For the latest stable version, please use spring-cloud-task 3.2.0!spring-doc.cn
Task Repository Schema
This appendix provides an ERD for the database schema used in the task repository.spring-doc.cn
task schema
Table Information
TASK_EXECUTION
Stores the task execution information.spring-doc.cn
Column Name Required Type Field Length Notes
TASK_EXECUTION_IDspring-doc.cn
TRUEspring-doc.cn
BIGINTspring-doc.cn
Xspring-doc.cn
Spring Cloud Task Framework at app startup establishes the next available id as obtained from the TASK_SEQ. Or if the record is created outside of task then the value must be populated at record creation time.spring-doc.cn
START_TIMEspring-doc.cn
FALSEspring-doc.cn
DATETIME(6)spring-doc.cn
Xspring-doc.cn
Spring Cloud Task Framework at app startup establishes the value.spring-doc.cn
END_TIMEspring-doc.cn
FALSEspring-doc.cn
Xspring-doc.cn
Spring Cloud Task Framework at app exit establishes the value.spring-doc.cn
TASK_NAMEspring-doc.cn
FALSEspring-doc.cn
VARCHARspring-doc.cn
100spring-doc.cn
Spring Cloud Task Framework at app startup will set this to "Application" unless user establish the name using the spring.application.name.spring-doc.cn
EXIT_CODEspring-doc.cn
FALSEspring-doc.cn
INTEGERspring-doc.cn
Xspring-doc.cn
Follows Spring Boot defaults unless overridden by the user as discussed here.spring-doc.cn
EXIT_MESSAGEspring-doc.cn
FALSEspring-doc.cn
2500spring-doc.cn
User Defined as discussed here.spring-doc.cn
ERROR_MESSAGEspring-doc.cn
FALSEspring-doc.cn
2500spring-doc.cn
LAST_UPDATEDspring-doc.cn
TRUEspring-doc.cn
TIMESTAMPspring-doc.cn
Xspring-doc.cn
Spring Cloud Task Framework at app startup establishes the value. Or if the record is created outside of task then the value must be populated at record creation time.spring-doc.cn
EXTERNAL_EXECUTION_IDspring-doc.cn
FALSEspring-doc.cn
250spring-doc.cn
If the spring.cloud.task.external-execution-id property is set then Spring Cloud Task Framework at app startup will set this to the value specified. More information can be found herespring-doc.cn
PARENT_TASK_EXECUTION_IDspring-doc.cn
FALSEspring-doc.cn
BIGINTspring-doc.cn
Xspring-doc.cn
If the spring.cloud.task.parent-execution-id property is set then Spring Cloud Task Framework at app startup will set this to the value specified. More information can be found herespring-doc.cn
TASK_EXECUTION_PARAMS
Stores the parameters used for a task executionspring-doc.cn
TRUEspring-doc.cn
BIGINTspring-doc.cn
Xspring-doc.cn
TASK_PARAMspring-doc.cn
FALSEspring-doc.cn
2500spring-doc.cn
TASK_TASK_BATCH
Used to link the task execution to the batch execution.spring-doc.cn
TRUEspring-doc.cn
BIGINTspring-doc.cn
Xspring-doc.cn
JOB_EXECUTION_IDspring-doc.cn
TRUEspring-doc.cn
BIGINTspring-doc.cn
Xspring-doc.cn
TASK_LOCK
Used for the single-instance-enabled feature discussed here.spring-doc.cn
LOCK_KEYspring-doc.cn
TRUEspring-doc.cn
CHARspring-doc.cn
36spring-doc.cn
UUID for the this lockspring-doc.cn
REGIONspring-doc.cn
TRUEspring-doc.cn
100spring-doc.cn
User can establish a group of locks using this field.spring-doc.cn
CLIENT_IDspring-doc.cn
TRUEspring-doc.cn
CHARspring-doc.cn
36spring-doc.cn
The task execution id that contains the name of the app to lock.spring-doc.cn
CREATED_DATEspring-doc.cn
TRUEspring-doc.cn
DATETIMEspring-doc.cn
Xspring-doc.cn
The date that the entry was createdspring-doc.cn
The DDL for setting up tables for each database type can be found here.
SQL Server
By default Spring Cloud Task uses a sequence table for determining the TASK_EXECUTION_ID for the TASK_EXECUTION table. However, when launching multiple tasks simultaneously while using SQL Server, this can cause a deadlock to occur on the TASK_SEQ table. The resolution is to drop the TASK_EXECUTION_SEQ table and create a sequence using the same name. For example:spring-doc.cn
DROP TABLE TASK_SEQ;
CREATE SEQUENCE [DBO].[TASK_SEQ] AS BIGINT
 START WITH 1
 INCREMENT BY 1;
Set the START WITH to a higher value than your current execution id.
