Introduction
Two flavors each of UDP inbound and outbound channel adapters are provided:spring-doc.cn
  • UnicastSendingMessageHandler sends a datagram packet to a single destination.spring-doc.cn
  • UnicastReceivingChannelAdapter receives incoming datagram packets.spring-doc.cn
  • MulticastSendingMessageHandler sends (broadcasts) datagram packets to a multicast address.spring-doc.cn
  • MulticastReceivingChannelAdapter receives incoming datagram packets by joining to a multicast address.spring-doc.cn
TCP inbound and outbound channel adapters are provided:spring-doc.cn
  • TcpSendingMessageHandler sends messages over TCP.spring-doc.cn
  • TcpReceivingChannelAdapter receives messages over TCP.spring-doc.cn
An inbound TCP gateway is provided. It allows for simple request-response processing. While the gateway can support any number of connections, each connection can only be processed serially. The thread that reads from the socket waits for, and sends, the response before reading again. If the connection factory is configured for single use connections, the connection is closed after the socket times out.spring-doc.cn
An outbound TCP gateway is provided. It allows for simple request-response processing. If the associated connection factory is configured for single-use connections, a new connection is immediately created for each new request. Otherwise, if the connection is in use, the calling thread blocks on the connection until either a response is received or a timeout or I/O error occurs.spring-doc.cn
The TCP and UDP inbound channel adapters and the TCP inbound gateway support the error-channel attribute. This provides the same basic functionality as described in Enter the GatewayProxyFactoryBean.spring-doc.cn
