This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Session 3.4.2!spring-doc.cn
Spring Session - find by username
This guide describes how to use Spring Session to find sessions by username.spring-doc.cn
You can find the completed guide in the findbyusername application.
Assumptions
The guide assumes you have already added Spring Session to your application by using the built-in Redis configuration support. The guide also assumes you have already applied Spring Security to your application. However, the guide is somewhat general purpose and can be applied to any technology with minimal changes, which we discuss later in the guide.spring-doc.cn
If you need to learn how to add Spring Session to your project, see the listing of samples and guides
About the Sample
Our sample uses this feature to invalidate the users session that might have been compromised. Consider the following scenario:spring-doc.cn
  • User goes to library and authenticates to the application.spring-doc.cn
  • User goes home and realizes they forgot to log out.spring-doc.cn
  • User can log in and end the session from the library using clues like the location, created time, last accessed time, and so on.spring-doc.cn
Would it not be nice if we could let the user invalidate the session at the library from any device with which they authenticate? This sample demonstrates how this is possible.spring-doc.cn
Using FindByIndexNameSessionRepository
To look up a user by their username, you must first choose a SessionRepository that implements FindByIndexNameSessionRepository. Our sample application assumes that the Redis support is already set up, so we are ready to go.spring-doc.cn
Mapping the User Name
FindByIndexNameSessionRepository can find a session only by the user name if the developer instructs Spring Session what user is associated with the Session. You can do so by ensuring that the session attribute with the name FindByUsernameSessionRepository.PRINCIPAL_NAME_INDEX_NAME is populated with the username.spring-doc.cn
Generally speaking, you can do so with the following code immediately after the user authenticates:spring-doc.cn
String username = "username";
this.session.setAttribute(FindByIndexNameSessionRepository.PRINCIPAL_NAME_INDEX_NAME, username);
Mapping the User Name with Spring Security
Since we use Spring Security, the user name is automatically indexed for us. This means we need not perform any steps to ensure the user name is indexed.spring-doc.cn
Adding Additional Data to the Session
It may be nice to associate additional information (such as the IP Address, the browser, location, and other details) to the session. Doing so makes it easier for the user to know which session they are looking at.spring-doc.cn
To do so, determine which session attribute you want to use and what information you wish to provide. Then create a Java bean that is added as a session attribute. For example, our sample application includes the location and access type of the session, as the following listing shows:spring-doc.cn
public class SessionDetails implements Serializable {
	private String location;
	private String accessType;
	public String getLocation() {
		return this.location;
	public void setLocation(String location) {
		this.location = location;
	public String getAccessType() {
		return this.accessType;
	public void setAccessType(String accessType) {
		this.accessType = accessType;
	private static final long serialVersionUID = 8850489178248613501L;
We then inject that information into the session on each HTTP request using a SessionDetailsFilter, as the following example shows:spring-doc.cn
public void doFilterInternal(HttpServletRequest request, HttpServletResponse response, FilterChain chain)
		throws IOException, ServletException {
	chain.doFilter(request, response);
	HttpSession session = request.getSession(false);
	if (session != null) {
		String remoteAddr = getRemoteAddress(request);
		String geoLocation = getGeoLocation(remoteAddr);
		SessionDetails details = new SessionDetails();
		details.setAccessType(request.getHeader("User-Agent"));
		details.setLocation(remoteAddr + " " + geoLocation);
		session.setAttribute("SESSION_DETAILS", details);
We obtain the information we want and then set the SessionDetails as an attribute in the Session. When we retrieve the Session by user name, we can then use the session to access our SessionDetails as we would any other session attribute.spring-doc.cn
You might wonder why Spring Session does not provide SessionDetails functionality out of the box. We have two reasons. The first reason is that it is very trivial for applications to implement this themselves. The second reason is that the information that is populated in the session (and how frequently that information is updated) is highly application-dependent.
Finding sessions for a specific user
We can now find all the sessions for a specific user. The following example shows how to do so:spring-doc.cn
@Autowired
FindByIndexNameSessionRepository<? extends Session> sessions;
@RequestMapping("/")
public String index(Principal principal, Model model) {
	Collection<? extends Session> usersSessions = this.sessions.findByPrincipalName(principal.getName()).values();
	model.addAttribute("sessions", usersSessions);
	return "index";
In our instance, we find all sessions for the currently logged in user. However, you can modify this for an administrator to use a form to specify which user to look up.spring-doc.cn
findbyusername Sample Application
This section describes how to use the findbyusername sample application.spring-doc.cn
Running the findbyusername Sample Application
You can run the sample by obtaining the source code and invoking the following command:spring-doc.cn
$ ./gradlew :spring-session-sample-boot-findbyusername:bootRun
For the sample to work, you must install Redis 2.8+ on localhost and run it with the default port (6379). Alternatively, you can update the RedisConnectionFactory to point to a Redis server. Another option is to use Docker to run Redis on localhost. See Docker Redis repository for detailed instructions.
You should now be able to access the application at localhost:8080/spring-doc.cn
Exploring the security Sample Application
You can now try using the application. Enter the following to log in:spring-doc.cn
Now click the Login button. You should now see a message indicating your are logged in with the user entered previously. You should also see a listing of active sessions for the currently logged in user.spring-doc.cn
You can emulate the flow we discussed in the About the Sample section by doing the following:spring-doc.cn
