This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data Couchbase 5.4.5!spring-doc.cn
Couchbase Transactions
Couchbase supports Distributed Transactions. This section documents how to use it with Spring Data Couchbase.spring-doc.cn
Requirements
  • Couchbase Server 6.6.1 or above.spring-doc.cn
  • Spring Data Couchbase 5.0.0-M5 or above.spring-doc.cn
  • NTP should be configured so nodes of the Couchbase cluster are in sync with time. The time being out of sync will not cause incorrect behavior, but can impact metadata cleanup.spring-doc.cn
  • The entity class must have an @Version Long property to hold the CAS value of the document.spring-doc.cn
Overview
The Spring Data Couchbase template operations insert, find, replace and delete and repository methods that use those calls can participate in a Couchbase Transaction. They can be executed in a transaction by using the @Transactional annotation, the CouchbaseTransactionalOperator, or in the lambda of a Couchbase Transaction.spring-doc.cn
Getting Started & Configuration
Couchbase Transactions are normally leveraged with a method annotated with @Transactional. The @Transactional operator is implemented with the CouchbaseTransactionManager which is supplied as a bean in the AbstractCouchbaseConfiguration. Couchbase Transactions can be used without defining a service class by using CouchbaseTransactionOperator which is also supplied as a bean in AbtractCouchbaseConfiguration. Couchbase Transactions can also be used directly using Spring Data Couchbase operations within a lambda Using Transactionsspring-doc.cn
Transactions with @Transactional
@Transactional defines as transactional a method or all methods on a class.spring-doc.cn
When this annotation is declared at the class level, it applies as a default to all methods of the declaring class and its subclasses.spring-doc.cn
[[-attribute-semantics]] === Attribute Semanticsspring-doc.cn
In this release, the Couchbase Transactions ignores the rollback attributes. The transaction isolation level is read-committed;spring-doc.cn
Example 1. Transaction Configuration and Use by @Transactional
The Configuration
@EnableCouchbaseRepositories("<parent-dir-of-repository-interfaces>")
@EnableReactiveCouchbaseRepositories("<parent-dir-of-repository-interfaces>")
@EnableTransactionManagement (1)
static class Config extends AbstractCouchbaseConfiguration {
  // Usual Setup
  @Override public String getConnectionString() { /* ... */ }
  @Override public String getUserName() { /* ... */ }
  @Override public String getPassword() { /* ... */ }
  @Override public String getBucketName() { /* ... */ }
  // Customization of transaction behavior is via the configureEnvironment() method
  @Override protected void configureEnvironment(final Builder builder) {
    builder.transactionsConfig(
      TransactionsConfig.builder().timeout(Duration.ofSeconds(30)));
The Transactional Service Class
Note that the body of @Transactional methods can be re-executed if the transaction fails. It is imperative that everthing in the method body be idempotent.spring-doc.cn
import reactor.core.publisher.Mono;
import reactor.core.publisher.Flux;
import org.springframework.stereotype.Service;
import org.springframework.transaction.annotation.Transactional;
final CouchbaseOperations personOperations;
final ReactiveCouchbaseOperations reactivePersonOperations;
@Service (2)
public class PersonService {
  final CouchbaseOperations operations;
  final ReactiveCouchbaseOperations reactiveOperations;
  public PersonService(CouchbaseOperations ops, ReactiveCouchbaseOperations reactiveOps) {
    operations = ops;
    reactiveOperations = reactiveOps;
  // no annotation results in this method being executed not in a transaction
  public Person save(Person p) {
    return operations.save(p);
  @Transactional
  public Person changeFirstName(String id, String newFirstName) {
    Person p = operations.findById(Person.class).one(id); (3)
    return operations.replaceById(Person.class).one(p.withFirstName(newFirstName);
  @Transactional
  public Mono<Person> reactiveChangeFirstName(String id, String newFirstName) {
    return personOperationsRx.findById(Person.class).one(person.id())
        .flatMap(p -> personOperationsRx.replaceById(Person.class).one(p.withFirstName(newFirstName)));
Using the @Transactional Service.
@Autowired PersonService personService; (4)
Person walterWhite = new Person( "Walter", "White");
Person p = personService.save(walterWhite); // this is not a transactional method
Person renamedPerson = personService.changeFirstName(walterWhite.getId(), "Ricky"); (5)
Functioning of the @Transactional method annotation requiresspring-doc.cn
  1. the configuration class to be annotated with @EnableTransactionManagement;spring-doc.cn
  2. the service object with the annotated methods must be annotated with @Service;spring-doc.cn
  3. the body of the method is executed in a transaction.spring-doc.cn
  4. the service object with the annotated methods must be obtained via @Autowired.spring-doc.cn
  5. the call to the method must be made from a different class than service because calling an annotated method from the same class will not invoke the Method Interceptor that does the transaction processing.spring-doc.cn
Transactions with CouchbaseTransactionalOperator
CouchbaseTransactionalOperator can be used to construct a transaction in-line without creating a service class that uses @Transactional. CouchbaseTransactionalOperator is available as a bean and can be instantiated with @Autowired. If creating one explicitly, it must be created with CouchbaseTransactionalOperator.create(manager) (NOT TransactionalOperator.create(manager)).spring-doc.cn
Example 2. Transaction Access Using TransactionalOperator.execute()
@Autowired TransactionalOperator txOperator;
@Autowired ReactiveCouchbaseTemplate reactiveCouchbaseTemplate;
Flux<Person> result = txOperator.execute((ctx) ->
  reactiveCouchbaseTemplate.findById(Person.class).one(person.id())
    .flatMap(p -> reactiveCouchbaseTemplate.replaceById(Person.class).one(p.withFirstName("Walt")))
Transactions Directly with the SDK
Spring Data Couchbase works seamlessly with the Couchbase Java SDK for transaction processing. Spring Data Couchbase operations that can be executed in a transaction will work directly within the lambda of a transactions().run() without involving any of the Spring Transactions mechanisms. This is the most straight-forward way to leverage Couchbase Transactions in Spring Data Couchbase.spring-doc.cn
Example 3. Transaction Access - Blocking
@Autowired CouchbaseTemplate couchbaseTemplate;
TransactionResult result = couchbaseTemplate.getCouchbaseClientFactory().getCluster().transactions().run(ctx -> {
  Person p = couchbaseTemplate.findById(Person.class).one(personId);
  couchbaseTemplate.replaceById(Person.class).one(p.withFirstName("Walt"));
Example 4. Transaction Access - Reactive
Mono<TransactionResult> result = reactiveCouchbaseTemplate.getCouchbaseClientFactory().getCluster().reactive().transactions()
  .run(ctx ->
    reactiveCouchbaseTemplate.findById(Person.class).one(personId)
