This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data REST 4.4.4! |
Overriding Spring Data REST Response Handlers
Sometimes, you may want to write a custom handler for a specific resource.
To take advantage of Spring Data REST’s settings, message converters, exception handling, and more, use the @RepositoryRestController
annotation instead of a standard Spring MVC @Controller
or @RestController
Controllers annotated with @RepositoryRestController
are served from the API base path defined in RepositoryRestConfiguration.setBasePath
, which is used by all other RESTful endpoints (for example, /api
The following example shows how to use the @RepositoryRestController
annotation:
class ScannerController {
private final ScannerRepository repository;
ScannerController(ScannerRepository repository) { (1)
this.repository = repository;
@GetMapping(path = "/scanners/search/producers") (2)
ResponseEntity<?> getProducers() {
List<String> producers = repository.listProducers(); (3)
// do some intermediate processing, logging, etc. with the producers
CollectionModel<String> resources = CollectionModel.of(producers); (4)
resources.add(linkTo(methodOn(ScannerController.class).getProducers()).withSelfRel()); (5)
// add other links as needed
return ResponseEntity.ok(resources); (6)
1 | This example uses constructor injection. |
2 | This handler plugs in a custom handler method as query method resource |
3 | This handler uses the underlying repository to fetch data, but then does some form of post processing before returning the final data set to the client. |
4 | The results of type T need to be wrapped up in a Spring HATEOAS CollectionModel<T> object to return a collection. EntityModel<T> or RepresentationModel<T> are suitable wrappers for a single item, respectively. |
5 | Add a link back to this exact method as a self link. |
6 | Returning the collection by using Spring MVC’s ResponseEntity wrapper ensures that the collection is properly wrapped and rendered in the proper accept type. |
CollectionModel
is for a collection, while EntityModel
— or the more general class RepresentationModel
— is for a single item. These types can be combined. If you know the links for each item in a collection, use CollectionModel<EntityModel<String>>
(or whatever the core domain type is rather than String
). Doing so lets you assemble links for each item as well as for the whole collection.
In this example, the combined path is RepositoryRestConfiguration.getBasePath() + /scanners/search/producers .
Obtaining Aggregate References
For custom controllers receiving PUT
and POST
requests, the request body usually contains a JSON document that will use URIs to express references to other resources.
For GET
requests, those references are handed in via a request parameter.
As of Spring Data REST 4.1, we provide AggregateReference<T, ID>
to be used as handler method parameter type to capture such references and resolve them into either the referenced aggregate’s identifier, the aggregate itself or a jMolecules Association
All you need to do is declare an @RequestParam
of that type and then consume either the identifier or the fully resolved aggregate.
@GetMapping(path = "/scanners")
@RequestParam AggregateReference<Producer, ProducerIdentifier> producer) {
var identifier = producer.resolveRequiredId();
// Alternatively
var aggregate = producer.resolveRequiredAggregate();
// Alternatively
@RequestParam AssociationAggregateReference<Producer, ProducerIdentifier> producer) {
var association = producer.resolveRequiredAssociation();
In case you are using jMolecules, AssociationAggregateReference
also allows you to obtain an Association
While both of the abstraction assume the value for the parameter to be a URI matching the scheme that Spring Data REST uses to expose item resources, that source value resolution can be customized by calling ….withIdSource(…)
on the reference instance to provide a function to extract the identifier value to be used for aggregate resolution eventually from the UriComponents
obtained from the URI received.
VS. @BasePathAwareController
If you are not interested in entity-specific operations but still want to build custom operations underneath basePath
, such as Spring MVC views, resources, and others, use @BasePathAwareController
If you’re using @RepositoryRestController
on your custom controller, it will only handle the request if your request mappings blend into the URI space used by the repository.
It will also apply the following extra functionality to the controller methods:
CORS configuration according as defined for the repository mapped to the base path segment used in the request mapping of the handler method.
Apply an
OpenEntityManagerInViewInterceptor
if JPA is used to make sure you can access properties marked as to be resolved lazily.
If you use @Controller or @RestController for anything, that code is totally outside the scope of Spring Data REST. This extends to request handling, message converters, exception handling, and other uses.
