基本用法
搜索和查找方式AttributesMapper
以下示例使用AttributesMapper构建一个包含所有 Person 对象的所有公用名的 List。spring-doc.cadn.net.cn
示例 1.AttributesMapper返回单个属性
import static org.springframework.ldap.query.LdapQueryBuilder.query;
public class PersonRepoImpl implements PersonRepo {
   private LdapClient ldapClient;
   public void setLdapClient(LdapClient ldapClient) {
      this.ldapClient = ldapClient;
   public List<String> getAllPersonNames() {
      return ldapClient.search()
                .query(query().where("objectclass").is("person"))
                .toList((Attributes attrs) -> (String) attrs.get("cn").get());
The inline implementation of AttributesMapper gets the desired attribute value from the Attributes object and returns it. Internally, LdapClient iterates over all entries found, calls the given AttributesMapper for each entry, and collects the results in a list. The list is then returned by the search method.spring-doc.cadn.net.cn
Note that the AttributesMapper implementation could easily be modified to return a full Person object, as follows:spring-doc.cadn.net.cn
Example 2. AttributesMapper that returns a Person object
   private class PersonAttributesMapper implements AttributesMapper<Person> {
      public Person mapFromAttributes(Attributes attrs) throws NamingException {
         Person person = new Person();
         person.setFullName((String)attrs.get("cn").get());
         person.setLastName((String)attrs.get("sn").get());
         person.setDescription((String)attrs.get("description").get());
         return person;
   public List<Person> getAllPersons() {
            .toList(new PersonAttributesMapper());
Entries in LDAP are uniquely identified by their distinguished name (DN). If you have the DN of an entry, you can retrieve the entry directly without querying for it. This is called a “lookup” in Java LDAP. The following example shows a lookup for a Person object:spring-doc.cadn.net.cn
Example 3. A lookup resulting in a Person object
   public Person findPerson(String dn) {
      return ldapClient.search().name(dn).toObject(new PersonAttributesMapper());
The preceding example looks up the specified DN and passes the found attributes to the supplied AttributesMapper — in this case, resulting in a Person object.spring-doc.cadn.net.cn
Building LDAP Queries
LDAP searches involve a number of parameters, including the following:spring-doc.cadn.net.cn
Spring LDAP provides an LdapQueryBuilder with a fluent API for building LDAP Queries.spring-doc.cadn.net.cn
Suppose you want to perform a search starting at the base DN dc=261consulting,dc=com, limiting the returned attributes to cn and sn, with a filter of (&(objectclass=person)(sn=?)), where we want the ? to be replaced with the value of the lastName parameter. The following example shows how to do it by using the LdapQueryBuilder:spring-doc.cadn.net.cn
Example 4. Building a search filter dynamically
   public List<String> getPersonNamesByLastName(String lastName) {
      LdapQuery query = query()
         .base("dc=261consulting,dc=com")
         .attributes("cn", "sn")
         .and("sn").is(lastName);
      return ldapClient.search().query(query)
            .toObject((Attributes attrs) -> (String) attrs.get("cn").get());
In addition to simplifying building of complex search parameters, the LdapQueryBuilder and its associated classes also provide proper escaping of any unsafe characters in search filters. This prevents “LDAP injection”, where a user might use such characters to inject unwanted operations into your LDAP operations.
LdapClient includes many overloaded methods for performing LDAP searches. This is in order to accommodate as many different use cases and programming style preferences as possible. For the vast majority of use cases, the methods that take an LdapQuery as input are the recommended methods to use.
The AttributesMapper is only one of the available callback interfaces you can use when handling search and lookup data. See Simplifying Attribute Access and Manipulation with DirContextAdapter for alternatives.
For more information on the LdapQueryBuilder, see Advanced LDAP Queries.spring-doc.cadn.net.cn
Dynamically Building Distinguished Names
The standard Java implementation of Distinguished Name (LdapName) performs well when it comes to parsing Distinguished Names. However, in practical use, this implementation has a number of shortcomings:spring-doc.cadn.net.cn
  • The LdapName implementation is mutable, which is badly suited for an object that represents identity.spring-doc.cadn.net.cn
  • Despite its mutable nature, the API for dynamically building or modifying Distinguished Names by using LdapName is cumbersome. Extracting values of indexed or (particularly) named components is also a little bit awkward.spring-doc.cadn.net.cn
  • Many of the operations on LdapName throw checked exceptions, requiring try-catch statements for situations where the error is typically fatal and cannot be repaired in a meaningful manner.spring-doc.cadn.net.cn
To simplify working with Distinguished Names, Spring LDAP provides an LdapNameBuilder, as well as a number of utility methods in LdapUtils that help when working with LdapName.spring-doc.cadn.net.cn
Examples
This section presents a few examples of the subjects covered in the preceding sections. The first example dynamically builds an LdapName by using LdapNameBuilder:spring-doc.cadn.net.cn
Example 5. Dynamically building an LdapName by using LdapNameBuilder
import org.springframework.ldap.support.LdapNameBuilder;
import javax.naming.Name;
  public static final String BASE_DN = "dc=example,dc=com";
  protected Name buildDn(Person p) {
    return LdapNameBuilder.newInstance(BASE_DN)
      .add("c", p.getCountry())
      .add("ou", p.getCompany())
      .add("cn", p.getFullname())
Assume that a Person has the following attributes:spring-doc.cadn.net.cn
Attribute Name Attribute Value
countryspring-doc.cadn.net.cn
Swedenspring-doc.cadn.net.cn
companyspring-doc.cadn.net.cn
Some Companyspring-doc.cadn.net.cn
fullnamespring-doc.cadn.net.cn
Some Personspring-doc.cadn.net.cn
The preceding code would then result in the following distinguished name:spring-doc.cadn.net.cn
cn=Some Person, ou=Some Company, c=Sweden, dc=example, dc=com
The following example extracts values from a distinguished name by using LdapUtilsspring-doc.cadn.net.cn
Example 6. Extracting values from a distinguished name by using LdapUtils
  protected Person buildPerson(Name dn, Attributes attrs) {
    person.setCountry(LdapUtils.getStringValue(dn, "c"));
    person.setCompany(LdapUtils.getStringValue(dn, "ou"));
    person.setFullname(LdapUtils.getStringValue(dn, "cn"));
    // Populate rest of person object using attributes.
    return person;
Since Java versions prior to and including 1.4 did not provide any public Distinguished Name implementation at all, Spring LDAP 1.x provided its own implementation, DistinguishedName. This implementation suffered from a couple of shortcomings of its own and has been deprecated in version 2.0. You should now use LdapName along with the utilities described earlier.spring-doc.cadn.net.cn
Binding and Unbinding
This section describes how to add and remove data. Updating is covered in the next section.spring-doc.cadn.net.cn
Adding Data
Inserting data in Java LDAP is called binding. This is somewhat confusing, because in LDAP terminology, “bind” means something completely different. A JNDI bind performs an LDAP Add operation, associating a new entry that has a specified distinguished name with a set of attributes. The following example adds data by using LdapClient:spring-doc.cadn.net.cn
Example 7. Adding data using Attributes
   public void create(Person p) {
      Name dn = buildDn(p);
      ldapClient.bind(dn).attributes(buildAttributes(p)).execute();
   private Attributes buildAttributes(Person p) {
      Attributes attrs = new BasicAttributes();
      BasicAttribute ocattr = new BasicAttribute("objectclass");
      ocattr.add("top");
      ocattr.add("person");
      attrs.put(ocattr);
      attrs.put("cn", "Some Person");
      attrs.put("sn", "Person");
      return attrs;
Manual attributes building is — while dull and verbose — sufficient for many purposes. You can, however, simplify the binding operation further, as described in Simplifying Attribute Access and Manipulation with DirContextAdapter.spring-doc.cadn.net.cn
Removing Data
Removing data in Java LDAP is called unbinding. A JNDI unbind performs an LDAP Delete operation, removing the entry associated with the specified distinguished name from the LDAP tree. The following example removes data by using LdapClient:spring-doc.cadn.net.cn
Example 8. Removing data
   public void delete(Person p) {
      ldapClient.unbind(dn).execute();
Updating
In Java LDAP, data can be modified in two ways: either by using rebind or by using modifyAttributes.spring-doc.cadn.net.cn
Updating by Using Rebind
A rebind is a crude way to modify data. It is basically an unbind followed by a bind. The following example invokes LDAP’s rebind:spring-doc.cadn.net.cn
Example 9. Modifying using rebind
   public void update(Person p) {
      ldapTemplate.bind(dn).attributes(buildAttributes(p)).replaceExisting(true).execute();
Updating by Using modifyAttributes
A more sophisticated way of modifying data is to use modifyAttributes. This operation takes an array of explicit attribute modifications and performs them on a specific entry, as follows:spring-doc.cadn.net.cn
Example 10. Modifying using modifyAttributes
   public void updateDescription(Person p) {
      Attribute attr = new BasicAttribute("description", p.getDescription())
      ModificationItem item = new ModificationItem(DirContext.REPLACE_ATTRIBUTE, attr);
      ldapTemplate.modify().name(dn).attributes(item).execute();
Building Attributes and ModificationItem arrays is a lot of work. However, as we describe in Simplifying Attribute Access and Manipulation with DirContextAdapter, Spring LDAP provides more help for simplifying these operations.spring-doc.cadn.net.cn
