This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data Relational 3.4.5!spring-doc.cn
Mapping
Rich mapping support is provided by the MappingJdbcConverter. MappingJdbcConverter has a rich metadata model that allows mapping domain objects to a data row. The mapping metadata model is populated by using annotations on your domain objects. However, the infrastructure is not limited to using annotations as the only source of metadata information. The MappingJdbcConverter also lets you map objects to rows without providing any additional metadata, by following a set of conventions.spring-doc.cn
This section describes the features of the MappingJdbcConverter, including how to use conventions for mapping objects to rows and how to override those conventions with annotation-based mapping metadata.spring-doc.cn
Read on the basics about Object Mapping Fundamentals before continuing with this chapter.spring-doc.cn
Convention-based Mapping
MappingJdbcConverter has a few conventions for mapping objects to rows when no additional mapping metadata is provided. The conventions are:spring-doc.cn
  • The short Java class name is mapped to the table name in the following manner. The com.bigbank.SavingsAccount class maps to the SAVINGS_ACCOUNT table name. The same name mapping is applied for mapping fields to column names. For example, the firstName field maps to the FIRST_NAME column. You can control this mapping by providing a custom NamingStrategy. See Mapping Configuration for more detail. Table and column names that are derived from property or class names are used in SQL statements without quotes by default. You can control this behavior by setting RelationalMappingContext.setForceQuote(true).spring-doc.cn
  • The converter uses any Spring Converters registered with CustomConversions to override the default mapping of object properties to row columns and values.spring-doc.cn
  • The fields of an object are used to convert to and from columns in the row. Public JavaBean properties are not used.spring-doc.cn
  • If you have a single non-zero-argument constructor whose constructor argument names match top-level column names of the row, that constructor is used. Otherwise, the zero-argument constructor is used. If there is more than one non-zero-argument constructor, an exception is thrown. Refer to Object Creation for further details.spring-doc.cn
Supported Types in Your Entity
The properties of the following types are currently supported:spring-doc.cn
  • All primitive types and their boxed types (int, float, Integer, Float, and so on)spring-doc.cn
  • Enums get mapped to their name.spring-doc.cn
  • Stringspring-doc.cn
  • java.util.Date, java.time.LocalDate, java.time.LocalDateTime, and java.time.LocalTimespring-doc.cn
  • Arrays and Collections of the types mentioned above can be mapped to columns of array type if your database supports that.spring-doc.cn
  • Anything your database driver accepts.spring-doc.cn
  • References to other entities. They are considered a one-to-one relationship, or an embedded type. It is optional for one-to-one relationship entities to have an id attribute. The table of the referenced entity is expected to have an additional column with a name based on the referencing entity see Back References. Embedded entities do not need an id. If one is present it gets mapped as a normal attribute without any special meaning.spring-doc.cn
  • Set<some entity> is considered a one-to-many relationship. The table of the referenced entity is expected to have an additional column with a name based on the referencing entity see Back References.spring-doc.cn
  • Map<simple type, some entity> is considered a qualified one-to-many relationship. The table of the referenced entity is expected to have two additional columns: One named based on the referencing entity for the foreign key (see Back References) and one with the same name and an additional _key suffix for the map key.spring-doc.cn
  • List<some entity> is mapped as a Map<Integer, some entity>. The same additional columns are expected and the names used can be customized in the same way.spring-doc.cn
    For List, Set, and Map naming of the back reference can be controlled by implementing NamingStrategy.getReverseColumnName(RelationalPersistentEntity<?> owner) and NamingStrategy.getKeyColumn(RelationalPersistentProperty property), respectively. Alternatively you may annotate the attribute with @MappedCollection(idColumn="your_column_name", keyColumn="your_key_column_name"). Specifying a key column for a Set has no effect.spring-doc.cn
  • Types for which you registered suitable custom converters.spring-doc.cn
Mapping Annotation Overview
The RelationalConverter can use metadata to drive the mapping of objects to rows. The following annotations are available:spring-doc.cn
  • @Id: Applied at the field level to mark the primary key.spring-doc.cn
  • @Table: Applied at the class level to indicate this class is a candidate for mapping to the database. You can specify the name of the table where the database is stored.spring-doc.cn
  • @Transient: By default, all fields are mapped to the row. This annotation excludes the field where it is applied from being stored in the database. Transient properties cannot be used within a persistence constructor as the converter cannot materialize a value for the constructor argument.spring-doc.cn
  • @PersistenceCreator: Marks a given constructor or static factory method — even a package protected one — to use when instantiating the object from the database. Constructor arguments are mapped by name to the values in the retrieved row.spring-doc.cn
  • @Value: This annotation is part of the Spring Framework. Within the mapping framework it can be applied to constructor arguments. This lets you use a Spring Expression Language statement to transform a key’s value retrieved in the database before it is used to construct a domain object. In order to reference a column of a given row one has to use expressions like: @Value("#root.myProperty") where root refers to the root of the given Row.spring-doc.cn
  • @Column: Applied at the field level to describe the name of the column as it is represented in the row, letting the name be different from the field name of the class. Names specified with a @Column annotation are always quoted when used in SQL statements. For most databases, this means that these names are case-sensitive. It also means that you can use special characters in these names. However, this is not recommended, since it may cause problems with other tools.spring-doc.cn
  • @Version: Applied at field level is used for optimistic locking and checked for modification on save operations. The value is null (zero for primitive types) is considered as marker for entities to be new. The initially stored value is zero (one for primitive types). The version gets incremented automatically on every update.spring-doc.cn
See Optimistic Locking for further reference.spring-doc.cn
The mapping metadata infrastructure is defined in the separate spring-data-commons project that is technology-agnostic. Specific subclasses are used in the JDBC support to support annotation based metadata. Other strategies can also be put in place (if there is demand).spring-doc.cn
Referenced Entities
The handling of referenced entities is limited. This is based on the idea of aggregate roots as described above. If you reference another entity, that entity is, by definition, part of your aggregate. So, if you remove the reference, the previously referenced entity gets deleted. This also means references are 1-1 or 1-n, but not n-1 or n-m.spring-doc.cn
If you have n-1 or n-m references, you are, by definition, dealing with two separate aggregates. References between those may be encoded as simple id values, which map properly with Spring Data JDBC. A better way to encode these, is to make them instances of AggregateReference. An AggregateReference is a wrapper around an id value which marks that value as a reference to a different aggregate. Also, the type of that aggregate is encoded in a type parameter.spring-doc.cn
Back References
All references in an aggregate result in a foreign key relationship in the opposite direction in the database. By default, the name of the foreign key column is the table name of the referencing entity.spring-doc.cn
Alternatively you may choose to have them named by the entity name of the referencing entity ignoring @Table annotations. You activate this behaviour by calling setForeignKeyNaming(ForeignKeyNaming.IGNORE_RENAMING) on the RelationalMappingContext.spring-doc.cn
For List and Map references an additional column is required for holding the list index or map key. It is based on the foreign key column with an additional _KEY suffix.spring-doc.cn
If you want a completely different way of naming these back references you may implement NamingStrategy.getReverseColumnName(RelationalPersistentEntity<?> owner) in a way that fits your needs.spring-doc.cn
Declaring and setting an AggregateReference
class Person {
	@Id long id;
	AggregateReference<Person, Long> bestFriend;
Person p1, p2 = // some initialization
p1.bestFriend = AggregateReference.to(p2.id);
You should not include attributes in your entities to hold the actual value of a back reference, nor of the key column of maps or lists. If you want these value to be available in your domain model we recommend to do this in a AfterConvertCallback and store the values in transient values.spring-doc.cn
Naming Strategy
By convention, Spring Data applies a NamingStrategy to determine table, column, and schema names defaulting to snake case. An object property named firstName becomes first_name. You can tweak that by providing a NamingStrategy in your application context.spring-doc.cn
Override table names
When the table naming strategy does not match your database table names, you can override the table name with the Table annotation. The element value of this annotation provides the custom table name. The following example maps the MyEntity class to the CUSTOM_TABLE_NAME table in the database:spring-doc.cn
@Table("CUSTOM_TABLE_NAME")
class MyEntity {
    @Id
    Integer id;
    String name;
You may use Spring Data’s SpEL support to dynamically create the table name. Once generated the table name will be cached, so it is dynamic per mapping context only.spring-doc.cn
Override column names
When the column naming strategy does not match your database table names, you can override the table name with the Column annotation. The element value of this annotation provides the custom column name. The following example maps the name property of the MyEntity class to the CUSTOM_COLUMN_NAME column in the database:spring-doc.cn
class MyEntity {
    @Id
    Integer id;
    @Column("CUSTOM_COLUMN_NAME")
    String name;
The MappedCollection annotation can be used on a reference type (one-to-one relationship) or on Sets, Lists, and Maps (one-to-many relationship). idColumn element of the annotation provides a custom name for the foreign key column referencing the id column in the other table. In the following example the corresponding table for the MySubEntity class has a NAME column, and the CUSTOM_MY_ENTITY_ID_COLUMN_NAME column of the MyEntity id for relationship reasons:spring-doc.cn
class MyEntity {
    @Id
    Integer id;
    @MappedCollection(idColumn = "CUSTOM_MY_ENTITY_ID_COLUMN_NAME")
    Set<MySubEntity> subEntities;
class MySubEntity {
    String name;
When using List and Map you must have an additional column for the position of a dataset in the List or the key value of the entity in the Map. This additional column name may be customized with the keyColumn Element of the MappedCollection annotation:spring-doc.cn
class MyEntity {
    @Id
    Integer id;
    @MappedCollection(idColumn = "CUSTOM_COLUMN_NAME", keyColumn = "CUSTOM_KEY_COLUMN_NAME")
    List<MySubEntity> name;
class MySubEntity {
    String name;
You may use Spring Data’s SpEL support to dynamically create column names. Once generated the names will be cached, so it is dynamic per mapping context only.spring-doc.cn
Embedded entities
Embedded entities are used to have value objects in your java data model, even if there is only one table in your database. In the following example you see, that MyEntity is mapped with the @Embedded annotation. The consequence of this is, that in the database a table my_entity with the two columns id and name (from the EmbeddedEntity class) is expected.spring-doc.cn
However, if the name column is actually null within the result set, the entire property embeddedEntity will be set to null according to the onEmpty of @Embedded, which nulls objects when all nested properties are null.
Opposite to this behavior USE_EMPTY tries to create a new instance using either a default constructor or one that accepts nullable parameter values from the result set.spring-doc.cn
Example 1. Sample Code of embedding objects
class MyEntity {
    @Id
    Integer id;
    @Embedded(onEmpty = USE_NULL) (1)
    EmbeddedEntity embeddedEntity;
class EmbeddedEntity {
    String name;
1 Nulls embeddedEntity if name in null. Use USE_EMPTY to instantiate embeddedEntity with a potential null value for the name property.
If you need a value object multiple times in an entity, this can be achieved with the optional prefix element of the @Embedded annotation. This element represents a prefix and is prepend for each column name in the embedded object.spring-doc.cn
Make use of the shortcuts @Embedded.Nullable & @Embedded.Empty for @Embedded(onEmpty = USE_NULL) and @Embedded(onEmpty = USE_EMPTY) to reduce verbosity and simultaneously set JSR-305 @javax.annotation.Nonnull accordingly.spring-doc.cn
class MyEntity {
    @Id
    Integer id;
    @Embedded.Nullable (1)
1 Shortcut for @Embedded(onEmpty = USE_NULL).
Embedded entities containing a Collection or a Map will always be considered non-empty since they will at least contain the empty collection or map. Such an entity will therefore never be null even when using @Embedded(onEmpty = USE_NULL).spring-doc.cn
Read Only Properties
Attributes annotated with @ReadOnlyProperty will not be written to the database by Spring Data, but they will be read when an entity gets loaded.spring-doc.cn
Spring Data will not automatically reload an entity after writing it. Therefore, you have to reload it explicitly if you want to see data that was generated in the database for such columns.spring-doc.cn
If the annotated attribute is an entity or collection of entities, it is represented by one or more separate rows in separate tables. Spring Data will not perform any insert, delete or update for these rows.spring-doc.cn
Insert Only Properties
Attributes annotated with @InsertOnlyProperty will only be written to the database by Spring Data during insert operations. For updates these properties will be ignored.spring-doc.cn
@InsertOnlyProperty is only supported for the aggregate root.spring-doc.cn
Customized Object Construction
The mapping subsystem allows the customization of the object construction by annotating a constructor with the @PersistenceConstructor annotation.The values to be used for the constructor parameters are resolved in the following way:spring-doc.cn
  • If a parameter is annotated with the @Value annotation, the given expression is evaluated, and the result is used as the parameter value.spring-doc.cn
  • If the Java type has a property whose name matches the given field of the input row, then its property information is used to select the appropriate constructor parameter to which to pass the input field value. This works only if the parameter name information is present in the Java .class files, which you can achieve by compiling the source with debug information or using the -parameters command-line switch for javac in Java 8.spring-doc.cn
  • Otherwise, a MappingException is thrown to indicate that the given constructor parameter could not be bound.spring-doc.cn
class OrderItem {
  private @Id final String id;
  private final int quantity;
  private final double unitPrice;
  OrderItem(String id, int quantity, double unitPrice) {
    this.id = id;
    this.quantity = quantity;
    this.unitPrice = unitPrice;
  // getters/setters omitted
Overriding Mapping with Explicit Converters
Spring Data allows registration of custom converters to influence how values are mapped in the database. Currently, converters are only applied on property-level, i.e. you can only convert single values in your domain to single values in the database and back. Conversion between complex objects and multiple columns isn’t supported.spring-doc.cn
Writing a Property by Using a Registered Spring Converter
The following example shows an implementation of a Converter that converts from a Boolean object to a String value:spring-doc.cn
import org.springframework.core.convert.converter.Converter;
@WritingConverter
public class BooleanToStringConverter implements Converter<Boolean, String> {
    public String convert(Boolean source) {
        return source != null && source ? "T" : "F";
There are a couple of things to notice here: Boolean and String are both simple types hence Spring Data requires a hint in which direction this converter should apply (reading or writing). By annotating this converter with @WritingConverter you instruct Spring Data to write every Boolean property as String in the database.spring-doc.cn
Reading by Using a Spring Converter
The following example shows an implementation of a Converter that converts from a String to a Boolean value:spring-doc.cn
@ReadingConverter
public class StringToBooleanConverter implements Converter<String, Boolean> {
    public Boolean convert(String source) {
        return source != null && source.equalsIgnoreCase("T") ? Boolean.TRUE : Boolean.FALSE;
There are a couple of things to notice here: String and Boolean are both simple types hence Spring Data requires a hint in which direction this converter should apply (reading or writing). By annotating this converter with @ReadingConverter you instruct Spring Data to convert every String value from the database that should be assigned to a Boolean property.spring-doc.cn
Registering Spring Converters with the JdbcConverter
class MyJdbcConfiguration extends AbstractJdbcConfiguration {
    protected List<?> userConverters() {
	return Arrays.asList(new BooleanToStringConverter(), new StringToBooleanConverter());
In previous versions of Spring Data JDBC it was recommended to directly overwrite AbstractJdbcConfiguration.jdbcCustomConversions(). This is no longer necessary or even recommended, since that method assembles conversions intended for all databases, conversions registered by the Dialect used and conversions registered by the user. If you are migrating from an older version of Spring Data JDBC and have AbstractJdbcConfiguration.jdbcCustomConversions() overwritten conversions from your Dialect will not get registered.
If you want to rely on Spring Boot to bootstrap Spring Data JDBC, but still want to override certain aspects of the configuration, you may want to expose beans of that type. For custom conversions you may e.g. choose to register a bean of type JdbcCustomConversions that will be picked up the by the Boot infrastructure. To learn more about this please make sure to read the Spring Boot Reference Documentation.spring-doc.cn
JdbcValue
Value conversion uses JdbcValue to enrich values propagated to JDBC operations with a java.sql.Types type. Register a custom write converter if you need to specify a JDBC-specific type instead of using type derivation. This converter should convert the value to JdbcValue which has a field for the value and for the actual JDBCType.spring-doc.cn
