This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data Relational 3.4.5! |
Getting Started
An easy way to bootstrap setting up a working environment is to create a Spring-based project in Spring Tools or from Spring Initializr.
First, you need to set up a running database server. Refer to your vendor documentation on how to configure your database for R2DBC access.
Requirements
Spring Data R2DBC requires Spring Framework 6.2.6 and above.
In terms of databases, Spring Data R2DBC requires a driver to abstract common SQL functionality over vendor-specific flavours. Spring Data R2DBC includes direct support for the following databases:
H2 (
io.r2dbc:r2dbc-h2
MariaDB (
org.mariadb:r2dbc-mariadb
Microsoft SQL Server (
io.r2dbc:r2dbc-mssql
MySQL (
io.asyncer:r2dbc-mysql
jasync-sql MySQL (
com.github.jasync-sql:jasync-r2dbc-mysql
Postgres (
io.r2dbc:r2dbc-postgresql
Oracle (
com.oracle.database.r2dbc:oracle-r2dbc
If you use a different database then your application won’t start up. The dialect section contains further detail on how to proceed in such case.
Hello World
To create a Spring project in STS:
Go to File → New → Spring Template Project → Simple Spring Utility Project, and press Yes when prompted. Then enter a project and a package name, such as
org.spring.r2dbc.example
Add the following to the
pom.xml
filesdependencies
element: -
Add the following to the pom.xml files
dependencies
element:<dependencies> <!-- other dependency elements omitted --> <dependency> <groupId>org.springframework.data</groupId> <artifactId>spring-data-r2dbc</artifactId> <version>3.5.0-SNAPSHOT</version> </dependency> <!-- a R2DBC driver --> <dependency> <groupId>io.r2dbc</groupId> <artifactId>r2dbc-h2</artifactId> <version>x.y.z</version> </dependency> </dependencies>
Change the version of Spring in the pom.xml to be
<spring.version>6.2.6</spring.version>
Add the following location of the Spring Milestone repository for Maven to your
pom.xml
such that it is at the same level as your<dependencies/>
element:<repositories> <repository> <id>spring-milestone</id> <name>Spring Maven MILESTONE Repository</name> <url>https://repo.spring.io/milestone</url> </repository> </repositories>
The repository is also browseable here.
You may also want to set the logging level to DEBUG
to see some additional information.
To do so, edit the application.properties
file to have the following content:
logging.level.org.springframework.r2dbc=DEBUG
Then you can, for example, create a Person
class to persist, as follows:
public class Person {
private final String id;
private final String name;
private final int age;
public Person(String id, String name, int age) {
this.id = id;
this.name = name;
this.age = age;
public String getId() {
return id;
public String getName() {
return name;
public int getAge() {
return age;
public String toString() {
return "Person [id=" + id + ", name=" + name + ", age=" + age + "]";
Next, you need to create a table structure in your database, as follows:
CREATE TABLE person(
id VARCHAR(255) PRIMARY KEY,
name VARCHAR(255),
age INT
You also need a main application to run, as follows:
import io.r2dbc.spi.ConnectionFactories;
import io.r2dbc.spi.ConnectionFactory;
import reactor.test.StepVerifier;
import org.apache.commons.logging.Log;
import org.apache.commons.logging.LogFactory;
import org.springframework.data.r2dbc.core.R2dbcEntityTemplate;
public class R2dbcApp {
private static final Log log = LogFactory.getLog(R2dbcApp.class);
ConnectionFactory connectionFactory = ConnectionFactories.get("r2dbc:h2:mem:///test?options=DB_CLOSE_DELAY=-1;DB_CLOSE_ON_EXIT=FALSE");
R2dbcEntityTemplate template = new R2dbcEntityTemplate(connectionFactory);
template.getDatabaseClient().sql("CREATE TABLE person" +
"(id VARCHAR(255) PRIMARY KEY," +
"name VARCHAR(255)," +
"age INT)")
.fetch()
.rowsUpdated()
.as(StepVerifier::create)
.expectNextCount(1)
.verifyComplete();
template.insert(Person.class)
.using(new Person("joe", "Joe", 34))
.expectNextCount(1)
.verifyComplete();
template.select(Person.class)
.first()
.doOnNext(it -> log.info(it))
.expectNextCount(1)
.verifyComplete();
When you run the main program, the preceding examples produce output similar to the following:
2018-11-28 10:47:03,893 DEBUG amework.core.r2dbc.DefaultDatabaseClient: 310 - Executing SQL statement [CREATE TABLE person(
name VARCHAR(255),
age INT
2018-11-28 10:47:04,074 DEBUG amework.core.r2dbc.DefaultDatabaseClient: 908 - Executing SQL statement [INSERT INTO person (id, name, age) VALUES($1, $2, $3)]
2018-11-28 10:47:04,092 DEBUG amework.core.r2dbc.DefaultDatabaseClient: 575 - Executing SQL statement [SELECT id, name, age FROM person]
2018-11-28 10:47:04,436 INFO org.spring.r2dbc.example.R2dbcApp: 43 - Person [id='joe', name='Joe', age=34]
Even in this simple example, there are few things to notice:
You can create an instance of the central helper class in Spring Data R2DBC (
R2dbcEntityTemplate
) by using a standardio.r2dbc.spi.ConnectionFactory
object. -
The mapper works against standard POJO objects without the need for any additional metadata (though you can, optionally, provide that information — see here.).
Mapping conventions can use field access.Notice that the
Person
class has only getters. -
If the constructor argument names match the column names of the stored row, they are used to instantiate the object.
Examples Repository
There is a GitHub repository with several examples that you can download and play around with to get a feel for how the library works.
Connecting to a Relational Database with Spring
One of the first tasks when using relational databases and Spring is to create a io.r2dbc.spi.ConnectionFactory
object by using the IoC container.
Make sure to use a supported database and driver.
Registering a ConnectionFactory
Instance using Java Configuration
The following example shows an example of using Java-based bean metadata to register an instance of io.r2dbc.spi.ConnectionFactory
object using Java Configuration@Configuration
public class ApplicationConfiguration extends AbstractR2dbcConfiguration {
public ConnectionFactory connectionFactory() {
return …
This approach lets you use the standard io.r2dbc.spi.ConnectionFactory
instance, with the container using Spring’s AbstractR2dbcConfiguration
.As compared to registering a ConnectionFactory
instance directly, the configuration support has the added advantage of also providing the container with an ExceptionTranslator
implementation that translates R2DBC exceptions to exceptions in Spring’s portable DataAccessException
hierarchy for data access classes annotated with the @Repository
annotation.This hierarchy and the use of @Repository
is described in Spring’s DAO support features.
also registers DatabaseClient
, which is required for database interaction and for Repository implementation.
Dialects
Spring Data R2DBC uses a Dialect
to encapsulate behavior that is specific to a database or its driver.
Spring Data R2DBC reacts to database specifics by inspecting the ConnectionFactory
and selects the appropriate database dialect accordingly.
If you use a database for which no dialect is available, then your application won’t start up.
In that case, you’ll have to ask your vendor to provide a Dialect
implementation.
Alternatively, you can implement your own Dialect
Dialects are resolved by
