3. CredHubOperations 简介
界面org.springframework.credhub.core.CredHubOperations和实现org.springframework.credhub.core.CredHubTemplate是 Spring CredHub 中的中心类。CredHubOperations提供对模拟完整 CredHub API 的其他作接口的访问:spring-doc.cadn.net.cn
 * Get the operations for saving, retrieving, and deleting credentials.
CredHubCredentialOperations credentials();
 * Get the operations for adding, retrieving, and deleting credential permissions.
CredHubPermissionOperations permissions();
CredHubPermissionV2Operations permissionsV2();
 * Get the operations for retrieving, regenerating, and updating certificates.
CredHubCertificateOperations certificates();
 * Get the operations for interpolating service binding credentials.
CredHubInterpolationOperations interpolation();
 * Get the operations for retrieving CredHub server information.
CredHubInfoOperations info();
3.2. CredHubOperations 自动配置
一个CredHubOperations正确配置应用程序属性后,使用 Spring Boot 自动配置创建 Spring Bean。 应用程序类可以自动装配此 bean 的实例以与 CredHub 服务器进行交互。spring-doc.cadn.net.cn
 * Copyright 2016-2020 the original author or authors.
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 *      https://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
package com.example.credhub;
import org.springframework.credhub.core.CredHubOperations;
import org.springframework.credhub.support.CredentialDetails;
import org.springframework.credhub.support.SimpleCredentialName;
import org.springframework.credhub.support.password.PasswordCredential;
import org.springframework.credhub.support.password.PasswordParameters;
import org.springframework.credhub.support.password.PasswordParametersRequest;
@Component
public class CredHubService {
	private final CredHubOperations credHubOperations;
	private final SimpleCredentialName credentialName;
	public CredHubService(CredHubOperations credHubOperations) {
		this.credHubOperations = credHubOperations;
		this.credentialName = new SimpleCredentialName("example", "password");
	public String generatePassword() {
		PasswordParameters parameters = PasswordParameters.builder()
			.length(12)
			.excludeLower(false)
			.excludeUpper(false)
			.excludeNumber(false)
			.includeSpecial(true)
		CredentialDetails<PasswordCredential> password = this.credHubOperations.credentials()
			.generate(PasswordParametersRequest.builder().name(this.credentialName).parameters(parameters).build());
		return password.getValue().getPassword();
	public String getPassword() {
			.getByName(this.credentialName, PasswordCredential.class);
