Annotated Endpoint Method Signature
So far, we have been injecting a simple String in our endpoint, but it can actually have a very flexible method signature. The following example rewrites it to inject the Order with a custom header:spring-doc.cn
@Component
public class MyService {
    @RabbitListener(queues = "myQueue")
    public void processOrder(Order order, @Header("order_type") String orderType) {
The following list shows the arguments that are available to be matched with parameters in listener endpoints:spring-doc.cn
  • The raw org.springframework.amqp.core.Message.spring-doc.cn
  • The MessageProperties from the raw Message.spring-doc.cn
  • The com.rabbitmq.client.Channel on which the message was received.spring-doc.cn
  • The org.springframework.messaging.Message converted from the incoming AMQP message.spring-doc.cn
  • @Header-annotated method arguments to extract a specific header value, including standard AMQP headers.spring-doc.cn
  • @Headers-annotated argument that must also be assignable to java.util.Map for getting access to all headers.spring-doc.cn
  • The converted payloadspring-doc.cn
A non-annotated element that is not one of the supported types (that is, Message, MessageProperties, Message<?> and Channel) is matched with the payload. You can make that explicit by annotating the parameter with @Payload. You can also turn on validation by adding an extra @Valid.spring-doc.cn
The ability to inject Spring’s message abstraction is particularly useful to benefit from all the information stored in the transport-specific message without relying on the transport-specific API. The following example shows how to do so:spring-doc.cn
public void processOrder(Message<Order> order) { ...
Handling of method arguments is provided by DefaultMessageHandlerMethodFactory, which you can further customize to support additional method arguments. The conversion and validation support can be customized there as well.spring-doc.cn
For instance, if we want to make sure our Order is valid before processing it, we can annotate the payload with @Valid and configure the necessary validator, as follows:spring-doc.cn
@EnableRabbit
public class AppConfig implements RabbitListenerConfigurer {
    public void configureRabbitListeners(RabbitListenerEndpointRegistrar registrar) {
        registrar.setMessageHandlerMethodFactory(myHandlerMethodFactory());
    public DefaultMessageHandlerMethodFactory myHandlerMethodFactory() {
        DefaultMessageHandlerMethodFactory factory = new DefaultMessageHandlerMethodFactory();
        factory.setValidator(myValidator());
        return factory;
