This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data JPA 3.4.4!spring-doc.cn
Stored Procedures
The JPA 2.1 specification introduced support for calling stored procedures by using the JPA criteria query API. We Introduced the @Procedure annotation for declaring stored procedure metadata on a repository method.spring-doc.cn
The examples to follow use the following stored procedure:spring-doc.cn
Example 1. The definition of the plus1inout procedure in HSQL DB.
DROP procedure IF EXISTS plus1inout
CREATE procedure plus1inout (IN arg int, OUT res int)
BEGIN ATOMIC
 set res = arg + 1;
END
Metadata for stored procedures can be configured by using the NamedStoredProcedureQuery annotation on an entity type.spring-doc.cn
Example 2. StoredProcedure metadata definitions on an entity.
@Entity
@NamedStoredProcedureQuery(name = "User.plus1", procedureName = "plus1inout", parameters = {
  @StoredProcedureParameter(mode = ParameterMode.IN, name = "arg", type = Integer.class),
  @StoredProcedureParameter(mode = ParameterMode.OUT, name = "res", type = Integer.class) })
public class User {}
Note that @NamedStoredProcedureQuery has two different names for the stored procedure. name is the name JPA uses. procedureName is the name the stored procedure has in the database.spring-doc.cn
You can reference stored procedures from a repository method in multiple ways. The stored procedure to be called can either be defined directly by using the value or procedureName attribute of the @Procedure annotation. This refers directly to the stored procedure in the database and ignores any configuration via @NamedStoredProcedureQuery.spring-doc.cn
Alternatively you may specify the @NamedStoredProcedureQuery.name attribute as the @Procedure.name attribute. If neither value, procedureName nor name is configured, the name of the repository method is used as the name attribute.spring-doc.cn
The following example shows how to reference an explicitly mapped procedure:spring-doc.cn
Example 3. Referencing explicitly mapped procedure with name "plus1inout" in database.
@Procedure("plus1inout")
Integer explicitlyNamedPlus1inout(Integer arg);
The following example is equivalent to the previous one but uses the procedureName alias:spring-doc.cn
Example 4. Referencing implicitly mapped procedure with name "plus1inout" in database via procedureName alias.
@Procedure(procedureName = "plus1inout")
Integer callPlus1InOut(Integer arg);
The following is again equivalent to the previous two but using the method name instead of an explicit annotation attribute.spring-doc.cn
Example 5. Referencing implicitly mapped named stored procedure "User.plus1" in EntityManager by using the method name.
@Procedure
Integer plus1inout(@Param("arg") Integer arg);
The following example shows how to reference a stored procedure by referencing the @NamedStoredProcedureQuery.name attribute.spring-doc.cn
Example 6. Referencing explicitly mapped named stored procedure "User.plus1IO" in EntityManager.
@Procedure(name = "User.plus1IO")
Integer entityAnnotatedCustomNamedProcedurePlus1IO(@Param("arg") Integer arg);
If the stored procedure getting called has a single out parameter that parameter may be returned as the return value of the method. If there are multiple out parameters specified in a @NamedStoredProcedureQuery annotation those can be returned as a Map with the key being the parameter name given in the @NamedStoredProcedureQuery annotation.spring-doc.cn
Note that if the stored procedure returns a ResultSet then any OUT parameters are omitted as Java can only return a single method return value unless the method declares a Map return type.
The following example shows how to obtain multiple OUT parameters if the stored procedure has multiple OUT parameters and is registered as @NamedStoredProcedureQuery. @NamedStoredProcedureQuery registration is required to provide parameter metadata.spring-doc.cn
Example 7. StoredProcedure metadata definitions on an entity.
@Entity
@NamedStoredProcedureQuery(name = "User.multiple_out_parameters", procedureName = "multiple_out_parameters", parameters = {
  @StoredProcedureParameter(mode = ParameterMode.REF_CURSOR, name = "some_cursor", type = void.class),
Example 8. Returning multiple OUT parameters
@Procedure(name = "User.multiple_out_parameters")
Map<String, Object> returnsMultipleOutParameters(@Param("arg") Integer arg);
