17. Flow Inheritance
Flow inheritance lets one flow inherit the configuration of another flow. Inheritance can occur at both the flow and state levels. A common use case is for a parent flow to define global transitions and exception handlers, and then each child flow can inherit those settings.
In order for a parent flow to be found, it must be added to the flow-registry, as any other flow.
17.1. Is Flow Inheritance Similar to Java Inheritance?
Flow inheritance is similar to Java inheritance in that elements defined in a parent are exposed through the child. However, there are key differences.
A child flow cannot override an element from a parent flow. Similar elements between the parent and child flows are merged. Unique elements in the parent flow are added to the child.
A child flow can inherit from multiple parent flows. Java inheritance is limited to a single class.
17.2. Types of Flow Inheritance
Spring Web Flow has two types of inheritance:
17.2.1. Flow-level Inheritance
Flow level inheritance is defined by the parent attribute on the flow element. The attribute contains a comma-separated list of flow identifiers from which to inherit. The child flow inherits from each parent in the order it is listed, adding elements and content to the resulting flow. The resulting flow from the first merge is considered the child in the second merge, and so on.
<flow parent="common-transitions, common-states">
17.3. State-level Inheritance
State-level inheritance is similar to flow-level inheritance, except only one state inherits from the parent, instead of the entire flow.
Unlike flow inheritance, only a single parent is allowed. Additionally, the identifier of the flow state to inherit from must also be defined. The identifiers for the flow and the state within that flow are separated by a # character.
The parent and child states must be of the same type. For instance, a view-state cannot inherit from an end-state, only another view-state.
<view-state id="child-state" parent="parent-flow#parent-view-state">
The intent for flow-level inheritance is to define common states to be added to and shared among multiple flow definitions, while the intent for state-level inheritance is to extend from and merge with a single parent state. Flow-level inheritance is a good fit for composition and multiple inheritance, but, at the state level you can still only inherit from a single parent state.
17.4. Abstract Flows
Often, parent flows are not designed to be run directly. In order to protect these flows from running, they can be marked as abstract. If an abstract flow attempts to run, a FlowBuilderException is thrown.
<flow abstract="true">
17.5. Inheritance Algorithm
When a child flow inherits from its parent, the parent and child are merged together to create a new flow. There are rules for every element in the Web Flow definition language that govern how that particular element is merged.
There are two types of elements:
  • Mergeable: Mergeable elements always attempt to merge together if the elements are similar.
  • Non-mergeable:Non-mergeable elements in a parent or child flow are always contained in the resulting flow intact. They are not modified as part of the merge process.
Paths to external resources in the parent flow should be absolute. Relative paths break when the two flows are merged unless the parent and child flow are in the same directory. Once merged, all relative paths in the parent flow become relative to the child flow.
17.5.1. Mergeable Elements
If the elements are of the same type and their keyed attribute is identical, the content of the parent element is merged with the child element. The merge algorithm continues to merge each sub-element of the merging parent and child. Otherwise, the parent element is added as a new element to the child.
In most cases, the added elements from a parent flow are added after elements in the child flow. Exceptions to this rule include action elements (evaluate, render, and set) that are added at the beginning. This allows for the results of parent actions to be used by child actions.
The mergeable elements are:
17.5.2. Non-mergeable Elements
The non-mergeable elements are:
APP信息
