Using Spring Statemachine
This part of the reference documentation explains the core functionality that Spring Statemachine provides to any Spring based application.
It includes the following topics:
Statemachine Configuration describes the generic configuration support.
State Machine ID describes the use of machine id.
State Machine Factories describes the generic state machine factory support.
Using Deferred Events describes the deferred event support.
Using Scopes describes the scope support.
Using Actions describes the actions support.
Using Guards describes the guard support.
Using Extended State describes the extended state support.
Using
StateContext
describes the state context support. -
Triggering Transitions describes the use of triggers.
Listening to State Machine Events describes the use of state machine listeners.
Context Integration describes the generic Spring application context support.
Using
StateMachineAccessor
describes the state machine internal accessor support. -
Using
StateMachineInterceptor
describes the state machine error handling support. -
State Machine Security describes the state machine security support.
State Machine Error Handling describes the state machine interceptor support.
State Machine Services describes the state machine service support.
Persisting a State Machine describes the state machine persisting support.
Spring Boot Support describes the Spring Boot support.
Monitoring a State Machine describes the monitoring and tracing support.
Using Distributed States describes the distributed state machine support.
Testing Support describes the state machine testing support.
Eclipse Modeling Support describes the state machine UML modeling support.
Repository Support describes the state machine repository config support.
12. Statemachine Configuration
One of the common tasks when using a state machine is to design its runtime configuration. This chapter focuses on how Spring Statemachine is configured and how it leverages Spring’s lightweight IoC containers to simplify the application internals to make it more manageable.
Configuration examples in this section are not feature complete. That is, you always need to have definitions of both states and transitions. Otherwise, state machine configuration would be ill-formed. We have simply made code snippets less verbose by leaving other needed parts out. |
12.1. Using enable
Annotations
We use two familiar Spring enabler annotations to ease configuration:
@EnableStateMachine
and @EnableStateMachineFactory
These annotations, when placed in a @Configuration
class, enable
some basic functionality needed by a state machine.
You can use @EnableStateMachine
when you need a configuration to create an
instance of StateMachine
. Usually, a @Configuration
class extends adapters
(EnumStateMachineConfigurerAdapter
or StateMachineConfigurerAdapter
), which
lets you override configuration callback methods. We automatically
detect whether you use these adapter classes and modify the runtime configuration
logic accordingly.
You can use @EnableStateMachineFactory
instance of a StateMachineFactory
Usage examples of these are shown in below sections. |
12.2. Configuring States
We get into more complex configuration examples a bit later in this guide, but
we first start with something simple. For most simple state
machine, you can use EnumStateMachineConfigurerAdapter
and define
possible states and choose the initial and optional end states.
@EnableStateMachine
public class Config1Enums
extends EnumStateMachineConfigurerAdapter<States, Events> {
public void configure(StateMachineStateConfigurer<States, Events> states)
throws Exception {
states
.withStates()
.initial(States.S1)
.end(States.SF)
.states(EnumSet.allOf(States.class));
You can also use strings instead of enumerations as states and
events by using StateMachineConfigurerAdapter
, as shown in the next example. Most
of the configuration examples ues enumerations, but, generally speaking,
you can interchange strings and enumerations.
@EnableStateMachine
public class Config1Strings
extends StateMachineConfigurerAdapter<String, String> {
public void configure(StateMachineStateConfigurer<String, String> states)
throws Exception {
states
.withStates()
.initial("S1")
.end("SF")
.states(new HashSet<String>(Arrays.asList("S1","S2","S3","S4")));
Using enumerations brings a safer set of states and event types but limits possible combinations to compile time. Strings do not have this limitation and let you use more dynamic ways to build state machine configurations but do not allow same level of safety. |
12.3. Configuring Hierarchical States
You can define hierarchical states can by using multiple withStates()
calls, where you can use parent()
to indicate that these
particular states are sub-states of some other state.
The following example shows how to do so:
@EnableStateMachine
public class Config2
throws Exception {
states
.withStates()
.initial(States.S1)
.state(States.S1)
.and()
.withStates()
.parent(States.S1)
.initial(States.S2)
.state(States.S2);
12.4. Configuring Regions
There are no special configuration methods to mark a collection of states to be part of an orthogonal state. To put it simply, orthogonal state is created when the same hierarchical state machine has multiple sets of states, each of which has an initial state. Because an individual state machine can only have one initial state, multiple initial states must mean that a specific state must have multiple independent regions. The following example shows how to define regions:
@EnableStateMachine
public class Config10
extends EnumStateMachineConfigurerAdapter<States2, Events> {
public void configure(StateMachineStateConfigurer<States2, Events> states)
throws Exception {
states
.withStates()
.initial(States2.S1)
.state(States2.S2)
.and()
.withStates()
.parent(States2.S2)
.initial(States2.S2I)
.state(States2.S21)
.end(States2.S2F)
.and()
.withStates()
.parent(States2.S2)
.initial(States2.S3I)
.state(States2.S31)
.end(States2.S3F);
When persisting machines with regions or generally
relying on any functionalities to reset a machine, you may need
to have a dedicated ID for a region. By default, this ID
is a generated UUID. As the following example shows, StateConfigurer
has
a method called region(String id)
that lets you set the ID for a region:
@EnableStateMachine
public class Config10RegionId
throws Exception {
states
.withStates()
.state(States2.S2)
.and()
.withStates()
.parent(States2.S2)
.region("R1")
.state(States2.S21)
.end(States2.S2F)
.and()
.withStates()
.parent(States2.S2)
.region("R2")
.state(States2.S31)
.end(States2.S3F);
12.5. Configuring Transitions
We support three different types of transitions: external
internal
, and local
. Transitions are triggered either by a signal
(which is an event sent into a state machine) or by a timer.
The following example shows how to define all three kinds of transitions:
@EnableStateMachine
public class Config3
throws Exception {
states
.withStates()
.initial(States.S1)
public void configure(StateMachineTransitionConfigurer<States, Events> transitions)
throws Exception {
transitions
.withExternal()
.source(States.S1).target(States.S2)
.event(Events.E1)
.and()
.withInternal()
.source(States.S2)
.event(Events.E2)
.and()
.withLocal()
.source(States.S2).target(States.S3)
.event(Events.E3);
12.6. Configuring Guards
You can use guards to protect state transitions. You can use the Guard
interface
to do an evaluation where a method has access to a StateContext
@EnableStateMachine
public class Config4
throws Exception {
transitions
.withExternal()
.event(Events.E1)
.guard(guard())
.and()
.withExternal()
.event(Events.E2)
.guardExpression("true");
public Guard<States, Events> guard() {
return new Guard<States, Events>() {
public boolean evaluate(StateContext<States, Events> context) {
return true;
In the preceding example, we used two different types of guard configurations. First, we
created a simple Guard
as a bean and attached it to the transition between
states S1
and S2
Second, we used a SPeL expression as a guard to dicate that the
expression must return a BOOLEAN
value. Behind the scenes, this
expression-based guard is a SpelExpressionGuard
. We attached it to
the transition between states S2
and S3
. Both guards
always evaluate to true
12.7. Configuring Actions
You can define actions to be executed with transitions and states. An action is always run as a result of a transition that originates from a trigger. The following example shows how to define an action:
@EnableStateMachine
public class Config51
throws Exception {
transitions
.withExternal()
.source(States.S1)
.target(States.S2)
.event(Events.E1)
.action(action());
public Action<States, Events> action() {
return new Action<States, Events>() {
public void execute(StateContext<States, Events> context) {
// do something
In the preceding example, a single Action
is defined as a bean named action
and associated
with a transition from S1
to S2
The following example shows how to use an action multiple times:
@EnableStateMachine
public class Config52
throws Exception {
states
.withStates()
.initial(States.S1, action())
.state(States.S1, action(), null)
.state(States.S2, null, action())
.state(States.S2, action())
.state(States.S3, action(), action());
// do something
Usually, you would not define the same Action instance for different
stages, but we did it here to not make too much noise in a code
snippet.
is defined by the bean named action
and associated
with states S1
, S2
, and S3
. We need to clarify what is going on here:
We defined an action for the initial state,
S1
We defined an entry action for state
S1
and left the exit action empty. -
We defined an exit action for state
S2
and left the entry action empty. -
We defined a single state action for state
S2
We defined both entry and exit actions for state
S3
Note that state
S1
is used twice withinitial()
andstate()
functions. You need to do this only if you want to define entry or exit actions with initial state.
Defining action with initial() function only runs a particular
action when a state machine or sub state is started. This action
is an initializing action that is run only once. An action defined
with state() is then run if the state machine transitions back
and forward between initial and non-initial states.
12.7.1. State Actions
State actions are run differently compared to entry and exit actions, because execution happens after state has been entered and can be cancelled if state exit happens before a particular action has been completed.
State actions are executed using normal reactive flow by subscribing with
a Reactor’s default parallel scheduler. This means that, whatever you do in your
action, you need to be able to catch InterruptedException
or, more generally,
periodically check whether Thread
is interrupted.
The following example shows typical configuration that uses default the IMMEDIATE_CANCEL
, which
would immediately cancel a running task when its state is complete:
@EnableStateMachine
static class Config1 extends StateMachineConfigurerAdapter<String, String> {
public void configure(StateMachineConfigurationConfigurer<String, String> config) throws Exception {
config
.withConfiguration()
.stateDoActionPolicy(StateDoActionPolicy.IMMEDIATE_CANCEL);
public void configure(StateMachineStateConfigurer<String, String> states) throws Exception {
states
.withStates()
.initial("S1")
.state("S2", context -> {})
.state("S3");
public void configure(StateMachineTransitionConfigurer<String, String> transitions) throws Exception {
transitions
.withExternal()
.source("S1")
.target("S2")
.event("E1")
.and()
.withExternal()
.source("S2")
.target("S3")
.event("E2");
You can set a policy to TIMEOUT_CANCEL
together with a global timeout
for each machine. This changes state behavior to await action completion
before cancelation is requested. The following example shows how to do so:
config
.stateDoActionPolicy(StateDoActionPolicy.TIMEOUT_CANCEL)
.stateDoActionPolicyTimeout(10, TimeUnit.SECONDS);
If Event
directly takes a machine into a state so that event headers
are available to a particular action, you can also use a dedicated
event header to set a specific timeout (defined in millis
You can use the reserved header value StateMachineMessageHeaders.HEADER_DO_ACTION_TIMEOUT
for this purpose. The following example shows how to do so:
@Autowired
StateMachine<String, String> stateMachine;
void sendEventUsingTimeout() {
stateMachine
.sendEvent(Mono.just(MessageBuilder
.withPayload("E1")
.setHeader(StateMachineMessageHeaders.HEADER_DO_ACTION_TIMEOUT, 5000)
.build()))
.subscribe();
12.7.2. Transition Action Error Handling
You can always catch exceptions manually. However, with actions defined for
transitions, you can define an error action that is called if an
exception is raised. The exception is then available from a StateContext
passed to that action. The following example shows how to create a state
that handles an exception:
@EnableStateMachine
public class Config53
throws Exception {
transitions
.withExternal()
.source(States.S1)
.target(States.S2)
.event(Events.E1)
.action(action(), errorAction());
throw new RuntimeException("MyError");
public Action<States, Events> errorAction() {
// RuntimeException("MyError") added to context
Exception exception = context.getException();
exception.getMessage();
If need be, you can manually create similar logic for every action. The following example shows how to do so:
throws Exception {
transitions
.withExternal()
.source(States.S1)
.target(States.S2)
.event(Events.E1)
.action(Actions.errorCallingAction(action(), errorAction()));
12.7.3. State Action Error Handling
Logic similar to the logic that handles errors in state transitions is also available for entry to a state and exit from a state.
For these situations, StateConfigurer
has methods called stateEntry
, stateDo
, and
stateExit
. These methods define an error
action together with a normal (non-error) action
The following example shows how to use all three methods:
@EnableStateMachine
public class Config55
throws Exception {
states
.withStates()
.initial(States.S1)
.stateEntry(States.S2, action(), errorAction())
.stateDo(States.S2, action(), errorAction())
.stateExit(States.S2, action(), errorAction())
.state(States.S3);
12.8. Configuring Pseudo States
Pseudo state configuration is usually done by configuring states and transitions. Pseudo states are automatically added to state machine as states.
12.8.1. Initial State
You can mark a particular state as initial state by using the initial()
method. This initial action is good, for example, to initialize
extended state variables. The following example shows how to use the initial()
method:
@EnableStateMachine
public class Config11
throws Exception {
states
.withStates()
.initial(States.S1, initialAction())
.end(States.SF)
public Action<States, Events> initialAction() {
// do something initially
12.8.2. Terminate State
You can mark a particular state as being an end state by using the end()
method.
You can do so at most once for each individual sub-machine or region.
The following example shows how to use the end()
method:
@EnableStateMachine
throws Exception {
states
.withStates()
.initial(States.S1)
.end(States.SF)
12.8.3. State History
You can define state history once for each individual state machine.
You need to choose its state identifier and set either History.SHALLOW
or
History.DEEP
. The following example uses History.SHALLOW
@EnableStateMachine
public class Config12
extends EnumStateMachineConfigurerAdapter<States3, Events> {
public void configure(StateMachineStateConfigurer<States3, Events> states)
throws Exception {
states
.withStates()
.initial(States3.S1)
.state(States3.S2)
.and()
.withStates()
.parent(States3.S2)
.initial(States3.S2I)
.state(States3.S21)
.state(States3.S22)
.history(States3.SH, History.SHALLOW);
public void configure(StateMachineTransitionConfigurer<States3, Events> transitions)
throws Exception {
transitions
.withHistory()
.source(States3.SH)
.target(States3.S22);
Also, as the preceding example shows, you can optionally define a default transition from a history state into a state vertex in a same machine. This transition takes place as a default if, for example, the machine has never been entered — thus, no history would be available. If a default state transition is not defined, then normal entry into a region is done. This default transition is also used if a machine’s history is a final state.
12.8.4. Choice State
Choice needs to be defined in both states and transitions to work
properly. You can mark a particular state as being a choice state by using the choice()
method. This state needs to match source state when a transition is
configured for this choice.
You can configure a transition by using withChoice()
, where you define source
state and a first/then/last
structure, which is equivalent to a normal
if/elseif/else
. With first
and then
, you can specify a guard just
as you would use a condition with if/elseif
clauses.
A transition needs to be able to exist, so you must make sure to use last
Otherwise, the configuration is ill-formed. The following example shows how to define
a choice state:
@EnableStateMachine
public class Config13
throws Exception {
states
.withStates()
.initial(States.SI)
.choice(States.S1)
.end(States.SF)
throws Exception {
transitions
.withChoice()
.source(States.S1)
.first(States.S2, s2Guard())
.then(States.S3, s3Guard())
.last(States.S4);
public Guard<States, Events> s2Guard() {
return false;
public Guard<States, Events> s3Guard() {
return true;
Actions can be run with both incoming and outgoing transitions of a choice pseudostate. As the following example shows, one dummy lambda action is defined that leads into a choice state and one similar dummy lambda action is defined for one outgoing transition (where it also defines an error action):
@EnableStateMachine
public class Config23
throws Exception {
states
.withStates()
.initial(States.SI)
.choice(States.S1)
.end(States.SF)
throws Exception {
transitions
.withExternal()
.source(States.SI)
.action(c -> {
// action with SI-S1
.target(States.S1)
.and()
.withChoice()
.source(States.S1)
.first(States.S2, c -> {
return true;
.last(States.S3, c -> {
// action with S1-S3
}, c -> {
// error callback for action S1-S3
Junction have same api format meaning actions can be defined similarly. |
12.8.5. Junction State
You need to define a junction in both states and transitions for it to work
properly. You can mark a particular state as being a choice state by using the junction()
method. This state needs to match the source state when a transition is
You can configure the transition by using withJunction()
structure (which is equivalent to a normal
if/elseif/else
). With first
and then
, you can specify a guard as
clauses.
The following example uses a junction:
@EnableStateMachine
public class Config20
throws Exception {
states
.withStates()
.initial(States.SI)
.junction(States.S1)
.end(States.SF)
throws Exception {
transitions
.withJunction()
.source(States.S1)
.last(States.S4);
return false;
return true;
The difference between choice and junction is purely academic, as both are
implemented with first/then/last structures . However, in theory, based
on UML modeling, choice allows only one incoming transition while
junction allows multiple incoming transitions. At a code level, the
functionality is pretty much identical.
12.8.6. Fork State
You must define a fork in both states and transitions for it to work
properly. You can mark a particular state as being a choice state by using the fork()
configured for this fork.
The target state needs to be a super state or an immediate state in a regions. Using a super state as a target takes all regions into initial states. Targeting individual state gives more controlled entry into regions. The following example uses a fork:
@EnableStateMachine
public class Config14
throws Exception {
states
.withStates()
.fork(States2.S2)
.state(States2.S3)
.and()
.withStates()
.parent(States2.S3)
.state(States2.S21)
.state(States2.S22)
.end(States2.S2F)
.and()
.withStates()
.parent(States2.S3)
.state(States2.S31)
.state(States2.S32)
.end(States2.S3F);
public void configure(StateMachineTransitionConfigurer<States2, Events> transitions)
throws Exception {
transitions
.withFork()
.source(States2.S2)
.target(States2.S22)
.target(States2.S32);
12.8.7. Join State
You must define a join in both states and transitions for it to work
properly. You can mark aparticular state as being a choice state by using the join()
method. This state does not need to match either source states or a
target state in a transition configuration.
You can select a target state where a transition goes when all source states have been joined. If you use state hosting regions as the source, the end states of a region are used as joins. Otherwise, you can pick any states from a region. The following exmaple uses a join:
@EnableStateMachine
public class Config15
throws Exception {
states
.withStates()
.state(States2.S3)
.join(States2.S4)
.state(States2.S5)
.and()
.withStates()
.parent(States2.S3)
.state(States2.S21)
.state(States2.S22)
.end(States2.S2F)
.and()
.withStates()
.parent(States2.S3)
.state(States2.S31)
.state(States2.S32)
.end(States2.S3F);
throws Exception {
transitions
.withJoin()
.source(States2.S2F)
.source(States2.S3F)
.target(States2.S4)
.and()
.withExternal()
.source(States2.S4)
.target(States2.S5);
You can also have multiple transitions originate from a
join state. It this case, we advise you to use guards and define your guards
such that only one guard evaluates to TRUE
at any given time. Otherwise,
transition behavior is not predictable. This is shown in the following example, where the guard
checks whether the extended state has variables:
@EnableStateMachine
public class Config22
throws Exception {
states
.withStates()
.state(States2.S3)
.join(States2.S4)
.state(States2.S5)
.end(States2.SF)
.and()
.withStates()
.parent(States2.S3)
.state(States2.S21)
.state(States2.S22)
.end(States2.S2F)
.and()
.withStates()
.parent(States2.S3)
.state(States2.S31)
.state(States2.S32)
.end(States2.S3F);
throws Exception {
transitions
.withJoin()
.target(States2.S4)
.and()
.withExternal()
.source(States2.S4)
.target(States2.S5)
.guardExpression("!extendedState.variables.isEmpty()")
.and()
.withExternal()
.source(States2.S4)
.target(States2.SF)
.guardExpression("extendedState.variables.isEmpty()");
12.8.8. Exit and Entry Point States
You can use exit and entry points to do more controlled exit and entry
from and into a submachine.
The following example uses the withEntry
and withExit
methods to define entry points:
@EnableStateMachine
static class Config21 extends StateMachineConfigurerAdapter<String, String> {
throws Exception {
states
.withStates()
.initial("S1")
.state("S2")
.state("S3")
.and()
.withStates()
.parent("S2")
.initial("S21")
.entry("S2ENTRY")
.exit("S2EXIT")
.state("S22");
throws Exception {
transitions
.withExternal()
.source("S1").target("S2")
.event("E1")
.and()
.withExternal()
.source("S1").target("S2ENTRY")
.event("ENTRY")
.and()
.withExternal()
.source("S22").target("S2EXIT")
.event("EXIT")
.and()
.withEntry()
.source("S2ENTRY").target("S22")
.and()
.withExit()
.source("S2EXIT").target("S3");
As shown in the preceding, you need to mark particular states as being exit
and
entry
states. Then you create a normal transitions into those states
and also specify withExit()
and withEntry()
, where those states
exit and entry respectively.
12.9. Configuring Common Settings
You can set part of a common state machine configuration by using
. With it you can set BeanFactory
and an autostart flag
for a state machine. It also lets you register StateMachineListener
instances,
configure transition conflict policy and region execution policy.
The following example shows how to use ConfigurationConfigurer
@EnableStateMachine
public class Config17
public void configure(StateMachineConfigurationConfigurer<States, Events> config)
throws Exception {
config
.autoStartup(true)
.machineId("myMachineId")
.beanFactory(new StaticListableBeanFactory())
.listener(new StateMachineListenerAdapter<States, Events>())
.transitionConflictPolicy(TransitionConflictPolicy.CHILD)
.regionExecutionPolicy(RegionExecutionPolicy.PARALLEL);
By default, the state machine autoStartup
flag is disabled, because all
instances that handle sub-states are controlled by the state machine itself
and cannot be automatically started. Also, it is much safer to leave
whether a machine should be started
automatically or not to the user. This flag controls only the autostart of a
top-level state machine.
Setting machineId
within a configuration class is simply a convenience for those times when
you want or need to do it there.
Registering StateMachineListener
instances is also partly for
convenience but is required if you want to catch a callback during a
state machine lifecycle, such as getting notified of a state machine’s
start and stop events. Note that you cannot listen a state
machine’s start events if autoStartup
is enabled, unless you register a listener
during a configuration phase.
You can use transitionConflictPolicy
when multiple
transition paths could be selected. One usual use case for this is when a
machine contains anonymous transitions that lead out from a sub-state
and a parent state and you want to define a policy in which one is
selected. This is a global setting within a machine instance and
defaults to CHILD
You can use withDistributed()
to configure DistributedStateMachine
. It
lets you set a StateMachineEnsemble
, which (if it exists) automatically
wraps any created StateMachine
with DistributedStateMachine
and
enables distributed mode. The following example shows how to use it:
@EnableStateMachine
public class Config18
throws Exception {
config
.withDistributed()
.ensemble(stateMachineEnsemble());
public StateMachineEnsemble<States, Events> stateMachineEnsemble()
throws Exception {
// naturally not null but should return ensemble instance
return null;
For more about distributed states, see Using Distributed States.
The StateMachineModelVerifier
interface is used internally to
do some sanity checks for a state machine’s structure. Its purpose is to
fail fast early instead of letting common configuration errors into a
state machine. By default, a verifier is automatically enabled and the
DefaultStateMachineModelVerifier
implementation is used.
With withVerifier()
, you can disable verifier or set a custom one if
needed. The following example shows how to do so:
@EnableStateMachine
public class Config19
throws Exception {
config
.withVerifier()
.enabled(true)
.verifier(verifier());
public StateMachineModelVerifier<States, Events> verifier() {
return new StateMachineModelVerifier<States, Events>() {
public void verify(StateMachineModel<States, Events> model) {
// throw exception indicating malformed model
For more about config model, see StateMachine Config Model.
The withSecurity , withMonitoring and withPersistence configuration methods
are documented in State Machine Security, Monitoring a State Machine, and
Using StateMachineRuntimePersister , respectively.
12.10. Configuring Model
StateMachineModelFactory
is a hook that lets you configure a statemachine model
without using a manual configuration. Essentially, it is a third-party
integration to integrate into a configuration model.
You can hook StateMachineModelFactory
into a configuration model by
using a StateMachineModelConfigurer
@EnableStateMachine
public static class Config1 extends StateMachineConfigurerAdapter<String, String> {
public void configure(StateMachineModelConfigurer<String, String> model) throws Exception {
model
.withModel()
.factory(modelFactory());
public StateMachineModelFactory<String, String> modelFactory() {
return new CustomStateMachineModelFactory();
The follwoing example uses CustomStateMachineModelFactory
to
define two states (S1
and S2
) and an event (E1
) between those
states:
public static class CustomStateMachineModelFactory implements StateMachineModelFactory<String, String> {
public StateMachineModel<String, String> build() {
ConfigurationData<String, String> configurationData = new ConfigurationData<>();
Collection<StateData<String, String>> stateData = new ArrayList<>();
stateData.add(new StateData<String, String>("S1", true));
stateData.add(new StateData<String, String>("S2"));
StatesData<String, String> statesData = new StatesData<>(stateData);
Collection<TransitionData<String, String>> transitionData = new ArrayList<>();
transitionData.add(new TransitionData<String, String>("S1", "S2", "E1"));
TransitionsData<String, String> transitionsData = new TransitionsData<>(transitionData);
StateMachineModel<String, String> stateMachineModel = new DefaultStateMachineModel<String, String>(configurationData,
statesData, transitionsData);
return stateMachineModel;
public StateMachineModel<String, String> build(String machineId) {
return build();
Defining a custom model is usually not what people are looking for, although it is possible. However, it is a central concept of allowing external access to this configuration model. |
You can find an example of using this model factory integration in Eclipse Modeling Support. You can find more generic info about custom model integration in Developer Documentation.
12.11. Things to Remember
When defining actions, guards, or any other references from a
configuration, it pays to remember how Spring Framework works
with beans. In the next example, we have defined a normal configuration with
states S1
and S2
and four transitions between those. All transitions
are guarded by either guard1
or guard2
. You must ensure that
guard1
is created as a real bean because it is annotated with
, while guard2
is not.
This means that event E3
would get the guard2
condition as
TRUE
, and E4
condition as FALSE
, because those are
coming from plain method calls to those functions.
However, because guard1
is defined as a @Bean
, it is proxied by the
Spring Framework. Thus, additional calls to its method result in
only one instantiation of that instance. Event E1
would first get the
proxied instance with condition TRUE
, while event E2
would get the same
instance with TRUE
condition when the method call was defined with
FALSE
. This is not a Spring State Machine-specific behavior. Rather, it is
how Spring Framework works with beans.
The following example shows how this arrangement works:
@EnableStateMachine
throws Exception {
states
.withStates()
.initial("S1")
.state("S2");
throws Exception {
transitions
.withExternal()
.source("S1").target("S2").event("E1").guard(guard1(true))
.and()
.withExternal()
.source("S1").target("S2").event("E2").guard(guard1(false))
.and()
.withExternal()
.source("S1").target("S2").event("E3").guard(guard2(true))
.and()
.withExternal()
.source("S1").target("S2").event("E4").guard(guard2(false));
public Guard<String, String> guard1(final boolean value) {
return new Guard<String, String>() {
public boolean evaluate(StateContext<String, String> context) {
return value;
public Guard<String, String> guard2(final boolean value) {
return value;
13. State Machine ID
Various classes and interfaces use machineId
either as a variable or as a
parameter in methods. This section takes a closer look at how
machineId
relates to normal machine operation and instantiation.
During runtime, a machineId
really does not have any big operational
role except to distinguish machines from each other — for example, when
following logs or doing deeper debugging. Having a lot of different
machine instances quickly gets developers lost in translation if there is
no easy way to identify these instances. As a result, we added the option to set the
machineId
13.1. Using @EnableStateMachine
Setting machineId
in Java configuration as mymachine
then exposes that value
for logs. This same machineId
is also available from the
StateMachine.getId()
method. The following example uses the machineId
method:
throws Exception {
config
.machineId("mymachine");
The following example of log output shows the mymachine
ID:
11:23:54,509 INFO main support.LifecycleObjectSupport [main] -
started S2 S1 / S1 / uuid=8fe53d34-8c85-49fd-a6ba-773da15fcaf1 / id=mymachine
The manual builder (see State Machine through a Builder) uses the same configuration interface, meaning that the behavior is equivalent. |
13.2. Using @EnableStateMachineFactory
You can see the same machineId
getting configured if you use a
StateMachineFactory
and request a new machine by using that ID,
as the following example shows:
StateMachineFactory<String, String> factory = context.getBean(StateMachineFactory.class);
StateMachine<String, String> machine = factory.getStateMachine("mymachine");
13.3. Using StateMachineModelFactory
Behind the scenes, all machine configurations are first translated into a
StateMachineModel
so that StateMachineFactory
need not know
from where the configuration originated, as a machine can be built from
Java configuration, UML, or a repository. If you want to go crazy, you can also use a custom
StateMachineModel
, which is the lowest possible
level at which to define configuration.
What do all of these have to do with a machineId
also has a method with the following signature:
StateMachineModel<S, E> build(String machineId)
which a StateMachineModelFactory
implementation may choose to use.
RepositoryStateMachineModelFactory
(see Repository Support) uses
machineId
to support different configurations in a persistent
store through Spring Data Repository interfaces. For example, both
StateRepository
and TransitionRepository
have a method (List<T>
findByMachineId(String machineId)
), to build different states and
transitions by a machineId
. With
, if machineId
is used as empty
or NULL, it defaults to repository configuration (in a backing-persistent model)
without a known machine id.
Currently, UmlStateMachineModelFactory does not distinguish between
different machine IDs, as UML source is always coming from the same
file. This may change in future releases.
14. State Machine Factories
There are use cases when a state machine needs to be created dynamically instead of by defining static configuration at compile time. For example, if there are custom components that use their own state machines and these components are created dynamically, it is impossible to have a static state machine that is built during the application start. Internally, state machines are always built through factory interfaces. This then gives you an option to use this feature programmatically. Configuration for a state machine factory is exactly the same as shown in various examples in this document where state machine configuration is hard coded.
14.1. Factory through an Adapter
Actually creating a state machine by using @EnableStateMachine
works through a factory, so @EnableStateMachineFactory
merely exposes
that factory through its interface. The following example uses
public class Config6
throws Exception {
states
.withStates()
.initial(States.S1)
.end(States.SF)
Now that you have used @EnableStateMachineFactory
to create a factory
instead of a state machine bean, you can inject it and use it (as is) to
request new state machines. The following example shows how to do so:
public class Bean3 {
@Autowired
StateMachineFactory<States, Events> factory;
void method() {
StateMachine<States,Events> stateMachine = factory.getStateMachine();
stateMachine.startReactively().subscribe();
14.1.1. Adapter Factory Limitations
The current limitation of factory is that all the actions and guard with which it associates a state machine share the same instance. This means that, from your actions and guard, you need to specifically handle the case in which the same bean is called by different state machines. This limitation is something that will be resolved in future releases.
14.2. State Machine through a Builder
Using adapters (as shown above) has a limitation imposed by its
requirement to work through Spring @Configuration
classes and the
application context. While this is a very clear model to configure a
state machine, it limits configuration at compile time,
which is not always what a user wants to do. If there is a requirement
to build more dynamic state machines, you can use a simple builder pattern
to construct similar instances. By using strings as states and
events, you can use this builder pattern to build fully dynamic state
machines outside of a Spring application context. The following example
shows how to do so:
StateMachine<String, String> buildMachine1() throws Exception {
Builder<String, String> builder = StateMachineBuilder.builder();
builder.configureStates()
.withStates()
.initial("S1")
.end("SF")
return builder.build();
The builder uses the same configuration interfaces behind the scenes that
the @Configuration
model uses for adapter classes. The same model goes to
configuring transitions, states, and common configuration through a builder’s
methods. This means that whatever you can use with a normal
you can use dynamically through a builder.
Currently, the builder.configureStates() , builder.configureTransitions() ,
and builder.configureConfiguration() interface methods cannot be
chained together, meaning that builder methods need to be called individually.
The following example sets a number of options with a builder:
StateMachine<String, String> buildMachine2() throws Exception {
.autoStartup(false)
.beanFactory(null)
.listener(null);
You need to understand when common configuration needs
to be used with machines instantiated from a builder. You can use a configurer
returned from a withConfiguration()
to setup autoStart
and BeanFactory
You can also use one to register a StateMachineListener
. If a StateMachine
instance returned from a builder is registered as a bean by using @Bean
, BeanFactory
is attached automatically. If you use instances outside of a spring application context,
you must use these methods to set up the needed facilities.
15. Using Deferred Events
When an event is sent, it may fire an EventTrigger
, which may then cause
a transition to happen, if a state machine is in a state where a trigger is
evaluated successfully. Normally, this may lead to a situation where
an event is not accepted and is dropped. However, you may wish
postpone this event until a state machine enters another state. In that case,
you can accept that event. In other words, an event
arrives at an inconvenient time.
Spring Statemachine provides a mechanism for deferring events for later processing. Every state can have a list of deferred events. If an event in the current state’s deferred event list occurs, the event is saved (deferred) for future processing until a state is entered that does not list the event in its deferred event list. When such a state is entered, the state machine automatically recalls any saved events that are no longer deferred and then either consumes or discards these events. It is possible for a superstate to have a transition defined on an event that is deferred by a substate. Following same hierarchical state machines concepts, the substate takes precedence over the superstate, the event is deferred, and the transition for the superstate is not run. With orthogonal regions, where one orthogonal region defers an event and another accepts the event, the accept takes precedence and the event is consumed and not deferred.
The most obvious use case for event deferring is when an event causes a transition into a particular state and the state machine is then returned back to its original state where a second event should cause the same transition. The following example shows this situation:
@EnableStateMachine
static class Config5 extends StateMachineConfigurerAdapter<String, String> {
throws Exception {
states
.withStates()
.initial("READY")
.state("DEPLOYPREPARE", "DEPLOY")
.state("DEPLOYEXECUTE", "DEPLOY");
throws Exception {
transitions
.withExternal()
.source("READY").target("DEPLOYPREPARE")
.event("DEPLOY")
.and()
.withExternal()
.source("DEPLOYPREPARE").target("DEPLOYEXECUTE")
.and()
.withExternal()
.source("DEPLOYEXECUTE").target("READY");
In the preceding example, the state machine has a state of READY
, which indicates that the machine is
ready to process events that would take it into a DEPLOY
state, where the
actual deployment would happen. After a deploy action has been run, the machine
is returned back to the READY
state. Sending multiple events in a
READY
state does not cause any trouble if the machine is using synchronous executors,
because event sending would block between event calls. However, if the executor uses
threads, other events may get lost, because the machine is no longer in a state where
events can be processed. Thus, deferring some of these events lets the machine
preserve them. The following example shows how to configure such an arrangement:
@EnableStateMachine
static class Config6 extends StateMachineConfigurerAdapter<String, String> {
throws Exception {
states
.withStates()
.initial("READY")
.state("DEPLOY", "DEPLOY")
.state("DONE")
.and()
.withStates()
.parent("DEPLOY")
.initial("DEPLOYPREPARE")
.state("DEPLOYPREPARE", "DONE")
.state("DEPLOYEXECUTE");
throws Exception {
transitions
.withExternal()
.source("READY").target("DEPLOY")
.event("DEPLOY")
.and()
.withExternal()
.and()
.withExternal()
.and()
.withExternal()
.source("READY").target("DONE")
.event("DONE")
.and()
.withExternal()
.source("DEPLOY").target("DONE")
.event("DONE");
In the preceding example, the state machine uses nested states instead of a flat
state model, so the DEPLOY
event can be deferred directly in a substate.
It also shows the concept of deferring the DONE
event in a
sub-state that would then override the anonymous transition between
the DEPLOY
and DONE
states if the state machine happens to be in a
DEPLOYPREPARE
state when the DONE
event is dispatched. In the
DEPLOYEXECUTE
state when the DONE
event is not deferred, this event would
be handled in a super state.
16. Using Scopes
Support for scopes in a state machine is very limited, but you can
enable session
scope by using a normal Spring @Scope
annotation in one of two ways:
If the state machine is built manually by using a builder and returned into the context as a
Through a configuration adapter.
Both of
these need @Scope
to be present, with scopeName
set to
session
and proxyMode
set to ScopedProxyMode.TARGET_CLASS
. The following examples
show both use cases:
public class Config3 {
@Scope(scopeName="session", proxyMode=ScopedProxyMode.TARGET_CLASS)
StateMachine<String, String> stateMachine() throws Exception {
.autoStartup(true);
.withStates()
.initial("S1")
.state("S2");
.withExternal()
.source("S1")
.target("S2")
.event("E1");
StateMachine<String, String> stateMachine = builder.build();
return stateMachine;
@EnableStateMachine
public static class Config4 extends StateMachineConfigurerAdapter<String, String> {
config
.autoStartup(true);
states
.withStates()
.initial("S1")
.state("S2");
transitions
.withExternal()
.source("S1")
.target("S2")
.event("E1");
TIP:See Scope for how to use session scoping.
Once you have scoped a state machine into session
, autowiring it into
a @Controller
gives a new state machine instance per session.
Each state machine is then destroyed when HttpSession
is invalidated.
The following example shows how to use a state machine in a controller:
@Controller
public class StateMachineController {
@Autowired
@RequestMapping(path="/state", method=RequestMethod.POST)
public HttpEntity<Void> setState(@RequestParam("event") String event) {
stateMachine
.withPayload(event).build()))
.subscribe();
return new ResponseEntity<Void>(HttpStatus.ACCEPTED);
@RequestMapping(path="/state", method=RequestMethod.GET)
@ResponseBody
public String getState() {
return stateMachine.getState().getId();
Using state machines in a session scopes needs careful planning,
mostly because it is a relatively heavy component.
Spring Statemachine poms have no dependencies to Spring MVC classes, which you will need to work with session scope. However, if you are working with a web application, you have already pulled those dependencies directly from Spring MVC or Spring Boot. |
17. Using Actions
Actions are one of the most useful components that you can use to interact and collaborate with a state machine. You can run actions in various places in a state machine and its states lifecycle — for example, entering or exiting states or during transitions. The following example shows how to use actions in a state machine:
throws Exception {
states
.withStates()
.initial(States.SI)
.state(States.S1, action1(), action2())
.state(States.S2, action1(), action2())
.state(States.S3, action1(), action3());
In the preceding example, the action1
and action2
beans are attached to the entry
and
exit
states, respectively. The following example defines those actions (and action3
public Action<States, Events> action1() {
public BaseAction action2() {
return new BaseAction();
public SpelAction action3() {
ExpressionParser parser = new SpelExpressionParser();
return new SpelAction(
parser.parseExpression(
"stateMachine.sendEvent(T(org.springframework.statemachine.docs.Events).E1)"));
public class BaseAction implements Action<States, Events> {
public class SpelAction extends SpelExpressionAction<States, Events> {
public SpelAction(Expression expression) {
super(expression);
You can directly implement Action
as an anonymous function or create
your own implementation and define the appropriate implementation as a
bean.
In the preceding example, action3
uses a SpEL expression to send the Events.E1
event into
a state machine.
StateContext is described in Using StateContext .
17.1. SpEL Expressions with Actions
You can also use a SpEL expression as a replacement for a
full Action
implementation.
17.2. Reactive Actions
Normal Action
interface is a simple functional method taking StateContext
and returning void. There’s nothing blocking here until you block
in a method itself and this is a bit of a problem as framework cannot
know what’s exactly happening inside of it.
public interface Action<S, E> {
void execute(StateContext<S, E> context);
To overcome this issue we’ve internally changed Action
handling to
process a plain java’s Function
taking StateContext
and returning
Mono
. This way we can call action and fully in a reactive way to
execute action only when it’s subscribed and in a non-blocking way
to wait completion.
public interface ReactiveAction<S, E> extends Function<StateContext<S, E>, Mono<Void>> {
Internally old |
18. Using Guards
As shown in Things to Remember, the guard1
and guard2
beans are attached to the entry and
exit states, respectively.
The following example also uses guards on events:
throws Exception {
transitions
.withExternal()
.source(States.SI).target(States.S1)
.event(Events.E1)
.guard(guard1())
.and()
.withExternal()
.event(Events.E1)
.guard(guard2())
.and()
.withExternal()
.event(Events.E2)
.guardExpression("extendedState.variables.get('myvar')");
You can directly implement Guard
bean. In the preceding example, guardExpression
checkS whether the extended
state variable named myvar
evaluates to TRUE
The following example implements some sample guards:
public Guard<States, Events> guard1() {
return true;
public BaseGuard guard2() {
return new BaseGuard();
public class BaseGuard implements Guard<States, Events> {
return false;
StateContext is described in section Using StateContext .
18.1. SpEL Expressions with Guards
full Guard implementation. The only requirement is that the expression needs
to return a Boolean
value to satisfy the Guard
implementation. This can be
demonstrated with a guardExpression()
function that takes an
expression as an argument.
18.2. Reactive Guards
Normal Guard
and returning boolean. There’s nothing blocking here until you block
public interface Guard<S, E> {
boolean evaluate(StateContext<S, E> context);
To overcome this issue we’ve internally changed Guard
handling to
taking StateContext
and returning
Mono<Boolean>
. This way we can call guard and fully in a reactive way
to evaluate it only when it’s subscribed and in a non-blocking way
to wait completion with a return value.
public interface ReactiveGuard<S, E> extends Function<StateContext<S, E>, Mono<Boolean>> {
Internally old |
19. Using Extended State
Assume that you need to create a state machine that tracks how many times a user is pressing a key on a keyboard and then terminates when keys are pressed 1000 times. A possible but really naive solution would be to create a new state for each 1000 key presses. You might suddenly have an astronomical number of states, which, naturally, is not very practical.
This is where extended state variables come to the rescue by not needing to add more states to drive state machine changes. Instead, you can do a simple variable change during a transition.
StateMachine
has a method called getExtendedState()
. It returns an
interface called ExtendedState
, which gives access to extended state
variables. You can access these variables directly through a state machine or through
StateContext
during a callback from actions or transitions.
public Action<String, String> myVariableAction() {
return new Action<String, String>() {
public void execute(StateContext<String, String> context) {
context.getExtendedState()
.getVariables().put("mykey", "myvalue");
If you need to get notified for extended state variable
changes, you have two options: either use StateMachineListener
or
listen for extendedStateChanged(key, value)
callbacks. The following example
uses the extendedStateChanged
method:
public class ExtendedStateVariableListener
extends StateMachineListenerAdapter<String, String> {
public void extendedStateChanged(Object key, Object value) {
// do something with changed variable
Alternatively, you can implement a Spring Application context listener for
OnExtendedStateChanged
. As mentioned in Listening to State Machine Events,
you can also listen all StateMachineEvent
events.
The following example uses onApplicationEvent
to listen for state changes:
public class ExtendedStateVariableEventListener
implements ApplicationListener<OnExtendedStateChanged> {
public void onApplicationEvent(OnExtendedStateChanged event) {
20. Using StateContext
StateContext
is one of the most important objects
when working with a state machine, as it is passed into various methods
and callbacks to give the current state of a state machine and
where it is possibly going. You can think of it as a
snapshot of the current state machine stage when
is when StateContext
is retreived.
In Spring Statemachine 1.0.x, StateContext usage was relatively naive
in terms of how it was used to pass stuff around as a simple “POJO”.
Starting from Spring Statemachine 1.1.x, its role has been greatly
improved by making it a first class citizen in a state machine.
You can use StateContext
to get access to the following:
The current
Message
orEvent
(or theirMessageHeaders
, if known). -
The state machine’s
Extended State
The
StateMachine
itself. -
To possible state machine errors.
To the current
Transition
, if applicable. -
The source state of the state machine.
The target state of the state machine.
The current
Stage
, as described in Stages.
StateContext
is passed into various components, such as
Action
and Guard
20.1. Stages
Stage
is arepresentation of a stage
on
which a state machine is currently interacting with a user. The currently available
stages are EVENT_NOT_ACCEPTED
, EXTENDED_STATE_CHANGED
STATE_CHANGED
, STATE_ENTRY
, STATE_EXIT
, STATEMACHINE_ERROR
STATEMACHINE_START
, STATEMACHINE_STOP
, TRANSITION
TRANSITION_START
, and TRANSITION_END
. These states may look familiar, as
they match how you can interact with listeners (as described in
Listening to State Machine Events).
21. Triggering Transitions
Driving a state machine is done by using transitions, which are triggered
by triggers. The currently supported triggers are EventTrigger
and
TimerTrigger
21.1. Using EventTrigger
EventTrigger
is the most useful trigger, because it lets you
directly interact with a state machine by sending events to it. These
events are also called signals. You can add a trigger to a transition
by associating a state with it during configuration.
@Autowired
void signalMachine() {
stateMachine
.withPayload("E1").build()))
.subscribe();
Message<String> message = MessageBuilder
.withPayload("E2")
.setHeader("foo", "bar")
stateMachine.sendEvent(Mono.just(message)).subscribe();
Whether you send one event or multiple events, result is always a sequence
of results. This is so because in a presence multiple reqions, results will
come back from multiple machines in those regions. This is shown
with method sendEventCollect
which gives a list of results. Method
itself is a just a syntactic sugar collecting Flux
as list. If there is
just one region, this list contains one result.
Message<String> message1 = MessageBuilder
.withPayload("E1")
Mono<List<StateMachineEventResult<String, String>>> results =
stateMachine.sendEventCollect(Mono.just(message1));
results.subscribe();
Nothing happens until returned flux is subscribed. See more about it from StateMachineEventResult. |
The preceding example sends an events by constructing a Mono
wrapping
a Message
and subscribing into returned Flux
of results. Message
lets
us add arbitrary extra information to an event, which is then visible
to StateContext
when (for example) you implement actions.
Message headers are generally passed on until machine runs to
completion for a specific event. For example if an event is causing
transition into a state A which have an anonymous transition into a
state B , original event is available for actions or guards in state
B .
It is also possible to send a Flux
of messages instead of sending just
one with a Mono
.withPayload("E1")
Message<String> message2 = MessageBuilder
.withPayload("E2")
Flux<StateMachineEventResult<String, String>> results =
stateMachine.sendEvents(Flux.just(message1, message2));
21.1.1. StateMachineEventResult
contains more detailed information about a result
of a event sending. From this you can get a Region
which handled an event,
Message
itself and what was an actual ResultType
. From ResultType
you
can see if message was accepted, denied or deferred. Generally speaking when
subscribtion completes, events are passed into a machine.
21.2. Using TimerTrigger
TimerTrigger
is useful when something needs to be triggered
automatically without any user interaction. Trigger
is added to a
transition by associating a timer with it during a configuration.
Currently, there are two types of supported timers, one that fires continuously and one that fires once a source state is entered. The following example shows how to use the triggers:
@EnableStateMachine
public class Config2 extends StateMachineConfigurerAdapter<String, String> {
throws Exception {
states
.withStates()
.initial("S1")
.state("S2")
.state("S3");
throws Exception {
transitions
.withExternal()
.and()
.withExternal()
.source("S1").target("S3").event("E2")
.and()
.withInternal()
.source("S2")
.action(timerAction())
.timer(1000)
.and()
.withInternal()
.source("S3")
.timerOnce(1000);
public TimerAction timerAction() {
return new TimerAction();
public class TimerAction implements Action<String, String> {
// do something in every 1 sec
The preceding example has three states: S1
, S2
, and S3
. We have a normal
external transition from S1
to S2
and from S1
to S3
with
events E1
and E2
, respectively. The interesting parts
for working with TimerTrigger
are when we define
internal transitions for source states S2
and S3
For both transitions, we invoke the Action
bean (timerAction
), where
source state S2
uses timer
and S3
uses timerOnce
Values given are in milliseconds (1000
milliseconds, or one second, in both cases).
Once a state machine receives event E1
, it does a transition
from S1
to S2
and the timer kicks in. When the state is S2
TimerTrigger
runs and causes a transition associated with that
state — in this case, the internal transition that has the
timerAction
defined.
Once a state machine receives the E2
, event it does a transition
from S1
to S3
and the timer kicks in. This timer is executed only once
after the state is entered (after a delay defined in a timer).
Behind the scenes, timers are simple triggers that may cause a
transition to happen. Defining a transition with a timer() keeps
firing triggers and causes transition only if the source state is active.
Transition with timerOnce() is a little different, as it
triggers only after a delay when a source state is actually entered.
Use timerOnce() if you want something to happen after a delay
exactly once when state is entered.
22. Listening to State Machine Events
There are use cases where you want to know what is happening with a state machine, react to something, or get logging details for debugging purposes. Spring Statemachine provides interfaces for adding listeners. These listeners then give an option to get callbacks when various state changes, actions, and so on happen.
You basically have two options: listen to Spring application context events or directly attach a listener to a state machine. Both of these basically provide the same information. One produces events as event classes, and the other produces callbacks via a listener interface. Both of these have pros and cons, which we discuss later.
22.1. Application Context Events
Application context events classes are OnTransitionStartEvent
OnTransitionEvent
, OnTransitionEndEvent
, OnStateExitEvent
OnStateEntryEvent
, OnStateChangedEvent
, OnStateMachineStart
OnStateMachineStop
, and others that extend the base event class,
StateMachineEvent
. These can be used as is with a Spring
ApplicationListener
StateMachine
sends context events through StateMachineEventPublisher
The default implementation is automatically created if a @Configuration
class is annotated with @EnableStateMachine
The following example gets a StateMachineApplicationEventListener
from a bean defined in a @Configuration
class:
public class StateMachineApplicationEventListener
implements ApplicationListener<StateMachineEvent> {
public void onApplicationEvent(StateMachineEvent event) {
public class ListenerConfig {
public StateMachineApplicationEventListener contextListener() {
return new StateMachineApplicationEventListener();
Context events are also automatically enabled by using @EnableStateMachine
with StateMachine
used to build a machine and registered as a bean,
@EnableStateMachine
public class ManualBuilderConfig {
public StateMachine<String, String> stateMachine() throws Exception {
.withStates()
.initial("S1")
.state("S2");
.withExternal()
.source("S1")
.target("S2")
.event("E1");
22.2. Using StateMachineListener
By using StateMachineListener
, you can either extend it and
implement all callback methods or use the StateMachineListenerAdapter
class, which contains stub method implementations and choose which ones
to override.
The following example uses the latter approach:
public class StateMachineEventListener
extends StateMachineListenerAdapter<States, Events> {
public void stateChanged(State<States, Events> from, State<States, Events> to) {
public void stateEntered(State<States, Events> state) {
public void stateExited(State<States, Events> state) {
public void transition(Transition<States, Events> transition) {
public void transitionStarted(Transition<States, Events> transition) {
public void transitionEnded(Transition<States, Events> transition) {
public void stateMachineStarted(StateMachine<States, Events> stateMachine) {
public void stateMachineStopped(StateMachine<States, Events> stateMachine) {
public void eventNotAccepted(Message<Events> event) {
public void stateMachineError(StateMachine<States, Events> stateMachine, Exception exception) {
public void stateContext(StateContext<States, Events> stateContext) {
In the preceding example, we created our own listener class
(StateMachineEventListener
) that extends
The stateContext
listener method gives access to various
StateContext
changes on a different stages. You can find more about about it in
Using StateContext
Once you have defined your own listener, you can registered it in a
state machine by using the addStateListener
method. It is a matter of
flavor whether to hook it up within a spring configuration or do it
manually at any time during the application life-cycle.
The following example shows how to attach a listener:
public class Config7 {
@Autowired
StateMachine<States, Events> stateMachine;
public StateMachineEventListener stateMachineEventListener() {
StateMachineEventListener listener = new StateMachineEventListener();
stateMachine.addStateListener(listener);
return listener;
22.3. Limitations and Problems
Spring application context is not the fastest event bus out there, so we
advise giving some thought to the rate of events the state machine
sends. For better performance, it may be better to use the
interface. For this specific reason,
you can use the contextEvents
flag with @EnableStateMachine
and
to disable Spring application context
events, as shown in the preceding section.
The following example shows how to disable Spring application context events:
@EnableStateMachine(contextEvents = false)
public class Config8
@EnableStateMachineFactory(contextEvents = false)
public class Config9
23. Context Integration
It is a little limited to do interaction with a state machine by either listening to its events or using actions with states and transitions. From time to time, this approach is going be too limited and verbose to create interaction with the application with which a state machine works. For this specific use case, we have made a Spring-style context integration that easily inserts state machine functionality into your beans.
The available annotations has been harmonized to enable access to the same state machine execution points that are available from Listening to State Machine Events.
You can use the @WithStateMachine
annotation to associate a state
machine with an existing bean. Then you can start adding
supported annotations to the methods of that bean.
@WithStateMachine
public class Bean1 {
@OnTransition
public void anyTransition() {
You can also attach any other state machine from an
application context by using the annotation name
field.
@WithStateMachine(name = "myMachineBeanName")
public class Bean2 {
@OnTransition
Sometimes, it is more convenient to use machine id
, which is something
you can set to better identify multiple instances. This ID maps to
the getId()
method in the StateMachine
interface.
@WithStateMachine(id = "myMachineId")
public class Bean16 {
@OnTransition
When using StateMachineFactory to generate state machines the state machine using dynamic provided id
, bean name will default to stateMachine
it’s not possible to use @WithStateMachine (id = "some-id")
since id
is only known at runtime.
In such a cases, use either @WithStateMachine
or @WithStateMachine(name = "stateMachine")
and all state machines generated by the factory will be atached to your bean or beans.
You can also use @WithStateMachine
as a meta-annotation, as shown
in the preceding example. In this case, you could annotate your bean with WithMyBean
@Target(ElementType.TYPE)
public @interface WithMyBean {
The return type of these methods does not matter and is effectively discarded. |
23.1. Enabling Integration
You can enable all the features of @WithStateMachine
by using
the @EnableWithStateMachine
annotation, which imports the needed
configuration into the Spring Application Context. Both
@EnableStateMachine
and @EnableStateMachineFactory
are already
annotated with this annotation, so there is no need to add it again.
However, if a machine is built and configured without
configuration adapters, you must use @EnableWithStateMachine
to use these features with @WithStateMachine
public static StateMachine<String, String> buildMachine(BeanFactory beanFactory) throws Exception {
.beanFactory(beanFactory);
.withStates()
.initial("S1")
.state("S2");
.withExternal()
.source("S1")
.target("S2")
.event("E1");
static class Bean17 {
@OnStateChanged
public void onStateChanged() {
If a machine is not created as a bean, you need to set
BeanFactory for a machine, as shown in the prededing example. Otherwise, tge machine is
unaware of handlers that call your @WithStateMachine methods.
23.2. Method Parameters
Every annotation support exactly the same set of possible method
parameters, but runtime behavior differs, depending on the
annotation itself and the stage in which the annotated method is called. To
better understand how context works, see
Using StateContext
For differences between method parameters, see the sections that desdribe the individual annotation, later in this document. |
Effectively, all annotated methods are called by using Spring SPel
expressions, which are built dynamically during the process. To make
this work, these expressions needs to have a root object (against which they evaluate).
This root object is a StateContext
. We have also made some
tweaks internally so that it is possible to access StateContext
methods
directly without going through the context handle.
The simplest method parameter is a StateContext
itself.
@WithStateMachine
@OnTransition
public void anyTransition(StateContext<String, String> stateContext) {
You can access the rest of the StateContext
content.
The number and order of the parameters does not matter.
The following example shows how to access the various parts of the StateContext
content:
@WithStateMachine
public class Bean4 {
@OnTransition
@EventHeaders Map<String, Object> headers,
@EventHeader("myheader1") Object myheader1,
@EventHeader(name = "myheader2", required = false) String myheader2,
ExtendedState extendedState,
StateMachine<String, String> stateMachine,
Message<String> message,
Exception e) {
Instead of getting all event headers with @EventHeaders , you can use
@EventHeader , which can bound to a single header.
23.3. Transition Annotations
The annotations for transitions are @OnTransition
, @OnTransitionStart
and @OnTransitionEnd
These annotations behave exactly the same. To show how they work, we show
how @OnTransition
is used. Within this annotation, a property’s
you can use source
and target
to qualify a transition. If
source
and target
are left empty, any transition is matched.
The following example shows how to use the @OnTransition
annotation
(remember that @OnTransitionStart
work the same way):
@WithStateMachine
public class Bean5 {
@OnTransition(source = "S1", target = "S2")
public void fromS1ToS2() {
@OnTransition
By default, you cannot use the @OnTransition
annotation with a state and
event enumerations that you have created, due to Java language limitations.
For this reason, you need to use string representations.
Additionally, you can access Event Headers
and
ExtendedState
by adding the needed arguments to a method. The method
is then called automatically with these arguments.
@WithStateMachine
public class Bean6 {
@StatesOnTransition(source = States.S1, target = States.S2)
public void fromS1ToS2(@EventHeaders Map<String, Object> headers, ExtendedState extendedState) {
However, if you want to have a type-safe annotation, you can
create a new annotation and use @OnTransition
as a meta-annotation.
This user-level annotation can make references to actual states and
events enumerations, and the framework tries to match these in the same way.
@Target(ElementType.METHOD)
@OnTransition
public @interface StatesOnTransition {
States[] source() default {};
States[] target() default {};
In the preceding example, we created a @StatesOnTransition
annotation that defines
source
and target
in a type-safe manner.
The following example uses that annotation in a bean:
@WithStateMachine
public class Bean7 {
23.4. State Annotations
The following annotations for states are available: @OnStateChanged
, @OnStateEntry
, and
@OnStateExit
. The following example shows how to use OnStateChanged
annotation (the
other two work the same way):
@WithStateMachine
public class Bean8 {
@OnStateChanged
public void anyStateChange() {
As you can with Transition Annotations, you can define target and source states. The following example shows how to do so:
@WithStateMachine
public class Bean9 {
@OnStateChanged(source = "S1", target = "S2")
public void stateChangeFromS1toS2() {
For type safety, new annotations need to be created for enumerations by using
@OnStateChanged
as a meta-annotation. The following examples show how to do so:
@OnStateChanged
public @interface StatesOnStates {
@WithStateMachine
public class Bean10 {
@StatesOnStates(source = States.S1, target = States.S2)
The methods for state entry and exit behave in the same way, as the following example shows:
@WithStateMachine
public class Bean11 {
@OnStateEntry
public void anyStateEntry() {
@OnStateExit
public void anyStateExit() {
23.5. Event Annotation
There is one event-related annotation. It is named @OnEventNotAccepted
If you specify the event
property, you can listen for a specific event not being
accepted. If you do not specify an event, you can list for any event not being
accepted. The following example shows both ways to use the @OnEventNotAccepted
annotation:
@WithStateMachine
public class Bean12 {
@OnEventNotAccepted
public void anyEventNotAccepted() {
@OnEventNotAccepted(event = "E1")
public void e1EventNotAccepted() {
23.6. State Machine Annotations
The following annotations are available for a state machine: @OnStateMachineStart
@OnStateMachineStop
, and @OnStateMachineError
During a state machine’s start and stop, lifecycle methods are called.
The following example shows how to use @OnStateMachineStart
and
@OnStateMachineStop
to listen to these events:
@WithStateMachine
public class Bean13 {
public void onStateMachineStart() {
@OnStateMachineStop
public void onStateMachineStop() {
If a state machine goes into an error with exception, @OnStateMachineStop
annotation is called. The following example shows how to use it:
@WithStateMachine
public class Bean14 {
public void onStateMachineError() {
23.7. Extended State Annotation
There is one extended state-related annotation. It is named
@OnExtendedStateChanged
. You can also listen to changes only
for specific key
changes. The following example shows how to use the
, both with and without a key
property:
@WithStateMachine
public class Bean15 {
@OnExtendedStateChanged(key = "key1")
public void key1Changed() {
24. Using StateMachineAccessor
StateMachine
is the main interface for communicating with a state machine.
From time to time, you may need to get more dynamic and
programmatic access to internal structures of a state machine and its
nested machines and regions. For these use cases, StateMachine
exposes a functional interface called StateMachineAccessor
, which provides
an interface to get access to individual StateMachine
and
Region
instances.
StateMachineFunction
is a simple functional interface that lets
you apply the StateMachineAccess
interface to a state machine. With
JDK 7, these create code that is a little verbose code. However, with JDK 8 lambdas,
the doce is relatively non-verbose.
The doWithAllRegions
method gives access to all Region
instances in
a state machine. The following example shows how to use it:
stateMachine.getStateMachineAccessor().doWithAllRegions(function -> function.setRelay(stateMachine));
.doWithAllRegions(access -> access.setRelay(stateMachine));
The doWithRegion
method gives access to single Region
instance in a
stateMachine.getStateMachineAccessor().doWithRegion(function -> function.setRelay(stateMachine));
.doWithRegion(access -> access.setRelay(stateMachine));
The withAllRegions
method gives access to all of the Region
instances in
for (StateMachineAccess<String, String> access : stateMachine.getStateMachineAccessor().withAllRegions()) {
access.setRelay(stateMachine);
.stream().forEach(access -> access.setRelay(stateMachine));
The withRegion
instance in a
.withRegion().setRelay(stateMachine);
25. Using StateMachineInterceptor
Instead of using a StateMachineListener
interface, you can
use a StateMachineInterceptor
. One conceptual difference is that you can use an
interceptor to intercept and stop a current state
change or change its transition logic. Instead of implementing a full interface,
you can use an adapter class called StateMachineInterceptorAdapter
to override
the default no-op methods.
You can register an interceptor through StateMachineAccessor
. The concept of
an interceptor is a relatively deep internal feature and, thus, is not
exposed directly through the StateMachine
interface.
The following example shows how to add a StateMachineInterceptor
and override selected
methods:
.withRegion().addStateMachineInterceptor(new StateMachineInterceptor<String, String>() {
public Message<String> preEvent(Message<String> message, StateMachine<String, String> stateMachine) {
return message;
public StateContext<String, String> preTransition(StateContext<String, String> stateContext) {
return stateContext;
public void preStateChange(State<String, String> state, Message<String> message,
Transition<String, String> transition, StateMachine<String, String> stateMachine,
StateMachine<String, String> rootStateMachine) {
public StateContext<String, String> postTransition(StateContext<String, String> stateContext) {
public void postStateChange(State<String, String> state, Message<String> message,
public Exception stateMachineError(StateMachine<String, String> stateMachine,
return exception;
For more about the error handling shown in preceding example, see State Machine Error Handling. |
26. State Machine Security
Security features are built atop of functionality from Spring Security. Security features are handy when it is required to protect part of a state machine execution and interaction with it.
We expect you to be fairly familiar with Spring Security, meaning that we do not go into details of how the overall security framework works. For this information, you should read the Spring Security reference documentation (available here). |
The first level of defense with security is naturally protecting events, which really drive what is going to happen in a state machine. You can then define more fine-grained security settings for transitions and actions. This parallel to giving an employee access to a building and then giving access to specific rooms within the building and even the ability to turn on and off the lights in specific rooms. If you trust your users, event security may be all you need. If not, you need to apply more detailed security.
You can find more detailed information in Understanding Security.
For a complete example, see the Security sample. |
26.1. Configuring Security
All generic configurations for security are done in
SecurityConfigurer
, which is obtained from
. By default, security is disabled,
even if Spring Security classes are
present. The following example shows how to enable security:
@EnableStateMachine
public void configure(StateMachineConfigurationConfigurer<String, String> config)
throws Exception {
config
.withSecurity()
.enabled(true)
.transitionAccessDecisionManager(null)
.eventAccessDecisionManager(null);
If you absolutely need to, you can customize AccessDecisionManager
for both events and
transitions. If you do not define decision managers or
set them to null
, default managers are created internally.
26.2. Securing Events
Event security is defined on a global level by a SecurityConfigurer
The following example shows how to enable event security:
@EnableStateMachine
throws Exception {
config
.withSecurity()
.enabled(true)
.event("true")
.event("ROLE_ANONYMOUS", ComparisonType.ANY);
In the preceding configuration example, we use an expression of true
, which always evaluates
to TRUE
. Using an expression that always evaluates to TRUE
would not make sense in a real application but shows the point that
expression needs to return either TRUE
or FALSE
. We also defined an
attribute of ROLE_ANONYMOUS
and a ComparisonType
of ANY
. For more about using attributes
and expressions, see Using Security Attributes and Expressions.
26.3. Securing Transitions
You can define transition security globally, as the following example shows.
@EnableStateMachine
throws Exception {
config
.withSecurity()
.enabled(true)
.transition("true")
.transition("ROLE_ANONYMOUS", ComparisonType.ANY);
If security is defined in a transition itself, it override any globally set security. The following example shows how to do so:
@EnableStateMachine
static class Config2 extends StateMachineConfigurerAdapter<String, String> {
public void configure(StateMachineTransitionConfigurer<String, String> transitions)
throws Exception {
transitions
.withExternal()
.source("S0")
.target("S1")
.event("A")
.secured("ROLE_ANONYMOUS", ComparisonType.ANY)
.secured("hasTarget('S1')");
For more about using attributes and expressions, see Using Security Attributes and Expressions.
26.4. Securing Actions
There are no dedicated security definitions for actions in a state
machine, but you can secure actions by using a global method security
from Spring Security. This requires that an Action
be
defined as a proxied @Bean
and its execute
method be annotated with
@Secured
@EnableStateMachine
static class Config3 extends StateMachineConfigurerAdapter<String, String> {
throws Exception {
config
.withSecurity()
.enabled(true);
public void configure(StateMachineStateConfigurer<String, String> states)
throws Exception {
states
.withStates()
.initial("S0")
.state("S1");
throws Exception {
transitions
.withExternal()
.source("S0")
.target("S1")
.action(securedAction())
.event("A");
@Scope(proxyMode = ScopedProxyMode.TARGET_CLASS)
public Action<String, String> securedAction() {
@Secured("ROLE_ANONYMOUS")
Global method security needs to be enabled with Spring Security. The following example shows how to do so:
public static class Config5 {
public InMemoryUserDetailsManager userDetailsService() {
UserDetails user = User.withDefaultPasswordEncoder()
.username("user")
.password("password")
.roles("USER")
return new InMemoryUserDetailsManager(user);
See the Spring Security reference guide (available here) for more detail.
26.5. Using Security Attributes and Expressions
Generally, you can define security properties in either of two ways: by using security attributes and by using security expressions. Attributes are easier to use but are relatively limited in terms of functionality. Expressions provide more features but are a little bit harder to use.
26.5.1. Generic Attribute Usage
By default, AccessDecisionManager
instances for events and
transitions both use a RoleVoter
, meaning you can use role attributes
For attributes, we have three different comparison types: ANY
, ALL
, and
MAJORITY
. These comparison types map onto default access decision managers
(AffirmativeBased
, UnanimousBased
, and ConsensusBased
, respectively).
If you have defined a custom AccessDecisionManager
, the comparison type is
effectively discarded, as it is used only to create a default manager.
26.5.2. Generic Expression Usage
Security expressions must return either TRUE
or FALSE
The base class for the expression root objects is
SecurityExpressionRoot
. It provides some common expressions, which
are available in both transition and event security. The following table
describes the most often used built-in expressions:
Expression | Description |
Returns |
Returns |
Returns |
Returns |
Allows direct access to the principal object that represents the current user. |
Allows direct access to the current |
Always evaluates to |
Returns |
Returns |
Returns |
Returns |
Returns |
Returns |
26.5.3. Event Attributes
You can match an event ID by using a prefix of EVENT_
. For example, matching
event A
would match an attribute of EVENT_A
26.5.4. Event Expressions
The base class for the expression root object for events is
EventSecurityExpressionRoot
. It provides access to a Message
object, which is passed around with eventing. EventSecurityExpressionRoot
has only one method, which the following table describes:
Returns |
26.5.5. Transition Attributes
When matching transition sources and targets, you can use the
TRANSITION_SOURCE_
and TRANSITION_TARGET_
prefixes respectively.
26.5.6. Transition Expressions
The base class for the expression root object for transitions is
TransitionSecurityExpressionRoot
Transition
object, which is passed around for transition changes.
has two methods, which the following
table describes:
Returns |
Returns |
26.6. Understanding Security
This section provides more detailed information about how security works within a state machine. You may not really need to know, but it is always better to be transparent instead of hiding all the magic what happens behind the scenes.
Security makes sense only if Spring Statemachine runs in a walled
garden where user have no direct access to the application and could consequently
modify Spring Security’s SecurityContext hold in a local thread.
If the user controls the JVM, then effectively there is no security
at all.
The integration point for security is created with a
, which is then automatically added into a
state machine if security is enabled. The specific class is
StateMachineSecurityInterceptor
, which intercepts events and
transitions. This interceptor then consults Spring Security’s
to determine whether an event can be sent or whether a transition can be
executed. Effectively, if a decision or a vote with a AccessDecisionManager
results in an exception, the event or transition is denied.
Due to how AccessDecisionManager
from Spring Security works, we
need one instance of it per secured object. This is one reason why there
are different managers for events and transitions. In this case, events
and transitions are different class objects that we secure.
By default, for events, voters (EventExpressionVoter
, EventVoter
, and
RoleVoter
) are added into an AccessDecisionManager
By default, for transitions, voters (TransitionExpressionVoter
TransitionVoter
, and RoleVoter
27. State Machine Error Handling
If a state machine detects an internal error during a state transition logic, it may throw an exception. Before this exception is processed internally, you are given a chance to intercept.
Normally, you can use StateMachineInterceptor
to intercept errors and the
following listing shows an example of it:
StateMachine<String, String> stateMachine;
void addInterceptor() {
function.addStateMachineInterceptor(new StateMachineInterceptorAdapter<String, String>() {
return exception;
When errors are detected, the normal event notify mechanism is executed.
This lets you use either a StateMachineListener
or a Spring Application
context event listener. For more about these, see
Having said that, the following example shows a simple listener:
public class ErrorStateMachineListener
public void stateMachineError(StateMachine<String, String> stateMachine, Exception exception) {
// do something with error
The following example shows a generic ApplicationListener
checking StateMachineEvent
public class GenericApplicationEventListener
if (event instanceof OnStateMachineError) {
You can also directly define ApplicationListener
to
recognize only StateMachineEvent
instances, as the following example shows:
public class ErrorApplicationEventListener
implements ApplicationListener<OnStateMachineError> {
public void onApplicationEvent(OnStateMachineError event) {
Actions defined for transitions also have their own error handling logic. See Transition Action Error Handling. |
With a reactive api’s it is possible to get Action execution error
back from a StateMachineEventResult. Having simple machine which
errors within action transitioning into state S1
@EnableStateMachine
public void configure(StateMachineStateConfigurer<String, String> states) throws Exception {
states
.withStates()
.initial("SI")
.stateEntry("S1", (context) -> {
throw new RuntimeException("example error");
public void configure(StateMachineTransitionConfigurer<String, String> transitions) throws Exception {
transitions
.withExternal()
.source("SI")
.target("S1")
.event("E1");
Below test concept shows how possible error can be consumed from a StateMachineEventResult.
@Autowired
private StateMachine<String, String> machine;
@Test
public void testActionEntryErrorWithEvent() throws Exception {
StepVerifier.create(machine.startReactively()).verifyComplete();
assertThat(machine.getState().getIds()).containsExactlyInAnyOrder("SI");
StepVerifier.create(machine.sendEvent(Mono.just(MessageBuilder.withPayload("E1").build())))
.consumeNextWith(result -> {
StepVerifier.create(result.complete()).consumeErrorWith(e -> {
assertThat(e).isInstanceOf(StateMachineException.class).cause().hasMessageContaining("example error");
}).verify();
.verifyComplete();
assertThat(machine.getState().getIds()).containsExactlyInAnyOrder("S1");
Error in entry/exit actions will not prevent transition to happen. |
28. State Machine Services
StateMachine services are higher-level implementations meant to
provide more user-level functionalities to ease normal runtime
operations. Currently, only one service interface
(StateMachineService
) exists.
29. Persisting a State Machine
Traditionally, an instance of a state machine is used as is within a running program. You can achieve more dynamic behavior by using dynamic builders and factories, which allows state machine instantiation on-demand. Building an instance of a state machine is a relatively heavy operation. Consequently, if you need to (for example) handle an arbitrary state change in a database by using a state machine, you need to find a better and faster way to do it.
The persist feature lets you save a state of a state machine into an external repository and later reset a state machine based off the serialized state. For example, if you have a database table keeping orders, it would be way too expensive to update an order state with a state machine if a new instance would need to be built for every change. The persist feature lets you reset a state machine state without instantiating a new state machine instance.
There is one recipe (see Persist) and one sample (see Persist) that provide more info about persisting states. |
While you can build a custom persistence feature by using a
, it has one conceptual problem. When a listener
notifies about a change of state, the state change has already happened. If a
custom persistent method within a listener fails to update the serialized
state in an external repository, the state in a state machine and the state in
an external repository are then in an inconsistent state.
You can instead use a state machine interceptor to try to save the
serialized state into external storage during the state
change within a state machine. If this interceptor callback fails,
you can halt the state change attempt and, instead of ending in an
inconsistent state, you can then handle this error manually. See
for how to use interceptors.
29.1. Using StateMachineContext
You cannot persist a StateMachine
by using normal java
serialization, as the object graph is too rich and contains too many
dependencies on other Spring context classes. StateMachineContext
is a runtime representation of a state machine that you can use to
restore an existing machine into a state represented by a particular
StateMachineContext
object.
StateMachineContext
contains two different ways to include information
for a child context. These are generally used when a machine contains
orthogonal regions. First, a context can have a list of child contexts
that can be used as is if they exist. Second, you can
include a list of references that are used if raw context children
are not in place. These child references are really the only way to
persist a machine where multiple parallel regions are running
independently.
The Data Multi Persist sample shows how you can persist parallel regions. |
29.2. Using StateMachinePersister
Building a StateMachineContext
and then restoring a state machine
from it has always been a little bit of “black magic” if done
manually. The StateMachinePersister
interface aims to ease these
operations by providing persist
and restore
methods. The default
implementation of this interface is DefaultStateMachinePersister
We can show how to use a StateMachinePersister
by following
a snippets from tests. We start by creating two similar configurations
(machine1
and machine2
) for a state machine. Note that we could build different
machines for this demonstration in other ways but this way
works for this case. The following example configures the two state machines:
@EnableStateMachine(name = "machine1")
static class Config1 extends Config {
@EnableStateMachine(name = "machine2")
static class Config2 extends Config {
static class Config extends StateMachineConfigurerAdapter<String, String> {
states
.withStates()
.initial("S1")
.state("S1")
.state("S2");
transitions
.withExternal()
.source("S1")
.target("S2")
.event("E1");
As we are using a StateMachinePersist
object, we can create an in-memory
implementation.
This in-memory sample is only for demonstration purposes. For real applications, you should use a real persistent storage implementation. |
The following listing shows how to use the in-memory sample:
static class InMemoryStateMachinePersist implements StateMachinePersist<String, String, String> {
private final HashMap<String, StateMachineContext<String, String>> contexts = new HashMap<>();
public void write(StateMachineContext<String, String> context, String contextObj) throws Exception {
contexts.put(contextObj, context);
public StateMachineContext<String, String> read(String contextObj) throws Exception {
return contexts.get(contextObj);
After we have instantiated the two different machines, we can transfer
machine1
into state S2
through event E1
. Then we can persist it and restore
machine2
InMemoryStateMachinePersist stateMachinePersist = new InMemoryStateMachinePersist();
StateMachinePersister<String, String, String> persister = new DefaultStateMachinePersister<>(stateMachinePersist);
StateMachine<String, String> stateMachine1 = context.getBean("machine1", StateMachine.class);
StateMachine<String, String> stateMachine2 = context.getBean("machine2", StateMachine.class);
stateMachine1.startReactively().block();
stateMachine1
.blockLast();
assertThat(stateMachine1.getState().getIds()).containsExactly("S2");
persister.persist(stateMachine1, "myid");
persister.restore(stateMachine2, "myid");
assertThat(stateMachine2.getState().getIds()).containsExactly("S2");
29.3. Using Redis
RepositoryStateMachinePersist
(which implements
StateMachinePersist
) offers support for persisting a state machine into Redis.
The specific implementation is a
RedisStateMachineContextRepository
, which uses kryo
serialization to
persist a StateMachineContext
into Redis
For StateMachinePersister
, we have a Redis-related
RedisStateMachinePersister
implementation, which takes an instance of
and uses String
as its context object.
See the Event Service sample for detailed usage. |
needs a
RedisConnectionFactory
for it to work. We recommend using a
JedisConnectionFactory
for it, as the preceding example shows.
29.4. Using StateMachineRuntimePersister
is a simple extension to
StateMachinePersist
that adds an interface-level method to get
associated with it. This interceptor is then
required to persist a machine during state changes without needing to
stop and start a machine.
Currently, there are implementations for this interface for the
supported Spring Data Repositories. These implementations are
JpaPersistingStateMachineInterceptor
, MongoDbPersistingStateMachineInterceptor
and RedisPersistingStateMachineInterceptor
See the Data Persist sample for detailed usage. |
30. Spring Boot Support
The auto-configuration module (spring-statemachine-autoconfigure
) contains all
the logic for integrating with Spring Boot, which provides functionality for
auto-configuration and actuators. All you need is to have this Spring Statemachine
library as part of a boot application.
30.1. Monitoring and Tracing
BootStateMachineMonitor
is created automatically and associated with
a state machine. BootStateMachineMonitor
is a custom StateMachineMonitor
implementation that integrates with Spring Boot’s MeterRegistry
and endpoints
through a custom StateMachineTraceRepository
. Optionally, you can disable this auto-configuration
by setting the spring.statemachine.monitor.enabled
key to
false
. The
Monitoring sample shows how to use this auto-configuration.
30.2. Repository Config
If the required classes are found from the classpath, Spring Data Repositories and entity class scanning is automatically auto-configured for Repository Support.
The currently supported configurations are JPA
, Redis
, and
MongoDB
. You can disable repository auto-configuration by using the
spring.statemachine.data.jpa.repositories.enabled
spring.statemachine.data.redis.repositories.enabled
and
spring.statemachine.data.mongo.repositories.enabled
properties, respectively.
31. Monitoring a State Machine
You can use StateMachineMonitor
to get more information about the
durations of how long transitions and actions take to execute. The following listing
shows how this interface is implemented.
public class TestStateMachineMonitor extends AbstractStateMachineMonitor<String, String> {
public void transition(StateMachine<String, String> stateMachine, Transition<String, String> transition,
long duration) {
public void action(StateMachine<String, String> stateMachine,
Function<StateContext<String, String>, Mono<Void>> action, long duration) {
Once you have a StateMachineMonitor
implementation, you can add it to
a state machine through configuration, as the following example shows:
@EnableStateMachine
public class Config1 extends StateMachineConfigurerAdapter<String, String> {
throws Exception {
config
.withMonitoring()
.monitor(stateMachineMonitor());
states
.withStates()
.initial("S1")
.state("S2");
transitions
.withExternal()
.source("S1")
.target("S2")
.event("E1");
public StateMachineMonitor<String, String> stateMachineMonitor() {
return new TestStateMachineMonitor();
See the Monitoring sample for detailed usage. |
32. Using Distributed States
Distributed state is probably one of a most complicated concepts of a Spring state machine. What exactly is a distributed state? A state within a single state machine is naturally really simple to understand, but, when there is a need to introduce a shared distributed state through a state machine, things get a little complicated.
Distributed state functionality is still a preview feature and is not yet considered to be stable in this particular release. We expect this feature to mature towards its first official release. |
For information about generic configuration support, see Configuring Common Settings. For an actual usage example, see the Zookeeper sample.
A distributed state machine is implemented through a
DistributedStateMachine
class that wraps an actual instance
of a StateMachine
. DistributedStateMachine
intercepts
communication with a StateMachine
instance and works with
distributed state abstractions handled through the
StateMachineEnsemble
interface. Depending on the actual implementation,
you can also use the StateMachinePersist
interface to serialize a
StateMachineContext
, which contains enough information to reset a
StateMachine
While a distributed state machine is implemented through an abstraction, only one implementation currently exists. It is based on Zookeeper.
The following example shows how to configure a Zookeeper-based distributed state machine`:
@EnableStateMachine
public class Config
throws Exception {
config
.withDistributed()
.ensemble(stateMachineEnsemble())
.and()
.withConfiguration()
.autoStartup(true);
throws Exception {
// config states
throws Exception {
// config transitions
public StateMachineEnsemble<String, String> stateMachineEnsemble()
throws Exception {
return new ZookeeperStateMachineEnsemble<String, String>(curatorClient(), "/zkpath");
public CuratorFramework curatorClient()
throws Exception {
CuratorFramework client = CuratorFrameworkFactory
.builder()
.defaultData(new byte[0])
.connectString("localhost:2181").build();
client.start();
return client;
You can find the current technical documentation for a Zookeeker-based distributed state machine in the appendix.
32.1. Using ZookeeperStateMachineEnsemble
itself needs two mandatory settings,
an instance of curatorClient
and a basePath
. The client is a
CuratorFramework
, and the path is the root of a tree in a Zookeeper
instance.
Optionally, you can set cleanState
, which defaults to TRUE
and clears existing data if no members exists in an ensemble. You can set
it to FALSE
if you want to preserve distributed state within
application restarts.
Optionally, you can set the size of a logSize
(defaults
to 32
) to a keep history of state changes. The value of this
setting must be a power of two. 32
is generally a good default
value. If a particular state machine is left behind by more than the
size of the log, it is put into an error state and disconnected from the
ensemble, indicating it has lost its history and its ability to fully reconstruct the
synchronized status.
33. Testing Support
We have also added a set of utility classes to ease testing of state machine instances. These are used in the framework itself but are also very useful for end users.
StateMachineTestPlanBuilder
builds a StateMachineTestPlan
which has one method (called test()
). That method runs a plan.
contains a fluent builder API to let you add
steps to a plan. During these steps, you can send events and check
various conditions, such as state changes, transitions, and extended state
variables.
The following example uses StateMachineBuilder
to build a state machine:
private StateMachine<String, String> buildMachine() throws Exception {
StateMachineBuilder.Builder<String, String> builder = StateMachineBuilder.builder();
builder.configureConfiguration()
.autoStartup(true);
builder.configureStates()
.withStates()
.initial("SI")
.state("S1");
builder.configureTransitions()
.withExternal()
.source("SI").target("S1")
.event("E1")
.action(c -> {
c.getExtendedState().getVariables().put("key1", "value1");
return builder.build();
In the following test plan, we have two steps. First, we check that the initial
state (SI
) is indeed set. Second, we send an event (E1
) and expect
one state change to happen and expect the machine to end up in a state of S1
The following listing shows the test plan:
StateMachine<String, String> machine = buildMachine();
StateMachineTestPlan<String, String> plan =
StateMachineTestPlanBuilder.<String, String>builder()
.defaultAwaitTime(2)
.stateMachine(machine)
.step()
.expectStates("SI")
.and()
.step()
.sendEvent("E1")
.expectStateChanged(1)
.expectStates("S1")
.expectVariable("key1")
.expectVariable("key1", "value1")
.expectVariableWith(hasKey("key1"))
.expectVariableWith(hasValue("value1"))
.expectVariableWith(hasEntry("key1", "value1"))
.expectVariableWith(not(hasKey("key2")))
.and()
plan.test();
These utilities are also used within a framework to test distributed state machine features. Note that you can add multiple machines to a plan. If you add multiple machines, you can also choose to send an event a particular machine, a random machine, or all machines.
The preceding testing example uses the following Hamcrest imports:
All possible options for expected results are documented in the Javadoc for
StateMachineTestPlanStepBuilder .
34. Eclipse Modeling Support
Defining a state machine configuration with UI modeling is supported through the Eclipse Papyrus framework.
From the Eclipse wizard, you can create a new Papyrus Model with the UML Diagram
Language. In this example, it is named simple-machine
. Then you
have an option to choose from various diagram kinds, and you must choose a StateMachine
Diagram
We want to create a machine that has two states (S1
and S2
), where
S1
is the initial state. Then, we need to create event E1
to do a transition
from S1
to S2
. In Papyrus, a machine would then look like something
the following example:
Behind the scenes, a raw UML file would look like the following example:
<uml:Model xmi:version="20131001" xmlns:xmi="http://www.omg.org/spec/XMI/20131001" xmlns:uml="http://www.eclipse.org/uml2/5.0.0/UML" xmi:id="_AMP3IP8fEeW45bORGB4c_A" name="RootElement">
<packagedElement xmi:type="uml:StateMachine" xmi:id="_AMRFQP8fEeW45bORGB4c_A" name="StateMachine">
<region xmi:type="uml:Region" xmi:id="_AMRsUP8fEeW45bORGB4c_A" name="Region1">
<transition xmi:type="uml:Transition" xmi:id="_chgcgP8fEeW45bORGB4c_A" source="_EZrg4P8fEeW45bORGB4c_A" target="_FAvg4P8fEeW45bORGB4c_A">
<trigger xmi:type="uml:Trigger" xmi:id="_hs5jUP8fEeW45bORGB4c_A" event="_NeH84P8fEeW45bORGB4c_A"/>
</transition>
<transition xmi:type="uml:Transition" xmi:id="_egLIoP8fEeW45bORGB4c_A" source="_Fg0IEP8fEeW45bORGB4c_A" target="_EZrg4P8fEeW45bORGB4c_A"/>
<subvertex xmi:type="uml:State" xmi:id="_EZrg4P8fEeW45bORGB4c_A" name="S1"/>
<subvertex xmi:type="uml:State" xmi:id="_FAvg4P8fEeW45bORGB4c_A" name="S2"/>
<subvertex xmi:type="uml:Pseudostate" xmi:id="_Fg0IEP8fEeW45bORGB4c_A"/>
</region>
</packagedElement>
<packagedElement xmi:type="uml:Signal" xmi:id="_L01D0P8fEeW45bORGB4c_A" name="E1"/>
<packagedElement xmi:type="uml:SignalEvent" xmi:id="_NeH84P8fEeW45bORGB4c_A" name="SignalEventE1" signal="_L01D0P8fEeW45bORGB4c_A"/>
</uml:Model>
When opening an existing model that has been defined as UML, you have three
files: .di , .notation , and .uml . If a model was not created in your
eclipse’s session, it does not understand how to open an actual state
chart. This is a known issue in the Papyrus plugin, and there is an easy
workaround. In a Papyrus perspective, you can see a model explorer for
your model. Double click Diagram StateMachine Diagram, which
instructs Eclipse to open this specific model in its proper Papyrus
modeling plugin.
34.1. Using UmlStateMachineModelFactory
After a UML file is in place in your project, you can import it into your
configuration by using StateMachineModelConfigurer
, where
is associated with a model.
is a special factory that knows how to
process a Eclipse Papyrus_generated UML structure. The source UML file can
either be given as a Spring Resource
or as a normal location string.
The following example shows how to create an instance of
@EnableStateMachine
public static class Config1 extends StateMachineConfigurerAdapter<String, String> {
public void configure(StateMachineModelConfigurer<String, String> model) throws Exception {
model
.withModel()
.factory(modelFactory());
public StateMachineModelFactory<String, String> modelFactory() {
return new UmlStateMachineModelFactory("classpath:org/springframework/statemachine/uml/docs/simple-machine.uml");
As usual, Spring Statemachine works with guards and actions, which are defined as beans. Those need to be hooked into UML by its internal modeling structure. The following sections show how customized bean references are defined within UML definitions. Note that it is also possible to register particular methods manually without defining those as beans.
If UmlStateMachineModelFactory
is created as a bean, its
ResourceLoader
is automatically wired to find registered actions and
guards. You can also manually define a
StateMachineComponentResolver
, which is then used to find these
components. The factory also has registerAction and
registerGuard methods, which you can use to register these components. For more
about this, see Using StateMachineComponentResolver
A UML model is relatively loose when it comes to an implementation such as Spring Statemachine itself. Spring Statemachine leaves how to implement a lot of features and functionalities up to the actual implementation. The following sections go through how Spring Statemachine implements UML models based on the Eclipse Papyrus plugin.
34.1.1. Using StateMachineComponentResolver
The next example shows how UmlStateMachineModelFactory
is defined with
a StateMachineComponentResolver
, which registers the
myAction
and myGuard
functions, respectively. Note that these components
are not created as beans. The following listing shows the example:
@EnableStateMachine
public static class Config2 extends StateMachineConfigurerAdapter<String, String> {
model
.withModel()
UmlStateMachineModelFactory factory = new UmlStateMachineModelFactory(
factory.setStateMachineComponentResolver(stateMachineComponentResolver());
return factory;
public StateMachineComponentResolver<String, String> stateMachineComponentResolver() {
DefaultStateMachineComponentResolver<String, String> resolver = new DefaultStateMachineComponentResolver<>();
resolver.registerAction("myAction", myAction());
resolver.registerGuard("myGuard", myGuard());
return resolver;
public Action<String, String> myAction() {
public Guard<String, String> myGuard() {
return new Guard<String, String>() {
public boolean evaluate(StateContext<String, String> context) {
return false;
34.2. Creating a Model
We start by creating an empty state machine model, shown in the following image:
You can start by creating a new model and giving it a name, as the following image shows:
Then you need to choose StateMachine Diagram, as follows:
You end up with an empty state machine.
In the preceding images, you should have created a sample named model
You should have wound up with three files: model.di
model.notation
, and model.uml
. You can then used these files in any other
Eclipse instance. Further, you can import model.uml
into a
Spring Statemachine.
34.3. Defining States
The state identifier comes from a component name in a diagram. You must have an initial state in your machine, which you can do by adding a root element and then drawing a transition to your own initial state, as the following image shows:
In the preceding image, we added a root element and an initial state (S1
). Then we drew a transition
between those two to indicate that S1
is an initial state.
In the preceding image, we added a second state (S2
) and added a transition between
S1 and S2 (indicating that we have two states).
34.4. Defining Events
To associate an event with a transition, you need to create a Signal
(E1
, in this case). To do so, choose RootElement → New Child → Signal.
The following image shows the result:
Then you need to crate a SignalEvent with the new Signal, E1
To do so, choose RootElement → New Child → SignalEvent.
Now that you have defined a SignalEvent
, you can use it to associate
a trigger with a transition. For more about that, see
Defining Transitions.
34.5. Defining Transitions
You can create a transition by drawing a transition line between the
source and target states. In the preceding images, we have states S1
and S2
and an
anonymous transition between the two. We want to associate event
E1
with that transition. We choose a transition, create a new
trigger, and define SignalEventE1 for that, as the following image shows:
This gives you something like the arrangement shown in the following image:
If you omit SignalEvent for a transition, it becomes an anonymous transition. |
34.6. Defining Timers
Transitions can also happen based on timed events. Spring Statemachine support two types of timers, ones which fires continuously on a background and ones which fires once with a delay when state is entered.
To add a new TimeEvent child to Model Explorer, modify When as an expression defined as LiteralInteger. The value of it (in milliseconds) becomes the timer. Leave Is Relative false to make the timer fire continuously.
To define one timed based event that triggers when a state is entered, the process is exactly same as described earlier, but leave Is Relative set to true. The following image shows the result:
Then the user can pick one of these timed events instead of a signal event for a particular transition.
34.7. Defining a Choice
A choice is defined by drawing one incoming transition into a
CHOICE state and drawing multiple outgoing transitions from it to target
states. The configuration model in our StateConfigurer
lets you define
an if/elseif/else structure. However, with UML, we need to work with
individual Guards for outgoing transitions.
You must ensure that the guards defined for transitions do not overlap so that, whatever happens, only one guard evaluates to TRUE at any given time. This gives precise and predictable results for choice branch evaluation. Also we recommend leaving one transition without a guard so that at least one transition path is guaranteed. The following image shows the result of making a choice with three branches:
Junction works similarly same, except that it allows multiple incoming transitions. Thus, its behavior compared to Choice is purely academic. The actual logic to select the outgoing transition is exactly the same. |
34.8. Defining a Junction
See Defining a Choice.
34.9. Defining Entry and Exit Points
You can use EntryPoint and ExitPoint to create controlled entry and exit
with states that have sub-states. In the following state chart, events E1
and
E2
have normal state behavior by entering and exiting state
S2
, where normal state behavior happens by entering initial state
S21
Using event E3
takes the machine into the ENTRY
EntryPoint, which then
leads to S22
without activating initial state S21
at any time.
Similarly the EXIT
ExitPoint with event E4
controls the specific exit
into state S4
, while normal exit behavior from S2
would take the
machine into state S3
. While on state S22
, you can choose from
events E4
and E2
to take the machine into states S3
or S4
respectively. The following image shows the result:
If state is defined as a sub-machine reference and you need to use entry and exit points, you must externally define a ConnectionPointReference, with its entry and exit reference set to point to a correct entry or exit point within a submachine reference. Only after that, is it possible to target a transition that correctly links from the outside to the inside of a sub-machine reference. With ConnectionPointReference, you may need to find these settings from Properties → Advanced → UML → Entry/Exit. The UML specification lets you define multiple entries and exits. However, with a state machine, only one is allowed. |
34.10. Defining History States
When working with history states, three different concepts are in play. UML defines a Deep History and a Shallow History. The Default History State comes into play when history state is not yet known. These are represented in following sections.
34.10.1. Shallow History
In the following image, Shallow History is selected and a transition is defined into it:
34.10.2. Deep History
Deep History is used for state that has other deep nested states, thus giving a chance to save whole nested state structure. The following image shows a definition that uses Deep History:
34.10.3. Default History
In cases where a Transition terminates on a history when
the state has not been entered before it had reached its
final state, there is an option to force
a transition to a specific substate, using the default
history mechanism. For this to happen, you must define a transition
into this default state. This is the transition from SH
to
S22
In the following image, state S22
is entered if state S2
has
never been active, as its history has never been recorded. If state
S2
has been active, then either S20
or S21
gets chosen.
34.11. Defining Forks and Joins
Both Fork and Join are represented as bars in Papyrus. As shown
in the next image, you need to draw one outgoing transition from FORK
into state
S2
to have orthogonal regions. JOIN
is then the reverse, where
joined states are collected together from incoming transitions.
34.12. Defining Actions
You can assoiate swtate entry and exit actions by using a behavior. For more about this, see Defining a Bean Reference.
34.12.1. Using an Initial Action
An initial action (as shown in Configuring Actions) is defined in UML by adding an action in the transition that leads from the Initial State marker into the actual state. This Action is then run when the state machine is started.
34.13. Defining Guards
You can define a guard by first adding a Constraint and then defining its Specification as OpaqueExpression, which works in the same way as Defining a Bean Reference.
34.14. Defining a Bean Reference
When you need to make a bean reference in any UML effect,
action, or guard, you can do so with
FunctionBehavior
or OpaqueBehavior
, where the defined language needs to
be bean
and the language body msut have a bean reference id.
34.15. Defining a SpEL Reference
When you need to use a SpEL expression instead of a bean reference in
any UML effect, action, or guard, you can do so by using
FunctionBehavior
or OpaqueBehavior
be spel
and the language body must be a SpEL expression.
34.16. Using a Sub-Machine Reference
Normally, when you use sub-states, you draw those into the state chart itself. The chart may become too complex and big to follow, so we also support defining a sub-state as a state machine reference.
To create a sub-machine reference, you must first create a new diagram and give it a name (for example, SubStateMachine Diagram). The following image shows the menu choices to use:
Give the new diagram the design you need. The following image shows a simple design as an example:
From the state you want to link (in this case,m state S2
), click the
Submachine
field and choose your linked machine (in our example,
SubStateMachine
Finally, in the following image, you can see that state S2
is linked to SubStateMachine
as a
sub-state.
34.17. Using a Machine Import
It’s also possible to use import functionality where uml files can reference to other models.
Within UmlStateMachineModelFactory
it’s possible to use additional resources or locations
to define referenced model files.
@EnableStateMachine
public static class Config3 extends StateMachineConfigurerAdapter<String, String> {
model
.withModel()
"classpath:org/springframework/statemachine/uml/import-main/import-main.uml",
new String[] { "classpath:org/springframework/statemachine/uml/import-sub/import-sub.uml" });
Links between files in uml models needs to be relative as otherwise things break when model files are copied out from a classpath to a temporary directory so that eclipse parsing classes can read those. |
35. Repository Support
This section contains documentation related to using 'Spring Data Repositories' in Spring Statemachine.
35.1. Repository Configuration
You can keep machine configuration in external storage, from which it can be loaded on demand, instead of creating a static configuration by using either Java configuration or UML-based configuration. This integration works through a Spring Data Repository abstraction.
We have created a special StateMachineModelFactory
implementation
called RepositoryStateMachineModelFactory
. It can use the base
repository interfaces (StateRepository
, TransitionRepository
ActionRepository
and GuardRepository
) and base entity
interfaces (RepositoryState
, RepositoryTransition
RepositoryAction
, and RepositoryGuard
Due to way how entities and repositories work in Spring Data,
from a user perspective, read access can be fully abstracted as it is
done in RepositoryStateMachineModelFactory
. There is no need to
know the actual mapped entity class with which a repository works.
Writing into a repository is always dependent on using a real
repository-specific entity class. From a machine-configuration point
of view, we do not need to know these, meaning that we do not need to know
whether the actual implementation is JPA, Redis, or anything else
that Spring Data supports. Using an actual repository-related
entity class comes into play when you manually try to write new
states or transitions into a backed repository.
Entity classes for RepositoryState and RepositoryTransition have a
machineId field, which is at your disposal and can be used to
differentiate between configurations — for example, if machines are built
via StateMachineFactory .
Actual implementations are documented in later sections. The following images are UML-equivalent state charts of repository configurations.
35.1.1. JPA
The actual repository implementations for JPA are
JpaStateRepository
, JpaTransitionRepository
, JpaActionRepository
and JpaGuardRepository
, which are backed by the
entity classes JpaRepositoryState
, JpaRepositoryTransition
JpaRepositoryAction
, and JpaRepositoryGuard
, respectively.
Unfortunately, version '1.2.8' had to make a change in JPA’s entity
model regarding used table names. Previously, generated table names
always had a prefix of JPA_REPOSITORY_ , derived from entity class
names. As this caused breaking issues with databases imposing
restrictions on database object lengths, all entity classes have
spesific definitions to force table names. For example,
JPA_REPOSITORY_STATE is now 'STATE' — and so on with other
ntity classes.
The generic way to update states and transitions manually for JPA is shown in the following example (equivalent to the machine shown in SimpleMachine):
@Autowired
StateRepository<JpaRepositoryState> stateRepository;
@Autowired
TransitionRepository<JpaRepositoryTransition> transitionRepository;
void addConfig() {
JpaRepositoryState stateS1 = new JpaRepositoryState("S1", true);
JpaRepositoryState stateS2 = new JpaRepositoryState("S2");
JpaRepositoryState stateS3 = new JpaRepositoryState("S3");
stateRepository.save(stateS1);
stateRepository.save(stateS2);
stateRepository.save(stateS3);
JpaRepositoryTransition transitionS1ToS2 = new JpaRepositoryTransition(stateS1, stateS2, "E1");
JpaRepositoryTransition transitionS2ToS3 = new JpaRepositoryTransition(stateS2, stateS3, "E2");
transitionRepository.save(transitionS1ToS2);
transitionRepository.save(transitionS2ToS3);
The following example is also equivalent to the machine shown in SimpleSubMachine.
@Autowired
@Autowired
void addConfig() {
JpaRepositoryState stateS21 = new JpaRepositoryState("S21", true);
stateS21.setParentState(stateS2);
JpaRepositoryState stateS22 = new JpaRepositoryState("S22");
stateS22.setParentState(stateS2);
stateRepository.save(stateS21);
stateRepository.save(stateS22);
JpaRepositoryTransition transitionS2ToS3 = new JpaRepositoryTransition(stateS21, stateS22, "E2");
JpaRepositoryTransition transitionS21ToS22 = new JpaRepositoryTransition(stateS2, stateS3, "E3");
transitionRepository.save(transitionS21ToS22);
First, you must access all repositories. The following example shows how to do so:
@Autowired
@Autowired
@Autowired
ActionRepository<JpaRepositoryAction> actionRepository;
@Autowired
GuardRepository<JpaRepositoryGuard> guardRepository;
Second, you mus create actions and guards. The following example shows how to do so:
JpaRepositoryGuard foo0Guard = new JpaRepositoryGuard();
foo0Guard.setName("foo0Guard");
JpaRepositoryGuard foo1Guard = new JpaRepositoryGuard();
foo1Guard.setName("foo1Guard");
JpaRepositoryAction fooAction = new JpaRepositoryAction();
fooAction.setName("fooAction");
guardRepository.save(foo0Guard);
guardRepository.save(foo1Guard);
actionRepository.save(fooAction);
Third, you must create states. The following example shows how to do so:
JpaRepositoryState stateS0 = new JpaRepositoryState("S0", true);
stateS0.setInitialAction(fooAction);
stateS1.setParentState(stateS0);
JpaRepositoryState stateS11 = new JpaRepositoryState("S11", true);
stateS11.setParentState(stateS1);
JpaRepositoryState stateS12 = new JpaRepositoryState("S12");
stateS12.setParentState(stateS1);
stateS2.setParentState(stateS0);
JpaRepositoryState stateS211 = new JpaRepositoryState("S211", true);
stateS211.setParentState(stateS21);
JpaRepositoryState stateS212 = new JpaRepositoryState("S212");
stateS212.setParentState(stateS21);
stateRepository.save(stateS0);
stateRepository.save(stateS11);
stateRepository.save(stateS12);
stateRepository.save(stateS211);
stateRepository.save(stateS212);
Fourth and finally, you must create transitions. The following example shows how to do so:
JpaRepositoryTransition transitionS1ToS1 = new JpaRepositoryTransition(stateS1, stateS1, "A");
transitionS1ToS1.setGuard(foo1Guard);
JpaRepositoryTransition transitionS1ToS11 = new JpaRepositoryTransition(stateS1, stateS11, "B");
JpaRepositoryTransition transitionS21ToS211 = new JpaRepositoryTransition(stateS21, stateS211, "B");
JpaRepositoryTransition transitionS1ToS2 = new JpaRepositoryTransition(stateS1, stateS2, "C");
JpaRepositoryTransition transitionS1ToS0 = new JpaRepositoryTransition(stateS1, stateS0, "D");
JpaRepositoryTransition transitionS211ToS21 = new JpaRepositoryTransition(stateS211, stateS21, "D");
JpaRepositoryTransition transitionS0ToS211 = new JpaRepositoryTransition(stateS0, stateS211, "E");
JpaRepositoryTransition transitionS1ToS211 = new JpaRepositoryTransition(stateS1, stateS211, "F");
JpaRepositoryTransition transitionS2ToS21 = new JpaRepositoryTransition(stateS2, stateS21, "F");
JpaRepositoryTransition transitionS11ToS211 = new JpaRepositoryTransition(stateS11, stateS211, "G");
JpaRepositoryTransition transitionS0 = new JpaRepositoryTransition(stateS0, stateS0, "H");
transitionS0.setKind(TransitionKind.INTERNAL);
transitionS0.setGuard(foo0Guard);
transitionS0.setActions(new HashSet<>(Arrays.asList(fooAction)));
JpaRepositoryTransition transitionS1 = new JpaRepositoryTransition(stateS1, stateS1, "H");
transitionS1.setKind(TransitionKind.INTERNAL);
JpaRepositoryTransition transitionS2 = new JpaRepositoryTransition(stateS2, stateS2, "H");
transitionS2.setKind(TransitionKind.INTERNAL);
transitionS2.setGuard(foo1Guard);
transitionS2.setActions(new HashSet<>(Arrays.asList(fooAction)));
JpaRepositoryTransition transitionS11ToS12 = new JpaRepositoryTransition(stateS11, stateS12, "I");
JpaRepositoryTransition transitionS12ToS212 = new JpaRepositoryTransition(stateS12, stateS212, "I");
JpaRepositoryTransition transitionS211ToS12 = new JpaRepositoryTransition(stateS211, stateS12, "I");
JpaRepositoryTransition transitionS11 = new JpaRepositoryTransition(stateS11, stateS11, "J");
JpaRepositoryTransition transitionS2ToS1 = new JpaRepositoryTransition(stateS2, stateS1, "K");
transitionRepository.save(transitionS1ToS1);
transitionRepository.save(transitionS1ToS11);
transitionRepository.save(transitionS21ToS211);
transitionRepository.save(transitionS1ToS0);
transitionRepository.save(transitionS211ToS21);
transitionRepository.save(transitionS0ToS211);
transitionRepository.save(transitionS1ToS211);
transitionRepository.save(transitionS2ToS21);
transitionRepository.save(transitionS11ToS211);
transitionRepository.save(transitionS0);
transitionRepository.save(transitionS1);
transitionRepository.save(transitionS2);
transitionRepository.save(transitionS11ToS12);
transitionRepository.save(transitionS12ToS212);
transitionRepository.save(transitionS211ToS12);
transitionRepository.save(transitionS11);
transitionRepository.save(transitionS2ToS1);
You can find a complete example here. This example also shows how you can pre-populate a repository from an existing JSON file that has definitions for entity classes.
35.1.2. Redis
The actual repository implementations for a Redis instance are
RedisStateRepository
, RedisTransitionRepository
, RedisActionRepository
and RedisGuardRepository
entity classes RedisRepositoryState
, RedisRepositoryTransition
RedisRepositoryAction
, and RedisRepositoryGuard
, respectively.
The next example shows the generic way to manually update states and transitions for Redis. This is equivalent to machine shown in SimpleMachine.
@Autowired
StateRepository<RedisRepositoryState> stateRepository;
@Autowired
TransitionRepository<RedisRepositoryTransition> transitionRepository;
void addConfig() {
RedisRepositoryState stateS1 = new RedisRepositoryState("S1", true);
RedisRepositoryState stateS2 = new RedisRepositoryState("S2");
RedisRepositoryState stateS3 = new RedisRepositoryState("S3");
RedisRepositoryTransition transitionS1ToS2 = new RedisRepositoryTransition(stateS1, stateS2, "E1");
RedisRepositoryTransition transitionS2ToS3 = new RedisRepositoryTransition(stateS2, stateS3, "E2");
The following example is equivalent to machine shown in SimpleSubMachine:
@Autowired
@Autowired
void addConfig() {
35.1.3. MongoDB
The actual repository implementations for a MongoDB instance are
MongoDbStateRepository
, MongoDbTransitionRepository
, MongoDbActionRepository
and MongoDbGuardRepository
entity classes MongoDbRepositoryState
, MongoDbRepositoryTransition
MongoDbRepositoryAction
, and MongoDbRepositoryGuard
, respectively.
The next example shows the generic way to manually update states and transitions for MongoDB. This is equivalent to the machine shown in SimpleMachine.
@Autowired
StateRepository<MongoDbRepositoryState> stateRepository;
@Autowired
TransitionRepository<MongoDbRepositoryTransition> transitionRepository;
void addConfig() {
MongoDbRepositoryState stateS1 = new MongoDbRepositoryState("S1", true);
MongoDbRepositoryState stateS2 = new MongoDbRepositoryState("S2");
MongoDbRepositoryState stateS3 = new MongoDbRepositoryState("S3");
MongoDbRepositoryTransition transitionS1ToS2 = new MongoDbRepositoryTransition(stateS1, stateS2, "E1");
MongoDbRepositoryTransition transitionS2ToS3 = new MongoDbRepositoryTransition(stateS2, stateS3, "E2");
The following example is equivalent to the machine shown in SimpleSubMachine.
@Autowired
@Autowired
void addConfig() {
MongoDbRepositoryState stateS21 = new MongoDbRepositoryState("S21", true);
MongoDbRepositoryState stateS22 = new MongoDbRepositoryState("S22");
MongoDbRepositoryTransition transitionS2ToS3 = new MongoDbRepositoryTransition(stateS21, stateS22, "E2");
MongoDbRepositoryTransition transitionS21ToS22 = new MongoDbRepositoryTransition(stateS2, stateS3, "E3");
35.2. Repository Persistence
Apart from storing machine configuration (as shown in Repository Configuration), in an external repository, you canx also persist machines into repositories.
The StateMachineRepository
interface is a central access point that
interacts with machine persistence and is backed by the entity class
35.2.1. JPA
The actual repository implementation for JPA is
JpaStateMachineRepository
, which is backed by the entity class
JpaRepositoryStateMachine
The following example shows the generic way to persist a machine for JPA:
@Autowired
StateMachineRepository<JpaRepositoryStateMachine> stateMachineRepository;
void persist() {
JpaRepositoryStateMachine machine = new JpaRepositoryStateMachine();
machine.setMachineId("machine");
machine.setState("S1");
// raw byte[] representation of a context
machine.setStateMachineContext(new byte[] { 0 });
stateMachineRepository.save(machine);
35.2.2. Redis
The actual repository implementation for a Redis is
RedisStateMachineRepository
RedisRepositoryStateMachine
The following example shows the generic way to persist a machine for Redis:
@Autowired
StateMachineRepository<RedisRepositoryStateMachine> stateMachineRepository;
void persist() {
RedisRepositoryStateMachine machine = new RedisRepositoryStateMachine();
35.2.3. MongoDB
The actual repository implementation for MongoDB is
MongoDbStateMachineRepository
MongoDbRepositoryStateMachine
The following example shows the generic way to persist a machine for MongoDB:
@Autowired
StateMachineRepository<MongoDbRepositoryStateMachine> stateMachineRepository;
void persist() {
MongoDbRepositoryStateMachine machine = new MongoDbRepositoryStateMachine();
