Usage
Spring Data Redis lets you easily implement domain entities, as shown in the following example:spring-doc.cn
Example 1. Sample Person Entity
@RedisHash("people")
public class Person {
  @Id String id;
  String firstname;
  String lastname;
  Address address;
We have a pretty simple domain object here. Note that it has a @RedisHash annotation on its type and a property named id that is annotated with org.springframework.data.annotation.Id. Those two items are responsible for creating the actual key used to persist the hash.spring-doc.cn
Properties annotated with @Id as well as those named id are considered as the identifier properties. Those with the annotation are favored over others.
To now actually have a component responsible for storage and retrieval, we need to define a repository interface, as shown in the following example:spring-doc.cn
Example 2. Basic Repository Interface To Persist Person Entities
public interface PersonRepository extends CrudRepository<Person, String> {
As our repository extends CrudRepository, it provides basic CRUD and finder operations. The thing we need in between to glue things together is the corresponding Spring configuration, shown in the following example:spring-doc.cn
Example 3. JavaConfig for Redis Repositories
@EnableRedisRepositories
public class ApplicationConfig {
  public RedisConnectionFactory connectionFactory() {
    return new LettuceConnectionFactory();
  public RedisTemplate<?, ?> redisTemplate(RedisConnectionFactory redisConnectionFactory) {
    RedisTemplate<byte[], byte[]> template = new RedisTemplate<byte[], byte[]>();
    template.setConnectionFactory(redisConnectionFactory);
    return template;
Given the preceding setup, we can inject PersonRepository into our components, as shown in the following example:spring-doc.cn
Example 4. Access to Person Entities
@Autowired PersonRepository repo;
public void basicCrudOperations() {
  Person rand = new Person("rand", "al'thor");
  rand.setAddress(new Address("emond's field", "andor"));
  repo.save(rand);                                         (1)
  repo.findOne(rand.getId());                              (2)
  repo.count();                                            (3)
  repo.delete(rand);                                       (4)
1 Generates a new id if the current value is null or reuses an already set id value and stores properties of type Person inside the Redis Hash with a key that has a pattern of keyspace:id — in this case, it might be people:5d67b7e1-8640-2024-beeb-c666fab4c0e5.
2 Uses the provided id to retrieve the object stored at keyspace:id.
3 Counts the total number of entities available within the keyspace, people, defined by @RedisHash on Person.
4 Removes the key for the given object from Redis.
Persisting References
Marking properties with @Reference allows storing a simple key reference instead of copying values into the hash itself. On loading from Redis, references are resolved automatically and mapped back into the object, as shown in the following example:spring-doc.cn
Example 5. Sample Property Reference
_class = org.example.Person
id = e2c7dcee-b8cd-4424-883e-736ce564363e
firstname = rand
lastname = al’thor
mother = people:a9d4b3a0-50d3-4538-a2fc-f7fc2581ee56      (1)
1 Reference stores the whole key (keyspace:id) of the referenced object.
Referenced Objects are not persisted when the referencing object is saved. You must persist changes on referenced objects separately, since only the reference is stored. Indexes set on properties of referenced types are not resolved.
Persisting Partial Updates
In some cases, you need not load and rewrite the entire entity just to set a new value within it. A session timestamp for the last active time might be such a scenario where you want to alter one property. PartialUpdate lets you define set and delete actions on existing objects while taking care of updating potential expiration times of both the entity itself and index structures. The following example shows a partial update:spring-doc.cn
Example 6. Sample Partial Update
PartialUpdate<Person> update = new PartialUpdate<Person>("e2c7dcee", Person.class)
  .set("firstname", "mat")                                                           (1)
  .set("address.city", "emond's field")                                              (2)
  .del("age");        (3)
template.update(update);
  .set("address", new Address("caemlyn", "andor"))                                   (4)
  .set("attributes", singletonMap("eye-color", "grey"));                             (5)
  .refreshTtl(true);        (6)
  .set("expiration", 1000);
1 Set the simple firstname property to mat.
2 Set the simple 'address.city' property to 'emond’s field' without having to pass in the entire object. This does not work when a custom conversion is registered.
3 Remove the age property.
4 Set complex address property.
5 Set a map of values, which removes the previously existing map and replaces the values with the given ones.
6 Automatically update the server expiration time when altering Time To Live.
Updating complex objects as well as map (or other collection) structures requires further interaction with Redis to determine existing values, which means that rewriting the entire entity might be faster.
