Proxy @RabbitListener and Generics
If your service is intended to be proxied (for example, in the case of @Transactional), you should keep in mind some considerations when the interface has generic parameters. Consider the following example:spring-doc.cn
interface TxService<P> {
   String handle(P payload, String header);
static class TxServiceImpl implements TxService<Foo> {
    @RabbitListener(...)
    public String handle(Thing thing, String rk) {
With a generic interface and a particular implementation, you are forced to switch to the CGLIB target class proxy because the actual implementation of the interface handle method is a bridge method. In the case of transaction management, the use of CGLIB is configured by using an annotation option: @EnableTransactionManagement(proxyTargetClass = true). And in this case, all annotations have to be declared on the target method in the implementation, as the following example shows:spring-doc.cn
    @Transactional
    public String handle(@Payload Foo foo, @Header("amqp_receivedRoutingKey") String rk) {
