Getting Started
Spring Vault support requires Vault 0.6 or higher and Java SE 6 or higher. An easy way to bootstrap setting up a working environment is to create a Spring based project in STS.
First you need to set up a running Vault server. Refer to the Vault for an explanation on how to startup a Vault instance.
To create a Spring project in STS go to File → New →
Spring Template Project → Simple Spring Utility Project →
press Yes when prompted.
Then enter a project and a package name such as org.spring.vault.example
Then add the following to pom.xml
dependencies section.
<dependencies>
<!-- other dependency elements omitted -->
<dependency>
<groupId>org.springframework.vault</groupId>
<artifactId>spring-vault-core</artifactId>
<version>3.2.0</version>
</dependency>
</dependencies>
If you are using a milestone or release candidate, you will also need to add the location of the Spring Milestone repository to your maven pom.xml
which is at the same level of your <dependencies/>
element.
<repositories>
<repository>
<id>spring-milestone</id>
<name>Spring Maven MILESTONE Repository</name>
<url>https://repo.spring.io/milestone</url>
</repository>
</repositories>
The repository is also browseable here.
If you are using a SNAPSHOT, you will also need to add the location of the Spring Snapshot repository to your maven pom.xml
element.
<repositories>
<repository>
<id>spring-snapshot</id>
<name>Spring Maven SNAPSHOT Repository</name>
<url>https://repo.spring.io/snapshot</url>
</repository>
</repositories>
Create a simple Secrets
class to persist:
package org.spring.vault.example;
public class Secrets {
String username;
String password;
public String getUsername() {
return username;
public String getPassword() {
return password;
And a main application to run
package org.springframework.vault.example;
import org.springframework.vault.authentication.TokenAuthentication;
import org.springframework.vault.client.VaultEndpoint;
import org.springframework.vault.core.VaultTemplate;
import org.springframework.vault.support.VaultResponseSupport;
public class VaultApp {
VaultTemplate vaultTemplate = new VaultTemplate(new VaultEndpoint(),
new TokenAuthentication("00000000-0000-0000-0000-000000000000"));
Secrets secrets = new Secrets();
secrets.username = "hello";
secrets.password = "world";
vaultTemplate.write("secret/myapp", secrets);
VaultResponseSupport<Secrets> response = vaultTemplate.read("secret/myapp", Secrets.class);
System.out.println(response.getData().getUsername());
vaultTemplate.delete("secret/myapp");
Even in this simple example, there are few things to take notice of
You can instantiate the central class of Spring Vault,
VaultTemplate
, using theorg.springframework.vault.client.VaultEndpoint
object and theClientAuthentication
. You are not required to spin up a Spring Context to use Spring Vault. -
Vault is expected to be configured with a root token of
to run this application. -
The mapper works against standard POJO objects without the need for any additional metadata (though you can optionally provide that information).
Mapping conventions can use field access. Notice the
Secrets
class has only getters. -
If the constructor argument names match the field names of the stored document, they will be used to instantiate the object.
