13. Rendering Views
This chapter shows you how to use the view-state
element to render views within a flow.
13.1. Defining View States
The view-state
element defines a step of the flow that renders a view and waits for a user event to resume, as follows:
<view-state id="enterBookingDetails">
<transition on="submit" to="reviewBooking" />
</view-state>
By convention, a view-state
maps its ID to a view template in the directory where the flow is located.
For example, the state in the preceding example might render /WEB-INF/hotels/booking/enterBookingDetails.xhtml
if the flow itself was located in the /WEB-INF/hotels/booking
directory.
The following image shows a sample directory structure with views and other resources, such as message bundles co-located with their flow definition:
13.2. Specifying View Identifiers
You can use the view
attribute to explicitly specify the ID of the view to render.
13.2.1. Flow Relative View IDs
The view ID may be a relative path to view resource in the flow’s working directory, as follows:
<view-state id="enterBookingDetails" view="bookingDetails.xhtml">
13.2.2. Absolute View IDs
The view ID may be a absolute path to a view resource in the webapp root directory, as follows:
<view-state id="enterBookingDetails" view="/WEB-INF/hotels/booking/bookingDetails.xhtml">
13.2.3. Logical View IDs
With some view frameworks, such as Spring MVC’s view framework, the view ID may also be a logical identifier resolved by the framework, as follows:
<view-state id="enterBookingDetails" view="bookingDetails">
See the Spring MVC integration section for more information on how to integrate with the MVC ViewResolver
infrastructure.
13.3. View scope
A view-state
allocates a new viewScope
when it enters.
You can reference this scope within the view-state
to assign variables that should live for the duration of the state.
This scope is useful for manipulating objects over a series of requests from the same view — often Ajax requests.
A view-state
destroys its viewScope
when it exits.
13.3.1. Allocating View Variables
You can use the var
tag to declare a view variable.
As with a flow variable, any @Autowired
references are automatically restored when the view state resumes.
The following listing declares a view variable:
<var name="searchCriteria" class="com.mycompany.myapp.hotels.SearchCriteria" />
13.3.2. Assigning a viewScope
Variable
You can use the on-render
tag to assign a variable from an action result before the view renders, as follows:
<on-render>
<evaluate expression="bookingService.findHotels(searchCriteria)" result="viewScope.hotels" />
</on-render>
13.3.3. Manipulating Objects in View Scope
Objects in view scope are often manipulated over a series of requests from the same view. The list is updated in view scope before each rendering. Asynchronous event handlers modify the current data page and then request re-rendering of the search results fragment. The following example pages through a search results list:
<view-state id="searchResults">
<on-render>
</on-render>
<transition on="next">
<evaluate expression="searchCriteria.nextPage()" />
<render fragments="searchResultsFragment" />
</transition>
<transition on="previous">
<evaluate expression="searchCriteria.previousPage()" />
</transition>
</view-state>
13.4. Running Render Actions
The on-render
element runs one or more actions before view rendering.
Render actions are run on the initial render as well as on any subsequent refreshes, including any partial re-renderings of the view.
The following listing defines an on-render
element:
<on-render>
</on-render>
13.5. Binding to a Model
You can use the model
attribute to declare a model to which object the view binds.
This attribute is typically used in conjunction with views that render data controls, such as forms.
It lets form data binding and validation behaviors to be driven from metadata on your model object.
The following example declares an enterBookingDetails
state that manipulates the booking
model:
<view-state id="enterBookingDetails" model="booking">
The model may be an object in any accessible scope, such as flowScope
or viewScope
Specifying a model
triggers the following behavior when a view event occurs:
View-to-model binding. On view postback, user input values are bound to model object properties for you.
Model validation. After binding, if the model object requires validation, that validation logic is invoked.
For a flow event that can drive a view state transition to be generated, model binding must successfully complete. If model binding fails, the view is re-rendered to let the user revise their edits.
13.6. Performing Type Conversion
When request parameters are used to populate the model (commonly referred to as data binding), type conversion is required to parse string-based request parameter values before setting target model properties. Default type conversion is available for many common Java types such as numbers, primitives, enums, and Dates. Users can also register their own type conversion logic for user-defined types and to override the default converters.
13.6.1. Type Conversion Options
Starting with version 2.1, Spring Web Flow uses the type conversion and formatting system for nearly all type conversion needs.
Previously, Web Flow applications used a type conversion mechanism that was different from the one in Spring MVC, which relied on the java.beans.PropertyEditor
abstraction.
Spring’s type conversion was actually influenced by Web Flow’s own type conversion system.
Hence, Web Flow users should find it natural to work with Spring type conversion.
Another obvious and important benefit of this change is that you can now use a single type conversion mechanism across Spring MVC And Spring Web Flow.
13.6.2. Upgrading to Spring 3 Type Conversion And Formatting
What does this mean, in practical terms, for existing applications? Existing applications are likely registering their own converters of type org.springframework.binding.convert.converters.Converter
through a sub-class of DefaultConversionService
available in Spring Binding.
Those converters can continue to be registered as before.
They have been adapted as the Spring GenericConverter
types and registered with a Spring org.springframework.core.convert.ConversionService
instance.
In other words, existing converters are invoked through Spring’s type conversion service.
The only exception to this rule are named converters, which you can reference from a binding
element in a view-state
, as follows:
public class ApplicationConversionService extends DefaultConversionService {
public ApplicationConversionService() {
addDefaultConverters();
addDefaultAliases();
addConverter("customConverter", new CustomConverter());
<binder>
<binding property="checkinDate" required="true" converter="customConverter" />
</binder>
</view-state>
Named converters are not supported and cannot be used with the type conversion service available in Spring. Therefore, such converters are not adapted and continue to work as before. That is, they do not involve the Spring type conversion. However, this mechanism is deprecated, and applications are encouraged to favor Spring type conversion and formatting features.
Also note that the existing Spring Binding DefaultConversionService
no longer registers any default converters.
Instead, Web Flow now relies on the default type converters and formatters in Spring.
In summary, Spring type conversion and formatting is now used almost exclusively in Web Flow. Although existing applications should work without any changes, we encourage moving towards unifying the type conversion needs of Spring MVC and Spring Web Flow parts of applications.
13.6.3. Configuring Type Conversion and Formatting
In Spring MVC, an instance of a FormattingConversionService
is created automatically through the custom MVC namespace, as follows:
xmlns:mvc="http://www.springframework.org/schema/mvc"
xsi:schemaLocation="
https://www.springframework.org/schema/mvc/spring-mvc.xsd
https://www.springframework.org/schema/beans/spring-beans.xsd">
<mvc:annotation-driven/>
Internally, that is done with the help of FormattingConversionServiceFactoryBean
, which registers a default set of converters and formatters.
You can customize the conversion service instance used in Spring MVC through the conversion-service
attribute, as follows:
<mvc:annotation-driven conversion-service="applicationConversionService" />
In Web Flow, an instance of a Spring Binding DefaultConversionService
, which does not register any converters, is automatically created.
Instead, it delegates to a FormattingConversionService
instance for all type conversion needs.
By default, this is not the same FormattingConversionService
instance as the one used in Spring.
However, that does not make a practical difference until you start registering your own formatters.
You can customize the DefaultConversionService
used in Web Flow through the flow-builder-services element, as follows:
<webflow:flow-builder-services id="flowBuilderServices" conversion-service="defaultConversionService" />
You can do the following to register your own formatters for use in both Spring MVC and in Spring Web Flow :
Create a class to register your custom formatters:
public class ApplicationConversionServiceFactoryBean extends FormattingConversionServiceFactoryBean { @Override protected void installFormatters(FormatterRegistry registry) { // ... } }
Configure the class for use in Spring MVC:
<?xml version="1.0" encoding="UTF-8"?> <beans xmlns="http://www.springframework.org/schema/beans" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:mvc="http://www.springframework.org/schema/mvc" xsi:schemaLocation=" http://www.springframework.org/schema/mvc https://www.springframework.org/schema/mvc/spring-mvc.xsd http://www.springframework.org/schema/beans https://www.springframework.org/schema/beans/spring-beans.xsd"> <mvc:annotation-driven conversion-service="applicationConversionService" /> <!-- Alternatively if you prefer annotations for DI: 1. Add @Component to the factory bean. 2. Add a component-scan element (from the context custom namespace) here. 3. Remove XML bean declaration below. --> <bean id="applicationConversionService" class="somepackage.ApplicationConversionServiceFactoryBean">
Connect the Web Flow
to the sameapplicationConversionService
bean used in Spring MVC:<webflow:flow-registry id="flowRegistry" flow-builder-services="flowBuilderServices" ... /> <webflow:flow-builder-services id="flowBuilderServices" conversion-service="defaultConversionService" ... /> <bean id="defaultConversionService" class="org.springframework.binding.convert.service.DefaultConversionService"> <constructor-arg ref="applicationConversionSevice"/> </bean>
You can also mix and match.
You can register new Spring Formatter
types through the applicationConversionService
You can register existing Spring Binding Converter
types through the defaultConversionService
13.6.4. Working With Spring Type Conversion And Formatting
`` An important concept to understand is the difference between type converters and formatters.
Type converters in Spring, provided in org.springframework.core
, are for general-purpose type conversion between any two object types.
In addition to the most simple Converter
type, two other interfaces are ConverterFactory
and GenericConverter
Formatters in Spring, provided in org.springframework.context
, have the more specialized purpose of representing Object
instances as String
instances.
The Formatter
interface extends the Printer
and Parser
interfaces for converting an Object
to a String
and turning a String
into an Object
Web developers may find the Formatter
interface to be most relevant, because it fits the needs of web applications for type conversion.
Object-to-Object conversion is a generalization of the more specific Object-to-String conversion.
In fact, Formatters are registered as GenericConverter types with Spring’s GenericConversionService , making them equal to any other converter.
13.6.5. Formatting Annotations
One of the best features of the type conversion is the ability to use annotations for better control over formatting in a concise manner.
You can place annotations on model attributes and on the arguments of @Controller
methods that are mapped to requests.
Spring provides two annotations (@NumberFormat
and @DateTimeFormat
), but you can create your own and have them be registered, along with the associated formatting logic.
13.6.6. Working With Dates
The @DateTimeFormat
annotation implies use of Joda Time.
If that is present on the classpath, the use of this annotation is enabled automatically.
By default, neither Spring MVC nor Web Flow register any other date formatters or converters.
Therefore, it is important for applications to register a custom formatter to specify the default way for printing and parsing dates.
The @DateTimeFormat
annotation, on the other hand, provides more fine-grained control where it is necessary to deviate from the default.
For more information on working with Spring type conversion and formatting, see the relevant sections of the Spring documentation.
13.7. Suppressing Binding
You can use the bind
attribute to suppress model binding and validation for particular view events.
The following example suppresses binding when the cancel
event occurs:
<transition on="proceed" to="reviewBooking">
<transition on="cancel" to="bookingCancelled" bind="false" />
</view-state>
13.8. Specifying Bindings Explicitly
You can use the binder
element to configure the exact set of model properties to which to apply data binding.
This lets you restrict the set of “allowed fields” per view.
Not using this could lead to a security issue, depending on the application domain and actual users, since, by default, if the binder element is not specified, all public properties of the model are eligible for data binding by the view.
By contrast, when the binder
element is specified, only the explicitly configured bindings are allowed.
The following example uses a binder
element:
<binder>
<binding property="creditCard" />
<binding property="creditCardName" />
<binding property="creditCardExpiryMonth" />
<binding property="creditCardExpiryYear" />
</binder>
<transition on="proceed" to="reviewBooking" />
<transition on="cancel" to="cancel" bind="false" />
</view-state>
Each binding may also apply a converter to format the model property value for display in a custom manner.
If no converter is specified, the default converter for the model property’s type is used.
The following example shows two binding
elements with converter
attributes:
<binder>
<binding property="checkinDate" converter="shortDate" />
<binding property="checkoutDate" converter="shortDate" />
</binder>
</view-state>
In the preceding example, the shortDate
converter is bound to the checkinDate
and checkoutDate
properties.
You can register custom converters with the application’s ConversionService
Each binding may also apply a required check to generate a validation error if the user-provided value is null on form postback, as follows:
<binder>
<binding property="checkinDate" converter="shortDate" required="true" />
<binding property="checkoutDate" converter="shortDate" required="true" />
<binding property="creditCard" required="true" />
<binding property="creditCardName" required="true" />
<binding property="creditCardExpiryMonth" required="true" />
<binding property="creditCardExpiryYear" required="true" />
</binder>
</view-state>
In the preceding example, all of the bindings are required. If one or more blank input values are bound, validation errors are generated and the view re-renders with those errors.
13.9. Validating a Model
Model validation is driven by constraints specified against a model object. Web Flow supports enforcing such constraints programmatically as well as declaratively with JSR-303 Bean Validation annotations.
13.9.1. JSR-303 Bean Validation
Web Flow provides built-in support for the JSR-303 Bean Validation API, building on the equivalent support available in Spring MVC.
To enable JSR-303 validation, configure the flow-builder-services with Spring MVC’s LocalValidatorFactoryBean
, as follows:
<webflow:flow-registry flow-builder-services="flowBuilderServices" />
<webflow:flow-builder-services id="flowBuilderServices" validator="validator" />
<bean id="validator" class="org.springframework.validation.beanvalidation.LocalValidatorFactoryBean" />
With the preceding example in place, the configured validator is applied to all model attributes after data binding.
Note that JSR-303 bean validation and validation by convention (explained in the next section) are not mutually exclusive. In other words, Web Flow applies all available validation mechanisms.
Partial Validation
JSR-303 Bean Validation supports partial validation through validation groups. The following example defines partial validation:
@NotNull
@Size(min = 2, max = 30, groups = State1.class)
private String name;
In a flow definition, you can specify validation hints on a view state or on a transition, and those are resolved to validation groups. The following example defines validation hints:
<view-state id="state1" model="myModel" validation-hints="'group1,group2'">
The validation-hints
attribute is an expression that, in the preceding example, resolves to a comma-delimited String
consisting of two hints: group1
and group2
. A ValidationHintResolver
is used to resolve these hints.
The BeanValidationHintResolver
used by default tries to resolve these strings to class-based bean validation groups.
To do that, it looks for matching inner types in the model or its parent.
For example, given org.example.MyModel
with inner types Group1
and Group2
, it is sufficient to supply the simple type names — that is, group1
and group2
You can also provide fully qualified type names.
A hint with a value of default
has a special meaning and is translated to the default validation group in Bean Validation: jakarta.validation.groups.Default
You can configure a custom ValidationHintResolver
, if necessary, through the validationHintResolver
property of the flow-builder-services
<webflow:flow-builder-services id="flowBuilderServices" validator=".." validation-hint-resolver=".." />
13.9.2. Programmatic Validation
There are two ways to perform model validation programatically.
The first is to implement validation logic in your model object.
The second is to implement an external Validator
Both ways provide you with a ValidationContext
to record error messages and access information about the current user.
Implementing a Model Validate Method
Defining validation logic in your model object is the simplest way to validate its state.
Once such logic is structured according to Web Flow conventions, Web Flow automatically invokes that logic during the view-state
postback lifecycle.
Web Flow conventions have you structure model validation logic by view-state
, letting you validate the subset of model properties that are editable on that view.
To do this, create a public method with a name of validate${state}
, where ${state}
is the ID of your view-state
for which you want validation to run.
The following example performs model validation:
public class Booking {
private Date checkinDate;
private Date checkoutDate;
public void validateEnterBookingDetails(ValidationContext context) {
MessageContext messages = context.getMessageContext();
if (checkinDate.before(today())) {
messages.addMessage(new MessageBuilder().error().source("checkinDate").
defaultText("Check in date must be a future date").build());
} else if (!checkinDate.before(checkoutDate)) {
messages.addMessage(new MessageBuilder().error().source("checkoutDate").
defaultText("Check out date must be later than check in date").build());
In the preceding example, when a transition is triggered in a enterBookingDetails
view-state
that is editing a Booking
model, Web Flow automatically invokes the validateEnterBookingDetails(ValidationContext)
method, unless validation has been suppressed for that transition.
The following example shows such a view-state
</view-state>
You can define any number of validation methods.
Generally, a flow edits a model over a series of views.
In that case, you would define a validate method for each view-state
for which validation needs to run.
Implementing a Validator
The second way to perform programmatic validation is to define a separate object, called a validator, which validates your model object.
To do this, first create a class whose name has the pattern ${model}Validator
, where ${model}
is the capitalized form of the model expression, such as Booking
Then define a public method with a name of validate${state}
, where ${state}
, such as enterBookingDetails
The class should then be deployed as a Spring bean.
Any number of validation methods can be defined.
The following example defines such a validator:
@Component
public class BookingValidator {
public void validateEnterBookingDetails(Booking booking, ValidationContext context) {
if (booking.getCheckinDate().before(today())) {
} else if (!booking.getCheckinDate().before(booking.getCheckoutDate())) {
view-state
model, Web Flow automatically invokes the validateEnterBookingDetails(Booking, ValidationContext)
A validator can also accept a Spring MVC Errors
object, which is required for invoking existing Spring validators.
Validators must be registered as Spring beans, employing the ${model}Validator
naming convention, to be automatically detected and invoked.
In the preceding example, Spring classpath scanning would detect the @Component
and automatically register it as a bean with a name of bookingValidator
Then, any time the booking
model needs to be validated, this bookingValidator
instance would be invoked for you.
Default Validate Method
A validator class can also define a method called validate
that is not associated (by convention) with any specific view-state
The following example defines such a method:
@Component
public void validate(Booking booking, ValidationContext context) {
In the preceding code sample, the validate
method is called every time a model of type Booking
is validated (unless validation has been suppressed for that transition). If needed, the default method can also be called in addition to an existing state-specific method.
Consider the following example:
@Component
In the preceding code sample, the validateEnterBookingDetails
method is called first.
The default validate
method is called next.
13.9.3. The ValidationContext
Interface
A ValidationContext
lets you obtain a MessageContext
to record messages during validation.
It also exposes information about the current user, such as the signaled userEvent
and the current user’s Principal
identity.
You can use this information to customize validation logic based on what button or link was activated in the UI or who is authenticated.
See the API Javadoc for ValidationContext
for more information.
13.10. Suppressing Validation
You can use the validate
attribute to suppress model validation for particular view events, as follows:
<view-state id="chooseAmenities" model="booking">
<transition on="back" to="enterBookingDetails" validate="false" />
</view-state>
In the preceding example, data binding still occurs on back
, but validation is suppressed.
13.11. Defining View Transitions
You can define one or more transition
elements to handle user events that may occur on the view.
A transition may take the user to another view, or it may run an action and re-render the current view.
A transition may also request the rendering of parts of a view (called “fragments”) when handling an Ajax event.
Finally, you can also define “global” transitions that are shared across all views.
The following sections discuss how to implement view transitions.
13.11.1. Transition Actions
A view-state
transition can invoke one or more actions before running.
These actions may return an error result to prevent the transition from exiting the current view-state
If an error result occurs, the view re-renders and should display an appropriate message to the user.
If the transition action invokes a plain Java method, the invoked method may return a boolean, whose value (true
or false
) indicates whether the transition should take place or be prevented from running.
A method can also return a String
where literal values of success
, yes
, or true
indicate the transition should occur, and any other value means the opposite.
You can use this technique to handle exceptions thrown by service-layer methods.
The following example invokes an action that calls a service and handles an exceptional situation:
<transition on="submit" to="bookingConfirmed">
<evaluate expression="bookingAction.makeBooking(booking, messageContext)" />
</transition>
public class BookingAction {
public boolean makeBooking(Booking booking, MessageContext context) {
try {
bookingService.make(booking);
return true;
} catch (RoomNotAvailableException e) {
context.addMessage(new MessageBuilder().error().
.defaultText("No room is available at this hotel").build());
return false;
When there is more than one action defined on a transition, if one returns an error result, the remaining actions in the set are not executed. If you need to ensure one transition action’s result cannot impact the execution of another, define a single transition action that invokes a method that encapsulates all the action logic.
13.11.2. Global Transitions
You can use the flow’s global-transitions
element to create transitions that apply across all views.
Global transitions are often used to handle global menu links that are part of the layout.
The following example defines a global-transition
element:
<global-transitions>
<transition on="login" to="login" />
<transition on="logout" to="logout" />
</global-transitions>
13.11.3. Event Handlers
From a view-state
, you can also define transitions without targets.
Such transitions are called “event handlers”.
The following example defines such a transition:
<transition on="event">
<!-- Handle event -->
</transition>
These event handlers do not change the state of the flow. They execute their actions and re-render the current view or one or more fragments of the current view.
13.11.4. Rendering Fragments
You can use the render
element within a transition to request partial re-rendering of the current view after handling the event, as follows:
</transition>
The fragments
attribute should reference the IDs of the view elements you wish to re-render.
You can specify multiple elements to re-render by separating them with a comma delimiter.
Such partial rendering is often used with events signaled by Ajax to update a specific zone of the view.
13.12. Working with Messages
Spring Web Flow’s MessageContext
is an API for recording messages during the course of flow executions.
You can add plain text messages to the context, as well as internationalized messages resolved by a Spring MessageSource
Messages are renderable by views and automatically survive flow execution redirects.
Three distinct message severities are provided: info
, warning
, and error
In addition, a convenient MessageBuilder
exists for fluently constructing messages.
13.12.1. Adding Plain Text Messages
You can add plain text messages to the context. The following example shows how to do so:
MessageContext context = ...
MessageBuilder builder = new MessageBuilder();
context.addMessage(builder.error().source("checkinDate")
.defaultText("Check in date must be a future date").build());
context.addMessage(builder.warn().source("smoking")
.defaultText("Smoking is bad for your health").build());
context.addMessage(builder.info()
.defaultText("We have processed your reservation - thank you and enjoy your stay").build());
13.12.2. Adding Internationalized Messages
You can add internationalized (that is, localized) messages to the context. The following example shows how to do so:
context.addMessage(builder.error().source("checkinDate").code("checkinDate.notFuture").build());
context.addMessage(builder.warn().source("smoking").code("notHealthy")
.resolvableArg("smoking").build());
context.addMessage(builder.info().code("reservationConfirmation").build());
13.12.3. Using Message Bundles
Internationalized messages are defined in message bundles accessed by a Spring MessageSource
To create a flow-specific message bundle, define messages.properties
files in your flow’s directory.
Create a default messages.properties
file and a .properties
file for each additional Locale
you need to support.
The following example defines a few messages:
#messages.properties
checkinDate=Check in date must be a future date
notHealthy={0} is bad for your health
reservationConfirmation=We have processed your reservation - thank you and enjoy your stay
From within a view or a flow, you may also access message resources by using the resourceBundle
EL variable, as follows:
<h:outputText value="#{resourceBundle.reservationConfirmation}" />
13.12.4. Understanding System-generated Messages
There are several places where Web Flow itself generates messages to display to the user. One important place this occurs is during view-to-model data binding. When a binding error (such as a type conversion error) occurs, Web Flow maps that error to a message that is automatically retrieved from your resource bundle. To look up the message to display, Web Flow tries resource keys that contain the binding error code and the target property name.
As an example, consider a binding to the checkinDate
property of a Booking
object.
Suppose the user typed in an alphabetic string.
In this case, a type conversion error is raised.
Web Flow maps the typeMismatch
error code to a message by first querying your resource bundle for a message with the following key:
booking.checkinDate.typeMismatch
The first part of the key is the model class’s short name. The second part of the key is the property name. The third part is the error code. This allows for the lookup of a unique message to display to the user when a binding fails on a model property. Such a message might say:
booking.checkinDate.typeMismatch=The check in date must be in the format yyyy-mm-dd.
If no such resource key of that form can be found, a more generic key is tried. This key is the error code. The field name of the property is provided as a message argument, as follows:
typeMismatch=The {0} field is of the wrong type.
13.13. Displaying Popups
You can use the popup
attribute to render a view in a modal popup dialog, as follows:
<view-state id="changeSearchCriteria" view="enterSearchCriteria.xhtml" popup="true">
When using Web Flow with the Spring Javascript library, no client-side code is necessary for the popup to display. Web Flow sends a response to the client to request a redirect to the view from a popup, and the client honors the request.
13.14. View Backtracking
By default, when you exit a view state and transition to a new view state, you can go back to the previous state by using the browser back button.
These view state history policies are configurable on a per-transition basis by using the history
attribute.
