For the latest stable version, please use Spring AMQP 3.2.0!spring-doc.cn
Using Container Factories
Listener container factories were introduced to support the @RabbitListener and registering containers with the RabbitListenerEndpointRegistry, as discussed in Programmatic Endpoint Registration.spring-doc.cn
Starting with version 2.1, they can be used to create any listener container — even a container without a listener (such as for use in Spring Integration). Of course, a listener must be added before the container is started.spring-doc.cn
There are two ways to create such containers:spring-doc.cn
The following example shows how to use a SimpleRabbitListenerEndpoint to create a listener container:spring-doc.cn
public SimpleMessageListenerContainer factoryCreatedContainerSimpleListener(
        SimpleRabbitListenerContainerFactory rabbitListenerContainerFactory) {
    SimpleRabbitListenerEndpoint endpoint = new SimpleRabbitListenerEndpoint();
    endpoint.setQueueNames("queue.1");
    endpoint.setMessageListener(message -> {
    return rabbitListenerContainerFactory.createListenerContainer(endpoint);
The following example shows how to add the listener after creation:spring-doc.cn
public SimpleMessageListenerContainer factoryCreatedContainerNoListener(
    SimpleMessageListenerContainer container = rabbitListenerContainerFactory.createListenerContainer();
    container.setMessageListener(message -> {
    container.setQueueNames("test.no.listener.yet");
    return container;
In either case, the listener can also be a ChannelAwareMessageListener, since it is now a sub-interface of MessageListener.spring-doc.cn
These techniques are useful if you wish to create several containers with similar properties or use a pre-configured container factory such as the one provided by Spring Boot auto configuration or both.spring-doc.cn
Containers created this way are normal @Bean instances and are not registered in the RabbitListenerEndpointRegistry.
