This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Session 3.4.2! |
Spring Session and Spring Security with Hazelcast
This guide describes how to use Spring Session along with Spring Security when you use Hazelcast as your data store. It assumes that you have already applied Spring Security to your application.
You cand find the completed guide in the Hazelcast Spring Security sample application. |
Updating Dependencies
Before you use Spring Session, you must update your dependencies. If you use Maven, you must add the following dependencies:
<dependencies>
<dependency>
<groupId>com.hazelcast</groupId>
<artifactId>hazelcast</artifactId>
<version>5.4.0</version>
</dependency>
<dependency>
<groupId>org.springframework</groupId>
<artifactId>spring-web</artifactId>
<version>6.2.4</version>
</dependency>
</dependencies>
Spring Configuration
After adding the required dependencies, we can create our Spring configuration.
The Spring configuration is responsible for creating a servlet filter that replaces the HttpSession
implementation with an implementation backed by Spring Session.
To do so, add the following Spring Configuration:
@EnableHazelcastHttpSession (1)
public class HazelcastHttpSessionConfig {
public HazelcastInstance hazelcastInstance() {
Config config = new Config();
AttributeConfig attributeConfig = new AttributeConfig()
.setName(HazelcastIndexedSessionRepository.PRINCIPAL_NAME_ATTRIBUTE)
.setExtractorClassName(PrincipalNameExtractor.class.getName());
config.getMapConfig(HazelcastIndexedSessionRepository.DEFAULT_SESSION_MAP_NAME) (2)
.addAttributeConfig(attributeConfig)
.addIndexConfig(
new IndexConfig(IndexType.HASH, HazelcastIndexedSessionRepository.PRINCIPAL_NAME_ATTRIBUTE));
SerializerConfig serializerConfig = new SerializerConfig();
serializerConfig.setImplementation(new HazelcastSessionSerializer()).setTypeClass(MapSession.class);
config.getSerializationConfig().addSerializerConfig(serializerConfig); (3)
return Hazelcast.newHazelcastInstance(config); (4)
1 | The @EnableHazelcastHttpSession annotation creates a Spring bean named springSessionRepositoryFilter that implements Filter .
The filter is in charge of replacing the HttpSession implementation to be backed by Spring Session.
In this instance, Spring Session is backed by Hazelcast. |
2 | In order to support retrieval of sessions by principal name index, an appropriate ValueExtractor needs to be registered.
Spring Session provides PrincipalNameExtractor for this purpose. |
3 | In order to serialize MapSession objects efficiently, HazelcastSessionSerializer needs to be registered. If this
is not set, Hazelcast will serialize sessions using native Java serialization. |
4 | We create a HazelcastInstance that connects Spring Session to Hazelcast.
By default, the application starts and connects to an embedded instance of Hazelcast.
For more information on configuring Hazelcast, see the reference documentation. |
If HazelcastSessionSerializer is preferred, it needs to be configured for all Hazelcast cluster members before they start.
In a Hazelcast cluster, all members should use the same serialization method for sessions. Also, if Hazelcast Client/Server topology
is used, then both members and clients must use the same serialization method. The serializer can be registered via ClientConfig
with the same SerializerConfiguration of members.
Servlet Container Initialization
Our Spring Configuration created a Spring bean named springSessionRepositoryFilter
The springSessionRepositoryFilter
bean is responsible for replacing the HttpSession
with a custom implementation that is backed by Spring Session.
In order for our Filter
to do its magic, Spring needs to load our SessionConfig
class.
Since our application is already loading Spring configuration by using our SecurityInitializer
class, we can add our SessionConfig
class to it.
The following listing shows how to do so:
public class SecurityInitializer extends AbstractSecurityWebApplicationInitializer {
public SecurityInitializer() {
super(SecurityConfig.class, SessionConfig.class);
Last, we need to ensure that our Servlet Container (that is, Tomcat) uses our springSessionRepositoryFilter
for every request.
It is extremely important that Spring Session’s springSessionRepositoryFilter
is invoked before Spring Security’s springSecurityFilterChain
Doing so ensures that the HttpSession
that Spring Security uses is backed by Spring Session.
Fortunately, Spring Session provides a utility class named AbstractHttpSessionApplicationInitializer
that makes this doing so easy.
The following example shows how to do so:
public class Initializer extends AbstractHttpSessionApplicationInitializer {
The name of our class (Initializer ) does not matter. What is important is that we extend AbstractHttpSessionApplicationInitializer .
By extending AbstractHttpSessionApplicationInitializer
, we ensure that the Spring Bean named springSessionRepositoryFilter
is registered with our servlet container for every request before Spring Security’s springSecurityFilterChain
Hazelcast Spring Security Sample Application
This section describes how to work with the Hazelcast Spring Security sample application.
Running the Sample Application
You can run the sample by obtaining the source code and invoking the following command:
$ ./gradlew :spring-session-sample-javaconfig-hazelcast:tomcatRun
By default, Hazelcast runs in embedded mode with your application. However, if you want to connect to a standalone instance instead, you can configure it by following the instructions in the reference documentation. |
You should now be able to access the application at localhost:8080/
Exploring the Security Sample Application
You can now try using the application. To do so, enter the following to log in:
Username user
Password password
Now click the Login button.
You should now see a message indicating that your are logged in with the user entered previously.
The user’s information is stored in Hazelcast rather than Tomcat’s HttpSession
implementation.
How Does It Work?
Instead of using Tomcat’s HttpSession
, we persist the values in Hazelcast.
Spring Session replaces the HttpSession
with an implementation that is backed by a Map
in Hazelcast.
When Spring Security’s SecurityContextPersistenceFilter
saves the SecurityContext
to the HttpSession
, it is then persisted into Hazelcast.
Interacting with the Data Store
You can remove the session by using a Java client, one of the other clients, or the management center.
Using the Console
For example, to remove the session by using the management center console after connecting to your Hazelcast node, run the following commands:
default> ns spring:session:sessions spring:session:sessions> m.clear
The Hazelcast documentation has instructions for the console. |
Alternatively, you can also delete the explicit key. Enter the following into the console, being sure to replace 7e8383a4-082c-4ffe-a4bc-c40fd3363c5e
with the value of your SESSION
cookie:
spring:session:sessions> m.remove 7e8383a4-082c-4ffe-a4bc-c40fd3363c5e
Now visit the application at localhost:8080/ and observe that we are no longer authenticated.
Using the REST API
As described in the section of the documentation that cover other clients, there is a REST API provided by the Hazelcast node(s).
For example, you could delete an individual key as follows (being sure to replace 7e8383a4-082c-4ffe-a4bc-c40fd3363c5e
with the value of your SESSION cookie):
$ curl -v -X DELETE http://localhost:xxxxx/hazelcast/rest/maps/spring:session:sessions/7e8383a4-082c-4ffe-a4bc-c40fd3363c5e
The port number of the Hazelcast node is printed to the console on startup. Replace xxxxx with the port number.
Now you can see that you are no longer authenticated with this session.
