This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.1.13! |
The Data Access Object (DAO) support in Spring is aimed at making it easy to work with data access technologies (such as JDBC, Hibernate, or JPA) in a consistent way. This lets you switch between the aforementioned persistence technologies fairly easily, and it also lets you code without worrying about catching exceptions that are specific to each technology.
Consistent Exception Hierarchy
Spring provides a convenient translation from technology-specific exceptions, such as
SQLException
to its own exception class hierarchy, which has DataAccessException
as
the root exception. These exceptions wrap the original exception so that there is never
any risk that you might lose any information about what might have gone wrong.
In addition to JDBC exceptions, Spring can also wrap JPA- and Hibernate-specific exceptions, converting them to a set of focused runtime exceptions. This lets you handle most non-recoverable persistence exceptions in only the appropriate layers, without having annoying boilerplate catch-and-throw blocks and exception declarations in your DAOs. (You can still trap and handle exceptions anywhere you need to though.) As mentioned above, JDBC exceptions (including database-specific dialects) are also converted to the same hierarchy, meaning that you can perform some operations with JDBC within a consistent programming model.
The preceding discussion holds true for the various template classes in Spring’s support
for various ORM frameworks. If you use the interceptor-based classes, the application must
care about handling HibernateExceptions
and PersistenceExceptions
itself, preferably by
delegating to the convertHibernateAccessException(..)
or convertJpaAccessException(..)
methods, respectively, of SessionFactoryUtils
. These methods convert the exceptions
to exceptions that are compatible with the exceptions in the org.springframework.dao
exception hierarchy. As PersistenceExceptions
are unchecked, they can get thrown, too
(sacrificing generic DAO abstraction in terms of exceptions, though).
The following image shows the exception hierarchy that Spring provides.
(Note that the class hierarchy detailed in the image shows only a subset of the entire
DataAccessException
hierarchy.)
Annotations Used to Configure DAO or Repository Classes
The best way to guarantee that your Data Access Objects (DAOs) or repositories provide
exception translation is to use the @Repository
annotation. This annotation also
lets the component scanning support find and configure your DAOs and repositories
without having to provide XML configuration entries for them. The following example shows
how to use the @Repository
annotation:
Java
Kotlin
@Repository (1)
public class SomeMovieFinder implements MovieFinder {
1 | The @Repository annotation. |
@Repository (1)
class SomeMovieFinder : MovieFinder {
Any DAO or repository implementation needs access to a persistence resource,
depending on the persistence technology used. For example, a JDBC-based repository
needs access to a JDBC DataSource
, and a JPA-based repository needs access to an
EntityManager
. The easiest way to accomplish this is to have this resource dependency
injected by using one of the @Autowired
, @Inject
, @Resource
or @PersistenceContext
annotations. The following example works for a JPA repository:
Java
Kotlin
@Repository
public class JpaMovieFinder implements MovieFinder {
@PersistenceContext
private EntityManager entityManager;
@Repository
class JpaMovieFinder : MovieFinder {
@PersistenceContext
private lateinit var entityManager: EntityManager
If you use the classic Hibernate APIs, you can inject SessionFactory
, as the following
example shows:
Java
Kotlin
@Repository
public class HibernateMovieFinder implements MovieFinder {
private SessionFactory sessionFactory;
@Autowired
public void setSessionFactory(SessionFactory sessionFactory) {
this.sessionFactory = sessionFactory;
@Repository
class HibernateMovieFinder(private val sessionFactory: SessionFactory) : MovieFinder {
The last example we show here is for typical JDBC support. You could have the DataSource
injected into an initialization method or a constructor, where you would create a JdbcTemplate
and other data access support classes (such as SimpleJdbcCall
and others) by using this
DataSource
. The following example autowires a DataSource
Java
Kotlin
@Repository
public class JdbcMovieFinder implements MovieFinder {
private JdbcTemplate jdbcTemplate;
@Autowired
public void init(DataSource dataSource) {
this.jdbcTemplate = new JdbcTemplate(dataSource);
@Repository
class JdbcMovieFinder(dataSource: DataSource) : MovieFinder {
private val jdbcTemplate = JdbcTemplate(dataSource)
See the specific coverage of each persistence technology for details on how to configure the application context to take advantage of these annotations. |
