Configuration
This section describes configuring Spring Data LDAP.
Spring LDAP repositories can be enabled by using a <data-ldap:repositories>
tag in your XML configuration or by using an @EnableLdapRepositories
annotation on a configuration class:
“Spring Namespace” (XML configuration)
“Annotation-based Configuration” (Java configuration)
To include support for LdapQuery
parameters in automatically generated repositories, have your interface extend LdapRepository
rather than CrudRepository
All Spring LDAP repositories must work with entities annotated with the ODM annotations, as described in Object-Directory Mapping.
Since all ODM managed classes must have a Distinguished Name as the ID, all Spring LDAP repositories must have the ID type parameter set to javax.naming.Name
Indeed, the built-in LdapRepository
only takes one type parameter: the managed entity class, which defaults the ID to javax.naming.Name
Due to specifics of the LDAP protocol, paging and sorting are not supported for Spring LDAP repositories.
You must use ODM annotations, such as org.springframework.ldap.odm.annotations.Id .
Using Spring Data’s annotation does not work, because Spring LDAP uses its own mapping layer.
The Spring Data LDAP repositories support can be activated through both JavaConfig as well as a custom XML namespace, as shown in the following example:
@EnableLdapRepositories("com.acme.*.repositories")
class MyConfig {
ContextSource contextSource() {
LdapContextSource ldapContextSource = new LdapContextSource();
ldapContextSource.setUserDn("cn=Admin");
ldapContextSource.setPassword("secret");
ldapContextSource.setUrl("ldap://127.0.0.1:389");
return ldapContextSource;
LdapTemplate ldapTemplate(ContextSource contextSource) {
return new LdapTemplate(contextSource);
This configuration causes the base packages to be scanned for interfaces that extend contain LDAP repositories and create Spring beans for each one found.
If no base package is configured, the infrastructure scans the package of the annotated configuration class.
Spring Namespace
The LDAP module of Spring Data contains a custom namespace that allows defining repository beans.
It also contains certain features and element attributes that are special to LDAP.
Generally, the LDAP repositories can be set up by using the repositories
element, as shown in the following example:
xmlns:ldap="http://www.springframework.org/schema/ldap"
xmlns:data-ldap="http://www.springframework.org/schema/data/ldap"
https://www.springframework.org/schema/ldap/spring-ldap.xsd
https://www.springframework.org/schema/data/ldap/spring-ldap.xsd">
<ldap:context-source url="ldap://127.0.0.1:389"
username="cn=Admin"
password="secret" />
<ldap:ldap-template />
<data-ldap:repositories base-package="com.acme.*.repositories" />
</beans>
By default, the repositories get an autowired LdapTemplate
Spring bean that is called ldapTemplate
, so you only need to configure ldap-template-ref
explicitly if you deviate from this convention.
Which is better, JavaConfig or XML? XML is how Spring was configured long ago. In today’s era of fast-growing Java, record types, annotations, and more, new projects typically use as much pure Java as possible. While there is no immediate plan to remove XML support, some of the newest features MAY not be available through XML. |
Using the repositories
element looks up Spring Data repositories as described in Creating Repository Instances.
Custom Namespace Attributes
Beyond the default attributes of the repositories
element, the LDAP namespace offers additional attributes to let you gain more detailed control over the setup of the repositories:
Explicitly wire the |
Spring Data LDAP requires a LdapMappingContext bean named ldapMappingContext to be present.
If no such bean is defined, then Spring Data LDAP registers a default instance in the application context.
