Request Execution
ExecutionGraphQlService is the main Spring abstraction to call GraphQL Java to execute requests. Underlying transports, such as the HTTP, delegate to ExecutionGraphQlService to handle requests.spring-doc.cn
The main implementation, DefaultExecutionGraphQlService, is configured with a GraphQlSource for access to the graphql.GraphQL instance to invoke.spring-doc.cn
GraphQLSource
GraphQlSource is a contract to expose the graphql.GraphQL instance to use that also includes a builder API to build that instance. The default builder is available via GraphQlSource.schemaResourceBuilder().spring-doc.cn
The Boot Starter creates an instance of this builder and further initializes it to load schema files from a configurable location, to expose properties to apply to GraphQlSource.Builder, to detect RuntimeWiringConfigurer beans, Instrumentation beans for GraphQL metrics, and DataFetcherExceptionResolver and SubscriptionExceptionResolver beans for exception resolution. For further customizations, you can also declare a GraphQlSourceBuilderCustomizer bean, for example:spring-doc.cn
import org.springframework.boot.autoconfigure.graphql.GraphQlSourceBuilderCustomizer;
public class GraphQlConfig {
	public GraphQlSourceBuilderCustomizer sourceBuilderCustomizer() {
		return (builder) ->
				builder.configureGraphQl((graphQlBuilder) ->
						graphQlBuilder.executionIdProvider(new CustomExecutionIdProvider()));
Schema Resources
GraphQlSource.Builder can be configured with one or more Resource instances to be parsed and merged together. That means schema files can be loaded from just about any location.spring-doc.cn
By default, the Boot starter looks for schema files with extensions ".graphqls" or ".gqls" under the location classpath:graphql/**, which is typically src/main/resources/graphql. You can also use a file system location, or any location supported by the Spring Resource hierarchy, including a custom implementation that loads schema files from remote locations, from storage, or from memory.spring-doc.cn
Use classpath*:graphql/**/ to find schema files across multiple classpath locations, e.g. across multiple modules.
Schema Creation
By default, GraphQlSource.Builder uses the GraphQL Java SchemaGenerator to create the graphql.schema.GraphQLSchema. This works for typical use, but if you need to use a different generator, you can register a schemaFactory callback:spring-doc.cn
GraphQlSource.Builder builder = ...
builder.schemaResources(..)
		.configureRuntimeWiring(..)
		.schemaFactory((typeDefinitionRegistry, runtimeWiring) -> {
			// create GraphQLSchema
See the GraphQlSource section for how to configure this with Spring Boot.spring-doc.cn
If interested in federation, please see the Federation section.spring-doc.cn
A RuntimeWiringConfigurer is useful to register the following:spring-doc.cn
Spring applications typically do not need to perform direct DataFetcher registrations. Instead, controller method are registered as DataFetchers via AnnotatedControllerConfigurer, which is a RuntimeWiringConfigurer.
GraphQL Java, server applications use Jackson only for serialization to and from maps of data. Client input is parsed into a map. Server output is assembled into a map based on the field selection set. This means you can’t rely on Jackson serialization/deserialization annotations. Instead, you can use custom scalar types.
The Boot Starter detects beans of type RuntimeWiringConfigurer and registers them in the GraphQlSource.Builder. That means in most cases, you’ll' have something like the following in your configuration:spring-doc.cn
	public RuntimeWiringConfigurer runtimeWiringConfigurer(BookRepository repository) {
		GraphQLScalarType scalarType = ... ;
		SchemaDirectiveWiring directiveWiring = ... ;
		return wiringBuilder -> wiringBuilder
				.scalar(scalarType)
				.directiveWiring(directiveWiring);
If you need to add a WiringFactory, e.g. to make registrations that take into account schema definitions, implement the alternative configure method that accepts both the RuntimeWiring.Builder and an output List<WiringFactory>. This allows you to add any number of factories that are then invoked in sequence.spring-doc.cn
TypeResolver
GraphQlSource.Builder registers ClassNameTypeResolver as the default TypeResolver to use for GraphQL Interfaces and Unions that don’t already have such a registration through a RuntimeWiringConfigurer. The purpose of a TypeResolver in GraphQL Java is to determine the GraphQL Object type for values returned from the DataFetcher for a GraphQL Interface or Union field.spring-doc.cn
ClassNameTypeResolver tries to match the simple class name of the value to a GraphQL Object Type and if it is not successful, it also navigates its super types including base classes and interfaces, looking for a match. ClassNameTypeResolver provides an option to configure a name extracting function along with Class to GraphQL Object type name mappings that should help to cover more corner cases:spring-doc.cn
ClassNameTypeResolver classNameTypeResolver = new ClassNameTypeResolver();
classNameTypeResolver.setClassNameExtractor((klass) -> {
	// Implement Custom ClassName Extractor here
builder.defaultTypeResolver(classNameTypeResolver);
Directives
The GraphQL language supports directives that "describe alternate runtime execution and type validation behavior in a GraphQL document". Directives are similar to annotations in Java but declared on types, fields, fragments and operations in a GraphQL document.spring-doc.cn
GraphQL Java provides the SchemaDirectiveWiring contract to help applications detect and handle directives. For more details, see Schema Directives in the GraphQL Java documentation.spring-doc.cn
In Spring GraphQL you can register a SchemaDirectiveWiring through a RuntimeWiringConfigurer. The Boot Starter detects such beans, so you might have something like:spring-doc.cn
	 public RuntimeWiringConfigurer runtimeWiringConfigurer() {
		  return builder -> builder.directiveWiring(new MySchemaDirectiveWiring());
For an example of directives support check out the Extended Validation for Graphql Java library.
ExecutionStrategy
An ExecutionStrategy in GraphQL Java drives the fetching of requested fields. To create an ExecutionStrategy, you need to provide a DataFetcherExceptionHandler. By default, Spring for GraphQL creates the exception handler to use as described in Exceptions and sets it on the GraphQL.Builder. GraphQL Java then uses that to create AsyncExecutionStrategy instances with the configured exception handler.spring-doc.cn
If you need to create a custom ExecutionStrategy, you can detect DataFetcherExceptionResolvers and create an exception handler in the same way, and use it to create the custom ExecutionStrategy. For example, in a Spring Boot application:spring-doc.cn
		ObjectProvider<DataFetcherExceptionResolver> resolvers) {
	DataFetcherExceptionHandler exceptionHandler =
			DataFetcherExceptionResolver.createExceptionHandler(resolvers.stream().toList());
	AsyncExecutionStrategy strategy = new CustomAsyncExecutionStrategy(exceptionHandler);
	return sourceBuilder -> sourceBuilder.configureGraphQl(builder ->
			builder.queryExecutionStrategy(strategy).mutationExecutionStrategy(strategy));
Schema Transformation
You can register a graphql.schema.GraphQLTypeVisitor via builder.schemaResources(..).typeVisitorsToTransformSchema(..) if you want to traverse and transform the schema after it is created, and make changes to the schema. Keep in mind that this is more expensive than Schema Traversal so generally prefer traversal to transformation unless you need to make schema changes.spring-doc.cn
Schema Traversal
You can register a graphql.schema.GraphQLTypeVisitor via builder.schemaResources(..).typeVisitors(..) if you want to traverse the schema after it is created, and possibly apply changes to the GraphQLCodeRegistry. Keep in mind, however, that such a visitor cannot change the schema. See Schema Transformation, if you need to make changes to the schema.spring-doc.cn
Schema Mapping Inspection
If a query, mutation, or subscription operation does not have a DataFetcher, it won’t return any data, and won’t do anything useful. Likewise, fields of schema types that are neither covered explicitly through a DataFetcher registration, nor implicitly by the default PropertyDataFetcher that finds matching Class properties, will always be null.spring-doc.cn
GraphQL Java does not perform checks to ensure every schema field is covered, and as a lower level library, GraphQL Java simply does not know what a DataFetcher can return or what arguments it depends on, and therefore cannot perform such verifications. This can result in gaps that depending on test coverage may not be discovered until runtime when clients may experience "silent" null values, or non-null field errors.spring-doc.cn
The SelfDescribingDataFetcher interface in Spring for GraphQL allows a DataFetcher to expose information such as return type and expected arguments. All built-in, Spring DataFetcher implementations for controller methods, for Querydsl and for Query by Example are implementations of this interface. For annotated controllers, the return type and expected arguments are based on the controller method signature. This makes it possible to inspect schema mappings on startup to ensure the following:spring-doc.cn
  • Schema fields have either a DataFetcher registration or a corresponding Class property.spring-doc.cn
  • DataFetcher registrations refer to a schema field that exists.spring-doc.cn
  • DataFetcher arguments have matching schema field arguments.spring-doc.cn
To enable schema inspection, customize GraphQlSource.Builder as shown below. In this case the report is simply logged, but you can choose to take any action:spring-doc.cn
		.inspectSchemaMappings(report -> {
			logger.debug(report);
An example report:spring-doc.cn
GraphQL schema inspection:
    Unmapped fields: {Book=[title], Author[firstName, lastName]} (1)
    Unmapped registrations: {Book.reviews=BookController#reviews[1 args]} (2)
    Unmapped arguments: {BookController#bookSearch[1 args]=[myAuthor]} (3)
    Skipped types: [BookOrAuthor] (4)
1 Schema fields that are not covered in any way
2 DataFetcher registrations to fields that don’t exist
3 DataFetcher expected arguments that don’t exist
4 Schema types that have been skipped (explained next)
In some cases, the Class type for a schema type is unknown. Maybe the DataFetcher does not implement SelfDescribingDataFetcher, or the declared return type is too general (e.g. Object) or unknown (e.g. List<?>), or a DataFetcher could be missing altogether. In such cases, the schema type is listed as skipped as it could not be verified. For every skipped type, a DEBUG message explains why it was skipped.spring-doc.cn
Unions and Interfaces
For unions, the inspection iterates over member types and tries to find the corresponding classes. For interfaces, the inspection iterates over implementation types and looks for the corresponding classes.spring-doc.cn
By default, corresponding Java classes can be detected out-of-the-box in the following cases:spring-doc.cn
  • The Class's simple name matches the GraphQL union member of interface implementation type name, and the Class is located in the same package as the return type of the controller method, or controller class, mapped to the union or interface field.spring-doc.cn
  • The Class is inspected in other parts of the schema where the mapped field is of a concrete union member or interface implementation type.spring-doc.cn
  • You have registered a TypeResolver that has explicit Class to GraphQL type mappings .spring-doc.cn
In none the above help, and GraphQL types are reported as skipped in the schema inspection report, you can make the following customizations:spring-doc.cn
  • Explicitly map a GraphQL type name to a Java class or classes.spring-doc.cn
  • Configure a function that customizes how a GraphQL type name is adapted to a simple Class name. This can help with a specific Java class naming conventions.spring-doc.cn
  • Provide a ClassNameTypeResolver to map a GraphQL type a Java classes.spring-doc.cn
For example:spring-doc.cn
		initializer -> initializer.classMapping("Author", Author.class)
		logger::debug);
Operation Caching
GraphQL Java must parse and validate an operation before executing it. This may impact performance significantly. To avoid the need to re-parse and validate, an application may configure a PreparsedDocumentProvider that caches and reuses Document instances. The GraphQL Java docs provide more details on query caching through a PreparsedDocumentProvider.spring-doc.cn
In Spring GraphQL you can register a PreparsedDocumentProvider through GraphQlSource.Builder#configureGraphQl: .spring-doc.cn
// Typically, accessed through Spring Boot's GraphQlSourceBuilderCustomizer
// Create provider
PreparsedDocumentProvider provider =
        new ApolloPersistedQuerySupport(new InMemoryPersistedQueryCache(Collections.emptyMap()));
		.configureGraphQl(graphQLBuilder -> graphQLBuilder.preparsedDocumentProvider(provider))
Thread Model
Most GraphQL requests benefit from concurrent execution in fetching nested fields. This is why most applications today rely on GraphQL Java’s AsyncExecutionStrategy, which allows data fetchers to return CompletionStage and to execute concurrently rather than serially.spring-doc.cn
Java 21 and virtual threads add an important ability to use more threads efficiently, but it is still necessary to execute concurrently rather than serially in order for request execution to complete more quickly.spring-doc.cn
Spring for GraphQL supports:spring-doc.cn
Spring for GraphQL runs on either Spring MVC or WebFlux as the transport. Spring MVC uses async request execution, unless the resulting CompletableFuture is done immediately after the GraphQL Java engine returns, which would be the case if the request is simple enough and did not require asynchronous data fetching.spring-doc.cn
Reactive DataFetcher
The default GraphQlSource builder enables support for a DataFetcher to return Mono or Flux which adapts those to a CompletableFuture where Flux values are aggregated and turned into a List, unless the request is a GraphQL subscription request, in which case the return value remains a Reactive Streams Publisher for streaming GraphQL responses.spring-doc.cn
A reactive DataFetcher can rely on access to Reactor context propagated from the transport layer, such as from a WebFlux request handling, see WebFlux Context.spring-doc.cn
In the case of subscription requests, GraphQL Java will produce items as soon as they are available and all their requested fields were fetched. Because this involves several layers of asynchronous data fetching, items might be sent over the wire out of their original order. If you wish GraphQL Java to buffer items and retain the original order, you can do so by setting the SubscriptionExecutionStrategy.KEEP_SUBSCRIPTION_EVENTS_ORDERED configuration flag in the GraphQLContext. This can be done, for example, with a custom Instrumentation:spring-doc.cn
import graphql.ExecutionResult;
import graphql.execution.SubscriptionExecutionStrategy;
import graphql.execution.instrumentation.InstrumentationContext;
import graphql.execution.instrumentation.InstrumentationState;
import graphql.execution.instrumentation.SimpleInstrumentationContext;
import graphql.execution.instrumentation.SimplePerformantInstrumentation;
import graphql.execution.instrumentation.parameters.InstrumentationExecutionParameters;
	public SubscriptionOrderInstrumentation subscriptionOrderInstrumentation() {
		return new SubscriptionOrderInstrumentation();
	static class SubscriptionOrderInstrumentation extends SimplePerformantInstrumentation {
		public InstrumentationContext<ExecutionResult> beginExecution(InstrumentationExecutionParameters parameters,
																InstrumentationState state) {
			// Enable option for keeping subscription results in upstream order
			parameters.getGraphQLContext().put(SubscriptionExecutionStrategy.KEEP_SUBSCRIPTION_EVENTS_ORDERED, true);
			return SimpleInstrumentationContext.noOp();
Context Propagation
Spring for GraphQL provides support to transparently propagate context from the HTTP transport, through GraphQL Java, and to DataFetcher and other components it invokes. This includes both ThreadLocal context from the Spring MVC request handling thread and Reactor Context from the WebFlux processing pipeline.spring-doc.cn
WebMvc
A DataFetcher and other components invoked by GraphQL Java may not always execute on the same thread as the Spring MVC handler, for example if an asynchronous WebGraphQlInterceptor or DataFetcher switches to a different thread.spring-doc.cn
Spring for GraphQL supports propagating ThreadLocal values from the Servlet container thread to the thread a DataFetcher and other components invoked by GraphQL Java to execute on. To do this, an application needs to implement io.micrometer.context.ThreadLocalAccessor for a ThreadLocal values of interest:spring-doc.cn
public class RequestAttributesAccessor implements ThreadLocalAccessor<RequestAttributes> {
    public Object key() {
        return RequestAttributesAccessor.class.getName();
    public RequestAttributes getValue() {
        return RequestContextHolder.getRequestAttributes();
    public void setValue(RequestAttributes attributes) {
        RequestContextHolder.setRequestAttributes(attributes);
    public void reset() {
        RequestContextHolder.resetRequestAttributes();
You can register a ThreadLocalAccessor manually on startup with the global ContextRegistry instance, which is accessible via io.micrometer.context.ContextRegistry#getInstance(). You can also register it automatically through the java.util.ServiceLoader mechanism.spring-doc.cn
WebFlux
A Reactive DataFetcher can rely on access to Reactor context that originates from the WebFlux request handling chain. This includes Reactor context added by WebGraphQlInterceptor components.spring-doc.cn
Exceptions
In GraphQL Java, DataFetcherExceptionHandler decides how to represent exceptions from data fetching in the "errors" section of the response. An application can register a single handler only.spring-doc.cn
Spring for GraphQL registers a DataFetcherExceptionHandler that provides default handling and enables the DataFetcherExceptionResolver contract. An application can register any number of resolvers via GraphQLSource builder and those are in order until one them resolves the Exception to a List<graphql.GraphQLError>. The Spring Boot starter detects beans of this type.spring-doc.cn
DataFetcherExceptionResolverAdapter is a convenient base class with protected methods resolveToSingleError and resolveToMultipleErrors.spring-doc.cn
The Annotated Controllers programming model enables handling data fetching exceptions with annotated exception handler methods with a flexible method signature, see @GraphQlExceptionHandler for details.spring-doc.cn
A GraphQLError can be assigned to a category based on the GraphQL Java graphql.ErrorClassification, or the Spring GraphQL ErrorType, which defines the following:spring-doc.cn
If an exception remains unresolved, by default it is categorized as an INTERNAL_ERROR with a generic message that includes the category name and the executionId from DataFetchingEnvironment. The message is intentionally opaque to avoid leaking implementation details. Applications can use a DataFetcherExceptionResolver to customize error details.spring-doc.cn
Unresolved exception are logged at ERROR level along with the executionId to correlate to the error sent to the client. Resolved exceptions are logged at DEBUG level.spring-doc.cn
Request Exceptions
The GraphQL Java engine may run into validation or other errors when parsing the request and that in turn prevent request execution. In such cases, the response contains a "data" key with null and one or more request-level "errors" that are global, i.e. not having a field path.spring-doc.cn
DataFetcherExceptionResolver cannot handle such global errors because they are raised before execution begins and before any DataFetcher is invoked. An application can use transport level interceptors to inspect and transform errors in the ExecutionResult. See examples under WebGraphQlInterceptor.spring-doc.cn
Subscription Exceptions
The Publisher for a subscription request may complete with an error signal in which case the underlying transport (e.g. WebSocket) sends a final "error" type message with a list of GraphQL errors.spring-doc.cn
DataFetcherExceptionResolver cannot resolve errors from a subscription Publisher, since the data DataFetcher only creates the Publisher initially. After that, the transport subscribes to the Publisher that may then complete with an error.spring-doc.cn
An application can register a SubscriptionExceptionResolver in order to resolve exceptions from a subscription Publisher in order to resolve those to GraphQL errors to send to the client.spring-doc.cn
Pagination
The GraphQL Cursor Connection specification defines a way to navigate large result sets by returning a subset of items at a time in which each item is paired with a cursor that clients can use to request more items before or after the referenced item.spring-doc.cn
The specification calls this pattern "Connections", and schema types whose name end with ~Connection are a connection type that represents a paginated result set. All connection types contain a field called "edges" where an ~Edge type contains the actual item, a cursor, and a field called "pageInfo" that indicates if more items exist forward and backward.spring-doc.cn
Connection Types
Connection types require boilerplate definitions that Spring for GraphQL’s ConnectionTypeDefinitionConfigurer can add transparently on startup, if not explicitly declared. That means you only need the below, and the connection and edge types will be added for you:spring-doc.cn
Query {
	books(first:Int, after:String, last:Int, before:String): BookConnection
type Book {
	title: String!
The spec defined first and after arguments for forward pagination allow clients to request the "first" N items "after" a given cursor. Similarly, the last and before arguments for backward pagination arguments allow requesting the "last" N items "before" a given cursor.spring-doc.cn
The spec discourages including both first and last and also states the outcome for pagination becomes unclear. In Spring for GraphQL if first or after are present, then last and before are ignored.
To have connection types generated, configure ConnectionTypeDefinitionConfigurer as follows:spring-doc.cn
		.typeDefinitionConfigurer(new ConnectionTypeDefinitionConfigurer)
The above will add the following type definitions:spring-doc.cn
type BookConnection {
	edges: [BookEdge]!
	pageInfo: PageInfo!
type BookEdge {
	node: Book!
	cursor: String!
type PageInfo {
	hasPreviousPage: Boolean!
	hasNextPage: Boolean!
	startCursor: String
	endCursor: String
The Boot Starter registers ConnectionTypeDefinitionConfigurer by default.spring-doc.cn
ConnectionAdapter
In addition to Connection Types in the schema, you will also need equivalent Java types. GraphQL Java provides those, including generic Connection and Edge types, and PageInfo.spring-doc.cn
You can return Connection from a controller method, but it requires boilerplate code to adapt your underlying data pagination mechanism to Connection, to create cursors, add ~Edge wrappers, and create a PageInfo.spring-doc.cn
Spring for GraphQL defines the ConnectionAdapter contract to adapt a container of items to Connection. Adapters are invoked from a DataFetcher decorator that is in turn added by a ConnectionFieldTypeVisitor. You can configure it as follows:spring-doc.cn
ConnectionAdapter adapter = ... ;
GraphQLTypeVisitor visitor = ConnectionFieldTypeVisitor.create(List.of(adapter)) (1)
		.typeDefinitionConfigurer(..)
		.typeVisitors(List.of(visitor)) (2)
1 Create type visitor with one or more ConnectionAdapters.
2 Resister the type visitor.
There are built-in built-in ConnectionAdapters for Spring Data’s Window and Slice. You can also create your own custom adapter. ConnectionAdapter implementations rely on a CursorStrategy to create cursors for returned items. The same strategy is also used to support the Subrange controller method argument that contains pagination input.spring-doc.cn
CursorStrategy
CursorStrategy is a contract to encode and decode a String cursor that refers to the position of an item within a large result set. The cursor can be based on an index or on a keyset.spring-doc.cn
A ConnectionAdapter uses this to encode cursors for returned items. Annotated Controllers methods, Querydsl repositories, and Query by Example repositories use it to decode cursors from pagination requests, and create a Subrange.spring-doc.cn
CursorEncoder is a related contract that further encodes and decodes String cursors to make them opaque to clients. EncodingCursorStrategy combines CursorStrategy with a CursorEncoder. You can use Base64CursorEncoder, NoOpEncoder or create your own.spring-doc.cn
There is a built-in CursorStrategy for the Spring Data ScrollPosition. The Boot Starter registers a CursorStrategy<ScrollPosition> with Base64Encoder when Spring Data is present.spring-doc.cn
Sort
There is no standard way to provide sort information in a GraphQL request. However, pagination depends on a stable sort order. You can use a default order, or otherwise expose input types and extract sort details from GraphQL arguments.spring-doc.cn
There is built-in support for Spring Data’s Sort as a controller method argument. For this to work, you need to have a SortStrategy bean.spring-doc.cn
Batch Loading
Given a Book and its Author, we can create one DataFetcher for a book and another for its author. This allows selecting books with or without authors, but it means books and authors aren’t loaded together, which is especially inefficient when querying multiple books as the author for each book is loaded individually. This is known as the N+1 select problem.spring-doc.cn
DataLoader
GraphQL Java provides a DataLoader mechanism for batch loading of related entities. You can find the full details in the GraphQL Java docs. Below is a summary of how it works:spring-doc.cn
  1. Register DataLoader's in the DataLoaderRegistry that can load entities, given unique keys.spring-doc.cn
  2. DataFetcher's can access DataLoader's and use them to load entities by id.spring-doc.cn
  3. A DataLoader defers loading by returning a future so it can be done in a batch.spring-doc.cn
  4. DataLoader's maintain a per request cache of loaded entities that can further improve efficiency.spring-doc.cn
BatchLoaderRegistry
The complete batching loading mechanism in GraphQL Java requires implementing one of several BatchLoader interface, then wrapping and registering those as DataLoaders with a name in the DataLoaderRegistry.spring-doc.cn
The API in Spring GraphQL is slightly different. For registration, there is only one, central BatchLoaderRegistry exposing factory methods and a builder to create and register any number of batch loading functions:spring-doc.cn
public class MyConfig {
	public MyConfig(BatchLoaderRegistry registry) {
		registry.forTypePair(Long.class, Author.class).registerMappedBatchLoader((authorIds, env) -> {
				// return Mono<Map<Long, Author>
		// more registrations ...
The Boot Starter declares a BatchLoaderRegistry bean that you can inject into your configuration, as shown above, or into any component such as a controller in order register batch loading functions. In turn the BatchLoaderRegistry is injected into DefaultExecutionGraphQlService where it ensures DataLoader registrations per request.spring-doc.cn
By default, the DataLoader name is based on the class name of the target entity. This allows an @SchemaMapping method to declare a DataLoader argument with a generic type, and without the need for specifying a name. The name, however, can be customized through the BatchLoaderRegistry builder, if necessary, along with other DataLoaderOptions.spring-doc.cn
To configure default DataLoaderOptions globally, to use as a starting point for any registration, you can override Boot’s BatchLoaderRegistry bean and use the constructor for DefaultBatchLoaderRegistry that accepts Supplier<DataLoaderOptions>.spring-doc.cn
For many cases, when loading related entities, you can use @BatchMapping controller methods, which are a shortcut for and replace the need to use BatchLoaderRegistry and DataLoader directly.spring-doc.cn
BatchLoaderRegistry provides other important benefits too. It supports access to the same GraphQLContext from batch loading functions and from @BatchMapping methods, as well as ensures Context Propagation to them. This is why applications are expected to use it. It is possible to perform your own DataLoader registrations directly but such registrations would forgo the above benefits.spring-doc.cn
Testing Batch Loading
Start by having BatchLoaderRegistry perform registrations on a DataLoaderRegistry:spring-doc.cn
BatchLoaderRegistry batchLoaderRegistry = new DefaultBatchLoaderRegistry();
// perform registrations...
DataLoaderRegistry dataLoaderRegistry = DataLoaderRegistry.newRegistry().build();
batchLoaderRegistry.registerDataLoaders(dataLoaderRegistry, graphQLContext);
Now you can access and test individual DataLoader's as follows:spring-doc.cn
DataLoader<Long, Book> loader = dataLoaderRegistry.getDataLoader(Book.class.getName());
loader.load(1L);
loader.loadMany(Arrays.asList(2L, 3L));
List<Book> books = loader.dispatchAndJoin(); // actual loading
assertThat(books).hasSize(3);
assertThat(books.get(0).getName()).isEqualTo("...");
