For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
ListView
ListView is a base implementation providing functionality to draw a list of items. Inherits BoxView.spring-doc.cn
ListView<T> is typed as its item and can take any object. Further item processing happens in a CellFactory. For conveniance there is a support for generic higher level list feature showing checked states as normal check and radio types. Essentially what you can have is a list of items which are shown as is, shown where any items can have a checked state or only one item can have a checked state.spring-doc.cn
ListView<String> view = new ListView<>();
view.setItems(List.of("item1", "item2"));
Default item style is nocheck but can be changed.spring-doc.cn
Supports NOCHECK, `CHECK and `RADIO`spring-doc.cn
ListView<String> view = new ListView<>(ItemStyle.CHECKED);
Customisation
How individual cells are shown depends on a CellFactory. Default implementation simply shows item using its toString() method.spring-doc.cn
It can be customised by modifying a used CellFactory.spring-doc.cn
record ExampleData(String name) {
static class ExampleListCell extends AbstractListCell<ExampleData> {
	public ExampleListCell(ExampleData item) {
		super(item);
	public void draw(Screen screen) {
		Rectangle rect = getRect();
		Writer writer = screen.writerBuilder().style(getStyle()).build();
		writer.text(getItem().name(), rect.x(), rect.y());
		writer.background(rect, getBackgroundColor());
And set it as a factory:spring-doc.cn
ListView<ExampleData> view = new ListView<>();
view.setCellFactory((list, item) -> new ExampleListCell(item));
Default Bindings
Default view commands are:spring-doc.cn
Table 1. ViewCommands
Command Description
LINE_UPspring-doc.cn
Selection moves up.spring-doc.cn
LINE_DOWNspring-doc.cn
Selection moves down.spring-doc.cn
Default key bindigs are:spring-doc.cn
Table 2. Key
Command Description
CursorUpspring-doc.cn
Bound ViewCommand LINE_UPspring-doc.cn
CursorDownspring-doc.cn
Bound ViewCommand LINE_DOWNspring-doc.cn
Enterspring-doc.cn
Choose active item.spring-doc.cn
Spacespring-doc.cn
Change active item selection state.spring-doc.cn
Default mouse bindigs are:spring-doc.cn
Table 3. Mouse
Command Description
Wheel | WheelUpspring-doc.cn
Wheel | WheelDownspring-doc.cn
Released | Button1spring-doc.cn
Choose itemspring-doc.cn
Events
Events are sent depending on a used list type.spring-doc.cn
Table 4. ListView Events
Event Description
ListViewOpenSelectedItemEventspring-doc.cn
Active item is requested to get opened.spring-doc.cn
ListViewSelectedItemChangedEventspring-doc.cn
Active item is changed.spring-doc.cn
