Prepared Statements
CQL statements that are executed multiple times can be prepared and stored in a PreparedStatement
object to improve query performance.
Both, the driver and Cassandra maintain a mapping of PreparedStatement
queries to their metadata.
You can use prepared statements through the following abstractions:
CqlTemplate
,AsyncCqlTemplate
, orReactiveCqlTemplate
through the choice of API -
CassandraTemplate
,AsyncCassandraTemplate
, orReactiveCassandraTemplate
by enabling prepared statements -
Cassandra repositories as they are built on top of the Template API
Using CqlTemplate
The CqlTemplate
class (and its asynchronous and reactive variants) offers various methods accepting static CQL, Statement
objects and PreparedStatementCreator
Methods accepting static CQL without additional arguments typically run the CQL statement as-is without further processing.
Methods accepting static CQL in combination with an arguments array (such as execute(String cql, Object… args)
and queryForRows(String cql, Object… args)
) use prepared statements.
Internally, these methods create a PreparedStatementCreator
and PreparedStatementBinder
objects to prepare the statement and later on to bind values to the statement to run it.
Spring Data Cassandra generally uses index-based parameter bindings for prepared statements.
Since Cassandra Driver version 4, prepared statements are cached on the driver level which removes the need to keep track of prepared statements in the application.
The following example shows how to issue a query with a parametrized prepared statement:
Imperative
Reactive
String lastName = cqlTemplate.queryForObject(
"SELECT last_name FROM t_actor WHERE id = ?",
String.class, 1212L);
Mono<String> lastName = reactiveCqlTemplate.queryForObject(
In cases where you require more control over statement preparation and parameter binding (for example, using named binding parameters), you can fully control prepared statement creation and parameter binding by calling query methods with PreparedStatementCreator
arguments:
Imperative
Reactive
List<String> lastNames = cqlTemplate.query(
session -> session.prepare("SELECT last_name FROM t_actor WHERE id = ?"),
ps -> ps.bind(1212L),
(row, rowNum) -> row.getString(0));
Flux<String> lastNames = reactiveCqlTemplate.query(
Spring Data Cassandra ships with classes supporting that pattern in the cql
package:
SimplePreparedStatementCreator
- utility class to create a prepared statement. -
ArgumentPreparedStatementBinder
- utility class to bind arguments to a prepared statement.
Using CassandraTemplate
The CassandraTemplate
class is built on top of CqlTemplate
to provide a higher level of abstraction.
The use of prepared statements can be controlled directly on CassandraTemplate
(and its asynchronous and reactive variants) by calling setUsePreparedStatements(false)
respective setUsePreparedStatements(true)
Note that the use of prepared statements by CassandraTemplate
is enabled by default.
The following example shows the use of methods that generate and that accept CQL:
Imperative
Reactive
template.setUsePreparedStatements(true);
Actor actorByQuery = template.selectOne(query(where("id").is(42)), Actor.class);
Actor actorByStatement = template.selectOne(
SimpleStatement.newInstance("SELECT id, name FROM actor WHERE id = ?", 42),
Actor.class);
Mono<Actor> actorByQuery = template.selectOne(query(where("id").is(42)), Actor.class);
Mono<Actor> actorByStatement = template.selectOne(
Actor.class);
Calling entity-bound methods such as select(Query, Class<T>)
or update(Query, Update, Class<T>)
build CQL statements themselves to perform the intended operations.
Some CassandraTemplate
methods (such as select(Statement<?>, Class<T>)
) also accepts CQL Statement
objects as part of their API.
It’s possible to participate in prepared statements when calling methods accepting a Statement
with a SimpleStatement
object.
The template API extracts the query string and parameters (positional and named parameters) and uses these to prepare, bind, and run the statement.
Non-SimpleStatement
objects cannot be used with prepared statements.
Caching Prepared Statements
Since Cassandra driver 4.0, prepared statements are cached by the CqlSession
cache so it is okay to prepare the same string twice.
Previous versions required caching of prepared statements outside of the driver.
See also the Driver documentation on Prepared Statements for further reference.
