This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data Elasticsearch 5.4.5! |
Upgrading from 5.2.x to 5.3.x
This section describes breaking changes from version 5.2.x to 5.3.x and how removed features can be replaced by new introduced features.
Breaking Changes
During the parameter replacement in @Query
annotated repository methods previous versions wrote the String "null" into the query that was sent to Elasticsearch
when the actual parameter value was null
. As Elasticsearch does not store null
values, this behaviour could lead to problems, for example whent the fields to be
searched contains the string "null"
. In Version 5.3 a null
value in a parameter will cause a ConversionException
to be thrown. If you are using "null"
as the
null_value
defined in a field mapping, then pass that string into the query instead of a Java null
