Listening to Multiple Queues
When you use the queues attribute, you can specify that the associated container can listen to multiple queues. You can use a @Header annotation to make the queue name from which a message was received available to the POJO method. The following example shows how to do so:spring-doc.cn
@Component
public class MyService {
    @RabbitListener(queues = { "queue1", "queue2" } )
    public void processOrder(String data, @Header(AmqpHeaders.CONSUMER_QUEUE) String queue) {
Starting with version 1.5, you can externalize the queue names by using property placeholders and SpEL. The following example shows how to do so:spring-doc.cn
@Component
    @RabbitListener(queues = "#{'${property.with.comma.delimited.queue.names}'.split(',')}" )
Prior to version 1.5, only a single queue could be specified this way. Each queue needed a separate property.spring-doc.cn
