For the latest stable version, please use Spring AMQP 3.2.0! |
Container Management
Containers created for annotations are not registered with the application context.
You can obtain a collection of all containers by invoking getListenerContainers()
on the
RabbitListenerEndpointRegistry
bean.
You can then iterate over this collection, for example, to stop or start all containers or invoke the Lifecycle
methods
on the registry itself, which will invoke the operations on each container.
You can also get a reference to an individual container by using its id
, using getListenerContainer(String id)
— for
example, registry.getListenerContainer("multi")
for the container created by the snippet above.
Starting with version 1.5.2, you can obtain the id
values of the registered containers with getListenerContainerIds()
Starting with version 1.5, you can now assign a group
to the container on the RabbitListener
endpoint.
This provides a mechanism to get a reference to a subset of containers.
Adding a group
attribute causes a bean of type Collection<MessageListenerContainer>
to be registered with the context with the group name.
By default, stopping a container will cancel the consumer and process all prefetched messages before stopping.
Starting with versions 2.4.14, 3.0.6, you can set the forceStop
container property to true to stop immediately after the current message is processed, causing any prefetched messages to be requeued.
This is useful, for example, if exclusive or single-active consumers are being used.
