This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data JPA 3.4.4! |
Frequently Asked Questions
Common
I’d like to get more detailed logging information on what methods are called inside
JpaRepository
for example. How can I gain them?You can make use of
CustomizableTraceInterceptor
provided by Spring, as shown in the following example:<bean id="customizableTraceInterceptor" class=" org.springframework.aop.interceptor.CustomizableTraceInterceptor"> <property name="enterMessage" value="Entering $[methodName]($[arguments])"/> <property name="exitMessage" value="Leaving $[methodName](): $[returnValue]"/> </bean> <aop:config> <aop:advisor advice-ref="customizableTraceInterceptor" pointcut="execution(public * org.springframework.data.jpa.repository.JpaRepository+.*(..))"/> </aop:config>
Auditing
I want to use Spring Data JPA auditing capabilities but have my database already configured to set modification and creation date on entities. How can I prevent Spring Data from setting the date programmatically?
Set the
set-dates
attribute of theauditing
namespace element tofalse
