For the latest stable version, please use Spring Integration 6.5.0!spring-doc.cn
Router Implementations
Since content-based routing often requires some domain-specific logic, most use cases require Spring Integration’s options for delegating to POJOs by using either the XML namespace support or annotations. Both of these are discussed later. However, we first present a couple of implementations that fulfill common requirements.spring-doc.cn
PayloadTypeRouter
A PayloadTypeRouter sends messages to the channel defined by payload-type mappings, as the following example shows:spring-doc.cn
<bean id="payloadTypeRouter"
      class="org.springframework.integration.router.PayloadTypeRouter">
    <property name="channelMapping">
        <map>
            <entry key="java.lang.String" value-ref="stringChannel"/>
            <entry key="java.lang.Integer" value-ref="integerChannel"/>
        </map>
    </property>
</bean>
Configuration of the PayloadTypeRouter is also supported by the namespace provided by Spring Integration (see Namespace Support), which essentially simplifies configuration by combining the <router/> configuration and its corresponding implementation (defined by using a <bean/> element) into a single and more concise configuration element. The following example shows a PayloadTypeRouter configuration that is equivalent to the one above but uses the namespace support:spring-doc.cn
<int:payload-type-router input-channel="routingChannel">
    <int:mapping type="java.lang.String" channel="stringChannel" />
    <int:mapping type="java.lang.Integer" channel="integerChannel" />
</int:payload-type-router>
The following example shows the equivalent router configured in Java:spring-doc.cn
@ServiceActivator(inputChannel = "routingChannel")
public PayloadTypeRouter router() {
    PayloadTypeRouter router = new PayloadTypeRouter();
    router.setChannelMapping(String.class.getName(), "stringChannel");
    router.setChannelMapping(Integer.class.getName(), "integerChannel");
    return router;
When using the Java DSL, there are two options.spring-doc.cn
First, you can define the router object as shown in the preceding example:spring-doc.cn
public IntegrationFlow routerFlow1() {
    return IntegrationFlow.from("routingChannel")
            .route(router())
            .get();
    return router;
Note that the router can be, but does not have to be, a @Bean. The flow registers it if it is not a @Bean.spring-doc.cn
Second, you can define the routing function within the DSL flow itself, as the following example shows:spring-doc.cn
public IntegrationFlow routerFlow2() {
            .<Object, Class<?>>route(Object::getClass, m -> m
                    .channelMapping(String.class, "stringChannel")
                    .channelMapping(Integer.class, "integerChannel"))
            .get();
HeaderValueRouter
A HeaderValueRouter sends Messages to the channel based on the individual header value mappings. When a HeaderValueRouter is created, it is initialized with the name of the header to be evaluated. The value of the header could be one of two things:spring-doc.cn
If it is an arbitrary value, additional mappings for these header values to channel names are required. Otherwise, no additional configuration is needed.spring-doc.cn
Spring Integration provides a simple namespace-based XML configuration to configure a HeaderValueRouter. The following example demonstrates configuration for the HeaderValueRouter when mapping of header values to channels is required:spring-doc.cn
<int:header-value-router input-channel="routingChannel" header-name="testHeader">
    <int:mapping value="someHeaderValue" channel="channelA" />
    <int:mapping value="someOtherHeaderValue" channel="channelB" />
</int:header-value-router>
During the resolution process, the router defined in the preceding example may encounter channel resolution failures, causing an exception. If you want to suppress such exceptions and send unresolved messages to the default output channel (identified with the default-output-channel attribute) set resolution-required to false.spring-doc.cn
Normally, messages for which the header value is not explicitly mapped to a channel are sent to the default-output-channel. However, when the header value is mapped to a channel name but the channel cannot be resolved, setting the resolution-required attribute to false results in routing such messages to the default-output-channel.spring-doc.cn
public HeaderValueRouter router() {
    HeaderValueRouter router = new HeaderValueRouter("testHeader");
    router.setChannelMapping("someHeaderValue", "channelA");
    router.setChannelMapping("someOtherHeaderValue", "channelB");
    return router;
When using the Java DSL, there are two options. First, you can define the router object as shown in the preceding example:spring-doc.cn
            .route(router())
            .get();
    return router;
            .route(Message.class, m -> m.getHeaders().get("testHeader", String.class),
                    m -> m
                        .channelMapping("someHeaderValue", "channelA")
                        .channelMapping("someOtherHeaderValue", "channelB"),
                e -> e.id("headerValueRouter"))
            .get();
Configuration where mapping of header values to channel names is not required, because header values themselves represent channel names. The following example shows a router that does not require mapping of header values to channel names:spring-doc.cn
<int:header-value-router input-channel="routingChannel" header-name="testHeader"/>
Since Spring Integration 2.1, the behavior of resolving channels is more explicit. For example, if you omit the default-output-channel attribute, the router was unable to resolve at least one valid channel, and any channel name resolution failures were ignored by setting resolution-required to false, then a MessageDeliveryException is thrown.spring-doc.cn
Basically, by default, the router must be able to route messages successfully to at least one channel. If you really want to drop messages, you must also have default-output-channel set to nullChannel.spring-doc.cn
RecipientListRouter
A RecipientListRouter sends each received message to a statically defined list of message channels. The following example creates a RecipientListRouter:spring-doc.cn
<bean id="recipientListRouter"
      class="org.springframework.integration.router.RecipientListRouter">
    <property name="channels">
        <list>
            <ref bean="channel1"/>
            <ref bean="channel2"/>
            <ref bean="channel3"/>
        </list>
    </property>
</bean>
Spring Integration also provides namespace support for the RecipientListRouter configuration (see Namespace Support) as the following example shows:spring-doc.cn
<int:recipient-list-router id="customRouter" input-channel="routingChannel"
        timeout="1234"
        ignore-send-failures="true"
        apply-sequence="true">
  <int:recipient channel="channel1"/>
  <int:recipient channel="channel2"/>
</int:recipient-list-router>
public RecipientListRouter router() {
    RecipientListRouter router = new RecipientListRouter();
    router.setSendTimeout(1_234L);
    router.setIgnoreSendFailures(true);
    router.setApplySequence(true);
    router.addRecipient("channel1");
    router.addRecipient("channel2");
    router.addRecipient("channel3");
    return router;
The following example shows the equivalent router configured by using the Java DSL:spring-doc.cn
public IntegrationFlow routerFlow() {
            .routeToRecipients(r -> r
                    .applySequence(true)
                    .ignoreSendFailures(true)
                    .recipient("channel1")
                    .recipient("channel2")
                    .recipient("channel3")
                    .sendTimeout(1_234L))
            .get();
The 'apply-sequence' flag here has the same effect as it does for a publish-subscribe-channel, and, as with a publish-subscribe-channel, it is disabled by default on the recipient-list-router. See PublishSubscribeChannel Configuration for more information.
Another convenient option when configuring a RecipientListRouter is to use Spring Expression Language (SpEL) support as selectors for individual recipient channels. Doing so is similar to using a filter at the beginning of a 'chain' to act as a “selective consumer”. However, in this case, it is all combined rather concisely into the router’s configuration, as the following example shows:spring-doc.cn
<int:recipient-list-router id="customRouter" input-channel="routingChannel">
    <int:recipient channel="channel1" selector-expression="payload.equals('foo')"/>
    <int:recipient channel="channel2" selector-expression="headers.containsKey('bar')"/>
In the preceding configuration, a SpEL expression identified by the selector-expression attribute is evaluated to determine whether this recipient should be included in the recipient list for a given input message. The evaluation result of the expression must be a boolean. If this attribute is not defined, the channel is always among the list of recipients.spring-doc.cn
RecipientListRouterManagement
Starting with version 4.1, the RecipientListRouter provides several operations to manipulate recipients dynamically at runtime. These management operations are presented by RecipientListRouterManagement through the @ManagedResource annotation. They are available by using Control Bus as well as by using JMX, as the following example shows:spring-doc.cn
<control-bus input-channel="controlBus"/>
<recipient-list-router id="simpleRouter" input-channel="routingChannelA">
   <recipient channel="channel1"/>
</recipient-list-router>
<channel id="channel2"/>
messagingTemplate.convertAndSend(controlBus, "@'simpleRouter.handler'.addRecipient('channel2')");
From the application start up the simpleRouter, has only one channel1 recipient. But after the addRecipient command, channel2 recipient is added. It is a “registering an interest in something that is part of the message” use case, when we may be interested in messages from the router at some time period, so we are subscribing to the recipient-list-router and, at some point, decide to unsubscribe.spring-doc.cn
Because of the runtime management operation for the <recipient-list-router>, it can be configured without any <recipient> from the start. In this case, the behavior of RecipientListRouter is the same when there is no one matching recipient for the message. If defaultOutputChannel is configured, the message is sent there. Otherwise, the MessageDeliveryException is thrown.spring-doc.cn
XPath Router
The XPath Router is part of the XML Module. See Routing XML Messages with XPath.spring-doc.cn
Routing and Error Handling
Spring Integration also provides a special type-based router called ErrorMessageExceptionTypeRouter for routing error messages (defined as messages whose payload is a Throwable instance). ErrorMessageExceptionTypeRouter is similar to the PayloadTypeRouter. In fact, they are almost identical. The only difference is that, while PayloadTypeRouter navigates the instance hierarchy of a payload instance (for example, payload.getClass().getSuperclass()) to find the most specific type and channel mappings, the ErrorMessageExceptionTypeRouter navigates the hierarchy of 'exception causes' (for example, payload.getCause()) to find the most specific Throwable type or channel mappings and uses mappingClass.isInstance(cause) to match the cause to the class or any super class.spring-doc.cn
The channel mapping order in this case matters. So, if there is a requirement to get mapping for an IllegalArgumentException, but not a RuntimeException, the last one must be configured on router first.
Since version 4.3 the ErrorMessageExceptionTypeRouter loads all mapping classes during the initialization phase to fail-fast for a ClassNotFoundException.
The following example shows a sample configuration for ErrorMessageExceptionTypeRouter:spring-doc.cn
public IntegrationFlow someFlow() {
    return f -> f
            .routeByException(r -> r
                 .channelMapping(IllegalArgumentException.class, "illegalChannel")
                 .channelMapping(NullPointerException.class, "npeChannel")
                 .defaultOutputChannel("defaultChannel"));
fun someFlow() =
    integrationFlow {
        routeByException {
                    channelMapping(IllegalArgumentException::class.java, "illegalChannel")
                    channelMapping(NullPointerException::class.java, "npeChannel")
someFlow() {
    integrationFlow {
        routeByException {
            channelMapping IllegalArgumentException, 'illegalChannel'
            channelMapping NullPointerException, 'npeChannel'
            defaultOutputChannel 'defaultChannel'
<int:exception-type-router input-channel="inputChannel"
                           default-output-channel="defaultChannel">
    <int:mapping exception-type="java.lang.IllegalArgumentException"
                 channel="illegalChannel"/>
    <int:mapping exception-type="java.lang.NullPointerException"
                 channel="npeChannel"/>
</int:exception-type-router>
<int:channel id="illegalChannel" />
<int:channel id="npeChannel" />
