cn
tickmark
tickmark
taskScheduler
(task-scheduler)spring-doc.cn
With the DMLC, the scheduler used to run the monitor task at the 'monitorInterval'.spring-doc.cn
tickmark
transactionManager
(transaction-manager)spring-doc.cn
External transaction manager for the operation of the listener. Also complementary to channelTransacted — if the Channel is transacted, its transaction is synchronized with the external transaction.spring-doc.cn
tickmark
tickmark
