Multi-method Listeners
Starting with version 1.5.0, you can specify the @RabbitListener annotation at the class level. Together with the new @RabbitHandler annotation, this lets a single listener invoke different methods, based on the payload type of the incoming message. This is best described using an example:spring-doc.cn
@RabbitListener(id="multi", queues = "someQueue")
@SendTo("my.reply.queue")
public class MultiListenerBean {
    @RabbitHandler
    public String thing2(Thing2 thing2) {
    @RabbitHandler
    public String cat(Cat cat) {
    @RabbitHandler
    public String hat(@Header("amqp_receivedRoutingKey") String rk, @Payload Hat hat) {
    @RabbitHandler(isDefault = true)
    public String defaultMethod(Object object) {
In this case, the individual @RabbitHandler methods are invoked if the converted payload is a Thing2, a Cat, or a Hat. You should understand that the system must be able to identify a unique method based on the payload type. The type is checked for assignability to a single parameter that has no annotations or that is annotated with the @Payload annotation. Notice that the same method signatures apply, as discussed in the method-level @RabbitListener (described earlier).spring-doc.cn
Starting with version 2.0.3, a @RabbitHandler method can be designated as the default method, which is invoked if there is no match on other methods. At most, one method can be so designated.spring-doc.cn
@RabbitHandler is intended only for processing message payloads after conversion, if you wish to receive the unconverted raw Message object, you must use @RabbitListener on the method, not the class.
