此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Data Relational 3.4.5spring-doc.cadn.net.cn
Auditing
Since Spring Data R2DBC 1.2, auditing can be enabled by annotating a configuration class with the @EnableR2dbcAuditing annotation, as the following example shows:spring-doc.cadn.net.cn
Activating auditing using JavaConfig
class Config {
    public ReactiveAuditorAware<AuditableUser> myAuditorProvider() {
        return new AuditorAwareImpl();
If you expose a bean of type ReactiveAuditorAware to the ApplicationContext, the auditing infrastructure picks it up automatically and uses it to determine the current user to be set on domain types. If you have multiple implementations registered in the ApplicationContext, you can select the one to be used by explicitly setting the auditorAwareRef attribute of @EnableR2dbcAuditing.spring-doc.cadn.net.cn
