Changes in 1.5 Since 1.4
spring-erlang
Is No Longer Supported
The spring-erlang
jar is no longer included in the distribution.
Use RabbitMQ REST API instead.
CachingConnectionFactory
Changes
Empty Addresses Property in CachingConnectionFactory
Previously, if the connection factory was configured with a host and port but an empty String was also supplied for
addresses
, the host and port were ignored.
Now, an empty addresses
String is treated the same as a null
, and the host and port are used.
URI Constructor
The CachingConnectionFactory
has an additional constructor, with a URI
parameter, to configure the broker connection.
Connection Reset
A new method called resetConnection()
has been added to let users reset the connection (or connections).
You might use this, for example, to reconnect to the primary broker after failing over to the secondary broker.
This does impact in-process operations.
The existing destroy()
method does exactly the same, but the new method has a less daunting name.
Properties to Control Container Queue Declaration Behavior
When the listener container consumers start, they attempt to passively declare the queues to ensure they are available
on the broker.
Previously, if these declarations failed (for example, because the queues didn’t exist) or when an HA queue was being
moved, the retry logic was fixed at three retry attempts at five-second intervals.
If the queues still do not exist, the behavior is controlled by the missingQueuesFatal
property (default: true
Also, for containers configured to listen from multiple queues, if only a subset of queues are available, the consumer
retried the missing queues on a fixed interval of 60 seconds.
The declarationRetries
, failedDeclarationRetryInterval
, and retryDeclarationInterval
properties are now configurable.
See Message Listener Container Configuration for more information.
Class Package Change
The RabbitGatewaySupport
class has been moved from o.s.amqp.rabbit.core.support
to o.s.amqp.rabbit.core
DefaultMessagePropertiesConverter
Changes
You can now configure the DefaultMessagePropertiesConverter
to
determine the maximum length of a LongString
that is converted
to a String
rather than to a DataInputStream
The converter has an alternative constructor that takes the value as a limit.
Previously, this limit was hard-coded at 1024
bytes.
(Also available in 1.4.4).
@RabbitListener
Improvements
@QueueBinding
for @RabbitListener
The bindings
attribute has been added to the @RabbitListener
annotation as mutually exclusive with the queues
attribute to allow the specification of the queue
, its exchange
, and binding
for declaration by a RabbitAdmin
on
the Broker.
SpEL in @SendTo
The default reply address (@SendTo
) for a @RabbitListener
can now be a SpEL expression.
Multiple Queue Names through Properties
You can now use a combination of SpEL and property placeholders to specify multiple queues for a listener.
See Annotation-driven Listener Endpoints for more information.
Automatic Exchange, Queue, and Binding Declaration
You can now declare beans that define a collection of these entities, and the RabbitAdmin
adds the
contents to the list of entities that it declares when a connection is established.
See Declaring Collections of Exchanges, Queues, and Bindings for more information.
RabbitTemplate
Changes
reply-address
Added
The reply-address
attribute has been added to the <rabbit-template>
component as an alternative reply-queue
See Request/Reply Messaging for more information.
(Also available in 1.4.4 as a setter on the RabbitTemplate
Blocking receive
Methods
The RabbitTemplate
now supports blocking in receive
and convertAndReceive
methods.
See Polling Consumer for more information.
Mandatory with sendAndReceive
Methods
When the mandatory
flag is set when using the sendAndReceive
and convertSendAndReceive
methods, the calling thread
throws an AmqpMessageReturnedException
if the request message cannot be delivered.
See Reply Timeout for more information.
Improper Reply Listener Configuration
The framework tries to verify proper configuration of a reply listener container when using a named reply queue.
See Reply Listener Container for more information.
RabbitManagementTemplate
Added
The RabbitManagementTemplate
has been introduced to monitor and configure the RabbitMQ Broker by using the REST API provided by its management plugin.
See RabbitMQ REST API for more information.
Listener Container Bean Names (XML)
The Normal Spring bean name overrides are applied.
If a later When migrating to this release, if you have |
However, to support starting and stopping containers as a group, a new group
attribute has been added.
When this attribute is defined, the containers created by this element are added to a bean with this name, of type Collection<SimpleMessageListenerContainer>
You can iterate over this group to start and stop containers.
Class-Level @RabbitListener
The @RabbitListener
annotation can now be applied at the class level.
Together with the new @RabbitHandler
method annotation, this lets you select the handler method based on payload type.
See Multi-method Listeners for more information.
: BackOff Support
The SimpleMessageListenerContainer
can now be supplied with a BackOff
instance for consumer
startup recovery.
Channel Close Logging
A mechanism to control the log levels of channel closure has been introduced. See Logging Channel Close Events.
Application Events
now emits application events when consumers fail.
See Consumer Events for more information.
Consumer Tag Configuration
Previously, the consumer tags for asynchronous consumers were generated by the broker. With this release, it is now possible to supply a naming strategy to the listener container. See Consumer Tags.
Using MessageListenerAdapter
The MessageListenerAdapter
now supports a map of queue names (or consumer tags) to method names, to determine
which delegate method to call based on the queue from which the message was received.
LocalizedQueueConnectionFactory
Added
is a new connection factory that connects to the node in a cluster where a mirrored queue actually resides.
Anonymous Queue Naming
Starting with version 1.5.3, you can now control how AnonymousQueue
names are generated.
See AnonymousQueue
