II. Reference
4. Shared components
This chapter explores the components that are shared between client- and server-side Spring-WS development. These interfaces and classes represent the building blocks of Spring-WS, so you need to understand what they do, even if you do not use them directly.
4.1. Web Service Messages
This section describes the messages and message factories that Spring-WS uses.
4.1.1. WebServiceMessage
One of the core interfaces of Spring Web Services is the WebServiceMessage
. This interface represents a protocol-agnostic XML message. The interface contains methods that provide access to the payload of the message, in the form of a javax.xml.transform.Source
or a javax.xml.transform.Result
. Source
and Result
are tagging interfaces that represent an abstraction over XML input and output. Concrete implementations wrap various XML representations, as indicated in the following table:
Source or Result implementation | Wrapped XML representation |
In addition to reading from and writing to the payload, a web service message can write itself to an output stream.
4.1.2. SoapMessage
SoapMessage
is a subclass of WebServiceMessage
. It contains SOAP-specific methods, such as getting SOAP Headers, SOAP Faults, and so on. Generally, your code should not be dependent on SoapMessage
, because the content of the SOAP Body (the payload of the message) can be obtained by using getPayloadSource()
and getPayloadResult()
in the WebServiceMessage
. Only when it is necessary to perform SOAP-specific actions (such as adding a header, getting an attachment, and so on) should you need to cast WebServiceMessage
to SoapMessage
4.1.3. Message Factories
Concrete message implementations are created by a WebServiceMessageFactory
. This factory can create an empty message or read a message from an input stream. There are two concrete implementations of WebServiceMessageFactory
. One is based on SAAJ, the SOAP with Attachments API for Java. The other is based on Axis 2’s AXIOM (AXis Object Model).
SaajSoapMessageFactory
The SaajSoapMessageFactory
uses the SOAP with Attachments API for Java (SAAJ) to create SoapMessage
implementations. SAAJ is part of J2EE 1.4, so it should be supported under most modern application servers. Here is an overview of the SAAJ versions supplied by common application servers:
Application Server | SAAJ Version |
BEA WebLogic 8 |
1.1 |
BEA WebLogic 9 |
1.1/1.21 |
IBM WebSphere 6 |
1.2 |
SUN Glassfish 1 |
1.3 |
1Weblogic 9 has a known bug in the SAAJ 1.2 implementation: it implements all the 1.2 interfaces but throws an |
Additionally, Java SE 6 includes SAAJ 1.3. You can wire up a SaajSoapMessageFactory
as follows:
<bean id="messageFactory" class="org.springframework.ws.soap.saaj.SaajSoapMessageFactory" />
SAAJ is based on DOM, the Document Object Model. This means that all SOAP messages are stored in memory. For larger SOAP messages, this may not be performant. In that case, the AxiomSoapMessageFactory might be more applicable.
The AxiomSoapMessageFactory
uses the AXis 2 Object Model (AXIOM) to create SoapMessage
implementations. AXIOM is based on StAX, the Streaming API for XML. StAX provides a pull-based mechanism for reading XML messages, which can be more efficient for larger messages.
To increase reading performance on the AxiomSoapMessageFactory
, you can set the payloadCaching
property to false (default is true). Doing so causesthe contents of the SOAP body to be read directly from the socket stream. When this setting is enabled, the payload can be read only once. This means that you have to make sure that any pre-processing (logging or other work) of the message does not consume it.
You can use the AxiomSoapMessageFactory
as follows:
<bean id="messageFactory" class="org.springframework.ws.soap.axiom.AxiomSoapMessageFactory">
<property name="payloadCaching" value="true"/>
</bean>
In addition to payload caching, AXIOM supports full streaming messages, as defined in the StreamingWebServiceMessage
. This means that you can directly set the payload on the response message, rather than writing it to a DOM tree or buffer.
Full streaming for AXIOM is used when a handler method returns a JAXB2-supported object. It automatically sets this marshalled object into the response message and writes it out to the outgoing socket stream when the response is going out.
For more information about full streaming, see the class-level Javadoc for StreamingWebServiceMessage
and StreamingPayload
SOAP 1.1 or 1.2
Both the SaajSoapMessageFactory
and the AxiomSoapMessageFactory
have a soapVersion
property, where you can inject a SoapVersion
constant. By default, the version is 1.1, but you can set it to 1.2:
xmlns:util="http://www.springframework.org/schema/util"
http://www.springframework.org/schema/beans/spring-beans-2.0.xsd
http://www.springframework.org/schema/util/spring-util-2.0.xsd">
<bean id="messageFactory" class="org.springframework.ws.soap.saaj.SaajSoapMessageFactory">
<property name="soapVersion">
<util:constant static-field="org.springframework.ws.soap.SoapVersion.SOAP_12"/>
</property>
</bean>
</beans>
In the preceding example, we define a SaajSoapMessageFactory
that accepts only SOAP 1.2 messages.
Even though both versions of SOAP are quite similar in format, the 1.2 version is not backwards compatible with 1.1, because it uses a different XML namespace. Other major differences between SOAP 1.1 and 1.2 include the different structure of a fault and the fact that One important thing to note with SOAP version numbers (or WS-* specification version numbers in general) is that the latest version of a specification is generally not the most popular version. For SOAP, this means that (currently) the best version to use is 1.1. Version 1.2 might become more popular in the future, but 1.1 is currently the safest bet. |
4.1.4. MessageContext
Typically, messages come in pairs: a request and a response. A request is created on the client-side, which is sent over some transport to the server-side, where a response is generated. This response gets sent back to the client, where it is read.
In Spring Web Services, such a conversation is contained in a MessageContext
, which has properties to get request and response messages. On the client-side, the message context is created by the WebServiceTemplate
. On the server-side, the message context is read from the transport-specific input stream. For example, in HTTP, it is read from the HttpServletRequest
, and the response is written back to the HttpServletResponse
4.2. TransportContext
One of the key properties of the SOAP protocol is that it tries to be transport-agnostic. This is why, for instance, Spring-WS does not support mapping messages to endpoints by HTTP request URL but rather by message content.
However, it is sometimes necessary to get access to the underlying transport, either on the client or the server side. For this, Spring Web Services has the TransportContext
. The transport context allows access to the underlying WebServiceConnection
, which typically is a HttpServletConnection
on the server side or a HttpUrlConnection
or CommonsHttpConnection
on the client side. For example, you can obtain the IP address of the current request in a server-side endpoint or interceptor:
TransportContext context = TransportContextHolder.getTransportContext();
HttpServletConnection connection = (HttpServletConnection )context.getConnection();
HttpServletRequest request = connection.getHttpServletRequest();
String ipAddress = request.getRemoteAddr();
4.3. Handling XML With XPath
One of the best ways to handle XML is to use XPath. Quoting [effective-xml], item 35:
XPath is a fourth generation declarative language that allows you to specify which nodes you want to process without specifying exactly how the processor is supposed to navigate to those nodes. XPath’s data model is very well designed to support exactly what almost all developers want from XML. For instance, it merges all adjacent text including that in CDATA sections, allows values to be calculated that skip over comments and processing instructions` and include text from child and descendant elements, and requires all external entity references to be resolved. In practice, XPath expressions tend to be much more robust against unexpected but perhaps insignificant changes in the input document.
Spring Web Services has two ways to use XPath within your application: the faster XPathExpression
or the more flexible XPathTemplate
4.3.1. XPathExpression
The XPathExpression
is an abstraction over a compiled XPath expression, such as the Java 5 javax.xml.xpath.XPathExpression
interface or the Jaxen XPath
class. To construct an expression in an application context, you can use XPathExpressionFactoryBean
. The following example uses this factory bean:
http://www.springframework.org/schema/beans/spring-beans-2.0.xsd">
<bean id="nameExpression" class="org.springframework.xml.xpath.XPathExpressionFactoryBean">
<property name="expression" value="/Contacts/Contact/Name"/>
</bean>
<bean id="myEndpoint" class="sample.MyXPathClass">
<constructor-arg ref="nameExpression"/>
</bean>
</beans>
The preceding expression does not use namespaces, but we could set those by using the namespaces
property of the factory bean. The expression can be used in the code as follows:
package sample;
public class MyXPathClass {
private final XPathExpression nameExpression;
public MyXPathClass(XPathExpression nameExpression) {
this.nameExpression = nameExpression;
public void doXPath(Document document) {
String name = nameExpression.evaluateAsString(document.getDocumentElement());
System.out.println("Name: " + name);
For a more flexible approach, you can use a NodeMapper
, which is similar to the RowMapper
in Spring’s JDBC support. The following example shows how to use it:
package sample;
private final XPathExpression contactExpression;
public MyXPathClass(XPathExpression contactExpression) {
this.contactExpression = contactExpression;
List contacts = contactExpression.evaluate(document,
new NodeMapper() {
public Object mapNode(Node node, int nodeNum) throws DOMException {
Element contactElement = (Element) node;
Element nameElement = (Element) contactElement.getElementsByTagName("Name").item(0);
Element phoneElement = (Element) contactElement.getElementsByTagName("Phone").item(0);
return new Contact(nameElement.getTextContent(), phoneElement.getTextContent());
PlainText Section qName; // do something with the list of Contact objects
Similar to mapping rows in Spring JDBC’s RowMapper
, each result node is mapped by using an anonymous inner class. In this case, we create a Contact
object, which we use later on.
4.3.2. XPathTemplate
The XPathExpression
lets you evaluate only a single, pre-compiled expression. A more flexible, though slower, alternative is the XpathTemplate
. This class follows the common template pattern used throughout Spring (JdbcTemplate
, JmsTemplate
, and others). The following listing shows an example:
package sample;
private XPathOperations template = new Jaxp13XPathTemplate();
public void doXPath(Source source) {
String name = template.evaluateAsString("/Contacts/Contact/Name", request);
// do something with name
4.4. Message Logging and Tracing
When developing or debugging a web service, it can be quite useful to look at the content of a (SOAP) message when it arrives or before it is sent. Spring Web Services offer this functionality, through the standard Commons Logging interface.
Make sure to use Commons Logging version 1.1 or higher. Earlier versions have class loading issues and do not integrate with the Log4J TRACE level. |
To log all server-side messages, set the org.springframework.ws.server.MessageTracing
logger level to DEBUG
or TRACE
. On the DEBUG
level, only the payload root element is logged. On the TRACE
level, the entire message content is logged. If you want to log only sent messages, use the org.springframework.ws.server.MessageTracing.sent
logger. Similarly, you can use org.springframework.ws.server.MessageTracing.received
to log only received messages.
On the client-side, similar loggers exist: org.springframework.ws.client.MessageTracing.sent
and org.springframework.ws.client.MessageTracing.received
The following example of a log4j.properties
configuration file logs the full content of sent messages on the client side and only the payload root element for client-side received messages. On the server-side, the payload root is logged for both sent and received messages:
log4j.rootCategory=INFO, stdout
log4j.logger.org.springframework.ws.client.MessageTracing.sent=TRACE
log4j.logger.org.springframework.ws.client.MessageTracing.received=DEBUG
log4j.logger.org.springframework.ws.server.MessageTracing=DEBUG
log4j.appender.stdout=org.apache.log4j.ConsoleAppender
log4j.appender.stdout.layout=org.apache.log4j.PatternLayout
log4j.appender.stdout.layout.ConversionPattern=%p [%c{3}] %m%n
With this configuration, a typical output is:
TRACE [client.MessageTracing.sent] Sent request [<SOAP-ENV:Envelope xmlns:SOAP-ENV="... DEBUG [server.MessageTracing.received] Received request [SaajSoapMessage {http://example.com}request] ... DEBUG [server.MessageTracing.sent] Sent response [SaajSoapMessage {http://example.com}response] ... DEBUG [client.MessageTracing.received] Received response [SaajSoapMessage {http://example.com}response] ...
5. Creating a Web service with Spring-WS
Spring-WS’s server-side support is designed around a MessageDispatcher
that dispatches incoming messages to endpoints, with configurable endpoint mappings, response generation, and endpoint interception. Endpoints are typically annotated with the @Endpoint
annotation and have one or more handling methods. These methods handle incoming XML request messages by inspecting parts of the message (typically the payload) and create some sort of response. You can annotate the method with another annotation, typically @PayloadRoot
, to indicate what sort of messages it can handle.
Spring-WS’s XML handling is extremely flexible. An endpoint can choose from a large number of XML handling libraries supported by Spring-WS, including:
The DOM family: W3C DOM, JDOM, dom4j, and XOM
SAX or StAX: For faster performance
XPath: To extract information from the message
Marshalling techniques (JAXB, Castor, XMLBeans, JiBX, or XStream): To convert the XML to objects and vice-versa
5.1. The MessageDispatcher
The server-side of Spring-WS is designed around a central class that dispatches incoming XML messages to endpoints. Spring-WS’s MessageDispatcher
is extremely flexible, letting you use any sort of class as an endpoint, as long as it can be configured in the Spring IoC container. In a way, the message dispatcher resembles Spring’s DispatcherServlet
, the
“Front Controller” used in Spring Web MVC.
The following sequence diagram shows the processing and dispatching flow of the MessageDispatcher
When a MessageDispatcher
is set up for use and a request comes in for that specific dispatcher, the MessageDispatcher
starts processing the request. The following process describes how MessageDispatcher
handles a request:
The configured
EndpointMapping(s)
is searched for an appropriate endpoint. If an endpoint is found, the invocation chain associated with the endpoint (pre-processors, post-processors, and endpoints) is invoked to create a response. -
An appropriate adapter is found for the endpoint. The
MessageDispatcher
delegates to this adapter to invoke the endpoint. -
If a response is returned, it is sent on its way. If no response is returned (which could be due to a pre- or post-processor intercepting the request, for example, for security reasons), no response is sent.
Exceptions that are thrown during the handling of the request get picked up by any of the endpoint exception resolvers that are declared in the application context. Using these exception resolvers lets you define custom behaviors (such as returning a SOAP fault), in case such exceptions get thrown.
has several properties for setting endpoint adapters, mappings, exception resolvers. However, setting these properties is not required, since the dispatcher automatically detects all of the types that are registered in the application context. You should set these properties only when you need to override detection.
The message dispatcher operates on a message context and not on a transport-specific input stream and output stream. As a result, transport-specific requests need to read into a MessageContext
. For HTTP, this is done with a WebServiceMessageReceiverHandlerAdapter
(which is a Spring Web HandlerInterceptor
) so that the MessageDispatcher
can be wired in a standard DispatcherServlet
. There is a more convenient way to do this, however, which is shown in MessageDispatcherServlet
5.2. Transports
Spring Web Services supports multiple transport protocols. The most common is the HTTP transport, for which a custom servlet is supplied, but you can also send messages over JMS and even email.
5.2.1. MessageDispatcherServlet
The MessageDispatcherServlet
is a standard Servlet
that conveniently extends from the standard Spring Web DispatcherServlet
and wraps a MessageDispatcher
. As a result, it combines the attributes of these into one. As a MessageDispatcher
, it follows the same request handling flow as described in the previous section. As a servlet, the MessageDispatcherServlet
is configured in the web.xml
of your web application. Requests that you want the MessageDispatcherServlet
to handle must be mapped by a URL mapping in the same web.xml
file. This is standard Java EE servlet configuration. The following example shows such a MessageDispatcherServlet
declaration and mapping:
<web-app>
<servlet>
<servlet-name>spring-ws</servlet-name>
<servlet-class>org.springframework.ws.transport.http.MessageDispatcherServlet</servlet-class>
<load-on-startup>1</load-on-startup>
</servlet>
<servlet-mapping>
<url-pattern>/*</url-pattern>
</servlet-mapping>
</web-app>
In the preceding example, all requests are handled by the spring-ws
. This is only the first step in setting up Spring Web Services, because the various component beans used by the Spring-WS framework also need to be configured. This configuration consists of standard Spring XML <bean/>
definitions. Because the MessageDispatcherServlet
is a standard Spring DispatcherServlet
, it
looks for a file named [servlet-name]-servlet.xml in the WEB-INF
directory of your web application and creates the beans defined there in a Spring container. In the preceding example, it looks for ‘/WEB-INF/spring-ws-servlet.xml’. This file contains all of the Spring Web Services beans, such as endpoints, marshallers, and so on.
As an alternative for web.xml
, if you run on a Servlet 3+ environment, you can configure Spring-WS programmatically. For this purpose, Spring-WS provides a number of abstract base classes that extend the WebApplicationInitializer
interface found in the Spring Framework. If you also use @Configuration
classes for your bean definitions, you should extend the AbstractAnnotationConfigMessageDispatcherServletInitializer
public class MyServletInitializer
extends AbstractAnnotationConfigMessageDispatcherServletInitializer {
protected Class<?>[] getRootConfigClasses() {
return new Class[]{MyRootConfig.class};
protected Class<?>[] getServletConfigClasses() {
return new Class[]{MyEndpointConfig.class};
In the preceding example, we tell Spring that endpoint bean definitions can be found in the MyEndpointConfig
class (which is a @Configuration
class). Other bean definitions (typically services, repositories, and so on) can be found in the MyRootConfig
class. By default, the AbstractAnnotationConfigMessageDispatcherServletInitializer
maps the servlet to two patterns: /services
and *.wsdl
, though you can change this by overriding the getServletMappings()
method. For more details on the programmatic configuration of the MessageDispatcherServlet
, refer to the Javadoc of AbstractMessageDispatcherServletInitializer
and AbstractAnnotationConfigMessageDispatcherServletInitializer
Automatic WSDL exposure
automatically detects any WsdlDefinition
beans defined in its Spring container. All the WsdlDefinition
detected beans are also exposed through a WsdlDefinitionHandlerAdapter
. This is a convenient way to expose your WSDL to clients by defining some beans.
By way of an example, consider the following <static-wsdl>
definition, defined in the Spring-WS configuration file (/WEB-INF/[servlet-name]-servlet.xml
). Take notice of the value of the id
attribute, because it is used when exposing the WSDL.
<sws:static-wsdl id="orders" location="orders.wsdl"/>
Alternatively, it can be a @Bean
method in a @Configuration
class:
public SimpleWsdl11Definition orders() {
return new SimpleWsdl11Definition(new ClassPathResource("orders.wsdl"));
You can access the WSDL defined in the orders.wsdl
file on the classpath through GET
requests to a URL of the following form (substitute the host, port and servlet context path as appropriate):
http://localhost:8080/spring-ws/orders.wsdl
All WsdlDefinition bean definitions are exposed by the MessageDispatcherServlet under their bean name with a suffix of`.wsdl`. So, if the bean name is echo , the host name is server , and the Servlet context (war name) is spring-ws , the WSDL can be found at http://server/spring-ws/echo.wsdl .
Another nice feature of the MessageDispatcherServlet
(or more correctly the WsdlDefinitionHandlerAdapter
) is that it can transform the value of the location
of all the WSDL that it exposes to reflect the URL of the incoming request.
Note that this location
transformation feature is off by default. To switch this feature on, you need to specify an initialization parameter to the MessageDispatcherServlet
<web-app>
<servlet>
<init-param>
<param-name>transformWsdlLocations</param-name>
<param-value>true</param-value>
</init-param>
</servlet>
<servlet-mapping>
</servlet-mapping>
</web-app>
If you use AbstractAnnotationConfigMessageDispatcherServletInitializer
, enabling transformation is as simple as overriding the isTransformWsdlLocations()
method to return true
Consult the class-level Javadoc on the WsdlDefinitionHandlerAdapter
class to learn more about the whole transformation process.
As an alternative to writing the WSDL by hand and exposing it with <static-wsdl>
, Spring Web Services can also generate a WSDL from an XSD schema. This is the approach shown in Publishing the WSDL. The next application context snippet shows how to create such a dynamic WSDL file:
<sws:dynamic-wsdl id="orders"
portTypeName="Orders"
locationUri="http://localhost:8080/ordersService/">
<sws:xsd location="Orders.xsd"/>
</sws:dynamic-wsdl>
Alternatively, you can use the Java @Bean
method:
public DefaultWsdl11Definition orders() {
DefaultWsdl11Definition definition = new DefaultWsdl11Definition();
definition.setPortTypeName("Orders");
definition.setLocationUri("http://localhost:8080/ordersService/");
definition.setSchema(new SimpleXsdSchema(new ClassPathResource("echo.xsd")));
return definition;
The <dynamic-wsdl>
element depends on the DefaultWsdl11Definition
class. This definition class uses WSDL providers in the org.springframework.ws.wsdl.wsdl11.provider
package and the ProviderBasedWsdl4jDefinition
class to generate a WSDL the first time it is requested. See the class-level Javadoc of these classes to see how you can extend this mechanism, if necessary.
The DefaultWsdl11Definition
(and therefore, the <dynamic-wsdl>
tag) builds a WSDL from an XSD schema by using conventions. It iterates over all element
elements found in the schema and creates a message
for all elements. Next, it creates a WSDL operation
for all messages that end with the defined request or response suffix. The default request suffix is Request
. The default response suffix is Response
, though these can be changed by setting the requestSuffix
and responseSuffix
attributes on <dynamic-wsdl />
, respectively. It also builds a portType
, binding
, and service
based on the operations.
For instance, if our Orders.xsd
schema defines the GetOrdersRequest
and GetOrdersResponse
elements, <dynamic-wsdl>
creates a GetOrdersRequest
message and a GetOrders
operation, which is put in a Orders
port type.
To use multiple schemas, either by includes or imports, you can put Commons XMLSchema on the class path. If Commons XMLSchema is on the class path, the <dynamic-wsdl>
element follows all XSD imports and includes and inlines them in the WSDL as a single XSD. This greatly simplifies the deployment of the schemas, while still making it possible to edit them separately.
Even though it can be handy to create the WSDL at runtime from your XSDs, there are a couple of drawbacks to this approach. First, though we try to keep the WSDL generation process consistent between releases, there is still the possibility that it changes (slightly). Second, the generation is a bit slow, though, once generated, the WSDL is cached for later reference. |
Therefore, you should use <dynamic-wsdl>
only during the development stages of your project. We recommend using your browser to download the generated WSDL, store it in the project, and expose it with <static-wsdl>
. This is the only way to be really sure that the WSDL does not change over time.
5.2.2. Wiring up Spring-WS in a DispatcherServlet
As an alternative to the MessageDispatcherServlet
, you can wire up a MessageDispatcher
in a standard, Spring-Web MVC DispatcherServlet
. By default, the DispatcherServlet
can delegate only to Controllers
, but we can instruct it to delegate to a MessageDispatcher
by adding a WebServiceMessageReceiverHandlerAdapter
to the servlet’s web application context:
<beans>
<bean class="org.springframework.ws.transport.http.WebServiceMessageReceiverHandlerAdapter"/>
<bean class="org.springframework.web.servlet.handler.SimpleUrlHandlerMapping">
<property name="defaultHandler" ref="messageDispatcher"/>
</bean
<bean id="messageDispatcher" class="org.springframework.ws.soap.server.SoapMessageDispatcher"/>
<bean class="org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter"/>
</beans>
Note that, by explicitly adding the WebServiceMessageReceiverHandlerAdapter
, the dispatcher servlet does not load the default adapters and is unable to handle standard Spring-MVC @Controllers
. Therefore, we add the RequestMappingHandlerAdapter
at the end.
In a similar fashion, you can wire a WsdlDefinitionHandlerAdapter
to make sure the DispatcherServlet
can handle implementations of the WsdlDefinition
interface:
<beans>
<bean class="org.springframework.ws.transport.http.WsdlDefinitionHandlerAdapter"/>
<property name="mappings">
<props>
<prop key="*.wsdl">myServiceDefinition</prop>
</props>
</property>
</bean>
<bean id="myServiceDefinition" class="org.springframework.ws.wsdl.wsdl11.SimpleWsdl11Definition">
<prop name="wsdl" value="/WEB-INF/myServiceDefintion.wsdl"/>
</bean>
</beans>
5.2.3. JMS transport
Spring Web Services supports server-side JMS handling through the JMS functionality provided in the Spring framework. Spring Web Services provides the WebServiceMessageListener
to plug in to a MessageListenerContainer
. This message listener requires a WebServiceMessageFactory
and MessageDispatcher
to operate. The following configuration example shows this:
<beans>
<bean id="connectionFactory" class="org.apache.activemq.ActiveMQConnectionFactory">
<property name="brokerURL" value="vm://localhost?broker.persistent=false"/>
</bean>
<bean id="messageFactory" class="org.springframework.ws.soap.saaj.SaajSoapMessageFactory"/>
<bean class="org.springframework.jms.listener.DefaultMessageListenerContainer">
<property name="connectionFactory" ref="connectionFactory"/>
<property name="destinationName" value="RequestQueue"/>
<property name="messageListener">
<bean class="org.springframework.ws.transport.jms.WebServiceMessageListener">
<property name="messageFactory" ref="messageFactory"/>
<property name="messageReceiver" ref="messageDispatcher"/>
</bean>
</property>
</bean>
<bean id="messageDispatcher" class="org.springframework.ws.soap.server.SoapMessageDispatcher">
<property name="endpointMappings">
<bean
class="org.springframework.ws.server.endpoint.mapping.PayloadRootAnnotationMethodEndpointMapping">
<property name="defaultEndpoint">
<bean class="com.example.MyEndpoint"/>
</property>
</bean>
</property>
</bean>
</beans>
5.2.4. Email Transport
In addition to HTTP and JMS, Spring Web Services also provides server-side email handling. This functionality is provided through the MailMessageReceiver
class. This class monitors a POP3 or IMAP folder, converts the email to a WebServiceMessage
, and sends any response by using SMTP. You can configure the host names through the storeUri
, which indicates the mail folder to monitor for requests (typically a POP3 or IMAP folder), and a transportUri
, which indicates the server to use for sending responses (typically an SMTP server).
You can configure how the MailMessageReceiver
monitors incoming messages with a pluggable strategy: the MonitoringStrategy
. By default, a polling strategy is used, where the incoming folder is polled for new messages every five minutes. You can change this interval by setting the pollingInterval
property on the strategy. By default, all MonitoringStrategy
implementations delete the handled messages. You can change this setting by setting the deleteMessages
property.
As an alternative to the polling approaches, which are quite inefficient, there is a monitoring strategy that uses IMAP IDLE. The IDLE command is an optional expansion of the IMAP email protocol that lets the mail server send new message updates to the MailMessageReceiver
asynchronously. If you use an IMAP server that supports the IDLE command, you can plug the ImapIdleMonitoringStrategy
into the monitoringStrategy
property. In addition to a supporting server, you need to use JavaMail version 1.4.1 or higher.
The following piece of configuration shows how to use the server-side email support, overriding the default polling interval to check every 30 seconds (30.000 milliseconds):
<beans>
<bean id="messagingReceiver" class="org.springframework.ws.transport.mail.MailMessageReceiver">
<property name="from" value="Spring-WS SOAP Server <[email protected]>"/>
<property name="storeUri" value="imap://server:[email protected]/INBOX"/>
<property name="transportUri" value="smtp://smtp.example.com"/>
<property name="monitoringStrategy">
<bean class="org.springframework.ws.transport.mail.monitor.PollingMonitoringStrategy">
<property name="pollingInterval" value="30000"/>
</bean>
</property>
</bean>
<bean
</property>
</bean>
</property>
</bean>
</beans>
5.2.5. Embedded HTTP Server transport
Spring Web Services provides a transport based on Sun’s JRE 1.6 HTTP server. The embedded HTTP Server is a standalone server that is simple to configure. It offers a lighter alternative to conventional servlet containers.
When using the embedded HTTP server, you need no external deployment descriptor (web.xml
). You need only define an instance of the server and configure it to handle incoming requests. The remoting module in the Core Spring Framework contains a convenient factory bean for the HTTP server: the SimpleHttpServerFactoryBean
. The most important property is contexts
, which maps context paths to corresponding HttpHandler
instances.
Spring Web Services provides two implementations of the HttpHandler
interface: WsdlDefinitionHttpHandler
and WebServiceMessageReceiverHttpHandler
. The former maps an incoming GET request to a WsdlDefinition
. The latter is responsible for handling POST requests for web services messages and, thus, needs a WebServiceMessageFactory
(typically a SaajSoapMessageFactory
) and a WebServiceMessageReceiver
(typically the SoapMessageDispatcher
) to accomplish its task.
To draw parallels with the servlet world, the contexts
property plays the role of servlet mappings in web.xml
and the WebServiceMessageReceiverHttpHandler
is the equivalent of a MessageDispatcherServlet
The following snippet shows a configuration example of the HTTP server transport:
<beans>
<bean id="messageReceiver" class="org.springframework.ws.soap.server.SoapMessageDispatcher">
<property name="endpointMappings" ref="endpointMapping"/>
</bean>
<bean id="endpointMapping" class="org.springframework.ws.server.endpoint.mapping.PayloadRootAnnotationMethodEndpointMapping">
<property name="defaultEndpoint" ref="stockEndpoint"/>
</bean>
<bean id="httpServer" class="org.springframework.remoting.support.SimpleHttpServerFactoryBean">
<property name="contexts">
<map>
<entry key="/StockService.wsdl" value-ref="wsdlHandler"/>
<entry key="/StockService" value-ref="soapHandler"/>
</map>
</property>
</bean>
<bean id="soapHandler" class="org.springframework.ws.transport.http.WebServiceMessageReceiverHttpHandler">
<property name="messageReceiver" ref="messageReceiver"/>
</bean>
<bean id="wsdlHandler" class="org.springframework.ws.transport.http.WsdlDefinitionHttpHandler">
<property name="definition" ref="wsdlDefinition"/>
</bean>
</beans>
For more information on the SimpleHttpServerFactoryBean
, see the Javadoc.
5.2.6. XMPP transport
Spring Web Services 2.0 introduced support for XMPP, otherwise known as Jabber. The support is based on the Smack library.
Spring Web Services support for XMPP is very similar to the other transports: There is a a XmppMessageSender
for the WebServiceTemplate
and a XmppMessageReceiver
to use with the MessageDispatcher
The following example shows how to set up the server-side XMPP components:
<beans>
<bean id="connection" class="org.springframework.ws.transport.xmpp.support.XmppConnectionFactoryBean">
<property name="host" value="jabber.org"/>
<property name="username" value="username"/>
<property name="password" value="password"/>
</bean>
<bean id="messagingReceiver" class="org.springframework.ws.transport.xmpp.XmppMessageReceiver">
<property name="connection" ref="connection"/>
</bean>
<bean
</property>
</bean>
</property>
</bean>
</beans>
5.2.7. MTOM
MTOM is the mechanism for sending binary data to and from Web Services. You can look at how to implement this with Spring WS through the MTOM sample.
5.3. Endpoints
Endpoints are the central concept in Spring-WS’s server-side support. Endpoints provide access to the application behavior, which is typically defined by a business service interface. An endpoint interprets the XML request message and uses that input to (typically) invoke a method on the business service. The result of that service invocation is represented as a response message. Spring-WS has a wide variety of endpoints and uses various ways to handle the XML message and to create a response.
You can create an endpoint by annotating a class with the @Endpoint
annotation. In the class, you define one or more methods that handle the incoming XML request, by using a wide variety of parameter types (such as DOM elements, JAXB2 objects, and others). You can indicate the sort of messages a method can handle by using another annotation (typically @PayloadRoot
Consider the following sample endpoint:
package samples;
@Endpoint (1)
public class AnnotationOrderEndpoint {
private final OrderService orderService;
@Autowired (2)
public AnnotationOrderEndpoint(OrderService orderService) {
this.orderService = orderService;
@PayloadRoot(localPart = "order", namespace = "http://samples") (5)
public void order(@RequestPayload Element orderElement) { (3)
Order order = createOrder(orderElement);
orderService.createOrder(order);
@PayloadRoot(localPart = "orderRequest", namespace = "http://samples") (5)
@ResponsePayload
public Order getOrder(@RequestPayload OrderRequest orderRequest, SoapHeader header) { (4)
checkSoapHeaderForSomething(header);
return orderService.getOrder(orderRequest.getId());
1 | The class is annotated with @Endpoint , marking it as a Spring-WS endpoint. |
2 | The constructor is marked with @Autowired so that the OrderService business service is injected into this endpoint. |
3 | The order method takes an Element (annotated with @RequestPayload ) as a parameter. This means that the payload of the message is passed on this method as a DOM element. The method has a void return type, indicating that no response message is sent.
For more information about endpoint methods, see @Endpoint handling methods. |
4 | The getOrder method takes an OrderRequest (also annotated with @RequestPayload ) as a parameter. This parameter is a JAXB2-supported object (it is annotated with @XmlRootElement ). This means that the payload of the message is passed to this method as a unmarshalled object. The SoapHeader type is also given as a parameter. On invocation, this parameter contains the SOAP header of the request message. The method is also annotated with @ResponsePayload , indicating that the return value (the Order ) is used as the payload of the response message.
5 | The two handling methods of this endpoint are marked with @PayloadRoot , indicating what sort of request messages can be handled by the method: the getOrder method is invoked for requests with a orderRequest local name and a http://samples namespace URI. The order method is invoked for requests with a order local name.
For more information about @PayloadRoot , see Endpoint mappings. |
To enable the support for @Endpoint
and related Spring-WS annotations, you need to add the following to your Spring application context:
xmlns:sws="http://www.springframework.org/schema/web-services"
http://www.springframework.org/schema/beans/spring-beans.xsd
http://www.springframework.org/schema/web-services/web-services.xsd">
*<sws:annotation-driven />
</beans>
Alternatively, if you use @Configuration
classes instead of Spring XML, you can annotate your configuration class with @EnableWs
@EnableWs
public class EchoConfig {
// @Bean definitions go here
To customize the @EnableWs
configuration, you can implement WsConfigurer
or, better yet, extend the WsConfigurerAdapter
@EnableWs
@ComponentScan(basePackageClasses = { MyConfiguration.class })
public class MyConfiguration extends WsConfigurerAdapter {
public void addInterceptors(List<EndpointInterceptor> interceptors) {
interceptors.add(new MyInterceptor());
public void addArgumentResolvers(List<MethodArgumentResolver> argumentResolvers) {
argumentResolvers.add(new MyArgumentResolver());
// More overridden methods ...
In the next couple of sections, a more elaborate description of the @Endpoint
programming model is given.
Endpoints, like any other Spring Bean, are scoped as a singleton by default. That is, one instance of the bean definition is created per container. Being a singleton implies that more than one thread can use it at the same time, so the endpoint has to be thread safe. If you want to use a different scope, such as prototype, see the Spring Reference documentation. |
Note that all abstract base classes provided in Spring-WS are thread safe, unless otherwise indicated in the class-level Javadoc.
5.3.1. @Endpoint
handling methods
For an endpoint to actually handle incoming XML messages, it needs to have one or more handling methods. Handling methods can take wide range of parameters and return types. However, they typically have one parameter that contains the message payload, and they return the payload of the response message (if any). This section covers which parameter and return types are supported.
To indicate what sort of messages a method can handle, the method is typically annotated with either the @PayloadRoot
or the @SoapAction
annotation. You can learn more about these annotations in Endpoint mappings.
The following example shows a handling method:
The order
Handling Method Parameters
The handling method typically has one or more parameters that refer to various parts of the incoming XML message. Most commonly, the handling method has a single parameter that maps to the payload of the message, but it can also map to other parts of the request message, such as a SOAP header. This section describes the parameters you can use in your handling method signatures.
To map a parameter to the payload of the request message, you need to annotate this parameter with the @RequestPayload
annotation. This annotation tells Spring-WS that the parameter needs to be bound to the request payload.
The following table describes the supported parameter types. It shows the supported types, whether the parameter should be annotated with @RequestPayload
, and any additional notes.
Name | Supported parameter types | @RequestPayload required? |
Additional notes |
TrAX |
Yes |
Enabled by default. |
W3C DOM |
Yes |
Enabled by default |
dom4j |
Yes |
Enabled when dom4j is on the classpath. |
JDOM |
Yes |
Enabled when JDOM is on the classpath. |
XOM |
Yes |
Enabled when XOM is on the classpath. |
StAX |
Yes |
Enabled when StAX is on the classpath. |
XPath |
Any boolean, double, |
No |
Enabled by default, see the section called |
Message context |
No |
SOAP |
No |
JAXB2 |
Any type that is annotated with |
Yes |
Enabled when JAXB2 is on the classpath. |
OXM |
Any type supported by a Spring OXM |
Yes |
Enabled when the |
The next few examples show possible method signatures. The following method is invoked with the payload of the request message as a DOM org.w3c.dom.Element
public void handle(@RequestPayload Element element)
The following method is invoked with the payload of the request message as a javax.xml.transform.dom.DOMSource
. The header
parameter is bound to the SOAP header of the request message.
public void handle(@RequestPayload DOMSource domSource, SoapHeader header)
The following method is invoked with the payload of the request message unmarshalled into a MyJaxb2Object
(which is annotated with @XmlRootElement
). The payload of the message is also given as a DOM Element
. The whole message context is passed on as the third parameter.
public void handle(@RequestPayload MyJaxb2Object requestObject, @RequestPayload Element element, Message messageContext)
As you can see, there are a lot of possibilities when it comes to defining how to handle method signatures. You can even extend this mechanism to support your own parameter types. See the Javadoc of DefaultMethodEndpointAdapter
and MethodArgumentResolver
to see how.
@XPathParam
One parameter type needs some extra explanation: @XPathParam
. The idea here is that you annotate one or more method parameters with an XPath expression and that each such annotated parameter is bound to the evaluation of the expression. The following example shows how to do so:
package samples;
@Endpoint
@Namespace(prefix = "s", uri="http://samples")
public Order getOrder(@XPathParam("/s:orderRequest/@id") int orderId) {
Order order = orderService.getOrder(orderId);
// create Source from order and return it
Since we use the s
prefix in our XPath expression, we must bind it to the http://samples
namespace. This is accomplished with the @Namespace
annotation. Alternatively, we could have placed this annotation on the type-level to use the same namespace mapping for all handler methods or even the package-level (in package-info.java
) to use it for multiple endpoints.
By using the @XPathParam
, you can bind to all the data types supported by XPath:
boolean
orBoolean
double
orDouble
String
Node
NodeList
In addition to this list, you can use any type that can be converted from a String
by a Spring conversion service.
Handling method return types
To send a response message, the handling needs to specify a return type. If no response message is required, the method can declare a void
return type. Most commonly, the return type is used to create the payload of the response message. However, you can also map to other parts of the response message. This section describes the return types you can use in your handling method signatures.
To map the return value to the payload of the response message, you need to annotate the method with the @ResponsePayload
annotation. This annotation tells Spring-WS that the return value needs to be bound to the response payload.
The following table describes the supported return types. It shows the supported types, whether the parameter should be annotated with @ResponsePayload
Name | Supported return types | @ResponsePayload required? |
Additional notes |
No response |
No |
TrAX |
Yes |
W3C DOM |
Yes |
dom4j |
Yes |
JDOM |
Yes |
XOM |
Yes |
JAXB2 |
Yes |
OXM |
Yes |
Enabled when the |
There are a lot of possibilities when it comes to defining handling method signatures. It is even possible to extend this mechanism to support your own parameter types. See the class-level Javadoc of DefaultMethodEndpointAdapter
and MethodReturnValueHandler
to see how.
5.4. Endpoint mappings
The endpoint mapping is responsible for mapping incoming messages to appropriate endpoints. Some endpoint mappings are enabled by default — for example, the PayloadRootAnnotationMethodEndpointMapping
or the SoapActionAnnotationMethodEndpointMapping
. However, we first need to examine the general concept of an EndpointMapping
An EndpointMapping
delivers a EndpointInvocationChain
, which contains the endpoint that matches the incoming request and may also contain a list of endpoint interceptors that are applied to the request and response. When a request comes in, the MessageDispatcher
hands it over to the endpoint mapping to let it inspect the request and come up with an appropriate EndpointInvocationChain
. Then the MessageDispatcher
invokes the endpoint and any interceptors in the chain.
The concept of configurable endpoint mappings that can optionally contain interceptors (which can, in turn, manipulate the request, the response, or both) is extremely powerful. A lot of supporting functionality can be built into custom EndpointMapping
implementations. For example, a custom endpoint mapping could choose an endpoint based not only on the contents of a message but also on a specific SOAP header (or, indeed, multiple SOAP headers).
Most endpoint mappings inherit from the AbstractEndpointMapping
, which offers an ‘interceptors’ property, which is the list of interceptors to use. EndpointInterceptors
are discussed in Intercepting Requests — the EndpointInterceptor
Interface. Additionally, there is the defaultEndpoint
, which is the default endpoint to use when this endpoint mapping does not result in a matching endpoint.
As explained in Endpoints, the @Endpoint
style lets you handle multiple requests in one endpoint class. This is the responsibility of the MethodEndpointMapping
. This mapping determines which method is to be invoked for an incoming request message.
There are two endpoint mappings that can direct requests to methods: the PayloadRootAnnotationMethodEndpointMapping
and the SoapActionAnnotationMethodEndpointMapping
You can enable both methods by using <sws:annotation-driven/>
in your application context.
The PayloadRootAnnotationMethodEndpointMapping
uses the @PayloadRoot
annotation, with the localPart
and namespace
elements, to mark methods with a particular qualified name. Whenever a message comes in with this qualified name for the payload root element, the method is invoked. For an example, see above.
Alternatively, the SoapActionAnnotationMethodEndpointMapping
uses the @SoapAction
annotation to mark methods with a particular SOAP Action. Whenever a message comes in with this SOAPAction
header, the method is invoked.
5.4.1. WS-Addressing
WS-Addressing specifies a transport-neutral routing mechanism. It is based on the To
and Action
SOAP headers, which indicate the destination and intent of the SOAP message, respectively. Additionally, WS-Addressing lets you define a return address (for normal messages and for faults) and a unique message identifier, which can be used for correlation. For more information on WS-Addressing, see https://en.wikipedia.org/wiki/WS-Addressing. The following example shows a WS-Addressing message:
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope"
xmlns:wsa="http://www.w3.org/2005/08/addressing">
<SOAP-ENV::Header>
<wsa:MessageID>urn:uuid:21363e0d-2645-4eb7-8afd-2f5ee1bb25cf</wsa:MessageID>
<wsa:ReplyTo>
<wsa:Address>http://example.com/business/client1</wsa:Address>
</wsa:ReplyTo>
<wsa:To S:mustUnderstand="true">http://example/com/fabrikam</wsa:To>
<wsa:Action>http://example.com/fabrikam/mail/Delete</wsa:Action>
</SOAP-ENV:Header>
<SOAP-ENV:Body>
<f:Delete xmlns:f="http://example.com/fabrikam">
<f:maxCount>42</f:maxCount>
</f:Delete>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
In the preceding example, the destination is set to http://example/com/fabrikam
, while the action is set to http://example.com/fabrikam/mail/Delete
. Additionally, there is a message identifier and a reply-to address. By default, this address is the “anonymous” address, indicating that a response should be sent byusing the same channel as the request (that is, the HTTP response), but it can also be another address, as indicated in this example.
In Spring Web Services, WS-Addressing is implemented as an endpoint mapping. By using this mapping, you associate WS-Addressing actions with endpoints, similar to the SoapActionAnnotationMethodEndpointMapping
described earlier.
Using AnnotationActionEndpointMapping
The AnnotationActionEndpointMapping
is similar to the SoapActionAnnotationMethodEndpointMapping
but uses WS-Addressing headers instead of the SOAP Action transport header.
To use the AnnotationActionEndpointMapping
, annotate the handling methods with the @Action
annotation, similar to the @PayloadRoot
and @SoapAction
annotations described in @Endpoint
handling methods and Endpoint mappings. The following example shows how to do so:
package samples;
@Endpoint
@Action("http://samples/RequestOrder")
public Order getOrder(OrderRequest orderRequest) {
@Action("http://samples/CreateOrder")
public void order(Order order) {
The preceding mapping routes requests that have a WS-Addressing Action
of http://samples/RequestOrder
to the getOrder
method. Requests with http://samples/CreateOrder
are routed to the order
method..
By default, the AnnotationActionEndpointMapping
supports both the 1.0 (May 2006), and the August 2004 editions of WS-Addressing. These two versions are most popular and are interoperable with Axis 1 and 2, JAX-WS, XFire, Windows Communication Foundation (WCF), and Windows Services Enhancements (WSE) 3.0. If necessary, specific versions of the spec can be injected into the versions
property.
In addition to the @Action
annotation, you can annotate the class with the @Address
annotation. If set, the value is compared to the To
header property of the incoming message.
Finally, there is the messageSenders
property, which is required for sending response messages to non-anonymous, out-of-bound addresses. You can set MessageSender
implementations in this property, the same as you would on the WebServiceTemplate
. See URIs and Transports.
5.4.2. Intercepting Requests — the EndpointInterceptor
Interface
The endpoint mapping mechanism has the notion of endpoint interceptors. These can be extremely useful when you want to apply specific functionality to certain requests — for example, dealing with security-related SOAP headers or the logging of request and response message.
Endpoint interceptors are typically defined by using a <sws:interceptors>
element in your application context. In this element, you can define endpoint interceptor beans that apply to all endpoints defined in that application context. Alternatively, you can use <sws:payloadRoot>
or <sws:soapAction>
elements to specify for which payload root name or SOAP action the interceptor should apply. The following example shows how to do so:
<sws:interceptors>
<bean class="samples.MyGlobalInterceptor"/>
<sws:payloadRoot namespaceUri="http://www.example.com">
<bean class="samples.MyPayloadRootInterceptor"/>
</sws:payloadRoot>
<sws:soapAction value="http://www.example.com/SoapAction">
<bean class="samples.MySoapActionInterceptor1"/>
<ref bean="mySoapActionInterceptor2"/>
</sws:soapAction>
</sws:interceptors>
<bean id="mySoapActionInterceptor2" class="samples.MySoapActionInterceptor2"/>
In the preceding example, we define one “global” interceptor (MyGlobalInterceptor
) that intercepts all requests and responses. We also define an interceptor that applies only to XML messages that have the http://www.example.com
as a payload root namespace. We could have defined a localPart
attribute in addition to the namespaceUri
to further limit the messages the to which interceptor applies. Finally, we define two interceptors that apply when the message has a http://www.example.com/SoapAction
SOAP action. Notice how the second interceptor is actually a reference to a bean definition outside of the <interceptors>
element. You can use bean references anywhere inside the <interceptors>
element.
When you use @Configuration
classes, you can extend from WsConfigurerAdapter
to add interceptors:
@EnableWs
public class MyWsConfiguration extends WsConfigurerAdapter {
interceptors.add(new MyPayloadRootInterceptor());
Interceptors must implement the EndpointInterceptor
interface from the org.springframework.ws.server
package. This interface defines three methods, one that can be used for handling the request message before the actual endpoint is processed, one that can be used for handling a normal response message, and one that can be used for handling fault messages. The second two are called after the endpoint is processed. These three methods should provide enough flexibility to do all kinds of pre- and post-processing.
The handleRequest(..)
method on the interceptor returns a boolean value. You can use this method to interrupt or continue the processing of the invocation chain. When this method returns true
, the endpoint processing chain will continue. When it returns false
interprets this to mean that the interceptor itself has taken care of things and does not continue processing the other interceptors and the actual endpoint in the invocation chain. The handleResponse(..)
and handleFault(..)
methods also have a boolean return value. When these methods return false
, the response will not be sent back to the client.
There are a number of standard EndpointInterceptor
implementations that you can use in your Web service. Additionally, there is the XwsSecurityInterceptor
, which is described in XwsSecurityInterceptor
PayloadLoggingInterceptor
and SoapEnvelopeLoggingInterceptor
When developing a web service, it can be useful to log the incoming and outgoing XML messages. Spring WS facilitates this with the PayloadLoggingInterceptor
classes. The former logs only the payload of the message to the Commons Logging Log. The latter logs the entire SOAP envelope, including SOAP headers. The following example shows how to define the PayloadLoggingInterceptor
in an endpoint mapping:
<sws:interceptors>
<bean class="org.springframework.ws.server.endpoint.interceptor.PayloadLoggingInterceptor"/>
</sws:interceptors>
Both of these interceptors have two properties, logRequest
and logResponse
, which can be set to false
to disable logging for either request or response messages.
You could use the WsConfigurerAdapter
approach, as described earlier, for the PayloadLoggingInterceptor
as well.
PayloadValidatingInterceptor
One of the benefits of using a contract-first development style is that we can use the schema to validate incoming and outgoing XML messages. Spring-WS facilitates this with the PayloadValidatingInterceptor
. This interceptor requires a reference to one or more W3C XML or RELAX NG schemas and can be set to validate requests, responses, or both.
Note that request validation may sound like a good idea, but it makes the resulting Web service very strict. Usually, it is not really important whether the request validates, only if the endpoint can get sufficient information to fulfill a request. Validating the response is a good idea, because the endpoint should adhere to its schema. Remember Postel’s Law: "Be conservative in what you do; be liberal in what you accept from others." |
The following example uses the PayloadValidatingInterceptor
. In this example, we use the schema in /WEB-INF/orders.xsd
to validate the response but not the request. Note that the PayloadValidatingInterceptor
can also accept multiple schemas by setting the schemas
property.
<bean id="validatingInterceptor"
class="org.springframework.ws.soap.server.endpoint.interceptor.PayloadValidatingInterceptor">
<property name="schema" value="/WEB-INF/orders.xsd"/>
<property name="validateRequest" value="false"/>
<property name="validateResponse" value="true"/>
</bean>
Of course, you could use the WsConfigurerAdapter
approach, as described earlier, for the PayloadValidatingInterceptor
as well.
Using PayloadTransformingInterceptor
To transform the payload to another XML format, Spring Web Services offers the PayloadTransformingInterceptor
. This endpoint interceptor is based on XSLT style sheets and is especially useful when supporting multiple versions of a web service, because you can transform the older message format to the newer format. The following example uses the PayloadTransformingInterceptor
<bean id="transformingInterceptor"
class="org.springframework.ws.server.endpoint.interceptor.PayloadTransformingInterceptor">
<property name="requestXslt" value="/WEB-INF/oldRequests.xslt"/>
<property name="responseXslt" value="/WEB-INF/oldResponses.xslt"/>
</bean>
In the preceding example, we transform requests by using /WEB-INF/oldRequests.xslt
and response messages by using /WEB-INF/oldResponses.xslt
. Note that, since endpoint interceptors are registered at the endpoint-mapping level, you can create an endpoint mapping that applies to the “old style” messages and add the interceptor to that mapping. Hence, the transformation applies only to these “old style” message.
approach, as described earlier, for the PayloadTransformingInterceptor
as well.
5.5. Handling Exceptions
Spring-WS provides EndpointExceptionResolvers
to ease the pain of unexpected exceptions occurring while your message is being processed by an endpoint that matched the request. Endpoint exception resolvers somewhat resemble the exception mappings that can be defined in the web application descriptor web.xml
. However, they provide a more flexible way to handle exceptions. They provide information about what endpoint was invoked when the exception was thrown. Furthermore, a programmatic way of handling exceptions gives you many more options for how to respond appropriately. Rather than expose the innards of your application by giving an exception and stack trace, you can handle the exception any way you want — for example, by returning a SOAP fault with a specific fault code and string.
Endpoint exception resolvers are automatically picked up by the MessageDispatcher
, so no explicit configuration is necessary.
Besides implementing the EndpointExceptionResolver
interface, which is only a matter of implementing the resolveException(MessageContext, endpoint, Exception)
method, you may also use one of the provided implementations. The simplest implementation is the SimpleSoapExceptionResolver
, which creates a SOAP 1.1 Server or SOAP 1.2 Receiver fault and uses the exception message as the fault string. The SimpleSoapExceptionResolver
is the default, but it can be overridden by explicitly adding another resolver.
5.5.1. SoapFaultMappingExceptionResolver
The SoapFaultMappingExceptionResolver
is a more sophisticated implementation. This resolver lets you take the class name of any exception that might be thrown and map it to a SOAP Fault:
<beans>
<bean id="exceptionResolver"
class="org.springframework.ws.soap.server.endpoint.SoapFaultMappingExceptionResolver">
<property name="defaultFault" value="SERVER"/>
<property name="exceptionMappings">
<value>
org.springframework.oxm.ValidationFailureException=CLIENT,Invalid request
</value>
</property>
</bean>
</beans>
The key values and default endpoint use a format of faultCode,faultString,locale
, where only the fault code is required. If the fault string is not set, it defaults to the exception message. If the language is not set, it defaults to English. The preceding configuration maps exceptions of type ValidationFailureException
to a client-side SOAP fault with a fault string of Invalid request
, as follows:
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
<SOAP-ENV:Body>
<SOAP-ENV:Fault>
<faultcode>SOAP-ENV:Client</faultcode>
<faultstring>Invalid request</faultstring>
</SOAP-ENV:Fault>
</SOAP-ENV:Body>
If any other exception occurs, it returns the default fault: a server-side fault with the exception message as the fault string.
5.5.2. Using SoapFaultAnnotationExceptionResolver
You can also annotate exception classes with the @SoapFault
annotation, to indicate the SOAP fault that should be returned whenever that exception is thrown. For these annotations to be picked up, you need to add the SoapFaultAnnotationExceptionResolver
to your application context. The elements of the annotation include a fault code enumeration, fault string or reason, and language. The following example shows such an exception:
package samples;
@SoapFault(faultCode = FaultCode.SERVER)
public class MyBusinessException extends Exception {
public MyClientException(String message) {
super(message);
Whenever the MyBusinessException
is thrown with the constructor string "Oops!"
during endpoint invocation, it results in the following response:
<SOAP-ENV:Body>
<SOAP-ENV:Fault>
<faultcode>SOAP-ENV:Server</faultcode>
<faultstring>Oops!</faultstring>
</SOAP-ENV:Fault>
</SOAP-ENV:Body>
5.6. Server-side Testing
When it comes to testing your Web service endpoints, you have two possible approaches:
Write Unit Tests, where you provide (mock) arguments for your endpoint to consume.
The advantage of this approach is that it is quite easy to accomplish (especially for classes annotated with
@Endpoint
). The disadvantage is that you are not really testing the exact content of the XML messages that are sent over the wire. -
Write Integrations Tests, which do test the contents of the message.
The first approach can easily be accomplished with mocking frameworks such as EasyMock, JMock, and others. The next section focuses on writing integration tests, using the test features introduced in Spring Web Services 2.0.
5.6.1. Writing server-side integration tests
Spring Web Services 2.0 introduced support for creating endpoint integration tests. In this context, an endpoint is a class that handles (SOAP) messages (see Endpoints).
The integration test support lives in the org.springframework.ws.test.server
package. The core class in that package is the MockWebServiceClient
. The underlying idea is that this client creates a request message and then sends it over to the endpoints that are configured in a standard MessageDispatcherServlet
application context (see MessageDispatcherServlet
). These endpoints handle the message and create a response. The client then receives this response and verifies it against registered expectations.
The typical usage of the MockWebServiceClient
is: .
Create a
instance by callingMockWebServiceClient.createClient(ApplicationContext)
orMockWebServiceClient.createClient(WebServiceMessageReceiver, WebServiceMessageFactory)
Send request messages by calling
sendRequest(RequestCreator)
, possibly by using the defaultRequestCreator
implementations provided inRequestCreators
(which can be statically imported). -
Set up response expectations by calling
andExpect(ResponseMatcher)
, possibly by using the defaultResponseMatcher
implementations provided inResponseMatchers
(which can be statically imported). Multiple expectations can be set up by chainingandExpect(ResponseMatcher)
calls.
Note that the MockWebServiceClient (and related classes) offers a “fluent” API, so you can typically use the code-completion features in your IDE to guide you through the process of setting up the mock server.
Also note that you can rely on the standard logging features available in Spring Web Services in your unit tests. Sometimes, it might be useful to inspect the request or response message to find out why a particular tests failed. See Message Logging and Tracing for more information. |
Consider, for example, the following web service endpoint class:
@Endpoint (1)
public class CustomerEndpoint {
@ResponsePayload (2)
public CustomerCountResponse getCustomerCount( (2)
@RequestPayload CustomerCountRequest request) { (2)
CustomerCountResponse response = new CustomerCountResponse();
response.setCustomerCount(10);
return response;
1 | The CustomerEndpoint in annotated with @Endpoint . See Endpoints. |
2 | The getCustomerCount() method takes a CustomerCountRequest as its argument and returns a CustomerCountResponse . Both of these classes are objects supported by a marshaller. For instance, they can have a @XmlRootElement annotation to be supported by JAXB2. |
The following example shows a typical test for CustomerEndpoint
@RunWith(SpringJUnit4ClassRunner.class) (2)
@ContextConfiguration("spring-ws-servlet.xml") (2)
public class CustomerEndpointIntegrationTest {
@Autowired
private ApplicationContext applicationContext; (3)
private MockWebServiceClient mockClient;
@Before
public void createClient() {
mockClient = MockWebServiceClient.createClient(applicationContext); (4)
@Test
public void customerEndpoint() throws Exception {
Source requestPayload = new StringSource(
"<customerCountRequest xmlns='http://springframework.org/spring-ws'>" +
"<customerName>John Doe</customerName>" +
"</customerCountRequest>");
Source responsePayload = new StringSource(
"<customerCountResponse xmlns='http://springframework.org/spring-ws'>" +
"<customerCount>10</customerCount>" +
"</customerCountResponse>");
mockClient.sendRequest(withPayload(requestPayload)). (5)
andExpect(payload(responsePayload)); (5)
1 | The CustomerEndpointIntegrationTest imports the MockWebServiceClient and statically imports RequestCreators and ResponseMatchers . |
2 | This test uses the standard testing facilities provided in the Spring Framework. This is not required but is generally the easiest way to set up the test. |
3 | The application context is a standard Spring-WS application context (see MessageDispatcherServlet ), read from spring-ws-servlet.xml . In this case, the application context contains a bean definition for CustomerEndpoint (or perhaps a <context:component-scan /> is used). |
4 | In a @Before method, we create a MockWebServiceClient by using the createClient factory method. |
5 | We send a request by calling sendRequest() with a withPayload() RequestCreator provided by the statically imported RequestCreators (see Using RequestCreator and RequestCreators ).
We also set up response expectations by calling This part of the test might look a bit confusing, but the code completion features of your IDE are of great help. After typing |
5.6.2. Using RequestCreator
and RequestCreators
Initially, the MockWebServiceClient
needs to create a request message for the endpoint to consume. The client uses the RequestCreator
strategy interface for this purpose:
public interface RequestCreator {
WebServiceMessage createRequest(WebServiceMessageFactory messageFactory)
throws IOException;
You can write your own implementations of this interface, creating a request message by using the message factory, but you certainly do not have to. The RequestCreators
class provides a way to create a RequestCreator
based on a given payload in the withPayload()
method. You typically statically import RequestCreators
5.6.3. Using ResponseMatcher
When the request message has been processed by the endpoint and a response has been received, the MockWebServiceClient
can verify whether this response message meets certain expectations. The client uses the ResponseMatcher
public interface ResponseMatcher {
void match(WebServiceMessage request,
WebServiceMessage response)
throws IOException, AssertionError;
Once again, you can write your own implementations of this interface, throwing AssertionError
instances when the message does not meet your expectations, but you certainly do not have to, as the ResponseMatchers
class provides standard ResponseMatcher
implementations for you to use in your tests. You typically statically import this class.
The ResponseMatchers
class provides the following response matchers:
ResponseMatchers method |
Description |
Expects a given response payload. |
Expects the response payload to validate against given XSD schemas. |
Expects a given XPath expression to exist, not exist, or evaluate to a given value. |
Expects a given SOAP header to exist in the response message. |
Expects that the response message does not contain a SOAP Fault. |
Expects the response message to contain a specific SOAP Fault. |
You can set up multiple response expectations by chaining andExpect()
calls:
mockClient.sendRequest(...).
andExpect(payload(expectedResponsePayload)).
andExpect(validPayload(schemaResource));
For more information on the response matchers provided by ResponseMatchers
, see the Javadoc.
6. Using Spring Web Services on the Client
Spring-WS provides a client-side Web service API that allows for consistent, XML-driven access to web services. It also caters to the use of marshallers and unmarshallers so that your service-tier code can deal exclusively with Java objects.
The org.springframework.ws.client.core
package provides the core functionality for using the client-side access API. It contains template classes that simplify the use of Web services, much like the core Spring JdbcTemplate
does for JDBC. The design principle common to Spring template classes is to provide helper methods to perform common operations and, for more sophisticated usage, delegate to user implemented callback interfaces. The web service template follows the same design. The classes offer various convenience methods for
Sending and receiving of XML messages
Marshalling objects to XML before sending
Allowing for multiple transport options
6.1. Using the Client-side API
This section describs how to use the client-side API. For how to use the server-side API, see Creating a Web service with Spring-WS.
6.1.1. WebServiceTemplate
The WebServiceTemplate
is the core class for client-side web service access in Spring-WS. It contains methods for sending Source
objects and receiving response messages as either Source
or Result
. Additionally, it can marshal objects to XML before sending them across a transport and unmarshal any response XML into an object again.
URIs and Transports
class uses an URI as the message destination. You can either set a defaultUri
property on the template itself or explicitly supply a URI when calling a method on the template. The URI is resolved into a WebServiceMessageSender
, which is responsible for sending the XML message across a transport layer. You can set one or more message senders by using the messageSender
or messageSenders
properties of the WebServiceTemplate
class.
HTTP transports
There are two implementations of the WebServiceMessageSender
interface for sending messages over HTTP. The default implementation is the HttpUrlConnectionMessageSender
, which uses the facilities provided by Java itself. The alternative is the HttpComponentsMessageSender
, which uses the Apache HttpComponents HttpClient. Use the latter if you need more advanced and easy-to-use functionality (such as authentication, HTTP connection pooling, and so forth).
To use the HTTP transport, either set the defaultUri
to something like http://example.com/services
or supply the uri
parameter for one of the methods.
The following example shows how to use default configuration for HTTP transports:
<beans>
<bean id="webServiceTemplate" class="org.springframework.ws.client.core.WebServiceTemplate">
<constructor-arg ref="messageFactory"/>
<property name="defaultUri" value="http://example.com/WebService"/>
</bean>
</beans>
The following example shows how to override the default configuration and how to use Apache HttpClient to authenticate with HTTP authentication:
<property name="messageSender">
<bean class="org.springframework.ws.transport.http.HttpComponentsMessageSender">
<property name="credentials">
<bean class="org.apache.http.auth.UsernamePasswordCredentials">
<constructor-arg value="john:secret"/>
</bean>
</property>
</bean>
</property>
</bean>
JMS transport
For sending messages over JMS, Spring Web Services provides JmsMessageSender
. This class uses the facilities of the Spring framework to transform the WebServiceMessage
into a JMS Message
, send it on its way on a Queue
or Topic
, and receive a response (if any).
To use JmsMessageSender
, you need to set the defaultUri
or uri
parameter to a JMS URI, which — at a minimum — consists of the jms:
prefix and a destination name. Some examples of JMS URIs are: jms:SomeQueue
, jms:SomeTopic?priority=3&deliveryMode=NON_PERSISTENT
, and jms:RequestQueue?replyToName=ResponseName
. For more information on this URI syntax, see the Javadoc for JmsMessageSender
By default, the JmsMessageSender
sends JMS BytesMessage
, but you can override this to use TextMessages
by using the messageType
parameter on the JMS URI — for example, jms:Queue?messageType=TEXT_MESSAGE
. Note that BytesMessages
are the preferred type, because TextMessages
do not support attachments and character encodings reliably.
The following example shows how to use the JMS transport in combination with an ActiveMQ connection factory:
<beans>
</bean>
<bean class="org.springframework.ws.transport.jms.JmsMessageSender">
</bean>
</property>
<property name="defaultUri" value="jms:RequestQueue?deliveryMode=NON_PERSISTENT"/>
</bean>
</beans>
Email Transport
Spring Web Services also provides an email transport, which you can use to send web service messages over SMTP and retrieve them over either POP3 or IMAP. The client-side email functionality is contained in the MailMessageSender
class. This class creates an email message from the request WebServiceMessage
and sends it over SMTP. It then waits for a response message to arrive at the incoming POP3 or IMAP server.
To use the MailMessageSender
, set the defaultUri
or uri
parameter to a mailto
URI — for example, mailto:[email protected]
or mailto:server@localhost?subject=SOAP%20Test
. Make sure that the message sender is properly configured with a transportUri
, which indicates the server to use for sending requests (typically a SMTP server), and a storeUri
, which indicates the server to poll for responses (typically a POP3 or IMAP server).
The following example shows how to use the email transport:
<beans>
<bean class="org.springframework.ws.transport.mail.MailMessageSender">
<property name="from" value="Spring-WS SOAP Client <[email protected]>"/>
<property name="transportUri" value="smtp://client:[email protected]"/>
<property name="storeUri" value="imap://client:[email protected]/INBOX"/>
</bean>
</property>
<property name="defaultUri" value="mailto:[email protected]?subject=SOAP%20Test"/>
</bean>
</beans>
XMPP Transport
Spring Web Services 2.0 introduced an XMPP (Jabber) transport, which you can use to send and receive web service messages over XMPP. The client-side XMPP functionality is contained in the XmppMessageSender
class. This class creates an XMPP message from the request WebServiceMessage
and sends it over XMPP. It then listens for a response message to arrive.
To use the XmppMessageSender
or uri
parameter to a xmpp
URI — for example, xmpp:[email protected]
. The sender also requires an XMPPConnection
to work, which can be conveniently created by using the org.springframework.ws.transport.xmpp.support.XmppConnectionFactoryBean
The following example shows how to use the XMPP transport:
<beans>
</bean>
<bean class="org.springframework.ws.transport.xmpp.XmppMessageSender">
</bean>
</property>
<property name="defaultUri" value="xmpp:[email protected]"/>
</bean>
</beans>
Message factories
In addition to a message sender, the WebServiceTemplate
requires a web service message factory. There are two message factories for SOAP: SaajSoapMessageFactory
and AxiomSoapMessageFactory
. If no message factory is specified (by setting the messageFactory
property), Spring-WS uses the SaajSoapMessageFactory
by default.
6.1.2. Sending and Receiving a WebServiceMessage
contains many convenience methods to send and receive web service messages. There are methods that accept and return a Source
and those that return a Result
. Additionally, there are methods that marshal and unmarshal objects to XML. The following example sends a simple XML message to a web service:
public class WebServiceClient {
private static final String MESSAGE =
"<message xmlns=\"http://tempuri.org\">Hello, Web Service World</message>";
private final WebServiceTemplate webServiceTemplate = new WebServiceTemplate();
public void setDefaultUri(String defaultUri) {
webServiceTemplate.setDefaultUri(defaultUri);
// send to the configured default URI
public void simpleSendAndReceive() {
StreamSource source = new StreamSource(new StringReader(MESSAGE));
StreamResult result = new StreamResult(System.out);
webServiceTemplate.sendSourceAndReceiveToResult(source, result);
// send to an explicit URI
public void customSendAndReceive() {
webServiceTemplate.sendSourceAndReceiveToResult("http://localhost:8080/AnotherWebService",
source, result);
<beans xmlns="http://www.springframework.org/schema/beans">
<bean id="webServiceClient" class="WebServiceClient">
<property name="defaultUri" value="http://localhost:8080/WebService"/>
</bean>
</beans>
The preceding example uses the WebServiceTemplate
to send a “Hello, World” message to the web service located at http://localhost:8080/WebService
(in the case of the simpleSendAndReceive()
method) and writes the result to the console. The WebServiceTemplate
is injected with the default URI, which is used because no URI was supplied explicitly in the Java code.
Note that the WebServiceTemplate
class is thread-safe once configured (assuming that all of its dependencies are also thread-safe, which is the case for all of the dependencies that ship with Spring-WS), so multiple objects can use the same shared WebServiceTemplate
instance. The WebServiceTemplate
exposes a zero-argument constructor and messageFactory
and messageSender
bean properties that you can use to construct the instance (by using a Spring container or plain Java code). Alternatively, consider deriving from Spring-WS’s WebServiceGatewaySupport
convenience base class, which exposes convenient bean properties to enable easy configuration. (You do not have to extend this base class. It is provided as a convenience class only.)
6.1.3. Sending and Receiving POJOs — Marshalling and Unmarshalling
To facilitate the sending of plain Java objects, the WebServiceTemplate
has a number of send(..)
methods that take an Object
as an argument for a message’s data content. The method marshalSendAndReceive(..)
in the WebServiceTemplate
class delegates the conversion of the request object to XML to a Marshaller
and the conversion of the response XML to an object to an Unmarshaller
. (For more information about marshalling and unmarshaller, see the Spring Framework reference documentation.) By using the marshallers, your application code can focus on the business object that is being sent or received and not be concerned with the details of how it is represented as XML. To use the marshalling functionality, you have to set a marshaller and an unmarshaller with the marshaller
and unmarshaller
class.
6.1.4. Using WebServiceMessageCallback
To accommodate setting SOAP headers and other settings on the message, the WebServiceMessageCallback
interface gives you access to the message after it has been created but before it is sent. The following example demonstrates how to set the SOAP action header on a message that is created by marshalling an object:
public void marshalWithSoapActionHeader(MyObject o) {
webServiceTemplate.marshalSendAndReceive(o, new WebServiceMessageCallback() {
public void doWithMessage(WebServiceMessage message) {
((SoapMessage)message).setSoapAction("http://tempuri.org/Action");
Note that you can also use the org.springframework.ws.soap.client.core.SoapActionCallback to set the SOAP action header.
WS-Addressing
In addition to the server-side WS-Addressing support, Spring Web Services also has support for this specification on the client-side.
For setting WS-Addressing headers on the client, you can use org.springframework.ws.soap.addressing.client.ActionCallback
. This callback takes the desired action header as a parameter. It also has constructors for specifying the WS-Addressing version and a To
header. If not specified, the To
header defaults to the URL of the connection being made.
The following example sets the Action
header to http://samples/RequestOrder
webServiceTemplate.marshalSendAndReceive(o, new ActionCallback("http://samples/RequestOrder"));
6.1.5. Using WebServiceMessageExtractor
The WebServiceMessageExtractor
interface is a low-level callback interface that you have full control over the process to extract an Object
from a received WebServiceMessage
invokes the extractData(..)
method on a supplied WebServiceMessageExtractor
while the underlying connection to the serving resource is still open. The following example shows the WebServiceMessageExtractor
in action:
public void marshalWithSoapActionHeader(final Source s) {
final Transformer transformer = transformerFactory.newTransformer();
webServiceTemplate.sendAndReceive(new WebServiceMessageCallback() {
transformer.transform(s, message.getPayloadResult());
new WebServiceMessageExtractor() {
public Object extractData(WebServiceMessage message) throws IOException {
// do your own transforms with message.getPayloadResult()
// or message.getPayloadSource()
6.2. Client-side Testing
When it comes to testing your Web service clients (that is, classes that use the WebServiceTemplate
to access a Web service), you have two possible approaches:
Write unit tests, which mock away the
WebServiceTemplate
class,WebServiceOperations
interface, or the complete client class.The advantage of this approach is that it s easy to accomplish. The disadvantage is that you are not really testing the exact content of the XML messages that are sent over the wire, especially when mocking out the entire client class.
Write integrations tests, which do test the contents of the message.
The first approach can easily be accomplished with mocking frameworks, such as EasyMock, JMock, and others. The next section focuses on writing integration tests, using the test features introduced in Spring Web Services 2.0.
6.2.1. Writing Client-side Integration Tests
Spring Web Services 2.0 introduced support for creating Web service client integration tests. In this context, a client is a class that uses the WebServiceTemplate
to access a web service.
The integration test support lives in the org.springframework.ws.test.client
package. The core class in that package is the MockWebServiceServer
. The underlying idea is that the web service template connects to this mock server and sends it a request message, which the mock server then verifies against the registered expectations. If the expectations are met, the mock server then prepares a response message, which is sent back to the template.
The typical usage of the MockWebServiceServer
is: .
Create a
instance by callingMockWebServiceServer.createServer(WebServiceTemplate)
,MockWebServiceServer.createServer(WebServiceGatewaySupport)
, orMockWebServiceServer.createServer(ApplicationContext)
Set up request expectations by calling
expect(RequestMatcher)
, possibly by using the defaultRequestMatcher
implementations provided inRequestMatchers
(which can be statically imported). Multiple expectations can be set up by chainingandExpect(RequestMatcher)
calls. -
Create an appropriate response message by calling
andRespond(ResponseCreator)
, possibly by using the defaultResponseCreator
implementations provided inResponseCreators
Use the
WebServiceTemplate
as normal, either directly of through client code. -
Call
MockWebServiceServer.verify()
to make sure that all expectations have been met.
Note that the MockWebServiceServer (and related classes) offers a 'fluent' API, so you can typically use the code-completion features in your IDE to guide you through the process of setting up the mock server.
Consider, for example, the following Web service client class:
public class CustomerClient extends WebServiceGatewaySupport { (1)
public int getCustomerCount() {
CustomerCountRequest request = new CustomerCountRequest(); (2)
request.setCustomerName("John Doe");
(CustomerCountResponse) getWebServiceTemplate().marshalSendAndReceive(request); (3)
return response.getCustomerCount();
1 | The CustomerClient extends WebServiceGatewaySupport , which provides it with a webServiceTemplate property. |
2 | CustomerCountRequest is an object supported by a marshaller. For instance, it can have an @XmlRootElement annotation to be supported by JAXB2. |
3 | The CustomerClient uses the WebServiceTemplate offered by WebServiceGatewaySupport to marshal the request object into a SOAP message and sends that to the web service. The response object is unmarshalled into a CustomerCountResponse . |
The following example shows a typical test for CustomerClient
@ContextConfiguration("integration-test.xml") (2)
public class CustomerClientIntegrationTest {
@Autowired
private CustomerClient client; (3)
private MockWebServiceServer mockServer; (4)
@Before
public void createServer() throws Exception {
mockServer = MockWebServiceServer.createServer(client);
@Test
public void customerClient() throws Exception {
mockServer.expect(payload(requestPayload)).andRespond(withPayload(responsePayload));(5)
int result = client.getCustomerCount(); (6)
assertEquals(10, result); (6)
mockServer.verify(); (7)
1 | The CustomerClientIntegrationTest imports the MockWebServiceServer and statically imports RequestMatchers and ResponseCreators . |
3 | The CustomerClient is configured in integration-test.xml and wired into this test using @Autowired . |
4 | In a @Before method, we create a MockWebServiceServer by using the createServer factory method. |
5 | We define expectations by calling expect() with a payload() RequestMatcher provided by the statically imported RequestMatchers (see Using RequestMatcher and RequestMatchers ).
We also set up a response by calling This part of the test might look a bit confusing, but the code-completion features of your IDE are of great help. After you type |
6 | We call getCustomerCount() on the CustomerClient , thus using the WebServiceTemplate . The template has been set up for “testing mode” by now, so no real (HTTP) connection is made by this method call. We also make some JUnit assertions based on the result of the method call. |
7 | We call verify() on the MockWebServiceServer , verifying that the expected message was actually received. |
6.2.2. Using RequestMatcher
and RequestMatchers
To verify whether the request message meets certain expectations, the MockWebServiceServer
uses the RequestMatcher
strategy interface. The contract defined by this interface is as follows:
public interface RequestMatcher {
void match(URI uri,
WebServiceMessage request)
throws IOException,
AssertionError;
You can write your own implementations of this interface, throwing AssertionError
exceptions when the message does not meet your expectations, but you certainly do not have to. The RequestMatchers
class provides standard RequestMatcher
The RequestMatchers
class provides the following request matchers:
RequestMatchers method |
Description |
Expects any sort of request. |
Expects a given request payload. |
Expects the request payload to validate against given XSD schemas. |
Expects a given SOAP header to exist in the request message. |
Expects a connection to the given URL. |
You can set up multiple request expectations by chaining andExpect()
calls:
mockServer.expect(connectionTo("http://example.com")).
andExpect(payload(expectedRequestPayload)).
andExpect(validPayload(schemaResource)).
andRespond(...);
For more information on the request matchers provided by RequestMatchers
, see the Javadoc.
6.2.3. Using ResponseCreator
When the request message has been verified and meets the defined expectations, the MockWebServiceServer
creates a response message for the WebServiceTemplate
to consume. The server uses the ResponseCreator
public interface ResponseCreator {
WebServiceMessage createResponse(URI uri,
throws IOException;
Once again, you can write your own implementations of this interface, creating a response message by using the message factory, but you certainly do not have to, as the ResponseCreators
class provides standard ResponseCreator
The ResponseCreators
class provides the following responses:
ResponseCreators method |
Description |
Creates a response message with a given payload. |
Creates an error in the response connection. This method gives you the opportunity to test your error handling. |
Throws an exception when reading from the response connection. This method gives you the opportunity to test your exception handling. |
Creates a response message with a given SOAP fault. This method gives you the opportunity to test your Fault handling. |
, see the Javadoc.
7. Securing Your Web services with Spring-WS
This chapter explains how to add WS-Security aspects to your Web services. We focus on the three different areas of WS-Security:
Authentication: This is the process of determining whether a principal is who they claim to be. In this context, a “principal” generally means a user, device or some other system that can perform an action in your application.
Digital signatures: The digital signature of a message is a piece of information based on both the document and the signer’s private key. It is created through the use of a hash function and a private signing function (encrypting with the signer’s private key).
Encryption and Decryption: Encryption is the process of transforming data into a form that is impossible to read without the appropriate key. It is mainly used to keep information hidden from anyone for whom it is not intended. Decryption is the reverse of encryption. It is the process of transforming encrypted data back into an readable form.
These three areas are implemented by using the XwsSecurityInterceptor
or Wss4jSecurityInterceptor
, which we describe in XwsSecurityInterceptor
and Using Wss4jSecurityInterceptor
, respectively
Note that WS-Security (especially encryption and signing) requires substantial amounts of memory and can decrease performance. If performance is important to you, you might want to consider not using WS-Security or using HTTP-based security. |
7.1. XwsSecurityInterceptor
The XwsSecurityInterceptor
is an EndpointInterceptor
(see Intercepting Requests — the EndpointInterceptor
Interface) that is based on SUN’s XML and Web Services Security package (XWSS). This WS-Security implementation is part of the Java Web Services Developer Pack (Java WSDP).
Like any other endpoint interceptor, it is defined in the endpoint mapping (see Endpoint mappings). This means that you can be selective about adding WS-Security support. Some endpoint mappings require it, while others do not.
Note that XWSS requires both a SUN 1.5 JDK and the SUN SAAJ reference implementation. The WSS4J interceptor does not have these requirements (see Using Wss4jSecurityInterceptor ).
requires a security policy file to operate. This XML file tells the interceptor what security aspects to require from incoming SOAP messages and what aspects to add to outgoing messages. The basic format of the policy file is explained in the following sections, but you can find a more in-depth tutorial here. You can set the policy with the policyConfiguration
property, which requires a Spring resource. The policy file can contain multiple elements — for example, require a username token on incoming messages and sign all outgoing messages. It contains a SecurityConfiguration
element (not a JAXRPCSecurity
element) as its root.
Additionally, the security interceptor requires one or more CallbackHandler
instances to operate. These handlers are used to retrieve certificates, private keys, validate user credentials, and so on. Spring-WS offers handlers for most common security concerns — for example, authenticating against a Spring Security authentication manager and signing outgoing messages based on a X509 certificate. The following sections indicate what callback handler to use for which security concern. You can set the callback handlers by using the callbackHandler
or callbackHandlers
property.
The following example that shows how to wire up the XwsSecurityInterceptor
<beans>
<bean id="wsSecurityInterceptor"
class="org.springframework.ws.soap.security.xwss.XwsSecurityInterceptor">
<property name="policyConfiguration" value="classpath:securityPolicy.xml"/>
<property name="callbackHandlers">
<list>
<ref bean="certificateHandler"/>
<ref bean="authenticationHandler"/>
</list>
</property>
</bean>
</beans>
This interceptor is configured by using the securityPolicy.xml
file on the classpath. It uses two callback handlers that are defined later in the file.
7.1.1. Keystores
For most cryptographic operations, you an use the standard java.security.KeyStore
objects. These operations include certificate verification, message signing, signature verification, and encryption. They exclude username and time-stamp verification. This section aims to give you some background knowledge on keystores and the Java tools that you can use to store keys and certificates in a keystore file. This information is mostly not related to Spring-WS but to the general cryptographic features of Java.
The java.security.KeyStore
class represents a storage facility for cryptographic keys and certificates. It can contain three different sort of elements:
Private Keys: These keys are used for self-authentication. The private key is accompanied by a certificate chain for the corresponding public key. Within the field of WS-Security, this accounts for message signing and message decryption.
Symmetric Keys: Symmetric (or secret) keys are also used for message encryption and decryption — the difference being that both sides (sender and recipient) share the same secret key.
Trusted certificates: These X509 certificates are called a “trusted certificate” because the keystore owner trusts that the public key in the certificates does indeed belong to the owner of the certificate. Within WS-Security, these certificates are used for certificate validation, signature verification, and encryption.
Using keytool
The keytool
program, a key and certificate management utility, is supplied with your Java Virtual Machine. You can use this tool to create new keystores, add new private keys and certificates to them, and so on. It is beyond the scope of this document to provide a full reference of the keytool
command, but you can find a reference here or by using the keytool -help
command on the command line.
Using KeyStoreFactoryBean
To easily load a keystore by using Spring configuration, you can use the KeyStoreFactoryBean
. It has a resource location property, which you can set to point to the path of the keystore to load. A password may be given to check the integrity of the keystore data. If a password is not given, integrity checking is not performed. The following listing configures a KeyStoreFactoryBean
<bean id="keyStore" class="org.springframework.ws.soap.security.support.KeyStoreFactoryBean">
<property name="password" value="password"/>
<property name="location" value="classpath:org/springframework/ws/soap/security/xwss/test-keystore.jks"/>
</bean>
If you do not specify the location property, a new, empty keystore is created, which is most likely not what you want. |
KeyStoreCallbackHandler
To use the keystores within a XwsSecurityInterceptor
, you need to define a KeyStoreCallbackHandler
. This callback has three properties with type keystore
: (keyStore
,trustStore
, and symmetricStore
). The exact stores used by the handler depend on the cryptographic operations that are to be performed by this handler. For private key operation, the keyStore
is used. For symmetric key operations, the symmetricStore
is used. For determining trust relationships, the trustStore
is used. The following table indicates this:
Cryptographic operation | Keystore used |
Certificate validation |
First |
Decryption based on private key |
Decryption based on symmetric key |
Encryption based on public key certificate |
Encryption based on symmetric key |
Signing |
Signature verification |
Additionally, the KeyStoreCallbackHandler
has a privateKeyPassword
property, which should be set to unlock the private keys contained in the`keyStore`.
If the symmetricStore
is not set, it defaults to the keyStore
. If the key or trust store is not set, the callback handler uses the standard Java mechanism to load or create it. See the JavaDoc of the KeyStoreCallbackHandler
to know how this mechanism works.
For instance, if you want to use the KeyStoreCallbackHandler
to validate incoming certificates or signatures, you can use a trust store:
<beans>
<bean id="keyStoreHandler" class="org.springframework.ws.soap.security.xwss.callback.KeyStoreCallbackHandler">
<property name="trustStore" ref="trustStore"/>
</bean>
<bean id="trustStore" class="org.springframework.ws.soap.security.support.KeyStoreFactoryBean">
<property name="location" value="classpath:truststore.jks"/>
<property name="password" value="changeit"/>
</bean>
</beans>
If you want to use it to decrypt incoming certificates or sign outgoing messages, you can use a key store:
<beans>
<property name="keyStore" ref="keyStore"/>
<property name="privateKeyPassword" value="changeit"/>
</bean>
<property name="location" value="classpath:keystore.jks"/>
</bean>
</beans>
The following sections indicate where the KeyStoreCallbackHandler
can be used and which properties to set for particular cryptographic operations.
7.1.2. Authentication
As stated in the introduction to this chapter, authentication is the task of determining whether a principal is who they claim to be. Within WS-Security, authentication can take two forms: using a username and password token (using either a plain text password or a password digest) or using a X509 certificate.
Plain Text Username Authentication
The simplest form of username authentication uses plain text passwords. In this scenario, the SOAP message contains a UsernameToken
element, which itself contains a Username
element and a Password
element which contains the plain text password. Plain text authentication can be compared to the basic authentication provided by HTTP servers.
Note that plain text passwords are not very secure. Therefore, you should always add additional security measures to your transport layer if you use them (using HTTPS instead of plain HTTP, for instance). |
To require that every incoming message contains a UsernameToken
with a plain text password, the security policy file should contain a RequireUsernameToken
element, with the passwordDigestRequired
attribute set to false
. You can find a reference of possible child elements here. The following listing shows how to include a RequireUsernameToken
element:
<xwss:SecurityConfiguration xmlns:xwss="http://java.sun.com/xml/ns/xwss/config">
<xwss:RequireUsernameToken passwordDigestRequired="false" nonceRequired="false"/>
</xwss:SecurityConfiguration>
If the username token is not present, the XwsSecurityInterceptor
returns a SOAP fault to the sender. If it is present, it fires a PasswordValidationCallback
with a PlainTextPasswordRequest
to the registered handlers. Within Spring-WS, there are three classes that handle this particular callback.
Using SimplePasswordValidationCallbackHandler
The simplest password validation handler is the SimplePasswordValidationCallbackHandler
. This handler validates passwords against an in-memory Properties
object, which you can specify byusing the users
property:
<bean id="passwordValidationHandler"
class="org.springframework.ws.soap.security.xwss.callback.SimplePasswordValidationCallbackHandler">
<property name="users">
<props>
<prop key="Bert">Ernie</prop>
</props>
</property>
</bean>
In this case, we are allowing only the user, "Bert", to log in by using the password, "Ernie".
Using SpringPlainTextPasswordValidationCallbackHandler
The SpringPlainTextPasswordValidationCallbackHandler
uses Spring Security to authenticate users. It is beyond the scope of this document to describe Spring Security, but it is a full-fledged security framework. You can read more about it in the Spring Security reference documentation.
requires an AuthenticationManager
to operate. It uses this manager to authenticate against a UsernamePasswordAuthenticationToken
that it creates. If authentication is successful, the token is stored in the SecurityContextHolder
. You can set the authentication manager by using the authenticationManager
property:
<beans>
<bean id="springSecurityHandler"
class="org.springframework.ws.soap.security.xwss.callback.SpringPlainTextPasswordValidationCallbackHandler">
<property name="authenticationManager" ref="authenticationManager"/>
</bean>
<bean id="authenticationManager" class="org.springframework.security.providers.ProviderManager">
<property name="providers">
<bean class="org.springframework.security.providers.dao.DaoAuthenticationProvider">
<property name="userDetailsService" ref="userDetailsService"/>
</bean>
</property>
</bean>
<bean id="userDetailsService" class="com.mycompany.app.dao.UserDetailService" />
</beans>
Using JaasPlainTextPasswordValidationCallbackHandler
The JaasPlainTextPasswordValidationCallbackHandler
is based on the standard Java Authentication and Authorization Service. It is beyond the scope of this document to provide a full introduction into JAAS, but a good tutorial is available.
requires only a loginContextName
to operate. It creates a new JAAS LoginContext
by using this name and handles the standard JAAS NameCallback
and PasswordCallback
by using the username and password provided in the SOAP message. This means that this callback handler integrates with any JAAS LoginModule
that fires these callbacks during the login()
phase, which is standard behavior.
You can wire up a JaasPlainTextPasswordValidationCallbackHandler
as follows:
<bean id="jaasValidationHandler"
class="org.springframework.ws.soap.security.xwss.callback.jaas.JaasPlainTextPasswordValidationCallbackHandler">
<property name="loginContextName" value="MyLoginModule" />
</bean>
In this case, the callback handler uses the LoginContext
named MyLoginModule
. This module should be defined in your jaas.config
file, as explained in the tutorial mentioned earlier.
Digest Username Authentication
When using password digests, the SOAP message also contains a UsernameToken
element. The difference is that the password is not sent as plain text, but as a digest. The recipient compares this digest to the digest he calculated from the known password of the user, and, if they are the same, the user is authenticated. This method is comparable to the digest authentication provided by HTTP servers.
element with a password digest, the security policy file should contain a RequireUsernameToken
attribute set to true
. Additionally, the nonceRequired
attribute should be set to true
: You can find a reference of possible child elements here. The following listing shows how to define a RequireUsernameToken
element:
<xwss:RequireUsernameToken passwordDigestRequired="true" nonceRequired="true"/>
with a DigestPasswordRequest
to the registered handlers. Within Spring-WS, two classes handle this particular callback: SimplePasswordValidationCallbackHandler
and SpringDigestPasswordValidationCallbackHandler
The SimplePasswordValidationCallbackHandler
can handle both plain text passwords as well as password digests. It is described in Using SimplePasswordValidationCallbackHandler
Using SpringDigestPasswordValidationCallbackHandler
The SpringDigestPasswordValidationCallbackHandler
requires a Spring Security UserDetailService
to operate. It uses this service to retrieve the password of the user specified in the token. The digest of the password contained in this details object is then compared with the digest in the message. If they are equal, the user has successfully authenticated, and a UsernamePasswordAuthenticationToken
. You can set the service by using the userDetailsService
property. Additionally, you can set a userCache
property, to cache loaded user details. The following example shows how to do so:
<beans>
<bean class="org.springframework.ws.soap.security.xwss.callback.SpringDigestPasswordValidationCallbackHandler">
</bean>
</beans>
Certificate Authentication
A more secure way of authentication uses X509 certificates. In this scenario, the SOAP message contains a`BinarySecurityToken`, which contains a Base 64-encoded version of a X509 certificate. The certificate is used by the recipient to authenticate. The certificate stored in the message is also used to sign the message (see Verifying Signatures).
To make sure that all incoming SOAP messages carry a`BinarySecurityToken`, the security policy file should contain a RequireSignature
element. This element can further carry other elements, which are covered in Verifying Signatures. You can find a reference of possible child elements here. The following listing shows how to define a RequireSignature
element:
<xwss:RequireSignature requireTimestamp="false">
When a message arrives that carries no certificate, the XwsSecurityInterceptor
returns a SOAP fault to the sender. If it is present, it fires a CertificateValidationCallback
. Three handlers within Spring-WS handle this callback for authentication purposes:
In most cases, certificate authentication should be preceded by certificate validation, since you want to authenticate against only valid certificates. Invalid certificates, such as certificates for which the expiration date has passed or which are not in your store of trusted certificates, should be ignored. In Spring-WS terms, this means that the
Using this setup, the interceptor first determines if the certificate in the message is valid buusing the keystore and then authenticating against it. |
Using KeyStoreCallbackHandler
The KeyStoreCallbackHandler
uses a standard Java keystore to validate certificates. This certificate validation process consists of the following steps: .
The handler checks whether the certificate is in the private
keyStore
. If it is, it is valid. -
If the certificate is not in the private keystore, the handler checks whether the current date and time are within the validity period given in the certificate. If they are not, the certificate is invalid. If it is, it continues with the final step.
A certification path for the certificate is created. This basically means that the handler determines whether the certificate has been issued by any of the certificate authorities in the
trustStore
. If a certification path can be built successfully, the certificate is valid. Otherwise, the certificate is not valid.
To use the KeyStoreCallbackHandler
for certificate validation purposes, you most likely need to set only the trustStore
property:
<beans>
</bean>
</bean>
</beans>
Using the setup shown in the preceding example, the certificate that is to be validated must be in the trust store itself or the trust store must contain a certificate authority that issued the certificate.
Using SpringCertificateValidationCallbackHandler
The SpringCertificateValidationCallbackHandler
requires an Spring Security AuthenticationManager
to operate. It uses this manager to authenticate against a X509AuthenticationToken
that it creates. The configured authentication manager is expected to supply a provider that can handle this token (usually an instance of X509AuthenticationProvider
). If authentication is successful, the token is stored in the SecurityContextHolder
property:
<beans>
<bean id="springSecurityCertificateHandler"
class="org.springframework.ws.soap.security.xwss.callback.SpringCertificateValidationCallbackHandler">
</bean>
<bean class="org.springframework.ws.soap.security.x509.X509AuthenticationProvider">
<property name="x509AuthoritiesPopulator">
<bean class="org.springframework.ws.soap.security.x509.populator.DaoX509AuthoritiesPopulator">
</bean>
</property>
</bean>
</property>
</bean>
</beans>
In this case, we use a custom user details service to obtain authentication details based on the certificate. See the Spring Security reference documentation for more information about authentication against X509 certificates.
Using JaasCertificateValidationCallbackHandler
The JaasCertificateValidationCallbackHandler
requires a loginContextName
by using this name and the X500Principal
of the certificate. This means that this callback handler integrates with any JAAS LoginModule
that handles X500 principals.
You can wire up a JaasCertificateValidationCallbackHandler
as follows:
class="org.springframework.ws.soap.security.xwss.callback.jaas.JaasCertificateValidationCallbackHandler">
<property name="loginContextName">MyLoginModule</property>
</bean>
named MyLoginModule
file and should be able to authenticate against X500 principals.
7.1.3. Digital Signatures
The digital signature of a message is a piece of information based on both the document and the signer’s private key. Two main tasks are related to signatures in WS-Security: verifying signatures and signing messages.
As with certificate-based authentication, a signed message contains a BinarySecurityToken
, which contains the certificate used to sign the message. Additionally, it contains a SignedInfo
block, which indicates what part of the message was signed.
To make sure that all incoming SOAP messages carry a BinarySecurityToken
element. It can also contain a SignatureTarget
element, which specifies the target message part that was expected to be signed and various other subelements. You can also define the private key alias to use, whether to use a symmetric instead of a private key, and many other properties. You can find a reference of possible child elements here. The following listing configures a RequireSignature
element:
<xwss:RequireSignature requireTimestamp="false"/>
If the signature is not present, the XwsSecurityInterceptor
returns a SOAP fault to the sender. If it is present, it fires a SignatureVerificationKeyCallback
to the registered handlers. Within Spring-WS, one class handles this particular callback: KeyStoreCallbackHandler
As described in KeyStoreCallbackHandler, KeyStoreCallbackHandler
uses a java.security.KeyStore
for handling various cryptographic callbacks, including signature verification. For signature verification, the handler uses the trustStore
property:
<beans>
</bean>
<property name="location" value="classpath:org/springframework/ws/soap/security/xwss/test-truststore.jks"/>
</bean>
</beans>
Signing Messages
When signing a message, the XwsSecurityInterceptor
adds the BinarySecurityToken
to the message. It also adds a SignedInfo
To sign all outgoing SOAP messages, the security policy file should contain a Sign
element, which specifies the target message part that was expected to be signed and various other subelements. You can also define the private key alias to use, whether to use a symmetric instead of a private key, and many other properties. You can find a reference of possible child elements here. The following example includes a Sign
element:
<xwss:Sign includeTimestamp="false" />
fires a SignatureKeyCallback
to the registered handlers. Within Spring-WS, the KeyStoreCallbackHandler
class handles this particular callback.
As described in KeyStoreCallbackHandler, the KeyStoreCallbackHandler
to handle various cryptographic callbacks, including signing messages. For adding signatures, the handler uses the keyStore
property. Additionally, you must set the privateKeyPassword
property to unlock the private key used for signing. The following example uses a KeyStoreCallbackHandler
<beans>
</bean>
</bean>
</beans>
7.1.4. Decryption and Encryption
When encrypting, the message is transformed into a form that can be read only with the appropriate key. The message can be decrypted to reveal the original, readable message.
Decryption
To decrypt incoming SOAP messages, the security policy file should contain a RequireEncryption
element. This element can further carry a EncryptionTarget
element that indicates which part of the message should be encrypted and a SymmetricKey
to indicate that a shared secret instead of the regular private key should be used to decrypt the message. You can read a description of the other elements here. The following example uses a RequireEncryption
element:
<xwss:RequireEncryption />
If an incoming message is not encrypted, the XwsSecurityInterceptor
returns a SOAP ault to the sender. If it is present, it fires a DecryptionKeyCallback
to handle various cryptographic callbacks, including decryption. For decryption, the handler uses the keyStore
property to unlock the private key used for decryption. For decryption based on symmetric keys, it uses the symmetricStore
. The following example uses KeyStoreCallbackHandler
<beans>
</bean>
</bean>
</beans>
Encryption
To encrypt outgoing SOAP messages, the security policy file should contain an Encrypt
to indicate that a shared secret instead of the regular public key should be used to encrypt the message. You can read a description of the other elements here. The following example uses an Encrypt
element:
<xwss:Encrypt />
fires an EncryptionKeyCallback
to the registered handlers to retrieve the encryption information. Within Spring-WS, the KeyStoreCallbackHandler
to handle various cryptographic callbacks, including encryption. For encryption based on public keys, the handler uses the trustStore
property. For encryption based on symmetric keys, it uses symmetricStore
<beans>
</bean>
</bean>
</beans>
7.1.5. Security Exception Handling
When a securement or validation action fails, the XwsSecurityInterceptor
throws a WsSecuritySecurementException
or WsSecurityValidationException
respectively. These exceptions bypass the standard exception handling mechanism but are handled by the interceptor itself.
exceptions are handled by the handleSecurementException
method of the XwsSecurityInterceptor
. By default, this method logs an error and stops further processing of the message.
Similarly, WsSecurityValidationException
exceptions are handled by the handleValidationException
. By default, this method creates a SOAP 1.1 Client or SOAP 1.2 sender fault and sends that back as a response.
Both handleSecurementException and handleValidationException are protected methods, which you can override to change their default behavior.
7.2. Using Wss4jSecurityInterceptor
The Wss4jSecurityInterceptor
Interface) that is based on Apache’s WSS4J.
WSS4J implements the following standards:
OASIS Web Services Security: SOAP Message Security 1.0 Standard 200401, March 2004
Username Token profile V1.0
X.509 Token Profile V1.0
This interceptor supports messages created by the AxiomSoapMessageFactory
and the SaajSoapMessageFactory
7.2.1. Configuring Wss4jSecurityInterceptor
WSS4J uses no external configuration file. The interceptor is entirely configured by properties. The validation and securement actions invoked by this interceptor are specified via validationActions
and securementActions
properties, respectively. Actions are passed as a space-separated strings. The following listing shows an example configuration:
<bean class="org.springframework.ws.soap.security.wss4j.Wss4jSecurityInterceptor">
<property name="validationActions" value="UsernameToken Encrypt"/>
<property name="securementActions" value="Encrypt"/>
</bean>
The following table shows the available validation actions:
Validation action | Description |
Validates username token |
Validates the timestamp |
Decrypts the message |
Validates the signature |
No action performed |
The following table shows the available securement actions:
Securement action | Description |
Adds a username token |
Adds a username token and a signature username token secret key |
Adds a timestamp |
Encrypts the response |
Signs the response |
The order of the actions is significant and is enforced by the interceptor. If its security actions were performed in a different order than the one specified by`validationActions`, the interceptor rejects an incoming SOAP message.
7.2.2. Handling Digital Certificates
For cryptographic operations that require interaction with a keystore or certificate handling (signature, encryption, and decryption operations), WSS4J requires an instance of`org.apache.ws.security.components.crypto.Crypto`.
Crypto
instances can be obtained from WSS4J’s CryptoFactory
or more conveniently with the Spring-WS`CryptoFactoryBean`.
CryptoFactoryBean
Spring-WS provides a convenient factory bean, CryptoFactoryBean
, that constructs and configures Crypto
instances through strongly typed properties (preferred) or through a Properties
object.
By default, CryptoFactoryBean
returns instances of org.apache.ws.security.components.crypto.Merlin
. You can change this by setting the cryptoProvider
property (or its equivalent org.apache.ws.security.crypto.provider
string property).
The following example configuration uses CryptoFactoryBean
<bean class="org.springframework.ws.soap.security.wss4j.support.CryptoFactoryBean">
<property name="keyStorePassword" value="mypassword"/>
<property name="keyStoreLocation" value="file:/path_to_keystore/keystore.jks"/>
</bean>
7.2.3. Authentication
This section addresses how to do authentication with Wss4jSecurityInterceptor
Validating Username Token
Spring-WS provides a set of callback handlers to integrate with Spring Security. Additionally, a simple callback handler, SimplePasswordValidationCallbackHandler
, is provided to configure users and passwords with an in-memory Properties
object.
Callback handlers are configured through the validationCallbackHandler
of the Wss4jSecurityInterceptor
property.
validates plain text and digest username tokens against an in-memory Properties
object. You can configure it as follows:
<bean id="callbackHandler"
class="org.springframework.ws.soap.security.wss4j.callback.SimplePasswordValidationCallbackHandler">
<props>
</props>
</property>
</bean>
Using SpringSecurityPasswordValidationCallbackHandler
The SpringSecurityPasswordValidationCallbackHandler
validates plain text and digest passwords by using a Spring Security UserDetailService
to operate. It uses this service to retrieve the the password (or a digest of the password) of the user specified in the token. The password (or a digest of the password) contained in this details object is then compared with the digest in the message. If they are equal, the user has successfully authenticated, and a UsernamePasswordAuthenticationToken
is stored in the`SecurityContextHolder`. You can set the service by using the userDetailsService
property, to cache loaded user details, as follows:
<beans>
<bean class="org.springframework.ws.soap.security.wss4j.callback.SpringDigestPasswordValidationCallbackHandler">
</bean>
</beans>
Adding Username Token
Adding a username token to an outgoing message is as simple as adding UsernameToken
to the securementActions
property of the Wss4jSecurityInterceptor
and specifying securementUsername
and`securementPassword`.
The password type can be set by setting the securementPasswordType
property. Possible values are PasswordText
for plain text passwords or PasswordDigest
for digest passwords, which is the default.
The following example generates a username token with a digest password:
<property name="securementActions" value="UsernameToken"/>
<property name="securementUsername" value="Ernie"/>
<property name="securementPassword" value="Bert"/>
</bean>
If the plain text password type is chosen, it is possible to instruct the interceptor to add Nonce
and Created
elements by setting the securementUsernameTokenElements
property. The value must be a list that contains the desired elements' names separated by spaces (case sensitive).
The following example generates a username token with a plain text password, a Nonce
, and a Created
element:
<property name="securementPasswordType" value="PasswordText"/>
<property name="securementUsernameTokenElements" value="Nonce Created"/>
</bean>
As certificate authentication is akin to digital signatures, WSS4J handles it as part of the signature validation and securement. Specifically, the securementSignatureKeyIdentifier
property must be set to DirectReference
in order to instruct WSS4J to generate a BinarySecurityToken
element containing the X509 certificate and to include it in the outgoing message. The certificate’s name and password are passed through the securementUsername
and securementPassword
properties, respectively, as the following example shows:
<property name="securementActions" value="Signature"/>
<property name="securementSignatureKeyIdentifier" value="DirectReference"/>
<property name="securementUsername" value="mycert"/>
<property name="securementPassword" value="certpass"/>
<property name="securementSignatureCrypto">
<property name="keyStorePassword" value="123456"/>
<property name="keyStoreLocation" value="classpath:/keystore.jks"/>
</bean>
</property>
</bean>
For the certificate validation, regular signature validation applies:
<property name="validationActions" value="Signature"/>
<property name="validationSignatureCrypto">
</bean>
</property>
</bean>
At the end of the validation, the interceptor automatically verifies the validity of the certificate by delegating to the default WSS4J implementation. If needed, you can change this behavior by redefining the verifyCertificateTrust
method.
For more detail, see to Digital Signatures.
7.2.4. Security Timestamps
This section describes the various timestamp options available in the Wss4jSecurityInterceptor
Validating Timestamps
To validate timestamps, add Timestamp
to the validationActions
property. You can override timestamp semantics specified by the initiator of the SOAP message by setting timestampStrict
to true
and specifying a server-side time-to-live in seconds (default: 300) by setting the timeToLive
property. The interceptor always rejects already expired timestamps, whatever the value of timeToLive
is.
In the following example, the interceptor limits the timestamp validity window to 10 seconds, rejecting any valid timestamp token outside that window:
<property name="validationActions" value="Timestamp"/>
<property name="timestampStrict" value="true"/>
<property name="timeToLive" value="10"/>
</bean>
Adding Timestamps
Adding Timestamp
property generates a timestamp header in outgoing messages. The timestampPrecisionInMilliseconds
property specifies whether the precision of the generated timestamp is in milliseconds. The default value is true
. The following listing adds a timestamp:
<property name="securementActions" value="Timestamp"/>
<property name="timestampPrecisionInMilliseconds" value="true"/>
</bean>
7.2.5. Digital Signatures
This section describes the various signature options available in the Wss4jSecurityInterceptor
To instruct the Wss4jSecurityInterceptor
, validationActions
must contain the Signature
action. Additionally, the validationSignatureCrypto
property must point to the keystore containing the public certificates of the initiator:
<bean id="wsSecurityInterceptor" class="org.springframework.ws.soap.security.wss4j.Wss4jSecurityInterceptor">
</bean>
</property>
</bean>
Signing Messages
Signing outgoing messages is enabled by adding the Signature
action to the securementActions
. The alias and the password of the private key to use are specified by the securementUsername
properties, respectively. securementSignatureCrypto
must point to the keystore that contains the private key:
<property name="securementUsername" value="mykey"/>
<property name="securementPassword" value="123456"/>
</bean>
</property>
</bean>
Furthermore, you can define the signature algorithm by setting the securementSignatureAlgorithm
property.
You can customize the key identifier type to use by setting the securementSignatureKeyIdentifier
property. Only IssuerSerial
and DirectReference
are valid for the signature.
The securementSignatureParts
property controls which part of the message is signed. The value of this property is a list of semicolon-separated element names that identify the elements to sign. The general form of a signature part is {}{namespace}Element
. Note that the first empty brackets are used for encryption parts only. The default behavior is to sign the SOAP body.
The following example shows how to sign the echoResponse
element in the Spring Web Services echo sample:
<property name="securementSignatureParts"
value="{}{http://www.springframework.org/spring-ws/samples/echo}echoResponse"/>
To specify an element without a namespace, use the string, Null
(case sensitive), as the namespace name.
If no other element in the request has a local name of Body
, the SOAP namespace identifier can be empty ({}
Signature Confirmation
Signature confirmation is enabled by setting enableSignatureConfirmation
to true
. Note that the signature confirmation action spans over the request and the response. This implies that secureResponse
and validateRequest
must be set to true
(which is the default value) even if there are no corresponding security actions. The following example sets the enableSignatureConfirmation
property to true
<property name="enableSignatureConfirmation" value="true"/>
<property name="keyStoreLocation" value="file:/keystore.jks"/>
</bean>
</property>
</bean>
7.2.6. Decryption and Encryption
This section describes the various decryption and encryption options available in the Wss4jSecurityInterceptor
Decryption
Decryption of incoming SOAP messages requires that the Encrypt
action be added to the validationActions
property. The rest of the configuration depends on the key information that appears in the message. (This is because WSS4J needs only a Crypto for encypted keys, whereas embedded key name validation is delegated to a callback handler.)
To decrypt messages with an embedded encrypted symmetric key (the xenc:EncryptedKey
element), validationDecryptionCrypto
needs to point to a keystore that contains the decryption private key. Additionally, validationCallbackHandler
has to be injected with a org.springframework.ws.soap.security.wss4j.callback.KeyStoreCallbackHandler
that specifies the key’s password:
<property name="validationActions" value="Encrypt"/>
<property name="validationDecryptionCrypto">
</bean>
</property>
<property name="validationCallbackHandler">
<bean class="org.springframework.ws.soap.security.wss4j.callback.KeyStoreCallbackHandler">
<property name="privateKeyPassword" value="mykeypass"/>
</bean>
</property>
</bean>
To support decryption of messages with an embedded key name ( ds:KeyName
element), you can configure a KeyStoreCallbackHandler
that points to the keystore with the symmetric secret key. The symmetricKeyPassword
property indicates the key’s password, the key name being the one specified by ds:KeyName
element:
<property name="keyStore">
<bean class="org.springframework.ws.soap.security.support.KeyStoreFactoryBean">
<property name="type" value="JCEKS"/>
<property name="password" value="123456"/>
</bean>
</property>
<property name="symmetricKeyPassword" value="mykeypass"/>
</bean>
</property>
</bean>
Encryption
Adding Encrypt
enables encryption of outgoing messages. You can set the certificate’s alias to use for the encryption by setting the securementEncryptionUser
property. The keystore where the certificate resides is accessed through the securementEncryptionCrypto
property. As encryption relies on public certificates, no password needs to be passed. The following example uses the securementEncryptionCrypto
property:
<property name="securementEncryptionUser" value="mycert"/>
<property name="securementEncryptionCrypto">
</bean>
</property>
</bean>
You can customize encryption in several ways: The key identifier type to use is defined by the securementEncryptionKeyIdentifier
property. Possible values are IssuerSerial
,X509KeyIdentifier
, DirectReference
,Thumbprint
, SKIKeyIdentifier
, and EmbeddedKeyName
If you choose the EmbeddedKeyName
type, you need to specify the secret key to use for the encryption. The alias of the key is set in the securementEncryptionUser
property, as for the other key identifier types. However, WSS4J requires a callback handler to fetch the secret key. Thus, you must provide securementCallbackHandler
with a KeyStoreCallbackHandler
that points to the appropriate keystore. By default, the ds:KeyName
element in the resulting WS-Security header takes the value of the securementEncryptionUser
property. To indicate a different name, you can set the securementEncryptionEmbeddedKeyName
with the desired value. In the next example, the outgoing message is encrypted with a key aliased secretKey
, whereas myKey
appears in ds:KeyName
element:
<property name="securementEncryptionKeyIdentifier" value="EmbeddedKeyName"/>
<property name="securementEncryptionUser" value="secretKey"/>
<property name="securementEncryptionEmbeddedKeyName" value="myKey"/>
<property name="securementCallbackHandler">
<property name="symmetricKeyPassword" value="keypass"/>
<property name="location" value="file:/keystore.jks"/>
<property name="type" value="jceks"/>
</bean>
</property>
</bean>
</property>
</bean>
The securementEncryptionKeyTransportAlgorithm
property defines which algorithm to use to encrypt the generated symmetric key. Supported values are http://www.w3.org/2001/04/xmlenc#rsa-1_5
, which is the default, and http://www.w3.org/2001/04/xmlenc#rsa-oaep-mgf1p
You can set the symmetric encryption algorithm to use by setting the securementEncryptionSymAlgorithm
property. Supported values are http://www.w3.org/2001/04/xmlenc#aes128-cbc
(default), http://www.w3.org/2001/04/xmlenc#tripledes-cbc
, http://www.w3.org/2001/04/xmlenc#aes256-cbc
, and http://www.w3.org/2001/04/xmlenc#aes192-cbc
Finally, the securementEncryptionParts
property defines which parts of the message are encrypted. The value of this property is a list of semicolon-separated element names that identify the elements to encrypt. An encryption mode specifier and a namespace identification, each inside a pair of curly brackets, may precede each element name. The encryption mode specifier is either {Content}
or {Element}
See the W3C XML Encryption specification about the differences between Element and Content encryption. The following example identifies the echoResponse
from the echo sample:
<property name="securementEncryptionParts"
value="{Content}{http://www.springframework.org/spring-ws/samples/echo}echoResponse"/>
Be aware that the element name, the namespace identifier, and the encryption modifier are case-sensitive. You can omit the encryption modifier and the namespace identifier. If you do, the encryption mode defaults to Content
, and the namespace is set to the SOAP namespace.
To specify an element without a namespace, use the value, Null
(case sensitive), as the namespace name. If no list is specified, the handler encrypts the SOAP Body in Content
mode by default.
7.2.7. Security Exception Handling
The exception handling of the Wss4jSecurityInterceptor
is identical to that of the XwsSecurityInterceptor
. See Security Exception Handling for more information.
