This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data JPA 3.4.5! |
Configuration
As a starting point for using Spring Data Envers, you need a project with Spring Data JPA on the classpath and an additional spring-data-envers
dependency:
<dependencies>
<!-- other dependency elements omitted -->
<dependency>
<groupId>org.springframework.data</groupId>
<artifactId>spring-data-envers</artifactId>
<version>3.3.12-SNAPSHOT</version>
</dependency>
</dependencies>
This also brings hibernate-envers
into the project as a transient dependency.
To enable Spring Data Envers and Spring Data JPA, we need to configure two beans and a special repositoryFactoryBeanClass
@EnableEnversRepositories
@EnableTransactionManagement
public class EnversDemoConfiguration {
public DataSource dataSource() {
EmbeddedDatabaseBuilder builder = new EmbeddedDatabaseBuilder();
return builder.setType(EmbeddedDatabaseType.HSQL).build();
public LocalContainerEntityManagerFactoryBean entityManagerFactory() {
HibernateJpaVendorAdapter vendorAdapter = new HibernateJpaVendorAdapter();
vendorAdapter.setGenerateDdl(true);
LocalContainerEntityManagerFactoryBean factory = new LocalContainerEntityManagerFactoryBean();
factory.setJpaVendorAdapter(vendorAdapter);
factory.setPackagesToScan("example.springdata.jpa.envers");
factory.setDataSource(dataSource());
return factory;
public PlatformTransactionManager transactionManager(EntityManagerFactory entityManagerFactory) {
JpaTransactionManager txManager = new JpaTransactionManager();
txManager.setEntityManagerFactory(entityManagerFactory);
return txManager;
To actually use Spring Data Envers, make one or more repositories into a RevisionRepository
by adding it as an extended interface:
interface PersonRepository
extends CrudRepository<Person, Long>,
RevisionRepository<Person, Long, Long> (1)
1 | The first type parameter (Person ) denotes the entity type, the second (Long ) denotes the type of the id property, and the last one (Long ) is the type of the revision number.
For Envers in default configuration, the revision number parameter should be Integer or Long . |
The entity for that repository must be an entity with Envers auditing enabled (that is, it must have an @Audited
annotation):
@Entity
@Audited
class Person {
@Id @GeneratedValue
Long id;
String name;
@Version Long version;
