Reactive Support
The framework provides a Reactive counterpart for almost all supported features.spring-doc.cn
If you put the word Reactive in front of a provided imperative component, you will likely find its Reactive counterpart.spring-doc.cn
However, the following is not yet supported:spring-doc.cn
Preface
We recommend using a Spring-Boot-First approach for Spring for Apache Pulsar-based applications, as that simplifies things tremendously. To do so, you can add the spring-pulsar-reactive-spring-boot-starter module as a dependency.
The majority of this reference expects the reader to be using the starter and gives most directions for configuration with that in mind. However, an effort is made to call out when instructions are specific to the Spring Boot starter usage.
