Object Mapping
Rich mapping support is provided by the MappingMongoConverter. The converter holds a metadata model that provides a full feature set to map domain objects to MongoDB documents. The mapping metadata model is populated by using annotations on your domain objects. However, the infrastructure is not limited to using annotations as the only source of metadata information. The MappingMongoConverter also lets you map objects to documents without providing any additional metadata, by following a set of conventions.spring-doc.cn
This section describes the features of the MappingMongoConverter, including fundamentals, how to use conventions for mapping objects to documents and how to override those conventions with annotation-based mapping metadata.spring-doc.cn
Object Mapping Fundamentals
This section covers the fundamentals of Spring Data object mapping, object creation, field and property access, mutability and immutability. Note, that this section only applies to Spring Data modules that do not use the object mapping of the underlying data store (like JPA). Also be sure to consult the store-specific sections for store-specific object mapping, like indexes, customizing column or field names or the like.spring-doc.cn
Core responsibility of the Spring Data object mapping is to create instances of domain objects and map the store-native data structures onto those. This means we need two fundamental steps:spring-doc.cn
  1. Instance creation by using one of the constructors exposed.spring-doc.cn
  2. Instance population to materialize all exposed properties.spring-doc.cn
Object creation
Spring Data automatically tries to detect a persistent entity’s constructor to be used to materialize objects of that type. The resolution algorithm works as follows:spring-doc.cn
  1. If there is a single static factory method annotated with @PersistenceCreator then it is used.spring-doc.cn
  2. If there is a single constructor, it is used.spring-doc.cn
  3. If there are multiple constructors and exactly one is annotated with @PersistenceCreator, it is used.spring-doc.cn
  4. If the type is a Java Record the canonical constructor is used.spring-doc.cn
  5. If there’s a no-argument constructor, it is used. Other constructors will be ignored.spring-doc.cn
The value resolution assumes constructor/factory method argument names to match the property names of the entity, i.e. the resolution will be performed as if the property was to be populated, including all customizations in mapping (different datastore column or field name etc.). This also requires either parameter names information available in the class file or an @ConstructorProperties annotation being present on the constructor.spring-doc.cn
The value resolution can be customized by using Spring Framework’s @Value value annotation using a store-specific SpEL expression. Please consult the section on store specific mappings for further details.spring-doc.cn
Object creation internals
To avoid the overhead of reflection, Spring Data object creation uses a factory class generated at runtime by default, which will call the domain classes constructor directly. I.e. for this example type:spring-doc.cn
class Person {
  Person(String firstname, String lastname) { … }
we will create a factory class semantically equivalent to this one at runtime:spring-doc.cn
class PersonObjectInstantiator implements ObjectInstantiator {
  Object newInstance(Object... args) {
    return new Person((String) args[0], (String) args[1]);
This gives us a roundabout 10% performance boost over reflection. For the domain class to be eligible for such optimization, it needs to adhere to a set of constraints:spring-doc.cn
If any of these criteria match, Spring Data will fall back to entity instantiation via reflection.spring-doc.cn
Property population
Once an instance of the entity has been created, Spring Data populates all remaining persistent properties of that class. Unless already populated by the entity’s constructor (i.e. consumed through its constructor argument list), the identifier property will be populated first to allow the resolution of cyclic object references. After that, all non-transient properties that have not already been populated by the constructor are set on the entity instance. For that we use the following algorithm:spring-doc.cn
  1. If the property is immutable but exposes a with… method (see below), we use the with… method to create a new entity instance with the new property value.spring-doc.cn
  2. If property access (i.e. access through getters and setters) is defined, we’re invoking the setter method.spring-doc.cn
  3. If the property is mutable we set the field directly.spring-doc.cn
  4. If the property is immutable we’re using the constructor to be used by persistence operations (see Object creation) to create a copy of the instance.spring-doc.cn
  5. By default, we set the field value directly.spring-doc.cn
Property population internals
Similarly to our optimizations in object construction we also use Spring Data runtime generated accessor classes to interact with the entity instance.spring-doc.cn
class Person {
  private final Long id;
  private String firstname;
  private @AccessType(Type.PROPERTY) String lastname;
  Person() {
    this.id = null;
  Person(Long id, String firstname, String lastname) {
    // Field assignments
  Person withId(Long id) {
    return new Person(id, this.firstname, this.lastame);
  void setLastname(String lastname) {
    this.lastname = lastname;
A generated Property Accessor
class PersonPropertyAccessor implements PersistentPropertyAccessor {
  private static final MethodHandle firstname;              (2)
  private Person person;                                    (1)
  public void setProperty(PersistentProperty property, Object value) {
    String name = property.getName();
    if ("firstname".equals(name)) {
      firstname.invoke(person, (String) value);             (2)
    } else if ("id".equals(name)) {
      this.person = person.withId((Long) value);            (3)
    } else if ("lastname".equals(name)) {
      this.person.setLastname((String) value);              (4)
1 PropertyAccessor’s hold a mutable instance of the underlying object. This is, to enable mutations of otherwise immutable properties.
2 By default, Spring Data uses field-access to read and write property values. As per visibility rules of private fields, MethodHandles are used to interact with fields.
3 The class exposes a withId(…) method that’s used to set the identifier, e.g. when an instance is inserted into the datastore and an identifier has been generated. Calling withId(…) creates a new Person object. All subsequent mutations will take place in the new instance leaving the previous untouched.
4 Using property-access allows direct method invocations without using MethodHandles.
This gives us a roundabout 25% performance boost over reflection. For the domain class to be eligible for such optimization, it needs to adhere to a set of constraints:spring-doc.cn
  • Types must not reside in the default or under the java package.spring-doc.cn
  • Types and their constructors must be publicspring-doc.cn
  • Types that are inner classes must be static.spring-doc.cn
  • The used Java Runtime must allow for declaring classes in the originating ClassLoader. Java 9 and newer impose certain limitations.spring-doc.cn
By default, Spring Data attempts to use generated property accessors and falls back to reflection-based ones if a limitation is detected.spring-doc.cn
Let’s have a look at the following entity:spring-doc.cn
A sample entity
class Person {
  private final @Id Long id;                                                (1)
  private final String firstname, lastname;                                 (2)
  private final LocalDate birthday;
  private final int age;                                                    (3)
  private String comment;                                                   (4)
  private @AccessType(Type.PROPERTY) String remarks;                        (5)
  static Person of(String firstname, String lastname, LocalDate birthday) { (6)
    return new Person(null, firstname, lastname, birthday,
      Period.between(birthday, LocalDate.now()).getYears());
  Person(Long id, String firstname, String lastname, LocalDate birthday, int age) { (6)
    this.id = id;
    this.firstname = firstname;
    this.birthday = birthday;
    this.age = age;
  Person withId(Long id) {                                                  (1)
    return new Person(id, this.firstname, this.lastname, this.birthday, this.age);
  void setRemarks(String remarks) {                                         (5)
    this.remarks = remarks;
1 The identifier property is final but set to null in the constructor. The class exposes a withId(…) method that’s used to set the identifier, e.g. when an instance is inserted into the datastore and an identifier has been generated. The original Person instance stays unchanged as a new one is created. The same pattern is usually applied for other properties that are store managed but might have to be changed for persistence operations. The wither method is optional as the persistence constructor (see 6) is effectively a copy constructor and setting the property will be translated into creating a fresh instance with the new identifier value applied.
2 The firstname and lastname properties are ordinary immutable properties potentially exposed through getters.
3 The age property is an immutable but derived one from the birthday property. With the design shown, the database value will trump the defaulting as Spring Data uses the only declared constructor. Even if the intent is that the calculation should be preferred, it’s important that this constructor also takes age as parameter (to potentially ignore it) as otherwise the property population step will attempt to set the age field and fail due to it being immutable and no with… method being present.
4 The comment property is mutable and is populated by setting its field directly.
5 The remarks property is mutable and is populated by invoking the setter method.
6 The class exposes a factory method and a constructor for object creation. The core idea here is to use factory methods instead of additional constructors to avoid the need for constructor disambiguation through @PersistenceCreator. Instead, defaulting of properties is handled within the factory method. If you want Spring Data to use the factory method for object instantiation, annotate it with @PersistenceCreator.
General recommendations
  • Try to stick to immutable objects — Immutable objects are straightforward to create as materializing an object is then a matter of calling its constructor only. Also, this avoids your domain objects to be littered with setter methods that allow client code to manipulate the objects state. If you need those, prefer to make them package protected so that they can only be invoked by a limited amount of co-located types. Constructor-only materialization is up to 30% faster than properties population.spring-doc.cn
  • Provide an all-args constructor — Even if you cannot or don’t want to model your entities as immutable values, there’s still value in providing a constructor that takes all properties of the entity as arguments, including the mutable ones, as this allows the object mapping to skip the property population for optimal performance.spring-doc.cn
  • Use factory methods instead of overloaded constructors to avoid @PersistenceCreator — With an all-argument constructor needed for optimal performance, we usually want to expose more application use case specific constructors that omit things like auto-generated identifiers etc. It’s an established pattern to rather use static factory methods to expose these variants of the all-args constructor.spring-doc.cn
  • Make sure you adhere to the constraints that allow the generated instantiator and property accessor classes to be used — spring-doc.cn
  • For identifiers to be generated, still use a final field in combination with an all-arguments persistence constructor (preferred) or a with… method — spring-doc.cn
  • Use Lombok to avoid boilerplate code — As persistence operations usually require a constructor taking all arguments, their declaration becomes a tedious repetition of boilerplate parameter to field assignments that can best be avoided by using Lombok’s @AllArgsConstructor.spring-doc.cn
Overriding Properties
Java allows a flexible design of domain classes where a subclass could define a property that is already declared with the same name in its superclass. Consider the following example:spring-doc.cn
public class SuperType {
   private CharSequence field;
   public SuperType(CharSequence field) {
      this.field = field;
   public CharSequence getField() {
      return this.field;
   public void setField(CharSequence field) {
      this.field = field;
public class SubType extends SuperType {
   private String field;
   public SubType(String field) {
      super(field);
      this.field = field;
   public String getField() {
      return this.field;
   public void setField(String field) {
      this.field = field;
      // optional
      super.setField(field);
Both classes define a field using assignable types. SubType however shadows SuperType.field. Depending on the class design, using the constructor could be the only default approach to set SuperType.field. Alternatively, calling super.setField(…) in the setter could set the field in SuperType. All these mechanisms create conflicts to some degree because the properties share the same name yet might represent two distinct values. Spring Data skips super-type properties if types are not assignable. That is, the type of the overridden property must be assignable to its super-type property type to be registered as override, otherwise the super-type property is considered transient. We generally recommend using distinct property names.spring-doc.cn
Spring Data modules generally support overridden properties holding different values. From a programming model perspective there are a few things to consider:spring-doc.cn
  1. Which property should be persisted (default to all declared properties)? You can exclude properties by annotating these with @Transient.spring-doc.cn
  2. How to represent properties in your data store? Using the same field/column name for different values typically leads to corrupt data so you should annotate least one of the properties using an explicit field/column name.spring-doc.cn
  3. Using @AccessType(PROPERTY) cannot be used as the super-property cannot be generally set without making any further assumptions of the setter implementation.spring-doc.cn
Kotlin support
Spring Data adapts specifics of Kotlin to allow object creation and mutation.spring-doc.cn
Kotlin object creation
Kotlin classes are supported to be instantiated, all classes are immutable by default and require explicit property declarations to define mutable properties.spring-doc.cn
  1. If there is a constructor that is annotated with @PersistenceCreator, it is used.spring-doc.cn
  2. If the type is a Kotlin data class the primary constructor is used.spring-doc.cn
  3. If there is a single static factory method annotated with @PersistenceCreator then it is used.spring-doc.cn
  4. If there is a single constructor, it is used.spring-doc.cn
  5. If there are multiple constructors and exactly one is annotated with @PersistenceCreator, it is used.spring-doc.cn
  6. If the type is a Java Record the canonical constructor is used.spring-doc.cn
  7. If there’s a no-argument constructor, it is used. Other constructors will be ignored.spring-doc.cn
Consider the following data class Person:spring-doc.cn
data class Person(val id: String, val name: String)
The class above compiles to a typical class with an explicit constructor. We can customize this class by adding another constructor and annotate it with @PersistenceCreator to indicate a constructor preference:spring-doc.cn
data class Person(var id: String, val name: String) {
    @PersistenceCreator
    constructor(id: String) : this(id, "unknown")
Kotlin supports parameter optionality by allowing default values to be used if a parameter is not provided. When Spring Data detects a constructor with parameter defaulting, then it leaves these parameters absent if the data store does not provide a value (or simply returns null) so Kotlin can apply parameter defaulting. Consider the following class that applies parameter defaulting for namespring-doc.cn
data class Person(var id: String, val name: String = "unknown")
Every time the name parameter is either not part of the result or its value is null, then the name defaults to unknown.spring-doc.cn
Delegated properties are not supported with Spring Data. The mapping metadata filters delegated properties for Kotlin Data classes. In all other cases you can exclude synthetic fields for delegated properties by annotating the property with @Transient.
Property population of Kotlin data classes
In Kotlin, all classes are immutable by default and require explicit property declarations to define mutable properties. Consider the following data class Person:spring-doc.cn
This class is effectively immutable. It allows creating new instances as Kotlin generates a copy(…) method that creates new object instances copying all property values from the existing object and applying property values provided as arguments to the method.spring-doc.cn
Kotlin Overriding Properties
Kotlin allows declaring property overrides to alter properties in subclasses.spring-doc.cn
open class SuperType(open var field: Int)
class SubType(override var field: Int = 1) :
	SuperType(field) {
Such an arrangement renders two properties with the name field. Kotlin generates property accessors (getters and setters) for each property in each class. Effectively, the code looks like as follows:spring-doc.cn
   private int field;
   public SuperType(int field) {
      this.field = field;
   public int getField() {
      return this.field;
   public void setField(int field) {
      this.field = field;
public final class SubType extends SuperType {
   private int field;
   public SubType(int field) {
      super(field);
      this.field = field;
      return this.field;
      this.field = field;
Getters and setters on SubType set only SubType.field and not SuperType.field. In such an arrangement, using the constructor is the only default approach to set SuperType.field. Adding a method to SubType to set SuperType.field via this.SuperType.field = … is possible but falls outside of supported conventions. Property overrides create conflicts to some degree because the properties share the same name yet might represent two distinct values. We generally recommend using distinct property names.spring-doc.cn
  3. Using @AccessType(PROPERTY) cannot be used as the super-property cannot be set.spring-doc.cn
Kotlin Value Classes
Kotlin Value Classes are designed for a more expressive domain model to make underlying concepts explicit. Spring Data can read and write types that define properties using Value Classes.spring-doc.cn
Consider the following domain model:spring-doc.cn
@JvmInline
value class EmailAddress(val theAddress: String)                                    (1)
data class Contact(val id: String, val name:String, val emailAddress: EmailAddress) (2)
1 A simple value class with a non-nullable value type.
2 Data class defining a property using the EmailAddress value class.
Non-nullable properties using non-primitive value types are flattened in the compiled class to the value type. Nullable primitive value types or nullable value-in-value types are represented with their wrapper type and that affects how value types are represented in the database.
Convention-based Mapping
MappingMongoConverter has a few conventions for mapping objects to documents when no additional mapping metadata is provided. The conventions are:spring-doc.cn
  • The short Java class name is mapped to the collection name in the following manner. The class com.bigbank.SavingsAccount maps to the savingsAccount collection name.spring-doc.cn
  • All nested objects are stored as nested objects in the document and not as DBRefs.spring-doc.cn
  • The converter uses any Spring Converters registered with it to override the default mapping of object properties to document fields and values.spring-doc.cn
  • The fields of an object are used to convert to and from fields in the document. Public JavaBean properties are not used.spring-doc.cn
  • If you have a single non-zero-argument constructor whose constructor argument names match top-level field names of document, that constructor is used.Otherwise, the zero-argument constructor is used.If there is more than one non-zero-argument constructor, an exception will be thrown.spring-doc.cn
How the _id field is handled in the mapping layer.
MongoDB requires that you have an _id field for all documents.If you don’t provide one the driver will assign a ObjectId with a generated value.The _id field can be of any type, other than arrays, so long as it is unique.The driver naturally supports all primitive types and Dates.When using the MappingMongoConverter there are certain rules that govern how properties from the Java class are mapped to the _id field.spring-doc.cn
The following outlines what field will be mapped to the _id document field:spring-doc.cn
  • A field annotated with @Id (org.springframework.data.annotation.Id) will be mapped to the _id field.
    Additionally, the name of the document field can be customized via the @Field annotation, in which case the document will not contain a field _id.spring-doc.cn
  • A field without an annotation but named id will be mapped to the _id field.spring-doc.cn
Table 1. Examples for the translation of _id field definitions
Field definition Resulting Id-Fieldname in MongoDB
String idspring-doc.cn
_idspring-doc.cn
@Field String idspring-doc.cn
_idspring-doc.cn
@Field("x") String idspring-doc.cn
xspring-doc.cn
@Id String xspring-doc.cn
_idspring-doc.cn
@Field("x") @Id String yspring-doc.cn
_id (@Field(name) is ignored, @Id takes precedence)spring-doc.cn
The following outlines what type conversion, if any, will be done on the property mapped to the _id document field.spring-doc.cn
  • If a field named id is declared as a String or BigInteger in the Java class it will be converted to and stored as an ObjectId if possible. ObjectId as a field type is also valid. If you specify a value for id in your application, the conversion to an ObjectId is done by the MongoDB driver. If the specified id value cannot be converted to an ObjectId, then the value will be stored as is in the document’s _id field. This also applies if the field is annotated with @Id.spring-doc.cn
  • If a field is annotated with @MongoId in the Java class it will be converted to and stored as using its actual type. No further conversion happens unless @MongoId declares a desired field type. If no value is provided for the id field, a new ObjectId will be created and converted to the properties type.spring-doc.cn
  • If a field is annotated with @MongoId(FieldType.…) in the Java class it will be attempted to convert the value to the declared FieldType. If no value is provided for the id field, a new ObjectId will be created and converted to the declared type.spring-doc.cn
  • If a field named id is not declared as a String, BigInteger, or ObjectID in the Java class then you should assign it a value in your application so it can be stored 'as-is' in the document’s _id field.spring-doc.cn
  • If no field named id is present in the Java class then an implicit _id file will be generated by the driver but not mapped to a property or field of the Java class.spring-doc.cn
When querying and updating MongoTemplate will use the converter to handle conversions of the Query and Update objects that correspond to the above rules for saving documents so field names and types used in your queries will be able to match what is in your domain classes.spring-doc.cn
Data Mapping and Type Conversion
Spring Data MongoDB supports all types that can be represented as BSON, MongoDB’s internal document format. In addition to these types, Spring Data MongoDB provides a set of built-in converters to map additional types. You can provide your own converters to adjust type conversion. See Custom Conversions - Overriding Default Mapping for further details.spring-doc.cn
Built in Type conversions:
Table 2. Type
Type Type conversion Sample
Stringspring-doc.cn
nativespring-doc.cn
{"firstname" : "Dave"}spring-doc.cn
double, Double, float, Floatspring-doc.cn
nativespring-doc.cn
{"weight" : 42.5}spring-doc.cn
int, Integer, short, Shortspring-doc.cn
native
32-bit integerspring-doc.cn
{"height" : 42}spring-doc.cn
long, Longspring-doc.cn
native
64-bit integerspring-doc.cn
Date, Timestampspring-doc.cn
nativespring-doc.cn
{"date" : ISODate("2019-11-12T23:00:00.809Z")}spring-doc.cn
byte[]spring-doc.cn
nativespring-doc.cn
{"bin" : { "$binary" : "AQIDBA==", "$type" : "00" }}spring-doc.cn
java.util.UUID (Legacy UUID)spring-doc.cn
nativespring-doc.cn
{"uuid" : { "$binary" : "MEaf1CFQ6lSphaa3b9AtlA==", "$type" : "03" }}spring-doc.cn
Datespring-doc.cn
nativespring-doc.cn
ObjectIdspring-doc.cn
nativespring-doc.cn
{"_id" : ObjectId("5707a2690364aba3136ab870")}spring-doc.cn
Array, List, BasicDBListspring-doc.cn
nativespring-doc.cn
{"cookies" : [ … ]}spring-doc.cn
boolean, Booleanspring-doc.cn
nativespring-doc.cn
{"active" : true}spring-doc.cn
nullspring-doc.cn
nativespring-doc.cn
{"value" : null}spring-doc.cn
Documentspring-doc.cn
nativespring-doc.cn
{"value" : { … }}spring-doc.cn
Decimal128spring-doc.cn
nativespring-doc.cn
{"value" : NumberDecimal(…)}spring-doc.cn
AtomicInteger
calling get() before the actual conversionspring-doc.cn
converter
{"value" : "741" }spring-doc.cn
AtomicLong
converter
BigIntegerspring-doc.cn
converter
Stringspring-doc.cn
BigDecimalspring-doc.cn
converter
Stringspring-doc.cn
{"value" : "741.99" }spring-doc.cn
URLspring-doc.cn
converterspring-doc.cn
{"website" : "https://spring.io/projects/spring-data-mongodb/" }spring-doc.cn
Localespring-doc.cn
{"locale : "en_US" }spring-doc.cn
char, Characterspring-doc.cn
{"char" : "a" }spring-doc.cn
NamedMongoScriptspring-doc.cn
converter
Codespring-doc.cn
{"_id" : "script name", value: (some javascript code)}spring-doc.cn
java.util.Currencyspring-doc.cn
{"currencyCode" : "EUR"}spring-doc.cn
Instant
(Java 8)spring-doc.cn
nativespring-doc.cn
Instant
(Joda, JSR310-BackPort)spring-doc.cn
LocalDate
(Joda, Java 8, JSR310-BackPort)spring-doc.cn
converter / native (Java8)[1]spring-doc.cn
{"date" : ISODate("2019-11-12T00:00:00.000Z")}spring-doc.cn
LocalDateTime, LocalTime
converter / native (Java8)[2]spring-doc.cn
DateTime (Joda)spring-doc.cn
ZoneId (Java 8, JSR310-BackPort)spring-doc.cn
{"zoneId" : "ECT - Europe/Paris"}spring-doc.cn
Boxspring-doc.cn
{"box" : { "first" : { "x" : 1.0 , "y" : 2.0} , "second" : { "x" : 3.0 , "y" : 4.0}}spring-doc.cn
Polygonspring-doc.cn
{"polygon" : { "points" : [ { "x" : 1.0 , "y" : 2.0} , { "x" : 3.0 , "y" : 4.0} , { "x" : 4.0 , "y" : 5.0}]}}spring-doc.cn
Circlespring-doc.cn
{"circle" : { "center" : { "x" : 1.0 , "y" : 2.0} , "radius" : 3.0 , "metric" : "NEUTRAL"}}spring-doc.cn
Pointspring-doc.cn
{"point" : { "x" : 1.0 , "y" : 2.0}}spring-doc.cn
GeoJsonPointspring-doc.cn
{"point" : { "type" : "Point" , "coordinates" : [3.0 , 4.0] }}spring-doc.cn
GeoJsonMultiPointspring-doc.cn
{"geoJsonLineString" : {"type":"MultiPoint", "coordinates": [ [ 0 , 0 ], [ 0 , 1 ], [ 1 , 1 ] ] }}spring-doc.cn
Spherespring-doc.cn
{"sphere" : { "center" : { "x" : 1.0 , "y" : 2.0} , "radius" : 3.0 , "metric" : "NEUTRAL"}}spring-doc.cn
GeoJsonPolygonspring-doc.cn
{"polygon" : { "type" : "Polygon", "coordinates" : [[ [ 0 , 0 ], [ 3 , 6 ], [ 6 , 1 ], [ 0 , 0 ] ]] }}spring-doc.cn
GeoJsonMultiPolygonspring-doc.cn
{"geoJsonMultiPolygon" : { "type" : "MultiPolygon", "coordinates" : [ [ [ [ -73.958 , 40.8003 ] , [ -73.9498 , 40.7968 ] ] ], [ [ [ -73.973 , 40.7648 ] , [ -73.9588 , 40.8003 ] ] ] ] }}spring-doc.cn
GeoJsonLineStringspring-doc.cn
{ "geoJsonLineString" : { "type" : "LineString", "coordinates" : [ [ 40 , 5 ], [ 41 , 6 ] ] }}spring-doc.cn
GeoJsonMultiLineStringspring-doc.cn
{"geoJsonLineString" : { "type" : "MultiLineString", coordinates: [ [ [ -73.97162 , 40.78205 ], [ -73.96374 , 40.77715 ] ], [ [ -73.97880 , 40.77247 ], [ -73.97036 , 40.76811 ] ] ] }}spring-doc.cn
Collection Handling
Collection handling depends on the actual values returned by MongoDB.spring-doc.cn
  • If a document does not contain a field mapped to a collection, the mapping will not update the property. Which means the value will remain null, a java default or any value set during object creation.spring-doc.cn
  • If a document contains a field to be mapped, but the field holds a null value (like: { 'list' : null }), the property value is set to null.spring-doc.cn
  • If a document contains a field to be mapped to a collection which is not null (like: { 'list' : [ …​ ] }), the collection is populated with the mapped values.spring-doc.cn
Generally, if you use constructor creation, then you can get hold of the value to be set. Property population can make use of default initialization values if a property value is not being provided by a query response.spring-doc.cn
Mapping Configuration
Unless explicitly configured, an instance of MappingMongoConverter is created by default when you create a MongoTemplate. You can create your own instance of the MappingMongoConverter. Doing so lets you dictate where in the classpath your domain classes can be found, so that Spring Data MongoDB can extract metadata and construct indexes. Also, by creating your own instance, you can register Spring converters to map specific classes to and from the database.spring-doc.cn
You can configure the MappingMongoConverter as well as com.mongodb.client.MongoClient and MongoTemplate by using either Java-based or XML-based metadata. The following example shows the configuration:spring-doc.cn
public class MongoConfig extends AbstractMongoClientConfiguration {
  public String getDatabaseName() {
    return "database";
  // the following are optional
  public String getMappingBasePackage() { (1)
    return "com.bigbank.domain";
  void configureConverters(MongoConverterConfigurationAdapter adapter) { (2)
  	adapter.registerConverter(new org.springframework.data.mongodb.test.PersonReadConverter());
  	adapter.registerConverter(new org.springframework.data.mongodb.test.PersonWriteConverter());
  public LoggingEventListener<MongoMappingEvent> mappingEventsListener() {
    return new LoggingEventListener<MongoMappingEvent>();
1 The mapping base package defines the root path used to scan for entities used to pre initialize the MappingContext. By default the configuration classes package is used.
2 Configure additional custom converters for specific domain types that replace the default mapping procedure for those types with your custom implementation.
  xmlns:mongo="http://www.springframework.org/schema/data/mongo"
  xsi:schemaLocation="
    http://www.springframework.org/schema/data/mongo https://www.springframework.org/schema/data/mongo/spring-mongo.xsd
    http://www.springframework.org/schema/beans https://www.springframework.org/schema/beans/spring-beans-3.0.xsd">
  <!-- Default bean name is 'mongo' -->
  <mongo:mongo-client host="localhost" port="27017"/>
  <mongo:db-factory dbname="database" mongo-ref="mongoClient"/>
  <!-- by default look for a Mongo object named 'mongo' - default name used for the converter is 'mappingConverter' -->
  <mongo:mapping-converter base-package="com.bigbank.domain">
    <mongo:custom-converters>
      <mongo:converter ref="readConverter"/>
      <mongo:converter>
        <bean class="org.springframework.data.mongodb.test.PersonWriteConverter"/>
      </mongo:converter>
    </mongo:custom-converters>
  </mongo:mapping-converter>
  <bean id="readConverter" class="org.springframework.data.mongodb.test.PersonReadConverter"/>
  <!-- set the mapping converter to be used by the MongoTemplate -->
  <bean id="mongoTemplate" class="org.springframework.data.mongodb.core.MongoTemplate">
    <constructor-arg name="mongoDbFactory" ref="mongoDbFactory"/>
    <constructor-arg name="mongoConverter" ref="mappingConverter"/>
  </bean>
  <bean class="org.springframework.data.mongodb.core.mapping.event.LoggingEventListener"/>
</beans>
AbstractMongoClientConfiguration requires you to implement methods that define a com.mongodb.client.MongoClient as well as provide a database name. AbstractMongoClientConfiguration also has a method named getMappingBasePackage(…) that you can override to tell the converter where to scan for classes annotated with the @Document annotation.spring-doc.cn
You can add additional converters to the converter by overriding the customConversionsConfiguration method. MongoDB’s native JSR-310 support can be enabled through MongoConverterConfigurationAdapter.useNativeDriverJavaTimeCodecs(). Also shown in the preceding example is a LoggingEventListener, which logs MongoMappingEvent instances that are posted onto Spring’s ApplicationContextEvent infrastructure.spring-doc.cn
Java Time Types
We recommend using MongoDB’s native JSR-310 support via MongoConverterConfigurationAdapter.useNativeDriverJavaTimeCodecs() as described above as it is using an UTC based approach. The default JSR-310 support for java.time types inherited from Spring Data Commons uses the local machine timezone as reference and should only be used for backwards compatibility.spring-doc.cn
AbstractMongoClientConfiguration creates a MongoTemplate instance and registers it with the container under the name mongoTemplate.
The base-package property tells it where to scan for classes annotated with the @org.springframework.data.mongodb.core.mapping.Document annotation.spring-doc.cn
If you want to rely on Spring Boot to bootstrap Data MongoDB, but still want to override certain aspects of the configuration, you may want to expose beans of that type. For custom conversions you may eg. choose to register a bean of type MongoCustomConversions that will be picked up the by the Boot infrastructure. To learn more about this please make sure to read the Spring Boot Reference Documentation.spring-doc.cn
Metadata-based Mapping
To take full advantage of the object mapping functionality inside the Spring Data MongoDB support, you should annotate your mapped objects with the @Document annotation. Although it is not necessary for the mapping framework to have this annotation (your POJOs are mapped correctly, even without any annotations), it lets the classpath scanner find and pre-process your domain objects to extract the necessary metadata. If you do not use this annotation, your application takes a slight performance hit the first time you store a domain object, because the mapping framework needs to build up its internal metadata model so that it knows about the properties of your domain object and how to persist them. The following example shows a domain object:spring-doc.cn
Example 1. Example domain object
package com.mycompany.domain;
@Document
public class Person {
  @Id
  private ObjectId id;
  @Indexed
  private Integer ssn;
  private String firstName;
  @Indexed
  private String lastName;
The @Id annotation tells the mapper which property you want to use for the MongoDB _id property, and the @Indexed annotation tells the mapping framework to call createIndex(…) on that property of your document, making searches faster. Automatic index creation is only done for types annotated with @Document.
Auto index creation is disabled by default and needs to be enabled through the configuration (see Index Creation).
Mapping Annotation Overview
The MappingMongoConverter can use metadata to drive the mapping of objects to documents. The following annotations are available:spring-doc.cn
  • @Id: Applied at the field level to mark the field used for identity purpose.spring-doc.cn
  • @MongoId: Applied at the field level to mark the field used for identity purpose. Accepts an optional FieldType to customize id conversion.spring-doc.cn
  • @Document: Applied at the class level to indicate this class is a candidate for mapping to the database. You can specify the name of the collection where the data will be stored.spring-doc.cn
  • @DBRef: Applied at the field to indicate it is to be stored using a com.mongodb.DBRef.spring-doc.cn
  • @DocumentReference: Applied at the field to indicate it is to be stored as a pointer to another document. This can be a single value (the id by default), or a Document provided via a converter.spring-doc.cn
  • @Indexed: Applied at the field level to describe how to index the field.spring-doc.cn
  • @CompoundIndex (repeatable): Applied at the type level to declare Compound Indexes.spring-doc.cn
  • @GeoSpatialIndexed: Applied at the field level to describe how to geoindex the field.spring-doc.cn
  • @TextIndexed: Applied at the field level to mark the field to be included in the text index.spring-doc.cn
  • @HashIndexed: Applied at the field level for usage within a hashed index to partition data across a sharded cluster.spring-doc.cn
  • @Language: Applied at the field level to set the language override property for text index.spring-doc.cn
  • @Transient: By default, all fields are mapped to the document. This annotation excludes the field where it is applied from being stored in the database. Transient properties cannot be used within a persistence constructor as the converter cannot materialize a value for the constructor argument.spring-doc.cn
  • @PersistenceConstructor: Marks a given constructor - even a package protected one - to use when instantiating the object from the database. Constructor arguments are mapped by name to the key values in the retrieved Document.spring-doc.cn
  • @Value: This annotation is part of the Spring Framework . Within the mapping framework it can be applied to constructor arguments. This lets you use a Spring Expression Language statement to transform a key’s value retrieved in the database before it is used to construct a domain object. In order to reference a property of a given document one has to use expressions like: @Value("#root.myProperty") where root refers to the root of the given document.spring-doc.cn
  • @Field: Applied at the field level it allows to describe the name and type of the field as it will be represented in the MongoDB BSON document thus allowing the name and type to be different than the fieldname of the class as well as the property type.spring-doc.cn
  • @Version: Applied at field level is used for optimistic locking and checked for modification on save operations. The initial value is zero (one for primitive types) which is bumped automatically on every update.spring-doc.cn
The mapping metadata infrastructure is defined in a separate spring-data-commons project that is technology agnostic. Specific subclasses are using in the MongoDB support to support annotation based metadata. Other strategies are also possible to put in place if there is demand.spring-doc.cn
Here is an example of a more complex mapping
@Document
@CompoundIndex(name = "age_idx", def = "{'lastName': 1, 'age': -1}")
public class Person<T extends Address> {
  @Id
  private String id;
  @Indexed(unique = true)
  @Field("fName")
  @Indexed
  private Integer age;
  @Transient
  private Integer accountTotal;
  @DBRef
  private List<Account> accounts;
  private T address;
  public Person(Integer ssn) {
    this.ssn = ssn;
  public Person(Integer ssn, String firstName, String lastName, Integer age, T address) {
    this.ssn = ssn;
    this.firstName = firstName;
    this.lastName = lastName;
    this.age = age;
    this.address = address;
  public String getId() {
    return id;
  // no setter for Id.  (getter is only exposed for some unit testing)
  public Integer getSsn() {
    return ssn;
// other getters/setters omitted
@Field(targetType=…​) can come in handy when the native MongoDB type inferred by the mapping infrastructure does not match the expected one. Like for BigDecimal, which is represented as String instead of Decimal128, just because earlier versions of MongoDB Server did not have support for it.spring-doc.cn
public class Balance {
  @Field(targetType = DECIMAL128)
  private BigDecimal value;
You may even consider your own, custom annotation.spring-doc.cn
@Target(ElementType.FIELD)
@Field(targetType = FieldType.DECIMAL128)
public @interface Decimal128 { }
  @Decimal128
Special Field Names
Generally speaking MongoDB uses the dot (.) character as a path separator for nested documents or arrays. This means that in a query (or update statement) a key like a.b.c targets an object structure as outlined below:spring-doc.cn
    'a' : {
        'b' : {
            'c' : …
Therefore, up until MongoDB 5.0 field names must not contain dots (.).
Using a MappingMongoConverter#setMapKeyDotReplacement allowed circumvent some of the limitations when storing Map structures by substituting dots on write with another character.spring-doc.cn
converter.setMapKeyDotReplacement("-");
source.map = Map.of("key.with.dot", "value")
converter.write(source,...) // -> map : { 'key-with-dot', 'value' }
With the release of MongoDB 5.0 this restriction on Document field names containing special characters was lifted. We highly recommend reading more about limitations on using dots in field names in the MongoDB Reference.
To allow dots in Map structures please set preserveMapKeys on the MappingMongoConverter.spring-doc.cn
Using @Field allows customizing the field name to consider dots in two ways.spring-doc.cn
  1. @Field(name = "a.b"): The name is considered to be a path. Operations expect a structure of nested objects such as { a : { b : … } }.spring-doc.cn
  2. @Field(name = "a.b", fieldNameType = KEY): The names is considered a name as-is. Operations expect a field with the given value as { 'a.b' : ….. }spring-doc.cn
Due to the special nature of the dot character in both MongoDB query and update statements field names containing dots cannot be targeted directly and therefore are excluded from being used in derived query methods. Consider the following Item having a categoryId property that is mapped to the field named cat.id.spring-doc.cn
public class Item {
	@Field(name = "cat.id", fieldNameType = KEY)
	String categoryId;
Its raw representation will look likespring-doc.cn
    'cat.id' : "5b28b5e7-52c2",
Since we cannot target the cat.id field directly (as this would be interpreted as a path) we need the help of the Aggregation Framework.spring-doc.cn
Query fields with a dot in its name
template.query(Item.class)
    // $expr : { $eq : [ { $getField : { input : '$$CURRENT', 'cat.id' }, '5b28b5e7-52c2' ] }
    .matching(expr(ComparisonOperators.valueOf(ObjectOperators.getValueOf("value")).equalToValue("5b28b5e7-52c2"))) (1)
    .all();
1 The mapping layer takes care of translating the property name value into the actual field name. It is absolutely valid to use the target field name here as well.
Update fields with a dot in its name
template.update(Item.class)
    .matching(where("id").is("r2d2"))
    // $replaceWith: { $setField : { input: '$$CURRENT', field : 'cat.id', value : 'af29-f87f4e933f97' } }
    .apply(AggregationUpdate.newUpdate(ReplaceWithOperation.replaceWithValue(ObjectOperators.setValueTo("value", "af29-f87f4e933f97")))) (1)
    .first();
The above shows a simple example where the special field is present on the top document level. Increased levels of nesting increase the complexity of the aggregation expression required to interact with the field.spring-doc.cn
Customized Object Construction
The mapping subsystem allows the customization of the object construction by annotating a constructor with the @PersistenceConstructor annotation. The values to be used for the constructor parameters are resolved in the following way:spring-doc.cn
  • If a parameter is annotated with the @Value annotation, the given expression is evaluated and the result is used as the parameter value.spring-doc.cn
  • If the Java type has a property whose name matches the given field of the input document, then it’s property information is used to select the appropriate constructor parameter to pass the input field value to. This works only if the parameter name information is present in the java .class files which can be achieved by compiling the source with debug information or using the new -parameters command-line switch for javac in Java 8.spring-doc.cn
  • Otherwise, a MappingException will be thrown indicating that the given constructor parameter could not be bound.spring-doc.cn
class OrderItem {
  private @Id String id;
  private int quantity;
  private double unitPrice;
  OrderItem(String id, @Value("#root.qty ?: 0") int quantity, double unitPrice) {
    this.id = id;
    this.quantity = quantity;
    this.unitPrice = unitPrice;
  // getters/setters ommitted
Document input = new Document("id", "4711");
input.put("unitPrice", 2.5);
input.put("qty",5);
OrderItem item = converter.read(OrderItem.class, input);
The SpEL expression in the @Value annotation of the quantity parameter falls back to the value 0 if the given property path cannot be resolved.
Additional examples for using the @PersistenceConstructor annotation can be found in the MappingMongoConverterUnitTests test suite.spring-doc.cn
Mapping Framework Events
Events are fired throughout the lifecycle of the mapping process. This is described in the Lifecycle Events section.spring-doc.cn
Declaring these beans in your Spring ApplicationContext causes them to be invoked whenever the event is dispatched.spring-doc.cn
1. Uses UTC zone offset. Configure via MongoConverterConfigurationAdapter
2. Uses UTC zone offset. Configure via MongoConverterConfigurationAdapter
