4. Introduction to ReactiveCredHubOperations
The interface org.springframework.credhub.core.ReactiveCredHubOperations and the implementation org.springframework.credhub.core.ReactiveCredHubTemplate are the central classes in Spring CredHub reactive support. ReactiveCredHubOperations provides access to additional operations interfaces that model the full CredHub API:spring-doc.cn
 * Get the operations for saving, retrieving, and deleting credentials.
ReactiveCredHubCredentialOperations credentials();
 * Get the operations for adding, retrieving, and deleting credential permissions.
ReactiveCredHubPermissionOperations permissions();
ReactiveCredHubPermissionV2Operations permissionsV2();
 * Get the operations for retrieving, regenerating, and updating certificates.
ReactiveCredHubCertificateOperations certificates();
 * Get the operations for interpolating service binding credentials.
ReactiveCredHubInterpolationOperations interpolation();
 * Get the operations for retrieving CredHub server information.
ReactiveCredHubInfoOperations info();
4.2. ReactiveCredHubOperations Auto-configuration
A ReactiveCredHubOperations Spring bean is created using Spring Boot auto-configuration when application properties are properly configured and the Spring WebFlux library is on the classpath. Application classes can autowire an instance of this bean to interact with a CredHub server.spring-doc.cn
 * Copyright 2016-2020 the original author or authors.
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 *      https://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
package com.example.credhub;
import reactor.core.publisher.Mono;
import org.springframework.credhub.core.ReactiveCredHubOperations;
import org.springframework.credhub.support.SimpleCredentialName;
import org.springframework.credhub.support.password.PasswordCredential;
import org.springframework.credhub.support.password.PasswordParameters;
import org.springframework.credhub.support.password.PasswordParametersRequest;
@Component
public class ReactiveCredHubService {
	private final ReactiveCredHubOperations credHubOperations;
	private final SimpleCredentialName credentialName;
	public ReactiveCredHubService(ReactiveCredHubOperations credHubOperations) {
		this.credHubOperations = credHubOperations;
		this.credentialName = new SimpleCredentialName("example", "password");
	public Mono<String> generatePassword() {
		PasswordParameters parameters = PasswordParameters.builder()
			.length(12)
			.excludeLower(false)
			.excludeUpper(false)
			.excludeNumber(false)
			.includeSpecial(true)
		return this.credHubOperations.credentials()
			.generate(PasswordParametersRequest.builder().name(this.credentialName).parameters(parameters).build(),
					PasswordCredential.class)
			.map((password) -> password.getValue().getPassword());
	public Mono<String> getPassword() {
			.getByName(this.credentialName, PasswordCredential.class)
