此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring LDAP 3.2.11spring-doc.cadn.net.cn
高级 LDAP 查询
本节介绍了如何将 LDAP 查询与 Spring LDAP 一起使用的各种方法。spring-doc.cadn.net.cn
LDAP 查询生成器参数
LdapQueryBuilder及其关联的类旨在支持可提供给 LDAP 搜索的所有参数。 支持以下参数:spring-doc.cadn.net.cn
LdapQueryBuilder是通过调用querymethod 的LdapQueryBuilder.它旨在用作 Fluent Builder API,其中首先定义基本参数,然后定义过滤器规范调用。开始后,通过调用wheremethod 的LdapQueryBuilder,稍后尝试调用 (例如)base被拒绝。基本搜索参数是可选的,但至少需要一个过滤器规范调用。 以下查询搜索对象类为Person:spring-doc.cadn.net.cn
示例 1.搜索具有 object class 的所有条目Person
import static org.springframework.ldap.query.LdapQueryBuilder.query;
List<Person> persons = ldapClient.search()
      .query(query().where("objectclass").is("person"))
      .toList(new PersonAttributesMapper());
The following query searches for all entries with an object class of person and a cn (common name) of John Doe:spring-doc.cadn.net.cn
Example 2. Search for all entries with object class person and cn=John Doe
      .query(query().where("objectclass").is("person").and("cn").is("John Doe"))
The following query searches for all entries with an object class of person and starting at a dc (domain component) of dc=261consulting,dc=com:spring-doc.cadn.net.cn
Example 3. Search for all entries with object class person starting at dc=261consulting,dc=com
      .query(query().base("dc=261consulting,dc=com").where("objectclass").is("person"))
The following query returns the cn (common name) attribute for all entries with an object class of person and starting at a dc (domain component) of dc=261consulting,dc=com:spring-doc.cadn.net.cn
Example 4. Search for all entries with class Person starting at dc=261consulting,dc=com, returning only the cn attribute
Stream<Person> persons = ldapClient.search()
             .attributes("cn")
             .where("objectclass").is("person")),
      .toStream(new PersonAttributesMapper());
The following query uses or to search for multiple spellings of a common name (cn):spring-doc.cadn.net.cn
Example 5. Search with or criteria
      .query(query().where("objectclass").is("person"),
             .and(query().where("cn").is("Doe").or("cn").is("Doo"))
Filter Criteria
The earlier examples demonstrate simple equals conditions in LDAP filters. The LDAP query builder has support for the following criteria types:spring-doc.cadn.net.cn
  • is: Specifies an equals (=) condition.spring-doc.cadn.net.cn
  • gte: Specifies a greater-than-or-equals (>=) condition.spring-doc.cadn.net.cn
  • lte: Specifies a less-than-or-equals (⇐) condition.spring-doc.cadn.net.cn
  • like: Specifies a “like” condition where wildcards can be included in the query — for example, where("cn").like("J*hn Doe") results in the following filter: (cn=J*hn Doe).spring-doc.cadn.net.cn
  • whitespaceWildcardsLike: Specifies a condition where all whitespace is replaced with wildcards — for example, where("cn").whitespaceWildcardsLike("John Doe") results in the following filter: (cn=John*Doe).spring-doc.cadn.net.cn
  • isPresent: Specifies a condition that checks for the presence of an attribute — for example, where("cn").isPresent() results in the following filter: (cn=*).spring-doc.cadn.net.cn
  • not: Specifies that the current condition should be negated — for example, where("sn").not().is("Doe) results in the following filter: (!(sn=Doe))spring-doc.cadn.net.cn
Hardcoded Filters
There may be occasions when you want to specify a hardcoded filter as input to an LdapQuery. LdapQueryBuilder has two methods for this purpose:spring-doc.cadn.net.cn
  • filter(String hardcodedFilter): Uses the specified string as a filter. Note that the specified input string is not touched in any way, meaning that this method is not particularly well suited if you are building filters from user input.spring-doc.cadn.net.cn
  • filter(String filterFormat, String…​ params): Uses the specified string as input to MessageFormat, properly encoding the parameters and inserting them at the specified places in the filter string.spring-doc.cadn.net.cn
  • filter(Filter filter): Uses the specified filter.spring-doc.cadn.net.cn
You cannot mix the hardcoded filter methods with the where approach described earlier. It is either one or the other. If you specify a filter by using filter(), you get an exception if you try to call where afterwards.spring-doc.cadn.net.cn
