For the latest stable version, please use Spring Data Commons 3.4.4!spring-doc.cn
Custom Repository Implementations
Spring Data provides various options to create query methods with little coding. But when those options don’t fit your needs you can also provide your own custom implementation for repository methods. This section describes how to do that.spring-doc.cn
Customizing Individual Repositories
To enrich a repository with custom functionality, you must first define a fragment interface and an implementation for the custom functionality, as follows:spring-doc.cn
Interface for custom repository functionality
interface CustomizedUserRepository {
  void someCustomMethod(User user);
Implementation of custom repository functionality
class CustomizedUserRepositoryImpl implements CustomizedUserRepository {
  public void someCustomMethod(User user) {
    // Your custom implementation
The most important part of the class name that corresponds to the fragment interface is the Impl postfix. You can customize the store-specific postfix by setting @Enable<StoreModule>Repositories(repositoryImplementationPostfix = …).spring-doc.cn
Historically, Spring Data custom repository implementation discovery followed a naming pattern that derived the custom implementation class name from the repository allowing effectively a single custom implementation.spring-doc.cn
A type located in the same package as the repository interface, matching repository interface name followed by implementation postfix, is considered a custom implementation and will be treated as a custom implementation. A class following that name can lead to undesired behavior.spring-doc.cn
We consider the single-custom implementation naming deprecated and recommend not using this pattern. Instead, migrate to a fragment-based programming model.spring-doc.cn
The implementation itself does not depend on Spring Data and can be a regular Spring bean. Consequently, you can use standard dependency injection behavior to inject references to other beans (such as a JdbcTemplate), take part in aspects, and so on.spring-doc.cn
Then you can let your repository interface extend the fragment interface, as follows:spring-doc.cn
Changes to your repository interface
interface UserRepository extends CrudRepository<User, Long>, CustomizedUserRepository {
  // Declare query methods here
Extending the fragment interface with your repository interface combines the CRUD and custom functionality and makes it available to clients.spring-doc.cn
Spring Data repositories are implemented by using fragments that form a repository composition. Fragments are the base repository, functional aspects (such as QueryDsl), and custom interfaces along with their implementations. Each time you add an interface to your repository interface, you enhance the composition by adding a fragment. The base repository and repository aspect implementations are provided by each Spring Data module.spring-doc.cn
The following example shows custom interfaces and their implementations:spring-doc.cn
Fragments with their implementations
interface HumanRepository {
  void someHumanMethod(User user);
class HumanRepositoryImpl implements HumanRepository {
  public void someHumanMethod(User user) {
interface ContactRepository {
  void someContactMethod(User user);
  User anotherContactMethod(User user);
class ContactRepositoryImpl implements ContactRepository {
  public void someContactMethod(User user) {
  public User anotherContactMethod(User user) {
The following example shows the interface for a custom repository that extends CrudRepository:spring-doc.cn
interface UserRepository extends CrudRepository<User, Long>, HumanRepository, ContactRepository {
Repositories may be composed of multiple custom implementations that are imported in the order of their declaration. Custom implementations have a higher priority than the base implementation and repository aspects. This ordering lets you override base repository and aspect methods and resolves ambiguity if two fragments contribute the same method signature. Repository fragments are not limited to use in a single repository interface. Multiple repositories may use a fragment interface, letting you reuse customizations across different repositories.spring-doc.cn
The following example shows a repository fragment and its implementation:spring-doc.cn
Fragments overriding save(…)
interface CustomizedSave<T> {
  <S extends T> S save(S entity);
class CustomizedSaveImpl<T> implements CustomizedSave<T> {
  public <S extends T> S save(S entity) {
The following example shows a repository that uses the preceding repository fragment:spring-doc.cn
Customized repository interfaces
interface UserRepository extends CrudRepository<User, Long>, CustomizedSave<User> {
interface PersonRepository extends CrudRepository<Person, Long>, CustomizedSave<Person> {
Configuration
The repository infrastructure tries to autodetect custom implementation fragments by scanning for classes below the package in which it found a repository. These classes need to follow the naming convention of appending a postfix defaulting to Impl.spring-doc.cn
The following example shows a repository that uses the default postfix and a repository that sets a custom value for the postfix:spring-doc.cn
Example 1. Configuration example
@EnableJpaRepositories(repositoryImplementationPostfix = "MyPostfix")
class Configuration { … }
<repositories base-package="com.acme.repository" />
<repositories base-package="com.acme.repository" repository-impl-postfix="MyPostfix" />
The first configuration in the preceding example tries to look up a class called com.acme.repository.CustomizedUserRepositoryImpl to act as a custom repository implementation. The second example tries to look up com.acme.repository.CustomizedUserRepositoryMyPostfix.spring-doc.cn
Resolution of Ambiguity
If multiple implementations with matching class names are found in different packages, Spring Data uses the bean names to identify which one to use.spring-doc.cn
Given the following two custom implementations for the CustomizedUserRepository shown earlier, the first implementation is used. Its bean name is customizedUserRepositoryImpl, which matches that of the fragment interface (CustomizedUserRepository) plus the postfix Impl.spring-doc.cn
Example 2. Resolution of ambiguous implementations
@Component("specialCustomImpl")
If you annotate the UserRepository interface with @Component("specialCustom"), the bean name plus Impl then matches the one defined for the repository implementation in com.acme.impl.two, and it is used instead of the first one.spring-doc.cn
Manual Wiring
If your custom implementation uses annotation-based configuration and autowiring only, the preceding approach shown works well, because it is treated as any other Spring bean. If your implementation fragment bean needs special wiring, you can declare the bean and name it according to the conventions described in the preceding section. The infrastructure then refers to the manually defined bean definition by name instead of creating one itself. The following example shows how to manually wire a custom implementation:spring-doc.cn
Example 3. Manual wiring of custom implementations
class MyClass {
  MyClass(@Qualifier("userRepositoryImpl") UserRepository userRepository) {
<beans:bean id="userRepositoryImpl" class="…">
  <!-- further configuration -->
</beans:bean>
Customize the Base Repository
The approach described in the preceding section requires customization of each repository interfaces when you want to customize the base repository behavior so that all repositories are affected. To instead change behavior for all repositories, you can create an implementation that extends the persistence technology-specific repository base class. This class then acts as a custom base class for the repository proxies, as shown in the following example:spring-doc.cn
Custom repository base class
class MyRepositoryImpl<T, ID>
  extends SimpleJpaRepository<T, ID> {
  private final EntityManager entityManager;
  MyRepositoryImpl(JpaEntityInformation entityInformation,
                          EntityManager entityManager) {
    super(entityInformation, entityManager);
    // Keep the EntityManager around to used from the newly introduced methods.
    this.entityManager = entityManager;
  @Transactional
    // implementation goes here
The class needs to have a constructor of the super class which the store-specific repository factory implementation uses. If the repository base class has multiple constructors, override the one taking an EntityInformation plus a store specific infrastructure object (such as an EntityManager or a template class).
The final step is to make the Spring Data infrastructure aware of the customized repository base class. In configuration, you can do so by using the repositoryBaseClass, as shown in the following example:spring-doc.cn
Example 4. Configuring a custom repository base class
@EnableJpaRepositories(repositoryBaseClass = MyRepositoryImpl.class)
class ApplicationConfiguration { … }
     base-class="….MyRepositoryImpl" />
