此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Data Relational 3.4.5! |
Getting Started
An easy way to bootstrap setting up a working environment is to create a Spring-based project in Spring Tools or from Spring Initializr.
First, you need to set up a running database server. Refer to your vendor documentation on how to configure your database for JDBC access.
Requirements
Spring Data JDBC requires Spring Framework 6.2.6 and above.
In terms of databases, Spring Data JDBC requires a dialect to abstract common SQL functionality over vendor-specific flavours. Spring Data JDBC includes direct support for the following databases:
DB2
H2
HSQLDB
MariaDB
Microsoft SQL Server
MySQL
Oracle
Postgres
If you use a different database then your application won’t start up. The dialect section contains further detail on how to proceed in such case.
Hello World
To create a Spring project in STS:
Go to File → New → Spring Template Project → Simple Spring Utility Project, and press Yes when prompted. Then enter a project and a package name, such as
org.spring.jdbc.example
Add the following to the
pom.xml
filesdependencies
element:<dependencies> <!-- other dependency elements omitted --> <dependency> <groupId>org.springframework.data</groupId> <artifactId>spring-data-jdbc</artifactId> <version>3.5.0-RC1</version> </dependency> </dependencies>
Change the version of Spring in the pom.xml to be
<spring.version>6.2.6</spring.version>
Add the following location of the Spring Milestone repository for Maven to your
pom.xml
such that it is at the same level as your<dependencies/>
element:<repositories> <repository> <id>spring-milestone</id> <name>Spring Maven MILESTONE Repository</name> <url>https://repo.spring.io/milestone</url> </repository> </repositories>
The repository is also browseable here.
Logging
Spring Data JDBC does little to no logging on its own.
Instead, the mechanics of JdbcTemplate
to issue SQL statements provide logging.
Thus, if you want to inspect what SQL statements are run, activate logging for Spring’s NamedParameterJdbcTemplate
or MyBatis.
You may also want to set the logging level to DEBUG
to see some additional information.
To do so, edit the application.properties
file to have the following content:
logging.level.org.springframework.jdbc=DEBUG
Examples Repository
There is a GitHub repository with several examples that you can download and play around with to get a feel for how the library works.
配置
The Spring Data JDBC repositories support can be activated by an annotation through Java configuration, as the following example shows:
@EnableJdbcRepositories (1)
class ApplicationConfig extends AbstractJdbcConfiguration { (2)
DataSource dataSource() { (3)
EmbeddedDatabaseBuilder builder = new EmbeddedDatabaseBuilder();
return builder.setType(EmbeddedDatabaseType.HSQL).build();
NamedParameterJdbcOperations namedParameterJdbcOperations(DataSource dataSource) { (4)
return new NamedParameterJdbcTemplate(dataSource);
TransactionManager transactionManager(DataSource dataSource) { (5)
return new DataSourceTransactionManager(dataSource);
1 | @EnableJdbcRepositories creates implementations for interfaces derived from Repository |
2 | AbstractJdbcConfiguration provides various default beans required by Spring Data JDBC |
3 | Creates a DataSource connecting to a database.
This is required by the following two bean methods. |
4 | Creates the NamedParameterJdbcOperations used by Spring Data JDBC to access the database. |
5 | Spring Data JDBC utilizes the transaction management provided by Spring JDBC. |
The configuration class in the preceding example sets up an embedded HSQL database by using the EmbeddedDatabaseBuilder
API of spring-jdbc
The DataSource
is then used to set up NamedParameterJdbcOperations
以及TransactionManager
We finally activate Spring Data JDBC repositories by using the @EnableJdbcRepositories
If no base package is configured, it uses the package in which the configuration class resides.
Extending AbstractJdbcConfiguration
ensures various beans get registered.
Overwriting its methods can be used to customize the setup (see below).
This configuration can be further simplified by using Spring Boot.
With Spring Boot a DataSource
is sufficient once the starter spring-boot-starter-data-jdbc
is included in the dependencies.
Everything else is done by Spring Boot.
There are a couple of things one might want to customize in this setup.
Dialects
Spring Data JDBC uses implementations of the interface Dialect
to encapsulate behavior that is specific to a database or its JDBC driver.
By default, the AbstractJdbcConfiguration
attempts to determine the dialect from the database configuration by obtaining a connection and registering the correct Dialect
You override AbstractJdbcConfiguration.jdbcDialect(NamedParameterJdbcOperations)
to customize dialect selection.
If you use a database for which no dialect is available, then your application won’t start up.
In that case, you’ll have to ask your vendor to provide a Dialect
implementation.
Alternatively, you can implement your own Dialect
Dialects are resolved by
