4. ReactiveCredHubOperations 简介
界面org.springframework.credhub.core.ReactiveCredHubOperations
和实现org.springframework.credhub.core.ReactiveCredHubTemplate
是 Spring CredHub 反应式支持中的中心类。ReactiveCredHubOperations
提供对模拟完整 CredHub API 的其他作接口的访问:
* Get the operations for saving, retrieving, and deleting credentials.
ReactiveCredHubCredentialOperations credentials();
* Get the operations for adding, retrieving, and deleting credential permissions.
ReactiveCredHubPermissionOperations permissions();
ReactiveCredHubPermissionV2Operations permissionsV2();
* Get the operations for retrieving, regenerating, and updating certificates.
ReactiveCredHubCertificateOperations certificates();
* Get the operations for interpolating service binding credentials.
ReactiveCredHubInterpolationOperations interpolation();
* Get the operations for retrieving CredHub server information.
ReactiveCredHubInfoOperations info();
4.1. 映射到 CredHub API
每个方法的Reactive…Operations
interfaces 直接映射到 CredHub HTTP API 的一个端点。
下表显示了 CredHub API 与相应的 Spring CredHub 之间的映射Reactive…Operations
接口。
CredHub 权限 API (v1) |
CredHub 权限 API (v2) |
4.2. ReactiveCredHubOperations 自动配置
一个ReactiveCredHubOperations
当应用程序属性已正确配置并且 Spring WebFlux 库位于 Classpath 上时,使用 Spring Boot 自动配置创建 Spring Bean。
应用程序类可以自动装配此 bean 的实例以与 CredHub 服务器进行交互。
* Copyright 2016-2020 the original author or authors.
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* https://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
package com.example.credhub;
import reactor.core.publisher.Mono;
import org.springframework.credhub.core.ReactiveCredHubOperations;
import org.springframework.credhub.support.SimpleCredentialName;
import org.springframework.credhub.support.password.PasswordCredential;
import org.springframework.credhub.support.password.PasswordParameters;
import org.springframework.credhub.support.password.PasswordParametersRequest;
@Component
public class ReactiveCredHubService {
private final ReactiveCredHubOperations credHubOperations;
private final SimpleCredentialName credentialName;
public ReactiveCredHubService(ReactiveCredHubOperations credHubOperations) {
this.credHubOperations = credHubOperations;
this.credentialName = new SimpleCredentialName("example", "password");
public Mono<String> generatePassword() {
PasswordParameters parameters = PasswordParameters.builder().length(12).excludeLower(false).excludeUpper(false)
.excludeNumber(false).includeSpecial(true).build();
return this.credHubOperations.credentials()
.generate(PasswordParametersRequest.builder().name(this.credentialName).parameters(parameters).build(),
PasswordCredential.class)
.map((password) -> password.getValue().getPassword());
public Mono<String> getPassword() {
return this.credHubOperations.credentials().getByName(this.credentialName, PasswordCredential.class)
