This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data REST 4.4.4!spring-doc.cn
Spring Data REST example projects
This appendix contains a list of Spring Data REST sample applications. The exact version of each example is not guaranteed to match the version of this reference manual.spring-doc.cn
To get them all, visit github.com/spring-projects/spring-data-examples and either clone or download a zipball. Doing so gives you example applications for all supported Spring Data projects. To see them, navigate to spring-data-examples/rest.
Multi-store Example
This example shows how to mix together several underlying Spring Data projects.spring-doc.cn
Projections
This example contains more detailed code you can use to explore projections.spring-doc.cn
Spring Data REST with Spring Security
This example shows how to secure a Spring Data REST application in multiple ways with Spring Security.spring-doc.cn
Starbucks example
This example exposes 10,843 Starbucks coffee shops through a RESTful API that allows access to the stores in a hypermedia-based way and exposes a resource to run a geo-location search for coffee shops.spring-doc.cn
