请访问:https://docs.spring.io/spring-framework/reference/6.0-SNAPSHOT/data-access/jdbc/parameter-handling.html Spring Framework Data Access Data Access with JDBC Common Problems with Parameter and Data Value Handling Modeling JDBC Operations as Java Objects Embedded Database Support
