This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data Relational 3.4.5!spring-doc.cn
Mapping
Rich mapping support is provided by the MappingR2dbcConverter. MappingR2dbcConverter has a rich metadata model that allows mapping domain objects to a data row. The mapping metadata model is populated by using annotations on your domain objects. However, the infrastructure is not limited to using annotations as the only source of metadata information. The MappingR2dbcConverter also lets you map objects to rows without providing any additional metadata, by following a set of conventions.spring-doc.cn
This section describes the features of the MappingR2dbcConverter, including how to use conventions for mapping objects to rows and how to override those conventions with annotation-based mapping metadata.spring-doc.cn
Read on the basics about Object Mapping Fundamentals before continuing with this chapter.spring-doc.cn
Convention-based Mapping
MappingR2dbcConverter has a few conventions for mapping objects to rows when no additional mapping metadata is provided. The conventions are:spring-doc.cn
  • The short Java class name is mapped to the table name in the following manner. The com.bigbank.SavingsAccount class maps to the SAVINGS_ACCOUNT table name. The same name mapping is applied for mapping fields to column names. For example, the firstName field maps to the FIRST_NAME column. You can control this mapping by providing a custom NamingStrategy. See Mapping Configuration for more detail. Table and column names that are derived from property or class names are used in SQL statements without quotes by default. You can control this behavior by setting RelationalMappingContext.setForceQuote(true).spring-doc.cn
  • Nested objects are not supported.spring-doc.cn
  • The converter uses any Spring Converters registered with CustomConversions to override the default mapping of object properties to row columns and values.spring-doc.cn
  • The fields of an object are used to convert to and from columns in the row. Public JavaBean properties are not used.spring-doc.cn
  • If you have a single non-zero-argument constructor whose constructor argument names match top-level column names of the row, that constructor is used. Otherwise, the zero-argument constructor is used. If there is more than one non-zero-argument constructor, an exception is thrown. Refer to Object Creation for further details.spring-doc.cn
By default, (unless explicitly configured) an instance of MappingR2dbcConverter is created when you create a DatabaseClient. You can create your own instance of the MappingR2dbcConverter. By creating your own instance, you can register Spring converters to map specific classes to and from the database.spring-doc.cn
You can configure the MappingR2dbcConverter as well as DatabaseClient and ConnectionFactory by using Java-based metadata. The following example uses Spring’s Java-based configuration:spring-doc.cn
If you set setForceQuote of the R2dbcMappingContext to true, table and column names derived from classes and properties are used with database specific quotes. This means that it is OK to use reserved SQL words (such as order) in these names. You can do so by overriding r2dbcMappingContext(Optional<NamingStrategy>) of AbstractR2dbcConfiguration. Spring Data converts the letter casing of such a name to that form which is also used by the configured database when no quoting is used. Therefore, you can use unquoted names when creating tables, as long as you do not use keywords or special characters in your names. For databases that adhere to the SQL standard, this means that names are converted to upper case. The quoting character and the way names get capitalized is controlled by the used Dialect. See R2DBC Drivers for how to configure custom dialects.spring-doc.cn
@Configuration class to configure R2DBC mapping support
public class MyAppConfig extends AbstractR2dbcConfiguration {
    public ConnectionFactory connectionFactory() {
        return ConnectionFactories.get("r2dbc:…");
    // the following are optional
    protected List<Object> getCustomConverters() {
        return List.of(new PersonReadConverter(), new PersonWriteConverter());
AbstractR2dbcConfiguration requires you to implement a method that defines a ConnectionFactory.spring-doc.cn
You can add additional converters to the converter by overriding the r2dbcCustomConversions method.spring-doc.cn
You can configure a custom NamingStrategy by registering it as a bean. The NamingStrategy controls how the names of classes and properties get converted to the names of tables and columns.spring-doc.cn
AbstractR2dbcConfiguration creates a DatabaseClient instance and registers it with the container under the name of databaseClient.
Metadata-based Mapping
To take full advantage of the object mapping functionality inside the Spring Data R2DBC support, you should annotate your mapped objects with the @Table annotation. Although it is not necessary for the mapping framework to have this annotation (your POJOs are mapped correctly, even without any annotations), it lets the classpath scanner find and pre-process your domain objects to extract the necessary metadata. If you do not use this annotation, your application takes a slight performance hit the first time you store a domain object, because the mapping framework needs to build up its internal metadata model so that it knows about the properties of your domain object and how to persist them. The following example shows a domain object:spring-doc.cn
Example domain object
package com.mycompany.domain;
@Table
public class Person {
    @Id
    private Long id;
    private Integer ssn;
    private String firstName;
    private String lastName;
The @Id annotation tells the mapper which property you want to use as the primary key.
Default Type Mapping
The following table explains how property types of an entity affect mapping:spring-doc.cn
Source Type Target Type Remarks
Primitive types and wrapper typesspring-doc.cn
Passthruspring-doc.cn
Can be customized using Explicit Converters.spring-doc.cn
JSR-310 Date/Time typesspring-doc.cn
String, BigInteger, BigDecimal, and UUIDspring-doc.cn
Enumspring-doc.cn
Stringspring-doc.cn
Can be customized by registering Explicit Converters.spring-doc.cn
Blob and Clobspring-doc.cn
byte[], ByteBufferspring-doc.cn
Considered a binary payload.spring-doc.cn
Collection<T>spring-doc.cn
Array of Tspring-doc.cn
Conversion to Array type if supported by the configured driver, not supported otherwise.spring-doc.cn
Arrays of primitive types, wrapper types and Stringspring-doc.cn
Array of wrapper type (e.g. int[]Integer[])spring-doc.cn
Driver-specific typesspring-doc.cn
Contributed as a simple type by the used R2dbcDialect.spring-doc.cn
Complex objectsspring-doc.cn
Target type depends on registered Converter.spring-doc.cn
Requires a Explicit Converters, not supported otherwise.spring-doc.cn
The native data type for a column depends on the R2DBC driver type mapping. Drivers can contribute additional simple types such as Geometry types.
Mapping Annotation Overview
The RelationalConverter can use metadata to drive the mapping of objects to rows. The following annotations are available:spring-doc.cn
  • @Id: Applied at the field level to mark the primary key.spring-doc.cn
  • @Table: Applied at the class level to indicate this class is a candidate for mapping to the database. You can specify the name of the table where the database is stored.spring-doc.cn
  • @Transient: By default, all fields are mapped to the row. This annotation excludes the field where it is applied from being stored in the database. Transient properties cannot be used within a persistence constructor as the converter cannot materialize a value for the constructor argument.spring-doc.cn
  • @PersistenceCreator: Marks a given constructor or static factory method — even a package protected one — to use when instantiating the object from the database. Constructor arguments are mapped by name to the values in the retrieved row.spring-doc.cn
  • @Value: This annotation is part of the Spring Framework. Within the mapping framework it can be applied to constructor arguments. This lets you use a Spring Expression Language statement to transform a key’s value retrieved in the database before it is used to construct a domain object. In order to reference a column of a given row one has to use expressions like: @Value("#root.myProperty") where root refers to the root of the given Row.spring-doc.cn
  • @Column: Applied at the field level to describe the name of the column as it is represented in the row, letting the name be different from the field name of the class. Names specified with a @Column annotation are always quoted when used in SQL statements. For most databases, this means that these names are case-sensitive. It also means that you can use special characters in these names. However, this is not recommended, since it may cause problems with other tools.spring-doc.cn
  • @Version: Applied at field level is used for optimistic locking and checked for modification on save operations. The value is null (zero for primitive types) is considered as marker for entities to be new. The initially stored value is zero (one for primitive types). The version gets incremented automatically on every update. See Optimistic Locking for further reference.spring-doc.cn
The mapping metadata infrastructure is defined in the separate spring-data-commons project that is technology-agnostic. Specific subclasses are used in the R2DBC support to support annotation based metadata. Other strategies can also be put in place (if there is demand).spring-doc.cn
Naming Strategy
By convention, Spring Data applies a NamingStrategy to determine table, column, and schema names defaulting to snake case. An object property named firstName becomes first_name. You can tweak that by providing a NamingStrategy in your application context.spring-doc.cn
Override table names
When the table naming strategy does not match your database table names, you can override the table name with the Table annotation. The element value of this annotation provides the custom table name. The following example maps the MyEntity class to the CUSTOM_TABLE_NAME table in the database:spring-doc.cn
@Table("CUSTOM_TABLE_NAME")
class MyEntity {
    @Id
    Integer id;
    String name;
You may use Spring Data’s SpEL support to dynamically create the table name. Once generated the table name will be cached, so it is dynamic per mapping context only.spring-doc.cn
Override column names
When the column naming strategy does not match your database table names, you can override the table name with the Column annotation. The element value of this annotation provides the custom column name. The following example maps the name property of the MyEntity class to the CUSTOM_COLUMN_NAME column in the database:spring-doc.cn
class MyEntity {
    @Id
    Integer id;
    @Column("CUSTOM_COLUMN_NAME")
    String name;
You may use Spring Data’s SpEL support to dynamically create column names. Once generated the names will be cached, so it is dynamic per mapping context only.spring-doc.cn
Read Only Properties
Attributes annotated with @ReadOnlyProperty will not be written to the database by Spring Data, but they will be read when an entity gets loaded.spring-doc.cn
Spring Data will not automatically reload an entity after writing it. Therefore, you have to reload it explicitly if you want to see data that was generated in the database for such columns.spring-doc.cn
If the annotated attribute is an entity or collection of entities, it is represented by one or more separate rows in separate tables. Spring Data will not perform any insert, delete or update for these rows.spring-doc.cn
Insert Only Properties
Attributes annotated with @InsertOnlyProperty will only be written to the database by Spring Data during insert operations. For updates these properties will be ignored.spring-doc.cn
@InsertOnlyProperty is only supported for the aggregate root.spring-doc.cn
Customized Object Construction
The mapping subsystem allows the customization of the object construction by annotating a constructor with the @PersistenceConstructor annotation.The values to be used for the constructor parameters are resolved in the following way:spring-doc.cn
  • If a parameter is annotated with the @Value annotation, the given expression is evaluated, and the result is used as the parameter value.spring-doc.cn
  • If the Java type has a property whose name matches the given field of the input row, then its property information is used to select the appropriate constructor parameter to which to pass the input field value. This works only if the parameter name information is present in the Java .class files, which you can achieve by compiling the source with debug information or using the -parameters command-line switch for javac in Java 8.spring-doc.cn
  • Otherwise, a MappingException is thrown to indicate that the given constructor parameter could not be bound.spring-doc.cn
class OrderItem {
    private @Id final String id;
    private final int quantity;
    private final double unitPrice;
    OrderItem(String id, int quantity, double unitPrice) {
        this.id = id;
        this.quantity = quantity;
        this.unitPrice = unitPrice;
    // getters/setters omitted
Overriding Mapping with Explicit Converters
When storing and querying your objects, it is often convenient to have a R2dbcConverter instance to handle the mapping of all Java types to OutboundRow instances. However, you may sometimes want the R2dbcConverter instances to do most of the work but let you selectively handle the conversion for a particular type — perhaps to optimize performance.spring-doc.cn
To selectively handle the conversion yourself, register one or more one or more org.springframework.core.convert.converter.Converter instances with the R2dbcConverter.spring-doc.cn
You can use the r2dbcCustomConversions method in AbstractR2dbcConfiguration to configure converters. The examples at the beginning of this chapter show how to perform the configuration with Java.spring-doc.cn
Custom top-level entity conversion requires asymmetric types for conversion. Inbound data is extracted from R2DBC’s Row. Outbound data (to be used with INSERT/UPDATE statements) is represented as OutboundRow and later assembled to a statement.
The following example of a Spring Converter implementation converts from a Row to a Person POJO:spring-doc.cn
@ReadingConverter
public class PersonReadConverter implements Converter<Row, Person> {
    public Person convert(Row source) {
        Person p = new Person(source.get("id", String.class),source.get("name", String.class));
        p.setAge(source.get("age", Integer.class));
        return p;
Please note that converters get applied on singular properties. Collection properties (e.g. Collection<Person>) are iterated and converted element-wise. Collection converters (e.g. Converter<List<Person>>, OutboundRow) are not supported.spring-doc.cn
R2DBC uses boxed primitives (Integer.class instead of int.class) to return primitive values.
The following example converts from a Person to a OutboundRow:spring-doc.cn
@WritingConverter
public class PersonWriteConverter implements Converter<Person, OutboundRow> {
    public OutboundRow convert(Person source) {
        OutboundRow row = new OutboundRow();
        row.put("id", Parameter.from(source.getId()));
        row.put("name", Parameter.from(source.getFirstName()));
        row.put("age", Parameter.from(source.getAge()));
        return row;
Overriding Enum Mapping with Explicit Converters
Some databases, such as Postgres, can natively write enum values using their database-specific enumerated column type. Spring Data converts Enum values by default to String values for maximum portability. To retain the actual enum value, register a @Writing converter whose source and target types use the actual enum type to avoid using Enum.name() conversion. Additionally, you need to configure the enum type on the driver level so that the driver is aware how to represent the enum type.spring-doc.cn
The following example shows the involved components to read and write Color enum values natively:spring-doc.cn
enum Color {
    Grey, Blue
class ColorConverter extends EnumWriteSupport<Color> {
class Product {
    @Id long id;
    Color color;
