Changes between 5.0 and 5.1
New Components
The following components are new in 5.1:spring-doc.cn
AmqpDedicatedChannelAdvice
Improved Function Support
The java.util.function interfaces now have improved integration support in the Framework components. Also, Kotlin lambdas now can be used for handler and source methods.spring-doc.cn
@LongRunningTest
A JUnit 5 @LongRunningTest conditional annotation is provided to check the environment or system properties for the RUN_LONG_INTEGRATION_TESTS entry with the value of true to determine if test should be run or skipped.spring-doc.cn
General Changes
The following changes have been made in version 5.1:spring-doc.cn
Java DSL
The IntegrationFlowContext is now an interface and IntegrationFlowRegistration is an inner interface of IntegrationFlowContext.spring-doc.cn
A new logAndReply() operator has been introduced for convenience when you wish to log at the end of a flow for request-reply configurations. This avoids confusion with log() which is treated as a one-way end flow component.spring-doc.cn
A generated bean name for any NamedComponent within an integration flow is now based on the component type for better readability from visual tools, logs analyzers and metrics collectors.spring-doc.cn
The GenericHandler.handle() now excepts a MessageHeaders type for the second argument.spring-doc.cn
Dispatcher Exceptions
Exceptions caught and re-thrown by AbstractDispatcher are now more consistent:spring-doc.cn
  • A MessagingException of any kind that has a failedMessage property is re-thrown unchanged.spring-doc.cn
  • All other exceptions are wrapped in a MessageDeliveryException with the failedMessage property set.spring-doc.cn
Previously:spring-doc.cn
  • A MessagingException of any kind that has a failedMessage property was re-thrown unchangedspring-doc.cn
  • A MessagingException that had no failedMessage property was wrapped in a MessagingException with the failedMessage property set.spring-doc.cn
  • Other RuntimeException instances were re-thrown unchanged.spring-doc.cn
  • Checked exceptions were wrapped in a MessageDeliveryException with the failedMessage property set.spring-doc.cn
Global Channel Interceptors
Global channel interceptors now apply to dynamically registered channels, such as through the IntegrationFlowContext when using the Java DSL or beans that are initialized using beanFactory.initializeBean(). Previously, when beans were created after the application context was refreshed, interceptors were not applied.spring-doc.cn
ChannelInterceptor.postReceive() is no longer called when no message is received; it is no longer necessary to check for a null Message<?>. Previously, the method was called. If you have an interceptor that relies on the previous behavior, implement afterReceiveCompleted() instead, since that method is invoked, regardless of whether a message is received or not. Furthermore, the PolledAmqpChannel and PolledJmsChannel previously did not invoke afterReceiveCompleted() with null; they now do.spring-doc.cn
ObjectToJsonTransformer
A new ResultType.BYTES mode is introduced for the ObjectToJsonTransformer.spring-doc.cn
See JSON Transformers for more information.spring-doc.cn
Integration Flows: Generated Bean Names
Starting with version 5.0.5, generated bean names for the components in an IntegrationFlow include the flow bean name, followed by a dot, as a prefix. For example, if a flow bean were named flowBean, a generated bean might be named flowBean.generatedBean.spring-doc.cn
See Working With Message Flows for more information.spring-doc.cn
Aggregator Changes
If the groupTimeout is evaluated to a negative value, an aggregator now expires the group immediately. Only null is considered as a signal to do nothing for the current message.spring-doc.cn
A new popSequence property has been introduced to allow (by default) to call a MessageBuilder.popSequenceDetails() for the output message. Also an AbstractAggregatingMessageGroupProcessor returns now an AbstractIntegrationMessageBuilder instead of the whole Message for optimization.spring-doc.cn
See Aggregator for more information.spring-doc.cn
@Publisher annotation changes
Starting with version 5.1, you must explicitly turn on the @Publisher AOP functionality by using @EnablePublisher or by using the <int:enable-publisher> child element on <int:annotation-config>. Also the proxy-target-class and order attributes have been added for tuning the ProxyFactory configuration.spring-doc.cn
Files Changes
If you are using FileExistsMode.APPEND or FileExistsMode.APPEND_NO_FLUSH you can provide a newFileCallback that will be called when creating a new file. This callback receives the newly created file and the message that triggered the callback. This could be used to write a CSV header, for an example.spring-doc.cn
The FileReadingMessageSource now doesn’t check and create a directory until its start() is called. So, if an Inbound Channel Adapter for the FileReadingMessageSource has autoStartup = false, there are no failures against the file system during application start up.spring-doc.cn
See File Support for more information.spring-doc.cn
AMQP Changes
We have made ID and Timestamp header mapping changes in the DefaultAmqpHeaderMapper. See the note near the bottom of AMQP Message Headers for more information.spring-doc.cn
The contentType header is now correctly mapped as an entry in the general headers map. See contentType Header for more information.spring-doc.cn
Starting with version 5.1.3, if a message conversion exception occurs when using manual acknowledgments, and an error channel is defined, the payload is a ManualAckListenerExecutionFailedException with additional channel and deliveryTag properties. This enables the error flow to ack/nack the original message. See Inbound Message Conversion for more information.spring-doc.cn
JDBC Changes
A confusing max-rows-per-poll property on the JDBC Inbound Channel Adapter and JDBC Outbound Gateway has been deprecated in favor of the newly introduced max-rows property.spring-doc.cn
The JdbcMessageHandler supports now a batchUpdate functionality when the payload of the request message is an instance of an Iterable type.spring-doc.cn
The indexes for the INT_CHANNEL_MESSAGE table (for the JdbcChannelMessageStore) have been optimized. If you have large message groups in such a store, you may wish to alter the indexes.spring-doc.cn
See JDBC Support for more information.spring-doc.cn
FTP and SFTP Changes
A RotatingServerAdvice is now available to poll multiple servers and directories with the inbound channel adapters. See Inbound Channel Adapters: Polling Multiple Servers and Directories and Inbound Channel Adapters: Polling Multiple Servers and Directories for more information.spring-doc.cn
Also, inbound adapter localFilenameExpression instances can contain the #remoteDirectory variable, which contains the remote directory being polled. The generic type of the comparators (used to sort the fetched file list for the streaming adapters) has changed from Comparator<AbstractFileInfo<F>> to Comparator<F>. See FTP Streaming Inbound Channel Adapter and SFTP Streaming Inbound Channel Adapter for more information.spring-doc.cn
In addition, the synchronizers for inbound channel adapters can now be provided with a Comparator. This is useful when using maxFetchSize to limit the files retrieved.spring-doc.cn
The CachingSessionFactory has a new property testSession which, when true, causes the factory to perform a test() operation on the Session when checking out an existing session from the cache.spring-doc.cn
The outbound gateway MPUT command now supports a message payload with a collection of files or strings. See SFTP Outbound Gateway and FTP Outbound Gateway for more information.spring-doc.cn
TCP Support
When using SSL, host verification is now enabled, by default, to prevent man-in-the-middle attacks with a trusted certificate. See Host Verification for more information.spring-doc.cn
In addition the key and trust store types can now be configured on the DefaultTcpSSLContextSupport.spring-doc.cn
Twitter Support
Since the Spring Social project has moved to end of life status, Twitter support in Spring Integration has been moved to the Extensions project. See Spring Integration Social Twitter for more information.spring-doc.cn
JMS Support
The JmsSendingMessageHandler now provides deliveryModeExpression and timeToLiveExpression options to determine respective QoS options for JMS message to send at runtime. The DefaultJmsHeaderMapper now allows to map inbound JMSDeliveryMode and JMSExpiration properties via setting to true respective setMapInboundDeliveryMode() and setMapInboundExpiration() options. When a JmsMessageDrivenEndpoint or JmsInboundGateway is stopped, the associated listener container is now shut down; this closes its shared connection and any consumers. You can configure the endpoints to revert to the previous behavior.spring-doc.cn
See JMS Support for more information.spring-doc.cn
HTTP/WebFlux Support
The statusCodeExpression (and Function) is now supplied with the RequestEntity<?> as a root object for evaluation context, so request headers, method, URI and body are available for target status code calculation.spring-doc.cn
See HTTP Support and WebFlux Support for more information.spring-doc.cn
JMX Changes
Object name key values are now quoted if they contain any characters other than those allowed in a Java identifier (or period .). For example org.springframework.integration:type=MessageChannel, name="input:foo.myGroup.errors". This has the side effect that previously "allowed" names, with such characters, will now be quoted. For example org.springframework.integration:type=MessageChannel, name="input#foo.myGroup.errors".spring-doc.cn
Micrometer Support Changes
It is now simpler to customize the standard Micrometer meters created by the framework. See Micrometer Integration for more information.spring-doc.cn
Integration Graph Customization
It is now possible to add additional properties to the IntegrationNode s via Function<NamedComponent, Map<String, Object>> additionalPropertiesCallback on the IntegrationGraphServer. See Integration Graph for more information.spring-doc.cn
Integration Global Properties
The Integration global properties (including defaults) can now be printed in the logs, when a DEBUG logic level is turned on for the org.springframework.integration category. See Global Properties for more information.spring-doc.cn
The receiveTimeout for @Poller
The @Poller annotation now provides a receiveTimeout option for convenience. See Using the @Poller Annotation for more information.spring-doc.cn
