REST Clients
The Spring Framework provides the following choices for making calls to REST endpoints:spring-doc.cn
RestClient
The RestClient is a synchronous HTTP client that offers a modern, fluent API. It offers an abstraction over HTTP libraries that allows for convenient conversion from a Java object to an HTTP request, and the creation of objects from an HTTP response.spring-doc.cn
Creating a RestClient
The RestClient is created using one of the static create methods. You can also use builder() to get a builder with further options, such as specifying which HTTP library to use (see Client Request Factories) and which message converters to use (see HTTP Message Conversion), setting a default URI, default path variables, default request headers, or uriBuilderFactory, or registering interceptors and initializers.spring-doc.cn
Once created (or built), the RestClient can be used safely by multiple threads.spring-doc.cn
The following sample shows how to create a default RestClient, and how to build a custom one.spring-doc.cn
RestClient defaultClient = RestClient.create();
RestClient customClient = RestClient.builder()
	.requestFactory(new HttpComponentsClientHttpRequestFactory())
	.messageConverters(converters -> converters.add(new MyCustomMessageConverter()))
	.baseUrl("https://example.com")
	.defaultUriVariables(Map.of("variable", "foo"))
	.defaultHeader("My-Header", "Foo")
	.defaultCookie("My-Cookie", "Bar")
	.requestInterceptor(myCustomInterceptor)
	.requestInitializer(myCustomInitializer)
val defaultClient = RestClient.create()
val customClient = RestClient.builder()
	.requestFactory(HttpComponentsClientHttpRequestFactory())
	.messageConverters { converters -> converters.add(MyCustomMessageConverter()) }
	.defaultUriVariables(mapOf("variable" to "foo"))
	.build()
Using the RestClient
When making an HTTP request with the RestClient, the first thing to specify is which HTTP method to use. This can be done with method(HttpMethod) or with the convenience methods get(), head(), post(), and so on.spring-doc.cn
Request URL
Next, the request URI can be specified with the uri methods. This step is optional and can be skipped if the RestClient is configured with a default URI. The URL is typically specified as a String, with optional URI template variables. The following example configures a GET request to example.com/orders/42:spring-doc.cn
int id = 42;
restClient.get()
	.uri("https://example.com/orders/{id}", id)
val id = 42
restClient.get()
A function can also be used for more controls, such as specifying request parameters.spring-doc.cn
String URLs are encoded by default, but this can be changed by building a client with a custom uriBuilderFactory. The URL can also be provided with a function or as a java.net.URI, both of which are not encoded. For more details on working with and encoding URIs, see URI Links.spring-doc.cn
Request headers and body
If necessary, the HTTP request can be manipulated by adding request headers with header(String, String), headers(Consumer<HttpHeaders>, or with the convenience methods accept(MediaType…​), acceptCharset(Charset…​) and so on. For HTTP requests that can contain a body (POST, PUT, and PATCH), additional methods are available: contentType(MediaType), and contentLength(long).spring-doc.cn
The request body itself can be set by body(Object), which internally uses HTTP Message Conversion. Alternatively, the request body can be set using a ParameterizedTypeReference, allowing you to use generics. Finally, the body can be set to a callback function that writes to an OutputStream.spring-doc.cn
Retrieving the response
Once the request has been set up, it can be sent by chaining method calls after retrieve(). For example, the response body can be accessed by using retrieve().body(Class) or retrieve().body(ParameterizedTypeReference) for parameterized types like lists. The body method converts the response contents into various types – for instance, bytes can be converted into a String, JSON can be converted into objects using Jackson, and so on (see HTTP Message Conversion).spring-doc.cn
The response can also be converted into a ResponseEntity, giving access to the response headers as well as the body, with retrieve().toEntity(Class)spring-doc.cn
Calling retrieve() by itself is a no-op and returns a ResponseSpec. Applications must invoke a terminal operation on the ResponseSpec to have any side effect. If consuming the response has no interest for your use case, you can use retrieve().toBodilessEntity().
This sample shows how RestClient can be used to perform a simple GET request.spring-doc.cn
String result = restClient.get() (1)
	.uri("https://example.com") (2)
	.retrieve() (3)
	.body(String.class); (4)
System.out.println(result); (5)
1 Set up a GET request
2 Specify the URL to connect to
3 Retrieve the response
4 Convert the response into a string
5 Print the result
val result= restClient.get() (1)
	.retrieve() (3)
	.body<String>() (4)
println(result) (5)
5 Print the result
Access to the response status code and headers is provided through ResponseEntity:spring-doc.cn
ResponseEntity<String> result = restClient.get() (1)
	.uri("https://example.com") (1)
	.retrieve()
	.toEntity(String.class); (2)
System.out.println("Response status: " + result.getStatusCode()); (3)
System.out.println("Response headers: " + result.getHeaders()); (3)
System.out.println("Contents: " + result.getBody()); (3)
1 Set up a GET request for the specified URL
2 Convert the response into a ResponseEntity
3 Print the result
val result = restClient.get() (1)
	.retrieve()
	.toEntity<String>() (2)
println("Response status: " + result.statusCode) (3)
println("Response headers: " + result.headers) (3)
println("Contents: " + result.body) (3)
3 Print the result
RestClient can convert JSON to objects, using the Jackson library. Note the usage of URI variables in this sample and that the Accept header is set to JSON.spring-doc.cn
int id = ...;
Pet pet = restClient.get()
	.uri("https://petclinic.example.com/pets/{id}", id) (1)
	.accept(APPLICATION_JSON) (2)
	.retrieve()
	.body(Pet.class); (3)
1 Using URI variables
2 Set the Accept header to application/json
3 Convert the JSON response into a Pet domain object
val id = ...
val pet = restClient.get()
	.retrieve()
	.body<Pet>() (3)
In the next sample, RestClient is used to perform a POST request that contains JSON, which again is converted using Jackson.spring-doc.cn
Pet pet = ... (1)
ResponseEntity<Void> response = restClient.post() (2)
	.uri("https://petclinic.example.com/pets/new") (2)
	.contentType(APPLICATION_JSON) (3)
	.body(pet) (4)
	.retrieve()
	.toBodilessEntity(); (5)
1 Create a Pet domain object
2 Set up a POST request, and the URL to connect to
3 Set the Content-Type header to application/json
4 Use pet as the request body
5 Convert the response into a response entity with no body.
val pet: Pet = ... (1)
val response = restClient.post() (2)
	.body(pet) (4)
	.retrieve()
	.toBodilessEntity() (5)
Error handling
By default, RestClient throws a subclass of RestClientException when retrieving a response with a 4xx or 5xx status code. This behavior can be overridden using onStatus.spring-doc.cn
	.uri("https://example.com/this-url-does-not-exist") (1)
	.retrieve()
	.onStatus(HttpStatusCode::is4xxClientError, (request, response) -> { (2)
		throw new MyCustomRuntimeException(response.getStatusCode(), response.getHeaders()); (3)
1 Create a GET request for a URL that returns a 404 status code
2 Set up a status handler for all 4xx status codes
3 Throw a custom exception
	.retrieve()
	.onStatus(HttpStatusCode::is4xxClientError) { _, response -> (2)
		throw MyCustomRuntimeException(response.getStatusCode(), response.getHeaders()) } (3)
	.body<String>()
Exchange
For more advanced scenarios, the RestClient gives access to the underlying HTTP request and response through the exchange() method, which can be used instead of retrieve(). Status handlers are not applied when use exchange(), because the exchange function already provides access to the full response, allowing you to perform any error handling necessary.spring-doc.cn
Pet result = restClient.get()
	.exchange((request, response) -> { (1)
		if (response.getStatusCode().is4xxClientError()) { (2)
			throw new MyCustomRuntimeException(response.getStatusCode(), response.getHeaders()); (2)
		else {
			Pet pet = convertResponse(response); (3)
			return pet;
1 exchange provides the request and response
2 Throw an exception when the response has a 4xx status code
3 Convert the response into a Pet domain object
	.accept(MediaType.APPLICATION_JSON)
	.exchange { request, response -> (1)
			throw MyCustomRuntimeException(response.getStatusCode(), response.getHeaders()) (2)
		} else {
			val pet: Pet = convertResponse(response) (3)
			pet
Jackson JSON Views
To serialize only a subset of the object properties, you can specify a Jackson JSON View, as the following example shows:spring-doc.cn
MappingJacksonValue value = new MappingJacksonValue(new User("eric", "7!jd#h23"));
value.setSerializationView(User.WithoutPasswordView.class);
ResponseEntity<Void> response = restClient.post() // or RestTemplate.postForEntity
	.body(value)
	.retrieve()
Multipart
To send multipart data, you need to provide a MultiValueMap<String, Object> whose values may be an Object for part content, a Resource for a file part, or an HttpEntity for part content with headers. For example:spring-doc.cn
MultiValueMap<String, Object> parts = new LinkedMultiValueMap<>();
parts.add("fieldPart", "fieldValue");
parts.add("filePart", new FileSystemResource("...logo.png"));
parts.add("jsonPart", new Person("Jason"));
HttpHeaders headers = new HttpHeaders();
headers.setContentType(MediaType.APPLICATION_XML);
parts.add("xmlPart", new HttpEntity<>(myBean, headers));
// send using RestClient.post or RestTemplate.postForEntity
In most cases, you do not have to specify the Content-Type for each part. The content type is determined automatically based on the HttpMessageConverter chosen to serialize it or, in the case of a Resource, based on the file extension. If necessary, you can explicitly provide the MediaType with an HttpEntity wrapper.spring-doc.cn
Once the MultiValueMap is ready, you can use it as the body of a POST request, using RestClient.post().body(parts) (or RestTemplate.postForObject).spring-doc.cn
If the MultiValueMap contains at least one non-String value, the Content-Type is set to multipart/form-data by the FormHttpMessageConverter. If the MultiValueMap has String values, the Content-Type defaults to application/x-www-form-urlencoded. If necessary the Content-Type may also be set explicitly.spring-doc.cn
To execute the HTTP request, RestClient uses a client HTTP library. These libraries are adapted via the ClientRequestFactory interface. Various implementations are available:spring-doc.cn
  • JdkClientHttpRequestFactory for Java’s HttpClientspring-doc.cn
  • HttpComponentsClientHttpRequestFactory for use with Apache HTTP Components HttpClientspring-doc.cn
  • JettyClientHttpRequestFactory for Jetty’s HttpClientspring-doc.cn
  • ReactorNettyClientRequestFactory for Reactor Netty’s HttpClientspring-doc.cn
  • SimpleClientHttpRequestFactory as a simple defaultspring-doc.cn
If no request factory is specified when the RestClient was built, it will use the Apache or Jetty HttpClient if they are available on the classpath. Otherwise, if the java.net.http module is loaded, it will use Java’s HttpClient. Finally, it will resort to the simple default.spring-doc.cn
Note that the SimpleClientHttpRequestFactory may raise an exception when accessing the status of a response that represents an error (for example, 401). If this is an issue, use any of the alternative request factories.
WebClient
WebClient is a non-blocking, reactive client to perform HTTP requests. It was introduced in 5.0 and offers an alternative to the RestTemplate, with support for synchronous, asynchronous, and streaming scenarios.spring-doc.cn
WebClient supports the following:spring-doc.cn
See WebClient for more details.spring-doc.cn
RestTemplate
The RestTemplate provides a high-level API over HTTP client libraries in the form of a classic Spring Template class. It exposes the following groups of overloaded methods:spring-doc.cn
The RestClient offers a more modern API for synchronous HTTP access. For asynchronous and streaming scenarios, consider the reactive WebClient.
Table 1. RestTemplate methods
Method group Description
getForObjectspring-doc.cn
Retrieves a representation via GET.spring-doc.cn
getForEntityspring-doc.cn
Retrieves a ResponseEntity (that is, status, headers, and body) by using GET.spring-doc.cn
headForHeadersspring-doc.cn
Retrieves all headers for a resource by using HEAD.spring-doc.cn
postForLocationspring-doc.cn
Creates a new resource by using POST and returns the Location header from the response.spring-doc.cn
postForObjectspring-doc.cn
Creates a new resource by using POST and returns the representation from the response.spring-doc.cn
postForEntityspring-doc.cn
putspring-doc.cn
Creates or updates a resource by using PUT.spring-doc.cn
patchForObjectspring-doc.cn
Updates a resource by using PATCH and returns the representation from the response. Note that the JDK HttpURLConnection does not support PATCH, but Apache HttpComponents and others do.spring-doc.cn
deletespring-doc.cn
Deletes the resources at the specified URI by using DELETE.spring-doc.cn
optionsForAllowspring-doc.cn
Retrieves allowed HTTP methods for a resource by using ALLOW.spring-doc.cn
exchangespring-doc.cn
More generalized (and less opinionated) version of the preceding methods that provides extra flexibility when needed. It accepts a RequestEntity (including HTTP method, URL, headers, and body as input) and returns a ResponseEntity.spring-doc.cn
These methods allow the use of ParameterizedTypeReference instead of Class to specify a response type with generics.spring-doc.cn
executespring-doc.cn
The most generalized way to perform a request, with full control over request preparation and response extraction through callback interfaces.spring-doc.cn
Initialization
RestTemplate uses the same HTTP library abstraction as RestClient. By default, it uses the SimpleClientHttpRequestFactory, but this can be changed via the constructor. See Client Request Factories.spring-doc.cn
RestTemplate can be instrumented for observability, in order to produce metrics and traces. See the RestTemplate Observability support section.
Body
Objects passed into and returned from RestTemplate methods are converted to and from HTTP messages with the help of an HttpMessageConverter, see HTTP Message Conversion.spring-doc.cn
Migrating from RestTemplate to RestClient
The following table shows RestClient equivalents for RestTemplate methods. It can be used to migrate from the latter to the former.spring-doc.cn
Table 2. RestClient equivalents for RestTemplate methods
RestTemplate method RestClient equivalent
getForObject(String, Class, Object…​)spring-doc.cn
get() .uri(String, Object…​) .retrieve() .body(Class)spring-doc.cn
getForObject(String, Class, Map)spring-doc.cn
get() .uri(String, Map) .retrieve() .body(Class)spring-doc.cn
getForObject(URI, Class)spring-doc.cn
get() .uri(URI) .retrieve() .body(Class)spring-doc.cn
getForEntity(String, Class, Object…​)spring-doc.cn
get() .uri(String, Object…​) .retrieve() .toEntity(Class)spring-doc.cn
getForEntity(String, Class, Map)spring-doc.cn
get() .uri(String, Map) .retrieve() .toEntity(Class)spring-doc.cn
getForEntity(URI, Class)spring-doc.cn
get() .uri(URI) .retrieve() .toEntity(Class)spring-doc.cn
headForHeaders(String, Object…​)spring-doc.cn
head() .uri(String, Object…​) .retrieve() .toBodilessEntity() .getHeaders()spring-doc.cn
headForHeaders(String, Map)spring-doc.cn
head() .uri(String, Map) .retrieve() .toBodilessEntity() .getHeaders()spring-doc.cn
headForHeaders(URI)spring-doc.cn
head() .uri(URI) .retrieve() .toBodilessEntity() .getHeaders()spring-doc.cn
postForLocation(String, Object, Object…​)spring-doc.cn
post() .uri(String, Object…​) .body(Object).retrieve() .toBodilessEntity() .getLocation()spring-doc.cn
postForLocation(String, Object, Map)spring-doc.cn
post() .uri(String, Map) .body(Object) .retrieve() .toBodilessEntity() .getLocation()spring-doc.cn
postForLocation(URI, Object)spring-doc.cn
post() .uri(URI) .body(Object) .retrieve() .toBodilessEntity() .getLocation()spring-doc.cn
postForObject(String, Object, Class, Object…​)spring-doc.cn
post() .uri(String, Object…​) .body(Object) .retrieve() .body(Class)spring-doc.cn
postForObject(String, Object, Class, Map)spring-doc.cn
post() .uri(String, Map) .body(Object) .retrieve() .body(Class)spring-doc.cn
postForObject(URI, Object, Class)spring-doc.cn
post() .uri(URI) .body(Object) .retrieve() .body(Class)spring-doc.cn
postForEntity(String, Object, Class, Object…​)spring-doc.cn
post() .uri(String, Object…​) .body(Object) .retrieve() .toEntity(Class)spring-doc.cn
postForEntity(String, Object, Class, Map)spring-doc.cn
post() .uri(String, Map) .body(Object) .retrieve() .toEntity(Class)spring-doc.cn
postForEntity(URI, Object, Class)spring-doc.cn
post() .uri(URI) .body(Object) .retrieve() .toEntity(Class)spring-doc.cn
put(String, Object, Object…​)spring-doc.cn
put() .uri(String, Object…​) .body(Object) .retrieve() .toBodilessEntity()spring-doc.cn
put(String, Object, Map)spring-doc.cn
put() .uri(String, Map) .body(Object) .retrieve() .toBodilessEntity()spring-doc.cn
put(URI, Object)spring-doc.cn
put() .uri(URI) .body(Object) .retrieve() .toBodilessEntity()spring-doc.cn
patchForObject(String, Object, Class, Object…​)spring-doc.cn
patch() .uri(String, Object…​) .body(Object) .retrieve() .body(Class)spring-doc.cn
patchForObject(String, Object, Class, Map)spring-doc.cn
patch() .uri(String, Map) .body(Object) .retrieve() .body(Class)spring-doc.cn
patchForObject(URI, Object, Class)spring-doc.cn
patch() .uri(URI) .body(Object) .retrieve() .body(Class)spring-doc.cn
delete(String, Object…​)spring-doc.cn
delete() .uri(String, Object…​) .retrieve() .toBodilessEntity()spring-doc.cn
delete(String, Map)spring-doc.cn
delete() .uri(String, Map) .retrieve() .toBodilessEntity()spring-doc.cn
delete(URI)spring-doc.cn
delete() .uri(URI) .retrieve() .toBodilessEntity()spring-doc.cn
optionsForAllow(String, Object…​)spring-doc.cn
options() .uri(String, Object…​) .retrieve() .toBodilessEntity() .getAllow()spring-doc.cn
optionsForAllow(String, Map)spring-doc.cn
options() .uri(String, Map) .retrieve() .toBodilessEntity() .getAllow()spring-doc.cn
optionsForAllow(URI)spring-doc.cn
options() .uri(URI) .retrieve() .toBodilessEntity() .getAllow()spring-doc.cn
exchange(String, HttpMethod, HttpEntity, Class, Object…​)spring-doc.cn
method(HttpMethod) .uri(String, Object…​) .headers(Consumer<HttpHeaders>) .body(Object) .retrieve() .toEntity(Class) [1]spring-doc.cn
exchange(String, HttpMethod, HttpEntity, Class, Map)spring-doc.cn
method(HttpMethod) .uri(String, Map) .headers(Consumer<HttpHeaders>) .body(Object) .retrieve() .toEntity(Class) [1]spring-doc.cn
exchange(URI, HttpMethod, HttpEntity, Class)spring-doc.cn
method(HttpMethod) .uri(URI) .headers(Consumer<HttpHeaders>) .body(Object) .retrieve() .toEntity(Class) [1]spring-doc.cn
exchange(String, HttpMethod, HttpEntity, ParameterizedTypeReference, Object…​)spring-doc.cn
method(HttpMethod) .uri(String, Object…​) .headers(Consumer<HttpHeaders>) .body(Object) .retrieve() .toEntity(ParameterizedTypeReference) [1]spring-doc.cn
exchange(String, HttpMethod, HttpEntity, ParameterizedTypeReference, Map)spring-doc.cn
method(HttpMethod) .uri(String, Map) .headers(Consumer<HttpHeaders>) .body(Object) .retrieve() .toEntity(ParameterizedTypeReference) [1]spring-doc.cn
exchange(URI, HttpMethod, HttpEntity, ParameterizedTypeReference)spring-doc.cn
method(HttpMethod) .uri(URI) .headers(Consumer<HttpHeaders>) .body(Object) .retrieve() .toEntity(ParameterizedTypeReference) [1]spring-doc.cn
exchange(RequestEntity, Class)spring-doc.cn
method(HttpMethod) .uri(URI) .headers(Consumer<HttpHeaders>) .body(Object) .retrieve() .toEntity(Class) [2]spring-doc.cn
exchange(RequestEntity, ParameterizedTypeReference)spring-doc.cn
method(HttpMethod) .uri(URI) .headers(Consumer<HttpHeaders>) .body(Object) .retrieve() .toEntity(ParameterizedTypeReference) [2]spring-doc.cn
execute(String, HttpMethod, RequestCallback, ResponseExtractor, Object…​)spring-doc.cn
method(HttpMethod) .uri(String, Object…​) .exchange(ExchangeFunction)spring-doc.cn
execute(String, HttpMethod, RequestCallback, ResponseExtractor, Map)spring-doc.cn
method(HttpMethod) .uri(String, Map) .exchange(ExchangeFunction)spring-doc.cn
execute(URI, HttpMethod, RequestCallback, ResponseExtractor)spring-doc.cn
method(HttpMethod) .uri(URI) .exchange(ExchangeFunction)spring-doc.cn
HTTP Interface
The Spring Framework lets you define an HTTP service as a Java interface with @HttpExchange methods. You can pass such an interface to HttpServiceProxyFactory to create a proxy which performs requests through an HTTP client such as RestClient or WebClient. You can also implement the interface from an @Controller for server request handling.spring-doc.cn
Start by creating the interface with @HttpExchange methods:spring-doc.cn
public interface RepositoryService {
	@GetExchange("/repos/{owner}/{repo}")
	Repository getRepository(@PathVariable String owner, @PathVariable String repo);
	// more HTTP exchange methods...
Now you can create a proxy that performs requests when methods are called.spring-doc.cn
For RestClient:spring-doc.cn
RestClient restClient = RestClient.builder().baseUrl("https://api.github.com/").build();
RestClientAdapter adapter = RestClientAdapter.create(restClient);
HttpServiceProxyFactory factory = HttpServiceProxyFactory.builderFor(adapter).build();
RepositoryService service = factory.createClient(RepositoryService.class);
For WebClient:spring-doc.cn
WebClient webClient = WebClient.builder().baseUrl("https://api.github.com/").build();
WebClientAdapter adapter = WebClientAdapter.create(webClient);
For RestTemplate:spring-doc.cn
RestTemplate restTemplate = new RestTemplate();
restTemplate.setUriTemplateHandler(new DefaultUriBuilderFactory("https://api.github.com/"));
RestTemplateAdapter adapter = RestTemplateAdapter.create(restTemplate);
@HttpExchange is supported at the type level where it applies to all methods:spring-doc.cn
@HttpExchange(url = "/repos/{owner}/{repo}", accept = "application/vnd.github.v3+json")
	@GetExchange
	@PatchExchange(contentType = MediaType.APPLICATION_FORM_URLENCODED_VALUE)
	void updateRepository(@PathVariable String owner, @PathVariable String repo,
			@RequestParam String name, @RequestParam String description, @RequestParam String homepage);
Method Parameters
Annotated, HTTP exchange methods support flexible method signatures with the following method parameters:spring-doc.cn
Method argument Description
URIspring-doc.cn
Dynamically set the URL for the request, overriding the annotation’s url attribute.spring-doc.cn
UriBuilderFactoryspring-doc.cn
Provide a UriBuilderFactory to expand the URI template and URI variables with. In effect, replaces the UriBuilderFactory (and its base URL) of the underlying client.spring-doc.cn
HttpMethodspring-doc.cn
Dynamically set the HTTP method for the request, overriding the annotation’s method attributespring-doc.cn
@RequestHeaderspring-doc.cn
Add a request header or multiple headers. The argument may be a single value, a Collection<?> of values, Map<String, ?>,MultiValueMap<String, ?>. Type conversion is supported for non-String values. Header values are added and do not override already added header values.spring-doc.cn
@PathVariablespring-doc.cn
Add a variable for expand a placeholder in the request URL. The argument may be a Map<String, ?> with multiple variables, or an individual value. Type conversion is supported for non-String values.spring-doc.cn
@RequestAttributespring-doc.cn
Provide an Object to add as a request attribute. Only supported by RestClient and WebClient.spring-doc.cn
@RequestBodyspring-doc.cn
Provide the body of the request either as an Object to be serialized, or a Reactive Streams Publisher such as Mono, Flux, or any other async type supported through the configured ReactiveAdapterRegistry.spring-doc.cn
@RequestParamspring-doc.cn
Add a request parameter or multiple parameters. The argument may be a Map<String, ?> or MultiValueMap<String, ?> with multiple parameters, a Collection<?> of values, or an individual value. Type conversion is supported for non-String values.spring-doc.cn
When "content-type" is set to "application/x-www-form-urlencoded", request parameters are encoded in the request body. Otherwise, they are added as URL query parameters.spring-doc.cn
@RequestPartspring-doc.cn
Add a request part, which may be a String (form field), Resource (file part), Object (entity to be encoded, for example, as JSON), HttpEntity (part content and headers), a Spring Part, or Reactive Streams Publisher of any of the above.spring-doc.cn
MultipartFilespring-doc.cn
Add a request part from a MultipartFile, typically used in a Spring MVC controller where it represents an uploaded file.spring-doc.cn
@CookieValuespring-doc.cn
Add a cookie or multiple cookies. The argument may be a Map<String, ?> or MultiValueMap<String, ?> with multiple cookies, a Collection<?> of values, or an individual value. Type conversion is supported for non-String values.spring-doc.cn
Method parameters cannot be null unless the required attribute (where available on a parameter annotation) is set to false, or the parameter is marked optional as determined by MethodParameter#isOptional.spring-doc.cn
Custom argument resolver
For more complex cases, HTTP interfaces do not support RequestEntity types as method parameters. This would take over the entire HTTP request and not improve the semantics of the interface. Instead of adding many method parameters, developers can combine them into a custom type and configure a dedicated HttpServiceArgumentResolver implementation.spring-doc.cn
In the following HTTP interface, we are using a custom Search type as a parameter:spring-doc.cn
	@GetExchange("/repos/search")
	List<Repository> searchRepository(Search search);
	fun searchRepository(search: Search): List<Repository>
We can implement our own HttpServiceArgumentResolver that supports our custom Search type and writes its data in the outgoing HTTP request.spring-doc.cn
static class SearchQueryArgumentResolver implements HttpServiceArgumentResolver {
	public boolean resolve(Object argument, MethodParameter parameter, HttpRequestValues.Builder requestValues) {
		if (parameter.getParameterType().equals(Search.class)) {
			Search search = (Search) argument;
			requestValues.addRequestParameter("owner", search.owner());
			requestValues.addRequestParameter("language", search.language());
			requestValues.addRequestParameter("query", search.query());
			return true;
		return false;
class SearchQueryArgumentResolver : HttpServiceArgumentResolver {
	override fun resolve(
		argument: Any?,
		parameter: MethodParameter,
		requestValues: HttpRequestValues.Builder
	): Boolean {
		if (parameter.getParameterType() == Search::class.java) {
			val search = argument as Search
			requestValues.addRequestParameter("owner", search.owner)
				.addRequestParameter("language", search.language)
				.addRequestParameter("query", search.query)
			return true
		return false
Finally, we can use this argument resolver during the setup and use our HTTP interface.spring-doc.cn
		.customArgumentResolver(new SearchQueryArgumentResolver())
RepositoryService repositoryService = factory.createClient(RepositoryService.class);
Search search = Search.create()
		.owner("spring-projects")
		.language("java")
		.query("rest")
List<Repository> repositories = repositoryService.searchRepository(search);
val restClient = RestClient.builder().baseUrl("https://api.github.com/").build()
val adapter = RestClientAdapter.create(restClient)
val factory = HttpServiceProxyFactory
	.customArgumentResolver(SearchQueryArgumentResolver())
	.build()
val repositoryService = factory.createClient<RepositoryService>(RepositoryService::class.java)
val search = Search(owner = "spring-projects", language = "java", query = "rest")
val repositories = repositoryService.searchRepository(search)
Return Values
The supported return values depend on the underlying client.spring-doc.cn
Clients adapted to HttpExchangeAdapter such as RestClient and RestTemplate support synchronous return values:spring-doc.cn
Method return value Description
voidspring-doc.cn
Perform the given request.spring-doc.cn
HttpHeadersspring-doc.cn
Perform the given request and return the response headers.spring-doc.cn
<T>spring-doc.cn
Perform the given request and decode the response content to the declared return type.spring-doc.cn
ResponseEntity<Void>spring-doc.cn
Perform the given request and return a ResponseEntity with the status and headers.spring-doc.cn
ResponseEntity<T>spring-doc.cn
Perform the given request, decode the response content to the declared return type, and return a ResponseEntity with the status, headers, and the decoded body.spring-doc.cn
Clients adapted to ReactorHttpExchangeAdapter such as WebClient, support all of above as well as reactive variants. The table below shows Reactor types, but you can also use other reactive types that are supported through the ReactiveAdapterRegistry:spring-doc.cn
Mono<Void>spring-doc.cn
Perform the given request, and release the response content, if any.spring-doc.cn
Mono<HttpHeaders>spring-doc.cn
Perform the given request, release the response content, if any, and return the response headers.spring-doc.cn
Mono<T>spring-doc.cn
Flux<T>spring-doc.cn
Perform the given request and decode the response content to a stream of the declared element type.spring-doc.cn
Mono<ResponseEntity<Void>>spring-doc.cn
Perform the given request, and release the response content, if any, and return a ResponseEntity with the status and headers.spring-doc.cn
Mono<ResponseEntity<T>>spring-doc.cn
Mono<ResponseEntity<Flux<T>>spring-doc.cn
Perform the given request, decode the response content to a stream of the declared element type, and return a ResponseEntity with the status, headers, and the decoded response body stream.spring-doc.cn
By default, the timeout for synchronous return values with ReactorHttpExchangeAdapter depends on how the underlying HTTP client is configured. You can set a blockTimeout value on the adapter level as well, but we recommend relying on timeout settings of the underlying HTTP client, which operates at a lower level and provides more control.spring-doc.cn
Error Handling
To customize error response handling, you need to configure the underlying HTTP client.spring-doc.cn
By default, RestClient raises RestClientException for 4xx and 5xx HTTP status codes. To customize this, register a response status handler that applies to all responses performed through the client:spring-doc.cn
		.defaultStatusHandler(HttpStatusCode::isError, (request, response) -> ...)
For more details and options, such as suppressing error status codes, see the Javadoc of defaultStatusHandler in RestClient.Builder.spring-doc.cn
By default, WebClient raises WebClientResponseException for 4xx and 5xx HTTP status codes. To customize this, register a response status handler that applies to all responses performed through the client:spring-doc.cn
		.defaultStatusHandler(HttpStatusCode::isError, resp -> ...)
HttpServiceProxyFactory factory = HttpServiceProxyFactory.builder(adapter).build();
For more details and options, such as suppressing error status codes, see the Javadoc of defaultStatusHandler in WebClient.Builder.spring-doc.cn
By default, RestTemplate raises RestClientException for 4xx and 5xx HTTP status codes. To customize this, register an error handler that applies to all responses performed through the client:spring-doc.cn
restTemplate.setErrorHandler(myErrorHandler);
For more details and options, see the Javadoc of setErrorHandler in RestTemplate and the ResponseErrorHandler hierarchy.spring-doc.cn
1. HttpEntity headers and body have to be supplied to the RestClient via headers(Consumer<HttpHeaders>) and body(Object).
2. RequestEntity method, URI, headers and body have to be supplied to the RestClient via method(HttpMethod), uri(URI), headers(Consumer<HttpHeaders>) and body(Object).
